View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. ELC - Wiring Diagram - '93 Eldorado, 4.9L
  2. Mystery Milan 2dr Conv.
  3. Price to pay for aSeville STS
  4. ABS and Traction Controll
  5. Would you trade your STS for a M-B 560sl?
  6. Cadillac Apparel, Accessories, Merchandise & Gifts
  7. Power window problems '95 STS
  8. Chrome Trim and Custom Headliner
  9. Brake Question (Feeling the Rotors on Hills)
  10. Suspension questions
  11. OMG... Unbelievable!
  12. Question about rims and tires for my 1990 Eldo Coupe
  13. 94 STS- Changed FPR and Weird Things Happened
  14. Seville SLS 96 blower fan gives odd noise
  15. Question for Ranger - online service manual
  16. 2001 sts owners names on DIC
  17. bose front door speakers
  18. Ipod capable?
  19. Cracked coolant reservoir! What to do.
  20. fiber optic cable splicing
  21. here we go again
  22. It's Back!!!
  23. How can I enable the DRL on a '99 EXPORT seville STS
  24. Very small coolant hose
  25. 02 censor
  26. Coolant Bleed Valves / Resevoir tank
  27. temp control problems in 2000 seville
  28. '92 Eldo ETC wheel bearing and hub
  29. check this out if you have had head gasket issues !
  30. Driver Window won't roll up
  31. Touching up Paint Job
  32. Battery Cables
  33. Eldo - anybody switch from 16 in stock to 17 in caddy stocks?
  34. 'Very Low Refrig' Error 98 Eldo
  35. Headlights acting strange
  36. Which Eldorado would you prefer?
  37. 17in STS wheels for sale
  38. Front Struts
  39. 1992 STS Trailor Hitch wiring
  40. How do I clean the AC blower in 2000 Seville?
  41. New Engine Possibley Has More Power?
  42. Blown Engine? I think so. 96 STS whats next.
  43. Need help on 98 cad seville sls
  44. Premium Vs E10 Gasoline
  45. Selling my STS and I find I'm elitist. . . or something
  46. Warky
  47. anyone want 94 eldo?
  48. Help needed with 99 sts
  49. Which would you buy? Eldorado or Seville? Why?
  50. OMG Ugly Pimp Eldorado
  51. A/C compressor cycles off too soon 98STS
  52. 99 STS code problems
  53. what is it
  54. Whats goes in YOUR tank? (later models of Sevilles)
  55. Wierd door problem
  56. AC compressor DIY
  57. 98 Seville water in trunk
  58. need help 95 sts wont start
  59. CKP issue 94 eldo/01 deville
  60. 1993 Eldorado for sale
  61. 2000 seville sts headlight. Any help?
  62. Help! Service soon light on after new exhaust installed...
  63. Traction control disable/lsd
  64. When I got my tires rotated........
  65. Changing 02 sensors 92 seville
  66. Shimmy at start up!
  67. Best mid 80's to early 90's Eldorado Model to Buy?
  68. Replacing the O2 sensors
  69. Bent Caddy want to unbend
  70. 99 Eldorado Questions - First Time Caddy Owner
  71. No radio no cigarette
  72. A Misfiring 1998 Seville SLS?
  73. Headlight dimming while braking
  74. 93 eldorado touring trunk draw down
  75. New Plugs And Oxygen Sensors Better Mpgs ?
  76. 1992 Seville 4.9 Fan Problems
  77. 1998+ Eldorado Parts
  78. 1997 Sls
  79. 95 seville body kit???
  80. early Eldorado Mods
  81. a engine cover suggestion
  82. excessive engine startup
  83. 96 Eldorado ETC Wiring Diagram
  84. 96 eldorada EBCM location
  85. Help me with my rim selection on my eldo
  86. 97 STS w/ ALL 6000K HIDS PICS
  87. Location Sunroof Drains '81 Eldorado
  88. 1979 El Dorado
  89. Feature Programming Won't Toggle To On
  90. Getting clips
  91. Getting a seville soon hopefully need advice
  92. Starter problem in the valley.......
  93. 94 seville sts front struts
  94. Battery / AMP DRAIN pt 352
  95. just a wierd question about keys
  96. Sway bar links
  97. PCV Issue?
  98. ´95 Eldo - searching switch for heating seat
  99. Drain plug?
  100. Drivers side floor wet and dripping 97 STS
  101. So I Think I Hit for the Cycle
  102. STS - How fast is this car supposed to shift? Potential problem...
  103. Rare STSi Photos
  104. fender bender
  105. '84 Eldorado convertible window motor relays
  106. Has anyone dropped their 92-02 Eldorado? Can you give me pointers..
  107. 1980 eldo w/368 dfi
  108. ordered exhaust
  109. air ride
  110. Ranger, Pros.. One more Question.
  111. OBD1 codes
  112. bad ball joint?
  113. 2002 Seville STS-questions too dumb to ask GM
  114. Noisy Pads
  115. Almost a matching ECT
  116. Electrical system partial failure
  117. 1996 sts stalled and wont restart
  118. Fuel Filter Brand
  119. Recent Seville SLS purchase
  120. Introduction
  121. Newbie Here
  122. What should i do?
  123. 96 Eldorado electrical
  124. Eldorado 1999 Water passenger side carpet
  125. Theft System Problem
  126. Time to analyze a NOISE (again)
  127. 1991 caddy eldorado problem
  128. 3rd Window Regulator?
  129. Fuel door release and trunk release buttons
  130. Love my SLS
  131. Eldorado Turn Signal Problems?
  132. new codes
  133. Heated Seat Problem
  134. I want to lower my seville
  135. Droopy bumper corners?
  136. Suspension prob on a 95 ETC``
  137. What's Going On With My Caddy.
  138. I Got 2 Chips
  139. Exhaust...right hand pipe only
  140. down again
  141. 1998 Eldorado Service Manual for a 1999
  142. no spark
  143. GM Remanufactured Shifting Problems
  144. Professionally Painted Northstar Engine Covers
  145. Do I need to pull fuse on Ride control with car on hoist before turning ignition on?
  146. Water in trunk
  147. Need confirmation of brake caliper bracket bolt torq
  148. Soften ride on 2002 Seville STS
  149. Radiator Problems
  150. 94-95 Northstars safe to buy?
  151. newby questions
  152. Brake Light Problem (dead side) + LED Reverse Lights (w. photos)
  153. Diagnostic Codes
  154. 96 El Dorado traction control issues
  155. lowering? 2000 sls
  156. help on code C1233 ABS and traction control
  157. Oil Cooler Line
  158. Overheating
  159. '96 STS Ignition Coils - Which Brand?
  160. Accident
  161. on the road again
  162. 94 STS Front Seat replacement
  163. Car chugging jerking during accelration
  164. Post your GAS MILEAGE...
  165. 1996 STS P0717 Input Speed Sensor Circuit Low Input
  166. Very Slight Miss at Idle
  167. The Worst Nightmare, Trans problem!
  168. confused
  169. camshaft sensor
  170. camshaft sensor
  171. New STS purchase
  172. 99 ETC Eldorado steering problem
  173. 98 Eldorado (base) Overheating Issues
  174. 93 Seville 4.9 Bad gas Mileage
  175. STS Display Customized??
  176. Easy Way
  177. 99 Eldo module mix up - please read
  178. Beware of aftermarket harmonic balancers.
  179. ac doesnt work right
  180. Rear Control Arm Bushings 95 SLS
  181. won't start
  182. Battery Draining Question
  183. Car died on highway
  184. 01 STS Cruise Control
  185. dancing fuel gauge!!!
  186. JET Chipped ETC v A.J. Equipped STS
  187. powertrain removal
  188. syptoms
  189. another one bites the dust
  190. Corsa Exhaust
  191. 94 Eldorado Transmission Issue
  192. Another Onstar Antenna
  193. Rear Disc Brake Piston
  194. heat\AC blower motor issue
  195. Transmission Having Problems Shifting
  196. 99 Eldorado blower motor pigtail voltage
  197. average MPG for any owner of 88-91 eldorado
  198. Waxing the steering wheel?
  199. Dead zone in '95 SLS Steering (variable assist problem?)
  200. BUYING AN 89 El Dorado PLEASE HELP!
  201. Magnaflow Direct-Fit Catalytic Converter?
  202. Where to place floor jack & jack stands on 2000 ETC
  203. I need help/wheel/hubcap
  204. Part number for Gold/Black 32 V Northstar Emblem
  205. Transmission mount
  206. 94 Eldorado question(s)
  207. code P080-won't clear
  208. 96 SLS wouldnt start
  209. Temperature Problems????
  210. Instrument Panel 1983 Eldorado Analog to Digital
  211. a lil confused
  212. 89 cadillac el dorado
  213. AMP Drain? Reserve power ?
  214. lookin for 97 (y) sls n for replacement
  215. Ranger, Pro's. I need a Little more help
  216. Scary Picture!
  217. torque in the bolts...lookin for info
  218. SERVICE ENGINE SOON when I did a burnout
  219. Where is the fuse/relay for the heater blower
  220. A/C, Driver side warm, Pass side cold.
  221. New to forum - 1993 Eldo question re seats
  222. What the HELL...?!
  223. Rear Window Child Safety feature stops window halfway
  224. 1998 STS low speed roughness and highway speed vibration
  225. door panel removal
  226. what do you think of this GRILL mod?
  227. Can you eliminate the idler pulley?
  228. starting to save up the $$$
  229. steering whine
  230. Gas Prices
  231. Where the heck is my relay ??? Help Please!
  232. 1997 SLS Northstar front suspension
  233. 1999 Eldorado Heater Fan Question
  234. Buying 98-00 seville, what to look for, please help me out
  235. Lights out in steering wheel
  236. True Xenons (high intensity discharge lights) retrofit, pics
  237. Engine coolant and engine swap
  238. 95 Eldorado n* Help with window problem? Clicking noise,
  239. C1762 - Left Rear Position Sensor Input Fault
  240. 76 Eldo Shop Manuals
  241. Engine still hesitating
  242. coolant flush
  243. intake Plenum
  244. Memory Seat
  245. Can someone tell me what's the deal with my Caddy?
  246. WOT or $500 cleaning service?
  247. Cargo net holder part number?
  248. Wheel torque specs
  249. Difference between 92 Seville base model and 92 Seville STS
  250. Vacation...BOOM..SMOKE...help!!
