- Any super built northstars out there the same as my 95 eldorado?
- 92 eldo trans leak.
- Replace Water Pump - How Much?
- Has anyone put roofracks on a seville?
- Electric Supercharger
- Aluminum Radiators for 86-91 Eldos/Sevilles?
- Timesert Kit for sale
- keyless
- 01 STS steering column rattle
- 1979-1985 Eldorado Electronic Level Control
- My 99 STS codes from hell
- 00 Seville SLS Speed Limited to 90
- STS sunroof problems
- Phantom Sunroof
- Any experience with Airtex fuel pumps?
- Biarritz vs. Base
- New Cadillac Eldorado owner with problems.
- Service suspension system dash alert
- 02 Seville Code P0410
- I think my starter went. Please help me!
- EVAP fixed. No codes, still gutless!
- seville shuts off when turning
- Anyone else's gas gauge ever do this?
- 94 & 95 Eldo N*- same engine
- Pls help, 2000 sts has no power and no rpms, boogs
- 1995 Cadillac Seville SLS remote keyless entry
- hvac fan problems 2001 STS
- 98 SLS hard to shift out of Park
- 98-04 Seville Owners...who accidently bought a bra??
- headlights turn off in parking lots
- check fuel gauge
- 2002 Seville Idling problem
- 03 SLS Hard starting
- Ugh, please help----HVAC meltdown
- ime to fix that ABS pump.
- Strutmasters: Canadian alternative?
- Help!!!!!
- 84 Eldo - Need Programer for climate control
- Interested in a 79 Seville -- Need Advice
- Looking at buying a 1992 Eldorado Touring
- 2000 Eldorado no power to Onstar/rear view mirror
- 82 Seville - Where's my fuse block - Trunk release not working
- Remove Stock Radio 99 sls
- Too much trans fluid? 4T80E
- 98STS Air Ride Compressor ??
- 98 STS Heat Blows Cold
- 1991 Seville - Diagnostic help please
- Did my water pump just give up?
- Slow acceleration 96 Eldo ETC
- Optima battery replacement
- Low Oil Pressure - Stop Engine
- Help with a Code
- Service Stability System - Traction control Problem
- Pcm po442 msmb1845 current
- 1995 ETC, will Concours digital cluster work?
- Starting issue
- 96 STS bumper and lower panel trim
- RKE Key Fobs
- ......antifreeze......
- NEWBIE...anyone in Illinois help???
- PCM reflashed after 2nd gear limp mode???
- '94 Seville SLS High HydroCarbon output
- Seat Rail Adjust for Tall Guy
- harsh cruise engagement
- service stability sys
- Ride level
- Defrost not blowing very hard?
- Need radiator help 99 STS
- Guages?
- Need help parts 88 Eldorado
- B440 current
- '97 STS Blinker Works Right, But Not Left
- overheating problem, may be hg
- Need some help guys, I hope it's ok to put all of this in one thread. 96 STS
- Help with trouble codes
- Throttle Position Switch vs Throttle Signal Switch
- 00 Seville no heat
- 98-03 STS headlights in 96 STS?
- Brake lights are always on!
- 2004 SLS Ext. Warranty about to Expire
- In need of help!!
- 71 convertible eldo ticking in the trunk
- 71 convertible eldo dimmer switch
- 98 STS no antifreeze
- Service Theft System warning
- WHY Would Anybody Do This!!!
- I need more power
- 2002 Seville SLS question: PCM P0106 Code
- I am pi$$ed!!!!!!!!!!!!
- Seek Instructions/tips for Alternator Change
- codes help
- '99 Seville Driver's Door Mirror Motor
- 02 SLS-Seat Heater Problems
- Winter storage: Indoor or outdoor?
- Front Strut Replacement active susp.
- Which service manual is good for Seville 99?
- My HEART FELT thanks to everyone here!!
- keyless2
- Interior Lighting Gremlins
- Defroster little air, Heater lots of air (84Eldo))
- Old unused Preston Anti-Freeze
- How to manually open or close the bend doors of AC?
- 97 seville sls cd player Model ###
- suspension compressor question?
- Bose Speakers 92 to 97 Cadillacs
- '98 Eldo won't start
- Question on 17" STS 7-spoke wheels
- Rattle on 02 Seville SLS
- Manual Downshift Question
- 99 STS - Slipping transmission might be low fluid?
- Anti-Seize & Spark Plugs
- Automatic healights question
- headlights question ???
- pump and clunk
- windshield wipers froze!
- Tight steering HELP(Strut Mount)?
- 92 Eldo Bose Gold Stereo antenna jack?
- Master Door Switch, Horn, Windows Not Working
- Battery or Alternator?
- ElDawg Saves Family's lives
- 99 SLS died while driving won't restart
- And Still no Over Drive
- 2002 SLS Imitates 1978 Elegante Seville
- 2000 Eldorado heater malfunction
- any sources for lower door trim?
- 98 STS Engine Swap Trouble
- Homelink Compatible?
- 2003 STS speedometer noise - need help to diagnose!
- What is acceptable coolant temperature
- 98 Eldorado ETC "check coolant"
- Rough idle, SES light and 2 codes
- 85 Eldo convertible top problem..
- Holy God....
- When to replace a 1999 Seville sls
- 94 seville sls "service ride control" code s030
- 99 Deville Concours Vin 9 - 99 sts vin 9
- E027 Code, A/C Problem and Service Ride Control
- 1985 Eldorado -- How Underpowered Were They????
- Monroe MA822 for rear shock replacements?
- Getting ready for my new exhuast....
- Unique Smell
- Engine Might Be Blown in My '94 STS
- 2000 Seville STS no pedal
- '03 STS Heat
- Thinking of buying...
- 95 Eldo PCM needed
- trunk pulldown cycling
- ENSURALL Extended Warranty Canada...
- 1976 Eldorado quarter panel filler
- Brake Lines 98 Eldorado
- Engine Oil Pressure Light On
- N* Swap - 03 or 04 engine into 01 car - Need to Reprogram ECM?
- 1997 eldorado (non ETC)
- 2000 Eldo Esc bad gas mileage
- Heated Windshield
- 94 SLS Code P29 Won't leave 2nd gear
- left front wheel locked
- Really heavy steering after steering gear replacement
- Help Intermintent stall/ No Start
- Removing Front Fender
- Various Noises Identification
- 94 SLS code P041 advice please!!
- 2003 STS warped rotors
- GPS question...
- What can i do to make my car faster
- 85 Eldorado trunk pulldown motor
- unplugged connection 95 Eldorado
- Right Rear Wheel Well Trim
- trunk pop not working click sound from modules
- trunk led gets no power
- 2000 Eldorado...right side vents only blowing hot air
- Please Help
- Coolant Connector part # 25689629
- 4T80 E Reverse issue
- Spun Rod Bearing - New Rod Options
- Seville Exhaust: Need Diagrams for 1999-2004 and 1993-1996
- Free shipping for all forum members - cadillac merchandise
- Interesting smell from A/C vents during driving
- Removing Dents on Top of Fender
- DIC went crazy
- 2002 Cadillac STS Shocks
- Used Transmission Help
- STS Fog Lights Not Working...
- 96 eldorado trunk and fuel release?
- A quick rave about EXCELLENT customer service
- 95 Eldorado no charging
- How do you replace alternator on a 1999 Cadillac ElDorado?
- Possible Water Pump and Alternator Problems.
- 2003 Seville STS suspension issue
- 1986 Cadillac Seville
- ? on PCV Valve replacement 02 Seville
- rear speaker removal
- P0300: bad coil?
- oil pressure???
- 99 STS to drop the engine just a little
- Adding a Subw0ofer and Amp
- Rattling A/C Compressor
- Traction Control light On / ELDORADO 96
- where is the fuel service valve?
- Remote jump start location on '03 Seville STS?
- 95 alternator wiring
- 01 STS subwoofer blown?
- In need of serious help!!!!
- 2000 Seville SLS coolant tank replacement
- From Russia with Love...
- Trouble w/ HID Headlight
- 97 SLS shift solenoid issue
- What is this part? PCV valve?
- Running Rich... I Think.
- 99 sts valve cover question
- Disableing Service Engine Light
- parts interchange?
- 97 Seville no cabin heat, engine overheated
- New Here: Difference B/T SLS & STS
- Squeaky Seat (Driver's Seat) - '96 Seville STS
- Another low mileage STS...
- Steering wheel part number
- How to remove dash pad on 2000 STS
- intake manifold torque sequence- 10 bolt
- 2003 STS Oil consumption and P0420 code
- 1985 eldorado heating and radio issue
- Seville Northstar
- car will not start in neutral
- 1988 eldorado opera lights
- Interior Readings Lights on
- New guy
- Parasitic Electrical Power Drain....HELP!!!
- VSS replacemnt help
- Need replacement struts on 99 STS...Arnott a good choice?
- 98+ STS, water in the taillights?
- Steering wheel position sensor
- Coolant Leak
- leak problem
- How to remove door pannel and leather seat cover?
- Videos: 1992 Seville and Eldorado Promo Vids
- New member - Looking at an 01 STS - what to look for
- C1214 & friend!
- 1985 Eldorado Antenna Replacement Question
- 99 Seville Nightmare!!!
- Help Changing Refrigerant On 97 Seville STS
- HVAC System Help Wanted
- Anyone run 215's?
- Blower fan ideas wanted
- should i get a new tranny or rebuild?
- New Seville STS owner
- A/C Compressor cycles too quickly after recharge?
- New Seville owner - trunk
- Motor/trans swap
- New To Cadillacs but I don't like this sound
- Navigation Disc Worth It?
