View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Instrument Cluster Milage??
  2. ETC Hood Ornament Opinions Wanted
  3. Seville & Eldorado Floor Mats - Custom Made
  4. Bench Bleeding Gone Bad? Help!
  5. Filler details
  6. Any good cadillac mechanics in the Detroit area?
  7. '68 Eldorado questions
  8. 1998 STS - Electrical, mechanical or both
  9. heated windshield on alternator
  10. Northstar problem
  11. Will this steering wheel fit a 1997 SLS?
  12. Gauges and A/C died....
  13. 2001 STS Replace "Crossover Gaskets" ??
  14. '89 Eldorado Pre-Purchase Questions
  15. I want to honk my horn when i lock the doors
  16. How do I disable the drls ?
  17. xenon replace
  18. Thinks the key is always in the ignition
  19. STS 2000 Lower Grille...
  20. 97 North* SLS Trunk lid problems
  21. Rear Rotors on Front
  22. Passenger seat vibrates and chirps
  23. New motor mount
  24. Would a 95 STS hood fit my 92 ETC?
  25. Paint Bubble on passenger door (2001 STS)
  26. 97 STS Battery Drain & Multimeter reading
  27. Carnut please.. 1984 ELD Conv. rear window
  28. 99 Seville - No dash lights or gauges
  29. Bought my first Cad!
  30. Heater not working
  31. Glitchy Startup
  32. 96 Eldorado - what to look for?
  33. Any tricks on getting new spark plugs in?
  34. Need new starter circuit relays (car refuses to start when hot)... where to get them?
  35. How to lube the checklink
  36. Please help with abandoned 94 ETC I just bought.
  37. A/C problem on 2000 SLS - no cold air on driver's side (pass side OK)
  38. Hello
  39. 1999 STS doors will not open?
  40. Flood Vehicle
  41. 2003 Sevelle sls blower motor
  42. 2002 STS "Service Stability System" Message
  43. 97 STS with no 1st gear
  44. Passkey relearn
  45. transmission control solenoid
  46. 1993 Seville CD player Component
  47. XM Radio loses signal, feel like a ping pong ball
  48. 97 eldorado electrical problems
  49. So I think I have a bad hub/bearing assembly- Ranger Sub Ewill
  50. The solution to my Seville's shimmy
  51. how to erease all codes in comp
  52. Delphi and AC Delco the same?
  53. 94 sts - No 3/4 gear after replacing shift solenoids
  54. Horn issue
  55. Sunroof drain tube question.
  56. So.... I installed the relay. And still have problem
  57. Wet carpet on passenger side rear
  58. Auxiliary input for 2002 Bose
  59. 99 Seville STS -Has code: C1243 - BPMV Pump Motor Stalled
  60. 99 STS won't shift at redline at WOT
  61. Gas door gone crazy!!! 1999 STS
  62. 256 Miles Range?
  63. So i was thinking about an exhaust setup...
  64. Any pointers before replacing the ABS pump?
  65. Low Oil Pressure 2001 Seville STS
  66. 97 sts electrical problem
  67. Where is my AC leaking from!???
  68. 98+ Seville lower silncer removal instructions
  69. Hidden Wiper Passenger Side
  70. Power Steering Fluid
  71. Seville & Eldorado Floor Mats - Custom Made
  72. Glove Box Won't Open
  73. Keyfob Quit Working - Not Allowed to Reprogram or Program New/Old One
  74. Knocking sound engine SLS 2000
  75. Radio Problem
  76. Anyone have experience with Arnott air ride suspension?
  77. New to the forum
  78. Wood Trim Kit
  79. 1992 Seville SLS 4.9 litre.
  80. After 40k miles driving my cadillac Seville SLS
  81. 97 SLS engine miss
  82. 93 Northstar STS will not turn over!
  83. Yes!!!!!!!!!!!!
  84. Update on the 70 Eldorado paint (pics)
  85. HID Conversion Kit
  86. Head gasket repair recommendations in New England
  87. 98 sls won't start
  88. what ignition coils
  89. CODES, again
  90. HELP, AC not working...IN SOUTH FLORIDA!
  91. Loosing coolant
  92. Magnetic Ride Control- A Good Read with an Awesome Vid
  93. radiator replacement ?
  94. AC Compressor runs, but air not cold
  95. worried - ac problem!!!
  96. how to check codes on a 96 eldorado
  97. Removing a Windsheild
  98. aftermarket body parts
  99. Missfire / studder / hesitation
  100. PLEASE HELP! 99 STS overheating
  101. HELP !!! Plenum Vacum Leaks
  102. Autocrossing the STS
  103. Any Ideas on a Peculiar Water Leak?
  104. I need help ?
  105. Replacement Key
  106. Say It Aint So!!!!!!!!!!
  107. Hydorgen Caddy Gas Saver?
  108. No Distributor Signal- '92 STS
  109. '99 STS Driver's Side Mirror
  110. Warning Summer Thieves
  111. A quick question about P0741..again.
  112. Need Blower Motor!
  113. bad struts or strut mounts?
  114. Pissed off...Mystery Hit
  115. cleaned throttle body...questions
  116. Tranny problems
  117. Dusty rear seat! door gaskets to blame?
  118. Been honored today...
  119. I need advice
  120. Newbie with issues
  121. SERVICE BRAKE FLUID SWITCH message
  122. $2500 later & still mad!!!
  123. ticking sound during acceleration
  124. Looking At A 1997 Seville SLS
  125. spark plugs and injector replacement
  126. 87 Seville No DIC, Climate Control readout
  127. 93 Seville/Eldorado FSM
  128. Have to make quick purchase decision
  129. 97 ETC exessive cranking periodically
  130. Need Help With New Tires
  131. Bad surge tank cap?
  132. Cadillac Seville & Eldorado Floormats
  133. Alternator Replacement
  134. driveaxle/hub nut size 94 STS
  135. Oil Cooler Union Plastic Retainer Rings
  136. 1994 STS over heating:
  137. ignition switch in dash
  138. Blower Motor Quit...
  139. 1996 STS overheating problem
  140. white smoke at WOT
  141. 1999 STS Over heat problem
  142. So where do you park if you don't want door dings?
  143. Pics Of My 1999 Sls Almost Done For Summer
  144. Spring Cleaning (with pics)
  145. STS / Eldorado body parts
  146. how to replace igniter wire????
  147. HT 4100 Engine: Any redeeming values?
  148. 96 Seville- No Fuel Pressure?
  149. Help requested: Trunk full of water, trunk motor switch defect
  150. 1993 Seville Hot Rod
  151. Difference in blower motors
  152. Bigger wheels but only in the rear = good idea ?
  153. at Ranger, i need help!
  154. interior lights are out???
  155. where is the BING? or the BONG
  156. Automatic Start/Keyless Entry
  157. 98 Seville STS P/S Pump Pulley
  158. 99 STS mufflers/tips for sale
  159. 2003 xenon
  160. Florida Sevilles/Eldorado's, yea you!!
  161. SERVICE STABILITY SYSTEM (and some WOT run videos and news
  162. Service Eng. Soon Light.
  163. track bar problem
  164. And Yet Another "Dreaded Shimmy" Question.
  165. Radiator?
  166. Removing gauge cluster
  167. 98 Seville STS EBTCM
  168. Pittsburgh mechanics?
  169. free
  170. Engine won't crank
  171. '96 instrument cluster needed
  172. head light xenon
  173. T O T A L E T C C L U S T E R
  174. Strange A/C Issue
  175. how to change lower control arms
  176. 93 sls wont start
  177. 1994 sts - Rough idle when warm
  178. 94 seville sts transmission gears question
  179. Losing Coolant = headgasket blow???
  180. Eldo Tire Question...
  181. Sunroof rear gutter help
  182. 2000 Sts --- Pcm P1860
  183. 92 SLS running hot.
  184. 99 STS service manual, water pump socket
  185. Torque converter
  186. BCM Failure - 1997 Seville STS
  187. 98 Eldo Transmission acting odd
  188. 95 etc A/C Temps and Pressures
  189. ETC XM Nightmare finally over...!
  190. '03 STS Variable Valve Timing?
  191. 95 STS REAR Knuckle Bushings
  192. "New" 2003 Seville STS
  193. alignment specs
  194. i have rear wheel steering!
  195. I love our new STS....BUT!
  196. 86-91 Bumper Lights
  197. 99_Seville_STS Can anyone help??
  198. 1996 STS swap with a 1999 engine/trans. Will it work?
  199. Silly question perhaps
  200. 70's half Eldorado and half trailer tow vehicle
  201. Car alarm self install on a 1990 Caddy Eldo
  202. Head Gasket Issues
  203. 71-78 Cadillac Eldorado / FWD
  204. How Do I Remove The Rear Seat in 82 Eldo?
  205. 92 Eldorado brake light problem
  206. 1995 STS Alternator
  207. Brake Light Problem
  208. The New STS or Classic Seville? What do You think is better?
  209. inop speedo, tach
  210. P0420 C1227 Codes 97 STS - hi mileage
  211. 2002 STS weak startup...
  212. engine transplant question
  213. "System Problem"
  214. i got my car back
  215. A few issues 98 STS
  216. 98 sts front motor mount
  217. Help Cadillac Tech can't find annoying cabin noise
  218. Engine Overheating. Engine Coolant. Confused
  219. 1997 SLS Engine Replacement
  220. New paint for my 70 Eldorado (pics)
  221. Turn Engine Off Warning on 96 SLS Seville
  222. Having problems STS 2002
  223. Dreaded vibration @ 65+
  224. 99 eldo, only complaint after first few weeks
  225. where could I post a "parts car"?
  226. fog light replacement
  227. Quick help! Runs with seven cylinders...
  228. '03 STS lurches forward when braking almost at a complete stop, maybe trans mount?
  229. Engine dies when put into gear
  230. Cruisen Smooth
  231. Help! my 95 eldo sprews out coolant after I park
  232. 82 Eldo Electrical Anomalies: Radio Digi Readout Etc..
  233. 82 Eldo Electrical Anomalies: Radio Digi Readout Etc..
  234. Pulling codes
  235. Defrost blower
  236. 2 Quick Service Questions
  237. Slight Vibration between 60 and 70
  238. Little Rough Idle at Cold Start
  239. Fan Noise
  240. whats going on?
  241. Flushing A/C system questions
  242. Engine noise...remove engine?
  243. Service Engine light
  244. JL9 brakes for my 02
  245. Fuel Pressure Gauge Recommendations
  246. idle relearn
  247. 1996 STS wont start
  248. cooling issue...
  249. ELC - Wiring Diagram - '93 Eldorado, 4.9L
  250. Mystery Milan 2dr Conv.
