View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Another blower motor issue
  2. STS 01 sunroof leak
  3. 93 El Dorado 4.9L turns off! Help Please!
  4. codes :(
  5. New brakes!!! with pics
  6. Timing Belt??? in a 1985 Eldorado??
  7. Cadillac and MPG
  8. Front End suspension CLANK - 99 STS - Phoenix
  9. Was involved in an accident with my Cadillac on Monday
  10. AC vac'd/recharged, code b1347 3 weeks later!!!
  11. 93 Seville Third brake light
  12. Crankshaft sensors
  13. Tach and codes
  14. Help! 93 Eldorado Windshield Chrome Trim Moulding
  15. Help with history codes, ABS and Traction Control
  16. 1998 Cadillac Eldorado Werid Over-Heating Problem
  17. Complete part list for Aftermarket Nav install?
  18. Transmission Stumble
  19. HG or not? Greetings from Belgium, Europe
  20. Right side accelerometer problems 94 ETC
  21. steering wheel swap?
  22. 1999 Seville Starting Problem
  23. 93 Eldorado NorthStar throttle body cleaning
  24. 91 Eldorado Code: service CCR system What does this mean?
  25. removing airbag and steering wheel ?
  26. Code 0441 Question
  27. 91 4.9l codes EO47 B334-337 diagnosis
  28. Motor mounts
  29. 1989 Eldo- MINT
  30. Several questions related to overheating (please help!)
  31. Rims offset max - min
  32. Ranger is right stay away from the cotton filters !
  33. A/C stopped working
  34. Rear parking sensor issue
  35. remote key fob problem...
  36. Most fuel efficient driving speed for the Seville
  37. Painters/body men: Prepping my 99 SLS for paint
  38. location and HOW to for the coolant surge line
  39. Which would you buy: 85 Eldo or 85 Seville?
  40. Crazy Eldo on eBay
  41. when AC on car gets up to 220 DEG
  42. Silly me.
  43. 1993 Eldorado - Electronic Level Control
  44. 2000 seville steering noise
  45. will these fit my car!!!!! please!!!!!
  46. 93 Eldorado North Star Y engine spark plug recommendation
  47. Old school STS commercial with Damon Wayans
  48. A/C cooling troubles
  49. 93 Eldorado North Star Radiator
  50. Difference Between Eldo and Eldo Biarritz?
  51. fuel pump
  52. Drivers Side A/C
  53. 02 STS Keyless Entry?
  54. anyone have a set of 18in sts/DTS wheels?
  55. Road sway on 2001 STS?
  56. Rock auto oil sending unit
  57. Front Calipers sticking
  58. 1998 STS P1811....Long shift and maximum adaptation limit reached
  59. P0446 EVAP Vent Solenoid Valve Control
  60. 93 Eldorado Cranks but Will Not Start
  61. Cadillac Seville & Eldorado Floor Mats - Custom Made
  62. stalled at stop light, now won't start
  63. 2002 and 2003 STS differences?
  64. Replace Fuel Line
  65. odd occurances 87 seville
  66. Want a 1980-85 Eldorado-- Should I Buy?
  67. Considering a 99 STS need imput!
  68. 85 Cadillac Seville Problem
  69. Fuel Gage fluctuates, how much is normal?
  70. Best Sim Convertible top cleaner?
  71. Need to replace a few things...
  72. 95 cadillac ledorado
  73. Summer Weather!
  74. No reason to worry? Coolant problems...
  75. 1985 Seville
  76. Tail Light
  77. Oil cooler lines corroded at radiator
  78. 92 Eldorado/rattle In Front End Please Help!!!
  79. How to remove radio, door panel. 03 Seville
  80. Is there a solution to repairing the Dashboard Liner?
  81. Thumping/Grinding noice on Right side of car
  82. Air Conditioning/Heater Blower 1997 SLS
  83. best site for wheels and tires???
  84. changing rotors. Hard???
  85. Thinking of buying 2001-2002 Eldorado
  86. Can you program your name into DIC?
  87. Subwoofer wire color 02-04 Seville
  88. 94 seville interior door panel on a 97?
  89. Turbo/Exhaust systems for 01 sls
  90. 96 STS Ride Control
  91. Oil Pressure sending unit/RPMS blahs
  92. Eldo 97 shakes at slow speed
  93. 99 STS A/C Refrigerant Overpressure
  94. flashing strobes illegal when parked???
  95. 15% Off** Forum Member Discount Code For Father's Day
  96. 1999 Eldorado Molding
  97. 99 Eldorado Help Please! from a nubie
  98. New Bose subwoofer smoking, blown out!
  99. Was Seville ordered or picked up on Dealer lot
  100. Painting 98-up SLS grille
  101. Brake Planet Brakes and Rotors
  102. 96 eldo handeling and hot weather performance
  103. Should I go for it?
  104. Aftermarket Stereo Install
  105. 04 sts seville bose rds issues
  106. misfire
  107. replacing tie rod ends and lower ball joints
  108. 2001 Seville Emergency Spare size
  109. I Pod connection
  110. Good independant Caddy mechanic Central Ohio
  111. AC condenser drain
  112. Rear sub replacement on 03 STS
  113. rear struts:worn?
  114. `97 Seville STS Trunk Pulldown
  115. hydra-matic 4T80-E Transmission
  116. Help with current codes: P0741 and P1860?
  117. Removing Interrior
  118. how many 1984 sivilles made with touring suspension
  119. leaking coolant behind front passenger side
  120. Change 2003 STS suspension to SLS type
  121. Please Help!!
  122. 1996 Cadillac STS Engine/trans Swap. Top or Bottom?
  123. 94 sts t073 traction disable no speeedo/AC
  124. Seville & Eldorado Custom Floor Mats
  125. 98 seville sts outside trunk light replacement
  126. 79 Cadillac Seville
  127. ah problem!
  128. Mystery "thump" when rolling to stop in neutral
  129. retaining clips for the lighting panel
  130. Amsoil in my 2001 STS?
  131. my 90eldo died the other day
  132. Sensor Air Valve Stem
  133. Detonation
  134. Install Eldorado Steering Wheel
  135. a/c leaking or is this normal?
  136. Newbie question...General reliability '03-'04 vs. '98-'00?
  137. AC Problem maybe ?
  138. 98 STS starting problems
  139. 98-04 black interior
  140. Severe engine miss mostly at idle-dark gas
  141. 1978 Seville Opera
  142. High side service port valve core 91 Eldorado
  143. 02 sensors pin number on pcm
  144. Eibach lowering Springs Eldo/Seville
  145. Service suspension
  146. 2001 Eldorado ESC mpg !!
  147. oil flow at valve covers
  148. 15% Off** Coupon Code For Forum Members
  149. Seville Stereo Question
  150. Chrome Lug Nuts?
  151. can rwd 18's fit
  152. AC charged still low refigerant code
  153. Sunroof problem
  154. '99 ETC Catalytic removal?
  155. $1570 to Replace AC Compressor
  156. 3rd Gear start when warm
  157. spoiler?
  158. RPM idle question
  159. heater inlet and outlet hoses
  160. 74 eldo: fabric convertible top (no vinyl) - which is the best adress ??
  161. Seville 94 SLS - couple of questions
  162. 2001 Cadillac Seville STS - Check Engine Oil
  163. 84 Seville misterious fuel problem.
  164. sunroof leaking discovery
  165. replacing suspension control module
  166. 1976 Eldorado Transmission Questions
  167. Seville & Eldorado Custom Floor Mats
  168. No Problems!
  169. Gauges, etc.
  170. Reverse Signal 1994 ETC
  171. right side mirror problem
  172. Transmission Filter
  173. 2001 Seville STS questions?
  174. flickering lights
  175. 1992 STS Digital instrument cluster issues
  176. Tranny speed sensor problem ***plz help***
  177. I Need Help With My Ac
  178. Anyone have a Rock Auto discount code
  179. won't start, service theft system and service fuel system
  180. 1995 Seville steering clank
  181. 1979 Cadillac Sevile by Gucci for sale
  182. Air intake on 01 Eldorado?
  183. Intermitent Power outage !!
  184. parting '98 eldo
  185. 79 Seville Brake System Proportioning Valve.
  186. Symtoms of bad/worn struts?
  187. Any solutions to 3-5 MPG loss on high mileage Northstar?
  188. radio removal
  189. Northstar engine shaking - what causes this?
  190. i want to blow my own horn!
  191. Thanks.
  192. ac squeek and bump
  193. no crank
  194. 95 SLS Coolant leak, pics included
  195. How to change O2 Sensor?
  196. 1993 Seville 4.9L -- Nothing happens in "start"
  197. Transmission solenoid Q'S
  198. Time for a tune-up, but are these the right parts?
  199. Coolant Question
  200. STS Magneride control. Does it really WORK?
  201. 93 Seville Water Pump
  202. 2000 Eldorado headrest
  203. 99 STS Overheating: Heater was cold
  204. Rear end steer over bumps... Not the knuckles! Yikes!
  205. fuel computer
  206. Where to get Bose 4.0 Speakers
  207. Compare CTS and ETC??
  208. 97 ELDO, window motor
  209. 95 cadillac please help with overheating problem no one can fix it?
  210. Spark Plug Replacement on 2002 Seville STS, PIECE OF CAKE!
  211. starting problem(sometimes) and idle problem
  212. No Start!!!!! Help
  213. Electrical Cutting Out 87 Seville
  214. Horn Not Working
  215. 93 Seville 4.9, no spark, no start
  216. 00 STS Will Not Stay Running
  217. need help on coolant tank draining....
  218. newbie here, is this seville worth saving?
  219. '94 STS - passenger’s seat rattles.
  220. HELP! 1993 4.6L STS serpentine belt routing diagram
  221. '94 STS strange AC\Ventilation filter?
  222. Instrument Cluster Milage??
  223. ETC Hood Ornament Opinions Wanted
  224. Seville & Eldorado Floor Mats - Custom Made
  225. Bench Bleeding Gone Bad? Help!
  226. Filler details
  227. Any good cadillac mechanics in the Detroit area?
  228. '68 Eldorado questions
  229. 1998 STS - Electrical, mechanical or both
  230. heated windshield on alternator
  231. Northstar problem
  232. Will this steering wheel fit a 1997 SLS?
  233. Gauges and A/C died....
  234. 2001 STS Replace "Crossover Gaskets" ??
  235. '89 Eldorado Pre-Purchase Questions
  236. I want to honk my horn when i lock the doors
  237. How do I disable the drls ?
  238. xenon replace
  239. Thinks the key is always in the ignition
  240. STS 2000 Lower Grille...
  241. 97 North* SLS Trunk lid problems
  242. Rear Rotors on Front
  243. Passenger seat vibrates and chirps
  244. New motor mount
  245. Would a 95 STS hood fit my 92 ETC?
  246. Paint Bubble on passenger door (2001 STS)
  247. 97 STS Battery Drain & Multimeter reading
  248. Carnut please.. 1984 ELD Conv. rear window
  249. 99 Seville - No dash lights or gauges
  250. Bought my first Cad!
