View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. '93 STS Lighting Problem
  2. 2000 Factory Service Manual
  3. 98 SLS front Valve Cover
  4. 94 ETC Waterpump Info
  5. 2003 STS "Rough Idle"
  6. 2002 STS Passenger seat issues
  7. 98 STS Lock Cyclinder Replacement
  8. What kind of cadillac is this?
  9. 1991 Eldorado Brake Light & Turn Signal Problem
  10. Need help IDing a part
  11. service air bag
  12. Ac - low refridgerant
  13. how to clean engine exterior
  14. Service electrical system message
  15. ABS disable?
  16. Looking for a 1968 or 1970 Eldorado...
  17. '85 Eldo Locks and Windows
  18. grills???
  19. Rear Brake Proportion Valve Replacement
  20. fuse?
  21. Where do I start???
  22. question about bolts holes for head gaskets
  23. power steering failure
  24. 1999 El Dorado a/c problem
  25. HID Headlight for 01 STS
  26. going check out a 99 eldorado
  27. Cd player dead ... cost of replacement ?
  28. 94 ETC Moonroof going crazy
  29. Still need help! Transmission issues 2002 Seville SLS 70k mi
  30. 2001 STS Nitrous Questions
  31. Codes ?
  32. Normal Cooling Fans Operation ???
  33. no door key, suggestions?
  34. custom exhaust cat delete
  35. At rest correct idle speed - 95 Eldo
  36. Leaks and Tires and Bends... OH MY! 2002 STS
  37. oil leak
  38. Bad battery destroys alternator
  39. Transmission is full but no fluid on the dipstick
  40. 93 Eldo A/C Vent Louver Removal
  41. HELP!!!Cam postion sensor causing no fuel
  42. Error Codes
  43. how to recharge FREON 94 Cadillac Eldorado Touring Coupe
  44. What do I do?
  45. Whats need to do head gasket job 97sts
  46. ABS/ traction control light issue
  47. Eldo, AC vents
  48. HELP!!! '02 Seville SLS tranny issues! dealership says $3k+!
  49. paint help
  50. Horn
  51. speedo, Heater & A/C problems
  52. Eldorado & seville floor mats - custom made
  53. 94 Eldo engine revs high then dies.
  54. Need Mechanic near exit 12 I-90 NY
  55. code c1727 arrnott shocks
  56. Coolant loss and temps,(yup another one)
  57. Head gasket or Radiator?
  58. Won't start at times
  59. '99 Eldorado Power Mirror Switch Question..
  60. how do you bypass the compressor?
  61. Head Gasket question
  62. Computer Grounding
  63. Power mirrors cease to work.
  64. the MAN!
  65. Power Lock Problems
  66. 84 Eldorado Olds 455 Swap Questions
  67. How do I remove the hood ornament
  68. Urgent Problem: 99' Seville STS
  69. Looking for advice....
  70. Oxygen Sensor on Board Test
  71. Factory Navigation Install into Non Nav Sevilles and Devilles
  72. newb here
  73. DASHPAD REMOVAL 1999 Seville STS ?
  74. It's not always the headgasket!
  75. How do you reset Oil needs change soon msg?
  76. Brake Pad Recommendation
  77. P0741 Question
  78. '90 seville, where is the interior relay center?
  79. Windows Won't Go Down!
  80. 03 STS - Occasional misfire on cyl 1 & 3, and PAS
  81. '90 seville...... dies while driving!
  82. Does a 94 Eldorado transmission have some type of breather?
  83. Tempting? '98 Coach Builders Ltd. Eldorado ETC 'Vert
  84. Front Shock Replacement, what else?
  85. Overhead console clips
  86. I got HIDS!!
  87. Has anyone ever replaced A/C high and low port valves?
  88. 91 Eldo Coolant Tube???
  89. how to take caulk off of the roof
  90. Need your Opinions
  91. Does anyone have a Rockauto discount code?
  92. Ipm b1344.....
  93. dim low beam lamps
  94. 1996 STS runs kinda hot/ How do I kno what color my car is?
  95. Power steering pump removal
  96. 76 Convertible motor
  97. trunk pull down
  98. Eleven codes
  99. Crank, no start-ideas?
  100. Another A/C question
  101. What Quantities of...
  102. Help with 1970 Eldorado wheels
  103. Windshield wiper problems
  104. Change oil after Overheating?
  105. Quick Question on Exhaust (97 Seville STS)
  106. Oil drip from RT. rear spring area 96 STS
  107. parting out 1969 Cadillac Eldorado
  108. Center exhaust hanger -2000 STS
  109. Help no pwr locks or windows
  110. serice engine soon light on
  111. 97 eldorado theft system car wont start
  112. 95 STS Starter HELP!
  113. still playing
  114. P083 Crankshaft to Ignition Module? How to change Crank Sensor?
  115. Stabilizer Bar Links
  116. 2002 sts gas mileage
  117. air in the cooling system..... BS?
  118. Horn help
  119. P0440 One last time please.........
  120. Speedometer reading zero and a few codes
  121. My First STS - a 1993 as my extra car - needed something in Philly - your opinion?
  122. Window Switch Removal
  123. Seville sls BLEEDING!!!
  124. another ac problem
  125. buddies STS worth saving
  126. silicone brake fluid
  127. radio swap
  128. MSD ignition coils GM-2 tower 'GOOD OR BAD'
  129. Cadillac STS 1996
  130. Electric problem
  131. Anybody want a 'slightly used' compressor? ()W $*&@_)#!
  132. P024 Code after solenoid job
  133. Overhead lights
  134. STS Transmission question
  135. tps repair
  136. Air inake system was loose
  137. 99 sts electrical problem
  138. 1992 Eldorado display problem
  139. I need help from people smarter than me!!
  140. engine revs
  141. Build Codes
  142. another front end groan, what is it?
  143. repairing car top
  144. Please Help!!!
  145. 96 ETC air blower top door under hood
  146. No heater A/C control
  147. It came today. 2000-2003 Eldo engine mount
  148. 1997 Eldorado Purchase
  149. Thermostat direction 4.5 - IN PROGRESS
  150. po151
  151. 82 eldo misbehaving!!
  152. 4.9L TB Tip
  153. 2000 Seville FSM
  154. TCS Code C1234 (Misprint in Helm?)
  155. 1995 Sls
  156. Power Window Problems
  157. octane needed for a 92 -93 eldo. 4.9
  158. 94 eldo with electronic problems
  159. who designed this ?
  160. Buying a 70 Eldo...what to look for...?
  161. 1971 Cadillac Eldorado floor panels
  162. 72 Eldorado wont start, no crank, no click
  163. 2000 eldo vibrating wheel at 60+
  164. Groaning sound in front end, 03 Seville STS
  165. Eldorado & Seville Floor Mats- Custom Made
  166. Evaporator Leak?- 96 STS
  167. Need help with coil part #
  168. Help With S Codes.. Rotors? Sensors?
  169. 99 STS: Which suspension do I have?
  170. Air condition prob
  171. 1998 Sls
  172. Vacuum diagram for '88 Eldorado
  173. 1976 Eldorado - Any good?
  174. 98-04 Seville Steering wheel controls - phone to HVAC
  175. found a 78 biarritz custom today, i think
  176. Confirm air ride compressor part # PLZ HELP
  177. Eldo Mufflers
  178. STS Codes
  179. New Brake Rotor / Pads are smelling ?
  180. 98 Eldorado O2 Sensor Replace
  181. eldorado steering rack
  182. Power Loss Update
  183. Program Homelink to Craftsman garage door opener
  184. Overheating Eldorado
  185. Clanking in Rear
  186. Eldorado suspension identification
  187. eldorado woodgrain wheels ?
  188. Looking for a exterior door part; 97 STS
  189. Good trade?
  190. Buying a '94 STS, few issues i noticed.
  191. Rear Link Bushing
  192. 96 etc seat recovering
  193. These cars are surprisingly good on gas!
  194. Question about radiator a/c fan
  195. climate and info center problem
  196. Codes are confusing? Need help
  197. ambient air temp error
  198. Possible Trans Problem/Jumps
  199. Service Stability Sys
  200. Service ride control message
  201. 1998 ETC "torque converter clutch" ???'s
  202. Another question. Car looks like...
  203. Power loss
  204. been playing
  205. How cold is your A/C ?
  206. Used Parts "JUNK" Dealers
  207. Complete LED interior with pictures
  208. 1999 el dorado alternator problems
  209. Anything to look for in a '94?
  210. 81 Seville Brakes
  211. Eldorado with Gold Trim
  212. Rear Shocks 98 STS
  213. RSS codes
  214. Easy Question
  215. 03 Seville Canvas Top
  216. Check gas cap ?
  217. Seville 96 tends to stall at traffic light - Solution
  218. need help finding correct part for front motor mount
  219. half of my car is heated, the other half not.
  220. 2001 STS fog light
  221. It's been a while for a glitch.....
  222. Subframe connectors
  223. 2000 seville steering woes
  224. Purchasing 2003 STS - Advice Needed
  225. orifice tube
  226. 85eldo airco problem
  227. 94 seville trans problem
  228. STS Purchase Advice
  229. Another question on oil..........
  230. "service Stability System"
  231. pass key problem?
  232. Assistance in acquiring part...
  233. 03 STS clunk noise felt through steering wheel
  234. Brake Pads?
  235. new and strange, 97 sts
  236. nice coolant leak......
  237. annoying problems
  238. Rain Sense Wiper Sensor
  239. Think my sts is poorly :(
  240. Clicking noise on Left turn
  241. 1998 STS is all over the road. HELP
  242. 1991 Eldorado runs like
  243. How to Turn off Service Engine Soon light in 1997 ETC?
  244. AC Compressor issues (in Canada if you can believe-it)
  245. "service Suspension System" Code On 98' Sts
  246. Blow horn when pressing the lock remote button twice, ideas?
  247. Thinking of buying a....
  248. Transmission problem - 2 gears only
  249. Transmission problem - 2 gears only
  250. What does this mean?
