View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. New Rotor Noise
  2. Service ride control codes help please.
  3. Eldorado, a gramps car?
  4. torque converter clutch
  5. suspension/handling
  6. 98-04 Trunk lid adjustment
  7. Need to find a brake light socket.
  8. Break rotors!
  9. 01 STS Cup Holder
  10. eldorado leaking coolant but dont know from where
  11. Clogged CAT - How to Tell?
  12. 1999 Seville SLS
  13. power steering pressure switch
  14. Rear-view mirror with compass on a '97 STS?
  15. Tan leather for my SLS seats.
  16. Trans fluid life always says 100% (01 STS)
  17. Electronics are not working after Jump Start
  18. Buying used struts (good idea?)
  19. Aww
  20. '01 STS Console - convert from CD Changer to regular console
  21. 2000 sts are they good ?
  22. Are any of these codes a danger to my driving??
  23. Cannot get ignition switch out
  24. 03 STS Purchase Advice
  25. Still an ignition problem
  26. 1976 Eldo Vert w/25 actual miles
  27. Bad Injector?
  28. Did I mess up the shocks or Air compressor
  29. eldorado heats up quick when in parked
  30. She finally went...
  31. 97 ETC transmission trouble
  32. Storing my 98 ETC for the Winter in NY - Any Tips or Advice?
  33. Air filter replacement on 01 STS
  34. Anyone have any interest in a 1997 Eldorado ETC?
  35. Firewall Acessability
  36. New here and need your advice...please.
  37. 1998 STS vs 1999 Eldarado better buy?
  38. bonnet emblem
  39. '00 STS driver window regulator pulley broke
  40. Elvis' 68 Eldorado FOUND (Pictures taken today)
  41. Heads Up Anyone?
  42. Anybody know the wiring for a 94 STS cd player
  43. Advice on front/rear shock replacement w/ used OEM 97 STS
  44. No Problems So Far
  45. Help!! before I throw my car in a lake!
  46. Ecm??
  47. Transmission Help
  48. More codes
  49. need some help with LED lights
  50. Wipers Won't Shut Off
  51. No Passenger Heat Just Blows Cold
  52. Guys I need your help - car illiterate here
  53. High speed vibration
  54. Gas octane
  55. Wiper problem
  56. Control Arm interchangeability
  57. drivers side mirror problem
  58. Sears Battery for 2002 Seville STS?
  59. '90 Seville: Blower Control Module?
  60. 95 STS blower/control module
  61. 99 STS Bose radio issues
  62. 97 STS alternator replacement. Does it really come out?
  63. 97 Seville STS no heat drivers side
  64. 99 STS Park to Drive problem
  65. Service Theft System
  66. Service Theft System
  67. no heat
  68. Fluids
  69. 01 Seville STS Powersteering Issue
  70. I Don't Know Why
  71. Keyless entry range
  72. 14.4mpg city 28hwy @ 80mph constant
  73. arnott question
  74. heated windshield
  75. P0122
  76. How do you install a new water pump belt
  77. BPMV C1242 C1243 Issues with wiring question
  78. STS Coilovers
  79. eldorado starting to heat up
  80. '93 STS Vacuum issues - PARTS!!??
  81. 92 ElDorado problems
  82. 97 ETC Rearview Mirror Replacement
  83. will the ecbm cause tranny problems?
  84. Need Replacement Keys
  85. 1992 eldorado cluster question
  86. 92 eldorado front struts
  87. what happened to my antifreeze?
  88. 1994 eldorado (FPR)
  89. Seville STS Tires
  90. Fuel Pump
  91. "TRACTION" Light comes on & the brakes activate by themselves?
  92. HomeLink - How to erase all buttons
  93. Talk me out of parting this car out
  94. mirror glass and then some...
  95. Looking for Stock Seville STS Rims and Good Treads!
  96. Quick code
  97. 1995 Interior Color
  98. Woo Hoo finally caught a break on my Eldorado !!!
  99. Energy Suspension Polyurethane Bushings
  100. 89 Seville Inexplicable/rapid overheating Help! (so it makes it home heh)
  101. 'Pop' felt in floor pan area
  102. 97 Seville blows air no heat
  103. 2001 STS Nitrous Questions PT. 2
  104. Jim Reeves 1960 Eldorado
  105. Heated seat
  106. EGR Valve Help - 98 STS
  107. 96' STS ABS Codes.. Advice needed
  108. HVAC Fan - Sounds like a kazoo.
  109. 8,300 Mile '02 STS - Bought
  110. 1997 Eldorado, 472 V8 Rear Wheel Drive
  111. Battery choice question
  112. my front pads were low and now my front brakes dont work....
  113. Vibration
  114. Tcs C1761
  115. STS 1999, ABS/TC light
  116. mod chip for 93 eldo???
  117. 91 Eldo w/ odd door lock problem
  118. codes question
  119. Throttle Body
  120. STS Top Speed
  121. Performance 94 STS vs 99 deville concours
  122. Seville & eldorado logo floormats
  123. 2003 SLS - Turning Signal on Passenger Mirror?
  124. drive shaft problems, probably damaged bearing
  125. another quick electrical question
  126. Sucking sound around PS pump end of intake
  127. Need to Replace Catback - Need Advice
  128. Got Rid of Console Squeak in 98+ Seville
  129. 99' sts power window
  130. 1997 Seville STS
  131. Jacking Points - 2003 Seville SLS
  132. rear reflector replacement On 2000 Eldo
  133. tail light/brake light/turn signal issues ('99 ETC)
  134. Replace Signal Flasher
  135. change engine oil code. on a eldorado
  136. 1996 STS "Battery No Charge" message
  137. Battery no charge
  138. still trying to get remote
  139. Feature Programming Problem on my 2000 STS
  140. information center display
  141. 94 Eldorado Speaker Issue
  142. Odd question here
  143. Sunroof Issue on '97 Eldo ETC
  144. Noisy First Gear???
  145. New to Forum with 78 El Dorado
  146. Leaking Sunroof on my 1999 STS.
  147. BAM014; needs help with front struts
  148. CKP Causing Power Loss?
  149. 94 Eldorado - I'm Discouraged - Need Advice
  150. Mechanic in WNY - Bit of a bind - Help!
  151. what trailer light connector do i need
  152. codes pulling out timing????
  153. spongy brakes
  154. 1992 eldorado
  155. 92 Eldorado Help!!!!
  156. nylon or steal fuel rail?
  157. 1991 Cadillac Eldorado
  158. 1985 Eldorado
  159. Are the 94 radios security locked liked the newer ones.
  160. How to wire fog lights to come on/off with headlites.
  161. 96 Eldorado horn not working?
  162. Check coolant level - how much to put in
  163. How to ruin a car
  164. "Trunk open" flashing on display
  165. No First gear "codes"
  166. Cadillac Service!
  167. Got some HIDs for the eldorado :)
  168. anyone have this grill
  169. Ball-joint & tie-rod question
  170. Rear Knuckle Solution
  171. EY-Pass/Fastlane on '93 Seville
  172. Caddy Comparison: '92 STS vs. '98 STS.
  173. Looking at a 2000 Cadillac Sevile STS tomorrow
  174. Spark plugs
  175. Service Idle Control System
  176. Suspension Noises
  177. P0741 TCC questions / 00 Seville STS
  178. help with AC
  179. Power!
  180. 03 STS Driver window will not auto go up..
  181. stock tires / stock rims
  182. Used N*'s for sale
  183. STS Only or SLS get the MagneRide adaptive suspension system
  184. How to refill A/C Refrigerant on '93 Seville
  185. Something isn't adding up...(help please)
  186. 2000 SLS Outer Tie Rod Removal
  187. 99 STS Baby Seat
  188. 2000 STS battery drain... please help
  189. BCM Question
  190. 12 disk changer for sale
  191. 94 sts egr question.
  192. can someone give me a list or diagram
  193. Interesting ebay find, one off GM studio 67 Eldo Phantom-X
  194. General question thread/issues
  195. my sons 95 sls is idleing to hi 1000rpms
  196. D.i.y. ?
  197. traded one clunk for another
  198. Wheel bearing myths
  199. Cant pull codes!
  200. Part Identification
  201. Alternator or Battery/connection?
  202. FPR Connection Problem
  203. 1991 Seville 4.9 Engine Cutting Out Intermittently at Idle
  204. 97 eldorado blower isnt blowing
  205. Think I have a big problem ?
  206. Sound Right for a Oil Casehalves replacment, reseal, etc,
  207. 96 Eldo ABS Light On; No Codes
  208. Realistic expectation for 01 SLS?
  209. Map light retention clips
  210. Quick Question
  211. MOD/HOW-TO: Seville Sport Mesh Grille
  212. 99 STS Camshaft position Sensor error
  213. sunroof seating
  214. Project: Part 2- Cure Front End Vibration
  215. Backup lights not working
  216. help finding fuse
  217. Need fuel sending unit....
  218. do they make a cadillac logo key chain like this?
  219. Low side AC port; '90 Eldorado?
  220. Rear Strut differences what one to use?
  221. Code B2477
  222. Code 99 ETC
  223. what size brake lines go on a 92 sts
  224. Quick code
  225. Friends wants a Cadillac!!! Look!!!!!
  226. Unusual Looking Eldorado
  227. Gasket fixer upper
  228. Need Tire Options
  229. 2001 STS or SLS
  230. Problem starting 93 eldorado
  231. Sunroof Gurgling and closing problem!
  232. 94 Eldo Exaust needed
  233. STS code help
  234. Cold start
  235. '93 N* Ear piercing whistle - Continuing glitch
  236. 1993 Eldorado trouble!
  237. 1997 Eldorado Power Seat
  238. Front Struts Seville STS 1992
  239. about to buy a 98 Eldorado 59K miles
  240. 95 eldorado, service light comes on/off?
  241. 2001 sts brake calipers
  242. help asap with dirver side window
  243. Serpentine Belt
  244. 2000 STS- Clunk noise when I shift into drive
  245. Does this look like an over extended CV joint?
  246. 85 eldo trans won't shift out of low-help
  247. 94 Touring Coupe - Sounds Like Loose Lumber In Trunk
  248. Driver's heat seat won't turn off - 1994 Eldorado ETC
  249. Really weird steering noise
  250. water pump cover gasket, 93 eldorado
