View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Frustrating ABS/TCS Issue on a 1999 Seville STS
  2. New to me 2000 STS
  3. 96 STS doesn't shift gears when warm - bad solenoids?
  4. 96 Eldorado Seville Heater AC Climate Control
  5. my 92 eldorado with 257,000 miles and running!
  6. Looking for a set of '67 Eldo Bucket Seats
  7. Headliner Replacement
  8. I look for some little things for my Eldorado 96
  9. 01 STS: Battery is AGM type? Need charger recommendation
  10. 94 ETC Long time to shift to 1 when cold
  11. What do these codes tell me?
  12. 2001 sls
  13. 1994 seville billet grille installed!
  14. 1990 eldorado biarritz opera lights
  15. 03 STS front mount Question
  16. i just smash the caddy
  17. ABS Light on but no codes
  18. Brake Pads, '91 STS
  19. 01 SLS IPC Problem
  20. 03 STS Casehalf oil leak
  21. Custom floor mats - free shipping
  22. daylight running lights
  23. 2002 SLS--Blower Motor
  24. steering has mind of its own
  25. 86 SLS A/C compressor R&R
  26. while were on alternators
  27. U must think people r Stupid!!!
  28. rough cold start
  29. Alternator help
  30. Oil leaks will total the car.
  31. Hello from Germany!
  32. spring perch isolator
  33. Feature Programming [DIC] problems in 98 STS
  34. Stock HID's not that bright. 2003 Seville STS
  35. Traction Control On/Off button not working
  36. Dieing speaker - Replacement advice
  37. 99 seville sls shifter console lamp
  38. TPMS problem
  39. New to me 2004 SLS
  40. Installing water pump 99 eldo
  41. help,temperature too high
  42. Eldorado Overheating whoos
  43. Replace '98 STS outside mirror
  44. '02 SLS - What Factory Wheels Interchange?
  45. 02 SLS Coolant Leak
  46. 1992 Eldorado digital dash
  47. Steering Position Sensor
  48. removing heater core 97 sev. sls
  49. Removing radio 90 Eldorado
  50. 99 SLS PCM Code 0404
  51. Muffler leaking water....?
  52. Stability and Airbag
  53. exhaust question
  54. Help--stuck on ignition switch replacement
  55. 95 eldorado doors won't open
  56. homelink garagedoor opener remote
  57. Axle seal leak on 04 SLS Northstar
  58. Heating - how long...
  59. 98-04 Seville PRNDL Lamp Replacement
  60. 95 Eldorado, probably head gaskets
  61. Looking At A 2001 Cadillac Seville STS
  62. lowering sts??
  63. Interesting Seville
  64. Name That Flange!!
  65. 94 ETC Battery No Charge Sometimes
  66. Pulled Codes on my 98 ETC, Have One Current
  67. how i fixed my key fob
  68. how i solved my leaky trunk
  69. Memory/Positioning - 99 Seville STS
  70. Key in Recall -- 99 Seville STS
  71. Change oil/check engine oil light
  72. 02 SLS--I messed up-help!
  73. 96 SLS Outside Mirrors Stuck Up and Out
  74. 2001 SLS Headlamp Lens Cover
  75. New and Improved Seville STS Trunk Leak
  76. Intermittent brake lights 99 ETC
  77. 1999 Cadillac STS CD Changer Interchangeability
  78. service suspension system,need help
  79. 98-04 STS HVAC Control dead bulbs
  80. Air ride (air bagged?) on a 67-78 Eldorado?
  81. I’m So Excited about my New 2003 STS
  82. coolant tabs?
  83. Seville gauge cluster compatibility
  84. Cadillac Seville / Cadillac Eldorado CUSTOM FLOOR MATS
  85. 99 eldo waterpump inlet housing leak
  86. 2000 Eldorado no heat, ac, rear defogger
  87. 2000 Seville STS - Replacing Alternator
  88. coolant change
  89. camshaft sensor for 1994 cadillac sts
  90. Neutral Safety Switch 1999 STS
  91. Hey, I Hope somebody can help me
  92. New to Forum - 98 STS 149K Engine Advice
  93. wood shifter complements Eldorado and pre 98 Seville
  94. '96 Eldorado starter
  95. 89 Biarritz Changing AC controls
  96. spring isolators
  97. 2000 seville sls what problems to expect
  98. No Heat
  99. 98 STS "Jacks Itself Up"
  100. FYI--Bumper cover repair-big hole
  101. Heated Seats not working/ Traction Control not working?
  102. Oxygen Sensor in 1994 Cadillac STS
  103. RPO Code Decoder - Spare Tire Well
  104. Steering Wheel Lights Out 2000 SLS
  105. New 1999 STS Owner With Problems
  106. My Seville has a home of its own!
  107. Eldo rack and pinion
  108. Theft System Problem, Car may Not Restart
  109. 99 Seville STS Service Stability System
  110. Signals
  111. Battery =o
  112. what color is red 2000 sls?
  113. 2000 SLS feel a click in shifter while driving
  114. SLS Bose Speaker Problems
  115. eldo exhaust
  116. 93 Eldo turn signal problem
  117. 2003 STS bad HID bulb or ballast?
  118. sunroof stuck open
  119. heater core
  120. 1996 Cadillac Seville SLS Codes...Please Help!!
  121. Loud humming noise coming from engine area.
  122. power steering leak
  123. Engine parts interchangability
  124. Free shipping offer to forum members
  125. Before (20s) After (17s)
  126. Name my tailpipes?
  127. cat converter? replace?
  128. FL Wheel speed sensor acting up
  129. 92 eldorado no heat drivers side
  130. My Seville leaks orange on the left.
  131. auto headlamps
  132. For those that have dropped
  133. leather dye?
  134. Absolutely no Interior / Courtesy Lights
  135. ABS Connector 96 Eldorado
  136. retrofitting eldroado headlights?
  137. Intermittant "snapshot taken"
  138. '92 Seville 4.9 A/C Conversion?
  139. Fog lights won't turn on
  140. Hello Gorgeous!
  141. Dimming headlights & jumping voltage
  142. transmission issue
  143. I dont have any keys
  144. 92 Seville
  145. Never thought I'd be this happy to get my fact. wheels
  146. trunk wont stay up
  147. rear brakes '92 seville STS
  148. Performance Exhuast for 02 STS
  149. 2000 sls code po385 car stalls or dont start
  150. 94 STS Transmission Issue - Lost O.D. & Drive
  151. 94 seville drivers side carpet
  152. 98 Eldorado ETC- parking mirror & washer pump
  153. 94 Seville Battery/Charging Problem?
  154. Need help with programming new FOB and spare key for 2000 sts
  155. CADILLAC 94 "SERVICE ENGINE SOON" light
  156. 2003 Seville - CPS Replacement
  157. Random "Stutter" while driving at constant speed
  158. cam belts
  159. 2000 Seville STS Northstar ticking sound when under load
  160. Car Stalling & Tight Steering
  161. Looking for a couple of small interior pieces...
  162. 95 SLS broken armrest
  163. No High Beams?
  164. ECU Program for '92 with a 4.9?
  165. 94 cadillac STS blower motor
  166. ETC side view mirror
  167. coolant pellets
  168. HELP! codes
  169. Poor cold temp start on 97 seville
  170. 2000 sls new purchase, 2 problems
  171. 99 SLS customizing?
  172. '03 STS - Can I use a magnet to reset TPMS?
  173. Error Codes
  174. Looking for a place that has parts for a 77 seville
  175. Eldorado Dash Install Kit
  176. k&N air filter question
  177. parking brake not coming off need help quick
  178. external regulator help
  179. 2000 seville sls bad fuel gauge
  180. Instant fuel mileage is eratic @ highway & city cruise control speeds
  181. No heat - after fixed leak
  182. 77 seville ECU
  183. Electrical Gremlins!!
  184. 99 Seville STS Steering Wheel Button Lights
  185. what is the best lube for bushings to make them stop squeaking?
  186. System Problem Question 87 Seville
  187. Service Stability System
  188. best tires for 2000 seville sls
  189. 1997 Cadillac STS Manufacturer Promotional Video
  190. humming from behind dash
  191. coolant amount
  192. eldo trans not hifting anymore - new member
  193. HID relay install
  194. Complete Vehicle shutdown
  195. 97 sts service steering and noise
  196. 2002 SLS...Anything to watch out for?
  197. lean banks
  198. Cold Start
  199. Trans
  200. We've sprung a leak captain...
  201. replacing radiator on 98 seville sts
  202. Heat and air dont sense inside temp 03 sls
  203. Timing belt or chain?(maintenace)
  204. fuel pump
  205. Heater not working and coolant leak
  206. Door lock actuator fine, little rubber piece is not.
  207. 1994 Cadillac Eldorado Rear Brake Wrenches
  208. 98 eldorado- consumer report buying guide
  209. Eldorado Exhaust
  210. no heat on drivers side floor
  211. 94' ETC Parts car, stuff for sale
  212. Power Steering Question
  213. Highbeam problem 98 sts
  214. ETC/32V Northstar emblems
  215. Bought 99 Eldo ETC, need some help.
  216. Cadillac Misfire/no torque
  217. Ranger- help
  218. 1996 STS transmission Shifting problems.
  219. coolant pellets question.
  220. Alignment didn't fix ...
  221. Oil Pan Gasket Leak?
  222. RPO code 1SB
  223. Cadillac Seville, front legroom
  224. how i solved my missfire headache
  225. need name for part
  226. oil change question
  227. has a mind of its own
  228. New Owner of a '96 STS that has some problems...
  229. Dextron and Mercron AFT Fluid
  230. windshield wiper acting funny
  231. Eldo Ground Effects
  232. Seville STS and flat battery
  233. Replacement VATS keys w/ Cadillac logo
  234. Tire/Wheel Question about 16/17's
  235. 1999 STS Out of control revving at start-up
  236. 2000 sts owners manual
  237. wheels
  238. Uh Oh... Rust
  239. 92 eldorado cold air coming from heater
  240. Remove and install '95 Seville Cupholder
  241. Transmission Interchange Question 4T80E
  242. Just got a Seville
  243. Need VIN sticker location for 1991 Eldo Please
  244. Custom Floor Mats - Cadillac Seville / Cadillac Eldorado
  245. My STS has codes.
  246. 96 STS tranny problems
  247. New caddy emblem on a 2000 STS
  248. Wot (proper way?)
  249. Finally found (and bought) Blk STS in Tx.
  250. Eldo won't hold idle
