- E041 code
- Heated Seat Failure Diag.
- Not sure who is to blame
- traction control 93 sts
- Low Fuel Pressure = Hard Cold Starts
- tampering with the gauges
- Needin danbucs advice !(monroe shock)
- Check oil level
- Need advice-2002 Seville Drvers Mirror Install
- 1993 Seville Drifting On The Highway??
- Cadillac mechanic in Philly Area?
- 1993 STS Stalls
- Need a little help
- 1998 Seville sls - Check grounds in Trunk?
- Seville STS code message
- 1995 Eldorado front passenger carpet removal
- Exhaust question
- Northstar water pump housing
- Problem draining engine coolant
- Heater Controls Not Working Properly
- DIC Personal Message
- 95 Seville Door Panel/Shift Console Removal
- anybody know what wheels these are
- Computer Chips
- will aftermarket projection lights for eldorado ever happend?
- To Fix or Not To Fix: '96 STS
- Yet another broken HVAC heater box.
- Adding Tire Pressure Monitoring to '99 Seville
- Climate Control/Fuel Average Lights Go out When Headlights Go On
- Service Engine Light
- Need rear air shocks for 90 Seville/Eldorado
- P/N to D/R at High Throttle Angle
- 2000 eldorado shut down
- My 1983 El Dog. (list of question from rwd conv. to SERVICE SOON)
- 1995 Eldorado: Heater Core, and several unkn RPO Codes
- Completely dead STS
- Rear Integration Module Best Price
- Life Of Battery
- Instrument Cluster Illumination
- heat-slow
- 2000 sls dies sporatically
- steel seal gasket repair?
- 1999 sts, c1211, c1217
- Align Headlights
- 99 eldorado air ride stuck up high
- I can hear water...
- Ignition Coil Noises or?
- Replacing '88 Bose/Delco radio with aftermarket unit?
- so i got the codes..
- MAF Sensor Performance
- Hood Release lever broken
- Theft Deterrent Question is the trunk alarmed?
- Engine coolant temp - PC1118 code
- 1998 Seville SLS Backfires/Misfires
- Need help with Parts
- WOW! DIRTY throttle body
- Bumper cover help 1996 ETC
- Trunk won't open...
- Rear shock replacement (advice, tips?)
- Dead Battery and Warm Instrument Cluster
- 17" tires; Cooper CS4 vs. Yokahama Advin
- Simple Question: Difference Between "Cornering" & "Sidemarker" Bulb?
- how to turn off auto light setting
- Wiper problem that needs diagnosing
- can't locate 95 fuel pump
- air ride compressor noise
- 1995 Cadillac Eldorado
- How to Bleed radiator?
- 1999 STS Speaker Question
- STS (1999) - Ride control - Compressor head
- 99sts, Which 17" tires should I get?
- Strange
- defogger/heater core? issues
- TECH 2 Programming Advice
- 87 seville cooling fan problems
- '02 SLS - Front interior map lights
- Dual Terminal Battery?
- Merry Christmas and a Happy New Year! Fröhliche Weihnachten und ein glückliches neues
- My Double Din install - 99 Eldo
- Heat problems on 99 Eldorado
- who is better to go to
- electronic head gaskets
- 1985 seville
- Looking for source for Rebuilt N* Engine
- (only) 3 Codes after HG Job!
- Rodents have invaded my Eldo
- 2 questions-air compressor-heater
- wipers not working
- Wipers have the “jitters” – suspect bad linkage
- New Direct Factory Replacement Battery $77.52!!!
- 98 Eldo key fob programming
- Problem with pass. climate control
- engine swap
- Unlocked New DIC Features on my ETC 98
- help. control panel wont turn off
- Quick Question
- Replaced blower control module, still no air.
- ON Star causing radio problems
- Cold Winter, Rough Idle during Stop
- Service electrical systems
- Blower motor power module install
- P1483 Engine Cooling System Performance
- Need Power Window Switch Master
- trunk problem
- 97 STS - Blower motor problems
- powertrain removal
- mint eldo on ebay for 2K
- driving with unfilled AC ?
- trying to upgrade my headlights
- Help--window won't go up
- any suggestions
- 99 Eldorado Heater/AC not blowing
- Need Wood/Leather Steering Wheel (ELDORADO)
- Lookin for Bumper trim
- seville computer problem, engine swap?
- Stock 97 SLS Strut Tower Brace fit 2000 STS?
- transmission?break down?
- Suspension Service & Coolant Level Warning
- Parts List Not Working??
- Will 2001 ETC Transmission work on 94 ETC?
- Need Some Info On a 1999 STS
- Cold weather oil
- 2000 sls, who makes the audio system
- Underhood Information Label??
- 1996 STS: "Service Ride Control"
- Radiator Fans on all the time
- 1997 Eldorado seat heating elements
- Anybody ever lower a Seville?
- 94 ElDorado Coolant Hot
- battery installation
- 98 seville sts stalling at idle
- Rough idle after new parts
- Seville SLS 96 tends to get some race intermittenly at stop light
- Power steering pump 94 cadillac STS
- Difference Between ETC and ESC?
- Ranger on vacation?
- Fast car!
- 98 STS Steering Pulse
- Sunroof problems
- 96 sls
- psst....hey STS/eldo guys
- Deville Seville wheel swap
- MSM B1875 Error Code? Anybody know how to fix?
- Longterm P0441 Code
- Automatic Headlights (why off?)
- Thanks to Submariner409, for the "Butt Plug"
- Wiper arm or linkage?
- 88 seville alternator swap-out
- led taillights
- 20's wheels scraping on the fenders
- power anntena problem
- 2001 Eldorado ESC-- what do you think?
- Help!
- Front Hub/Wheel Bearing Assembly Bolts?
- My New (to me) Caddy!
- 1985 Eldorado
- Wipers and washer problem
- Here is '94 SLS heater core replacement procedure
- Idler Pulley Bolt Snapped
- Faulty Fuel Gauge
- clicking sound while driving (like turn signal) that comes and goes
- Low Idle
- battery type?
- 01 SLS Tail lamps replacement bulb numbers
- 1992 Seville RKE ( how to identify it )
- 95 ETC no shift from 1st
- 99 STS Snow Tire Sizes?
- Anyone have any spare lug nuts/caps laying around?
- What Now!!!
- Power Steering Fluid
- coolant change 01 sls help?
- 01 sls trunk deck running lights questions
- 2002 Eldorado trunk will not latch...
- 03 STS HVAC creeks and other sounds...
- Soldered O2 sensor wires causing p0171 & p0174?
- Need good source for generic struts 94 SLS
- 94 SLS heater core
- Audio system questions
- speed limiter
- Boze amps
- blown headlight fuse
- Eldo with t-tops
- help
- Help !! Can't get gas door to release
- On Cloud ???
- A/C compressor cluch Help
- heater core
- fuel filter replacement
- steering wheel fitment
- Quick Lube Place Overfilled Transmission
- need some battery help
- sts or sls
- code 0440 evaporative emission
- 91 Eldo Water Pump Tips
- 2000 STS totaled - for sale
- transmission question
- Listen to Bose Radio W/Engine off?
- I Have codes
- 97 Seville STS Right Front Speaker Crackling
- So what's with the yellow headlights on Sevilles?
- To All The Guys....
- Super/turbocharging an El Dorado?
- 1996 Seville SLS Codes, have questions
- Biggest tire size on stock 95 STS
- cant get it working
- 1999 STS help
- A few ? about 95 Eldorado
- 92 Seville Keyless Entry Module Location?
- mirror problem solved!
- Viper remote
- Adding Later Options to 99 STS
- Cruise control issues
- Anyone want a project?
- 97 seville questions
- Montana Blue Eldorado
- OnStar to Bluetooth conversion complete - 01 STS
- Rain in trunk
- 92-97 Sevilletinted taillights
- where to find....
- 2000 sls adding power outlets
- 2002 SLS: Engine Randomly Shuts Off
- 2000 sts help!!
- Seville Speed Limiter Removal
- Most Economical Method to Replace Remote
- Seville Buying Tips Tricks Cheats Things to Look For?
- Any mechanics in the Brooklyn, Queens sec
- Eldorado/DeVille Mirror Interchangeable?
- Need Help Identifying Part
- RPM drop while deceleration
- Assistance please!
- Where Can I Buy a TECH 2
- RPO codes for my -93 ETC
- Just another cheap internet engine scam?
- Frustrating ABS/TCS Issue on a 1999 Seville STS
- New to me 2000 STS
- 96 STS doesn't shift gears when warm - bad solenoids?
- 96 Eldorado Seville Heater AC Climate Control
- my 92 eldorado with 257,000 miles and running!
- Looking for a set of '67 Eldo Bucket Seats
- Headliner Replacement
- I look for some little things for my Eldorado 96
- 01 STS: Battery is AGM type? Need charger recommendation
- 94 ETC Long time to shift to 1 when cold
- What do these codes tell me?
- 2001 sls
- 1994 seville billet grille installed!
- 1990 eldorado biarritz opera lights
- 03 STS front mount Question
- i just smash the caddy
- ABS Light on but no codes
