View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Free Shipping Offer - Cadillac merchandise
  2. P0741 code.....
  3. What is this called and where can i get another one!?
  4. Wreath & Skull Apparel
  5. Trunk Measures
  6. 2002 eldo collector series exhaust
  7. horn hunking constant while driving
  8. Theftlock Activated
  9. RKE programing
  10. Eldorado's Dead
  11. What to do?
  12. ac not working in idle
  13. yeah my dad broke something
  14. water pump pulley removal?
  15. A lot of crazy symptoms
  16. $8.88 - Wreath & Skull Decals
  17. Anybody heard of a camshaft breaking on a NS.
  18. Power Steering Rack
  19. Engine Swap?
  20. Need help with A/C issues
  21. Last 02 selling question
  22. Any other suggestions for mufflers other than stock
  23. Electrical problem on STS - DTC combination
  24. Funny Button
  25. Power Seat Control Module 2000 Eldorado
  26. RE: Transmission will not shift correctly
  27. hoses?
  28. pcm
  29. 01 STS rough idle on start up
  30. 1999 STS Breaths Better Now...Air Box Opened
  31. 97 Eldorado Oil Pan Sensor
  32. 1999 STS Digital Speedometer Not Working
  33. Question about bulbs
  34. 1975 Eldorado won't start or run- fuel issue?
  35. eldorado leaking something
  36. Overheating - water pump?
  37. My Seville hates me...
  38. 96 STS Erratic Blinking
  39. what is it worth?.. my 02 STS
  40. Vibration
  41. SYstem Code
  42. Just got a '98 Eldorado convertable
  43. Bumper Replica of STS Pace Car
  44. body work
  45. Correct oil to my Seville STS '98
  46. eldorado kinda heating up
  47. Built in factor phone
  48. Can I remove/hollow catalytic converter?
  49. stupid question???
  50. Aux input verification
  51. rear seat belt stuck
  52. steering wheel control light bulb out
  53. 00 SLS Passenger window/mirror/door lock controls?
  54. 96 Seville DEAD! Code help please!
  55. 3rd brake light is driving me nuts!!!
  56. 98-04 Seville Owners...who has 18" wheels?
  57. Cadillac Seville / Cadillac Eldorado - Custom Floor & Trunk Mats
  58. to who ever has a TCC stuck off.( P0741) LOOK HERE
  59. Cost to replace headgasket
  60. Need Help Finding PCV Valve
  61. 89-91 eldoraod door moulding NEEDED
  62. Code R015 SIR Passenger Initiator Resistance High
  63. This one even has me stumped
  64. STSi Bumper For Sale...
  65. Poor Gas Mileage
  66. Turn Traction Control Back on? Tons of codes
  67. remote keyless entry question
  68. Hard Starts - Any idea where to begin?
  69. Good Wiper Blade for Eldorado96
  70. New Around Here
  71. STS Pace Car 2000
  72. Need Some Quick Answers
  73. No heat, no codes
  74. Traction control off???
  75. Sluggish, Sputtering, Power loss
  76. 1993 Seville STS--Where is Starter Enable Relay?
  77. Tune Up question
  78. battery drain 75 eldo convertible
  79. Why is my cooling system under vacuum?
  80. I install like a pro. (Not)
  81. Daytime Running Lights
  82. Hub/Bearing and Axle: Diagnosis and Decision
  83. Starting problems...Security issue? Passkey? Relays? Please help!
  84. codes..help
  85. A/C unit gone crazy
  86. head gasket repair additives any good
  87. Cadillac Seville / Cadillac Eldorado - Custom Floor & Trunk Mats
  88. code P0446
  89. Lower door molding
  90. Cant pull codes Help!
  91. Cadillac Window Decals/Banners
  92. What is the proper coolant for a 97 STS?
  93. New A/C pump
  94. HELP!!! ran out of gas, possible reset????
  95. Strut Replacements
  96. Eldorado 1997 Cooling issues (please no!)
  97. ac compressor relay not grounding to cut it on need some advice.
  98. Free shipping offer ends this evening - cadillac merchandise & custom floor mats
  99. 88 Eldorado B556 Code
  100. Speaker Door help
  101. Got Codes!
  102. 180K maintenance -- UPDATE -- please help
  103. how do i remove the eldorado climate control module?
  104. 92 Eldorado stalling/rough idle with code E070
  105. Clicking / Ratcheting Sound From Rear
  106. Check Coolant Level
  107. Another Trunk Water Leak Fixed!
  108. Coolant Leak Back of Engine Near Flywheel
  109. Quick CKP Question
  110. rear lights name???
  111. I have a code....
  112. ect sensor R&R?
  113. Steering issue
  114. A011 current?
  115. ect sensor?
  116. tires area making funny noise
  117. Center Console Lights Out
  118. Center Sole Lights Out
  119. rear window cadillac decal
  120. Signed Pinstripes
  121. '89 eldo transaxle-R&R
  122. Need some Pro advice
  123. Passenger Heated Seat
  124. 93 Seville 4.9 Running rough
  125. ELC Wiring Color Codes 97 Seville
  126. First Caddy - First Post - Need Assistance
  127. WTB STS struts
  128. Front End Vibration
  129. '00 Seville tailight out
  130. 02 Seville Wheel Bearing Hub failures
  131. Radiator Split
  132. Eldorado convertible -- frame reinforcement
  133. 1996 sls smokes
  134. security light coming on while driving
  135. will 1999 sts steering wheel fit 99 eldo??
  136. 75 eldo convertible top motor and glass question
  137. Solid front motor mount
  138. 97 sts driver seat
  139. Ride Height Sensors - aftermarket availability?
  140. Spark plug replacement
  141. newest addition
  142. My new 1988 Eldorado
  143. old Cadillac Eldorado concept
  144. 98 Seville SLS gets hot
  145. 01 seville fuel gauge
  146. traction control
  147. STS or SLS front grille?
  148. 1995 Eldorado: tire fitment
  149. 78 eldo Dips in power when accelerating. Any Ideas?
  150. will this blower motor fit?
  151. air conditioning prob
  152. Outside bottom door trim
  153. aftermarket performance muffler opinions wanted
  154. Removing Front Car Seats
  155. ABS and traction controll lights
  156. Service Stability System warning
  157. To buy or not to buy...
  158. reset dash signals?
  159. 2000 STS - top front radiator hose
  160. Self locking glove compartment door
  161. 1996 seville drivers side mirror
  162. 03 SLS with possible tranny issue
  163. Looking at an 01' STS, Overdrive not working?
  164. Shifting from Park to Drive
  165. 75 eldorado vacuume lines diagram
  166. 2002 Eldorado ETC Collectors Series
  167. 1985 Seville door handle/latch
  168. need help with oil pressure lines from radiator to block
  169. Possible Broke Fuel Pump ??car wont start??
  170. Free shipping offer for forum members
  171. 2001 Lowering Springs?
  172. 2001 Seville STRUT and shocks ?
  173. 98 SLS lower control arm question
  174. What is this little vent in my 2000 STS
  175. Just bought a 2001 Seville SLS
  176. Cadillac Seville / Cadillac Eldorado Floor Mats Custom Made
  177. Help 2001 STS Heater Problem
  178. 55 watts or 100 watts Xenons
  179. Gas over flowing from filler
  180. 1975 eldo tires w/ whitewall?
  181. 98 Seville STS
  182. By Way of Introduction New Owner 1999 Eldo
  183. 00 STS Service Elec Sys/Instrument cluster
  184. Did my first WOT's since HG job
  185. Interior lights keep coming on and off...Help!
  186. 180K Maintenance Items -- Worthwhile?
  187. Service Stability System with ABS and IPC codes
  188. 00 Cadillac SLS Tranny Codes and Issues
  189. Performance Ignition Wires?
  190. Anybody know where to find interior waste basket?
  191. Stock to BOSE conversion
  192. What sts years have the most problems
  193. 75 eldo door locks
  194. Considering a 2002 SLS -- Opinions wanted
  195. Groaning and Whining
  196. 94 sts with arnott shocks/struts codes???
  197. 1975 eldo heater?
  198. Anyone have experience with a Snap-on MT2500 scanner
  199. need help with starter wiring on 72 Eldorado--unknown loose wires
  200. Removing Outside Door Trim
  201. 99 seville
  202. Oil pressure sensor - location and how to change
  203. Ding a Ling
  204. Body Control Module
  205. N* mechanic in north Dallas area
  206. 85 Eldorado dies when key released from start position
  207. 1999 Eldorado driver window won't go down
  208. Cadillac computer
  209. Big Brake Kit for 95 SLS?
  210. belt just popped out of no where
  211. Can you interchange the ignition modules?
  212. Need Help!!!! Cold Air Intake Or Intake system
  213. 72 convertible: fusible links and 93 rim/tires
  214. 96 eldo IR 1740
  215. 95*eldorado hi / lo idle code po46
  216. Blower Fan on an 85 Seville... I think there is hope.
  217. Coolant Leak....Again
  218. Kalamazoo?
  219. Anyone want to change your defunct onstar into bluetooth device ?
  220. MAP for mid 80-90's
  221. help new here
  222. Best way to remove Cell Phone Dock.
  223. Instrument panel problem?
  224. E071 Snapshot? on 92 Eldorado
  225. 1976 Eldorado Trunk Pull Down Motor
  226. Radio wont shut off
  227. 92 Eldorado touring, gas into oil leak, any hope?
  228. Seville Brakes
  229. Trunk motor, what is going on here?
  230. I thought I had enough gas.....
  231. 02 Seville Seat issues
  232. 2000 STS Power Steering line
  233. Nylon Fuel Rails Recall?
  234. Snapshot access
  235. Suicide Doors on a Seville?
  236. fuel depressurization when car is not driven for 2 days
  237. Cadillac Seville / Cadillac Eldorado Custom Floor Mats
  238. 1997 seville radiator replacement
  239. 92 Eldorado mechanical seatback struts?!
  240. Need some help with an '85 Eldorado...
  241. Water on the floor
  242. Climate Control Problem
  243. Keyless entry fuel door
  244. 96 Eldo ETC AC1340 Code
  245. '99 Seville STS on Ice
  246. replacing a cracked side mirror, just the glass...go to dealer or glass company??
  247. water leak
  248. Big Trans Trouble??
  249. Cool 1969 Cadillac Eldorado article!
  250. 92' Eldorado E027 & E030 Codes
