: 2009-2015 Cadillac CTS-V Performance Mods
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14
  1. Lifter failure
  2. Cats or no cats? Hmm...
  3. D3 Springs...Question
  4. Smokey's Tune on my 2012 CTS-V Sedan
  5. Road Course impression
  6. IAT and custom intake pipes
  7. 2013 V-Coupe 600 hp mods:
  8. new plugs
  9. dyno results II
  10. 2013 CTSV Dyno...Only mod is an airaid intake, no tune.
  11. *Whst is the Maximum Safe Rev Limit
  12. AIR RAID or D3 intake
  13. 9 Sec 2013 CTSV coupe
  14. New Motor Time - Thanks to Ed Hutchings
  15. In search of a new intake FORCED AIR. Airaid no results
  16. Looking to buy a tune.. Need some recommendations please..
  17. Nitrous peeps & connoisseurs in here, please
  18. What do you guys think?
  19. Engine Oil & Tranny Fluid
  20. Road course oil level
  21. Airaid CAI
  22. Help for aftermarket wheels
  23. Header help
  24. Hennessey Performance
  25. Dyno results
  26. R compound tires
  27. Wtb: cold intake for 2013 coupe?
  28. Stock pulley tune.....
  29. QTP exhaust cutouts - Sedan placement
  30. Titanium rotors? How do you think?
  31. Corsa cat back exhaust.
  32. muffler delete, any advice/concerns ?
  33. How strong is the factory short block and Transmission?
  34. Ported vs. Larger TB?
  35. brake hoses
  36. Wagner Perfect Stop Semi-Metallic pads
  37. Mods and Warranties
  38. Cheapest way for nice sounding exhaust ?
  39. D3 Chassis Bracing for CTS-V Sedan \ Wagon in stock now
  40. Headers Install Tips or Help
  41. ZR1 Blower
  42. Troubleshooting HELP NEEDED
  43. Will 2007 V Headers fit 2011 V?
  44. Boost not building sometimes
  45. Results from racing last night...
  46. Maximum Performance Mods to Safely Maintain a DD?
  47. I wsnt to get a self Tuner !!!
  48. wagon + american racing headers question
  49. Fresh Red Painted Calipers, Brembo decal, ceramic pads and new tire setup.
  50. Fuel Pump Limitations?
  51. Recommendations/Pictures of Sedans with wider tires???
  52. Intercooler pump flow data
  53. GM Performance parts question
  54. Manual V launch technique
  55. Looking for Performance Shop Advice in NJ
  56. Carbon Brake conversion for CTS V?
  57. Any 355mm rotors weights 2.5kg(5.3lbs)?
  58. Another Oil Catch Can Thread
  59. Mustang 585rwhp...Dynojet??
  60. Is AT V accelerate faster than MT V?
  61. Tune and air temperature
  62. weapon x motor sport
  63. Auto or manual which one you have
  64. Installing heat exchanger need help
  65. Kooks Spring Breakout Header Sale- Free Coating, or Save A LOT - Free Shipping!
  66. Some questions here need advise,thanks.
  67. What AFR are you guys running? holy crap these mods pull
  68. ADM built V does 192.4 at the Texas Mile
  69. Hi new girl needs help 😉
  70. Coupe Exhaust options and prices
  71. Hi from new guy...
  72. Mechanic For Hire
  73. need diagram for bbk's
  74. Will a cat delete and true 3" exhaust to stock mufflers flow close to headers +
  75. GForce Chip
  76. Need to make my final choice on MODS fast.
  77. how do the Corsa sports compare in sound to a stock C63?
  78. CTS-V Weight
  79. A6 coupe put down 620 RWH
  80. Black plastic engine covers, remove or leave in place?
  81. Info on OEM solid BREMBO front rotors and pads
  82. New personal 1/4 mile best
  83. Doing my own mods...need experience based input!
  84. Famoso Test And Tune April 13-14, So Cal.
  85. Will a Water/Methenol Injection system work on my car?
  86. Max boost with stock Cats.
  87. Auto Pride Cocepts / Good Guys
  88. CTS-V Wagon: Corsa Axle Back Sport or Touring?
  89. Starter removal
  90. Need Some Help. Does anyone have a Right Front Caliper laying around? I need just 1.
  91. STOCK ZR1 and Caddy CTSV stock injectors. These are OEM- For Sale
  92. Average RWHP/RWTQ on stock A6 V
  93. Stage 1 + HX needed?
  94. Magnaflow
  95. Opportunity for possible free labor, recommendations on how to use it?
  96. Selling my headers/exhaust, thanks for looking
  97. March Texas Mile 196.2 New CTSV Record!
  98. New personal record: less than 2 weeks stock
  99. cat delete pipes
  100. Used CTS-V Coupe...missing cat converter.
  101. Heel Toe
  102. CTS-V Brake Pad Data
  103. Modded or Stock? That is the question!
  104. muffler delete iside muffler itself pics and video ecellent mod for a coupe enjoy
  105. Will a cam shaft from a ZR1 increase idle in a LSA motor?
  106. 18" track package wheel setup
  107. Anyone with similar mods? trying to get a HP range where I should be?
  108. RX Catch Can Help
  109. Where can I go to get custom designed wheels made w/o braking the bank?
  110. torco?
  111. All about your Snout, Pulley, and Barrings.
  112. Atco visit today
  113. Trinity Tunes
  114. d3 CA Intake
  115. MPG on 600+ rwhp V's....
  116. Anyone heard of engine failure on daily driven V cars putting out @ 680whp ?
  117. FLowmasters - anyone running them?
  118. Difference between LSA and LS9
  119. Corsa VS Borla Axle Back VS SW Chamber & TypeCatback
  120. Terrible sound with the LPE Solid Isolator Coupler. See before and after video
  121. Optima Ultimate Street Car Challenge (Cadillac CTS-V Sedan)
  122. Test
  123. Wait4Me your PM box is full. Was hoping you or another expert can tell me what to do!
  124. Video Added. Had 2.4 pulley pressed on and have a deep whine sound. Please Listen.
  125. Just finished Headers, CAI, and 2.4 Pulley. I have a question on the Whine Sound
  126. What does the OEM wheels weigh? I'm thinking of ordering Forgeline wheels
  127. Some exhaust note vids, Stainless Works headers & QTP cutouts
  128. Slick Advantage?
  129. Airaid before and after Dyno results
  130. S-Shaped Hose Part Number for W4M HX?
  131. 2.5 upper pulley - bearing failure? SC noise video
  132. D3 Cadillac is at it again!
  133. Wheels
  134. Watch Dyno Tune by Shawn Church...headers GLOW!
  135. Stock dyno results - Any more contributors so I can keep this chart active?
  136. No compression #5 cylinder, leaking oil from the rear main seal
  137. No compression #5 cylinder, leaking oil from rear main seal.
  138. Can you get 700whp w/o adding a cam or NOS?
  139. TSW Nurburgring on 305/35/18 Mickey Thompsons
  140. Header question
  141. Cam question
  142. Traction Control question
  143. Increase boost on stock pulley?
  144. Dyno results stock ~VS~ Cat back Magnaflow
  145. Corsa Sport Axle-Back For Sale
  146. Corvette to V -- HPDE's
  147. Cadillac Service Departments and Tuners in the DC Area?
  148. Questions About Modifying the CTS-V Without Voiding the Warranty
  149. Dyno Shootout tonight 08 Mbz E63 AMG ~VS~ 2010 CTS-V Sedan
  150. Newbie in the V world
  151. Hennessey's 1200 HP V
  152. Mods, Tune, and Injector Help.
  153. Are any vendors up for a CAI comparison test?
  154. Air Raid CAI with Dry filter will take best offer. Less then 500 miles
  155. Potential tune on new 13 v- sedan, MT
  156. CTS-V Sedan ready for the TRACK!
  157. Oil Drip
  158. boost goes up, then down, then back up
  159. Nasty whine from installing 2.55 upper pulley help?
  160. SuperSonic Blue coming to CTS V (Silver Frost as well)
  161. what other size can i go with on the rear tire?
  162. Baer Brake Differences?
  163. Ok- I have had my V for 2 months now...
  164. CTS-V needs an advise on performance parts
  165. Transmission tunes? who has them and who is the best?
  166. squeaky front passenger side. need help
  167. V-Coupe red-line
  168. 2012 Black Diamond Coupe - Corsa Sport / Airaid
  169. tune questions
  170. Testimonial: Hennessey stands behind its products
  171. Save $350 and get free shipping with a Power Package from Stainless Works
  172. Question about 26" tall drag radials
  173. Stainless Works Headers + B&B Mufflers
  174. Tax Return Season SPECIALS!
  175. TPMS and Tire Question
  176. Corsa touring exhaust system
  177. Great Track wheel and tire set up has to go! Hankook Ventus R-s3 Thanks for looking!
  178. V2 american racing headers vs stainless works?
  179. Performance shop near St. Augustine or Jax?
  180. Rubbing question with rear tire/rim combination
  181. Rubbing question with rear tire/rom combination
  182. Exhaust system
  183. GF Performance Chip. Has anyone tried it?
  184. Does anyone have 19x11s on their coupe or wider?
  185. Help! First tune problems!
  186. Pulley question
  187. Wait4mePerformance 1.8 Ratio Rockers
  188. coupler problem
  189. Catless exhaust, headers, ported tb and snout, 2.5"
  190. Exciting News - CORSA signs on as a Class Sponsor for the 2013 Cadillac Challenge
  191. Line lock
  192. LSA timing chain tension guide issue
  193. Expectations...
  194. Noob Question on raising redline
  195. Ghost Cam Lope Tune
  196. Strange how sport mode starting in 1st does not help ET?
  197. Diablosport Intune plus cold air intake?
  198. Church
  199. 2012 V Blower skips after Ligenfelter pully upgrade - anyone else have this problem
  200. Looking for D3 STREET PERFORMANCE KIT: STAGE 1 Dyno vs Stock results.
  201. Kooks headers
  202. Labor for Heads and Cam install
  203. Differant wheel size drivability question?????
  204. Air / Fuel Mix
  205. Highest Stock Boost Guage Reading?
  206. How to launch a V
  207. Went to Lingenfelter Nats this summer and jumped on the free dyno just for fun
  208. Pulley brand
  209. What would 7-8k get me?
  210. Anyone running 19" TSW Nurburgring wheels?
  211. Stock air box how many air inlets ?
  212. Manual V's! that are still stock how do you shift to get into the 11's
  213. Winter tires
  214. Airaid Oiled filter vs Dry filtert....
  215. First Track Weekend on New Tires and Brakes: Questions
  216. Loss of power with headers?
  217. Heres what I'm researching for my Vagon
  218. Will 17 in rims fit on the rear tires of v2 coupe?
  219. Diablo sport or hptuners....
  220. Black Out your exhaust with Stainless Works
  221. Think of buying hoosier DR
  222. Best way to log data?
  223. Lingenfelter vs D3
  224. Where can I get 295/35/19 Michelin PSS
  225. 305x35x19?
  226. Exhaust Sale @ MarylandSpeed! (Borla, Corsa, B&B, Kooks, Magnaflow, SW etc) FREE SHP!
  227. Anyone Going to Texas Mile
  228. Offset on 18's help needed
  229. Installed HX on my own....
  230. 650 lpe
  231. Tune
  232. Swap 9.1" ATI for 9.5"
  233. Wanting to run MT 305's on the rear on stock wheels
  234. 1/8 mile track time
  235. 345/30/18's on 18x12's V coupe ... they are on!
  236. Lead me down the right path the first time
  237. Wait4me HX
  238. Corsa Axel Back Sports for 2012 V Sedan
  239. CTS-V L92 Heads/Custom Cam
  240. Valve guide failure
  241. My '13 V makes 711 rwh/ 647 rwt! Thank you 21st Century Muscle Cars!
  242. CAI for California Smog Legal
  243. Wheels and tires for the strip?
  244. Any thoughts?
  245. Eibach springs
  246. Cammed/Bolted Coupe Dyno
  247. Selling 850 Injector Dynamics , 10" lower and ERA intake!!!
  248. Beating Godzilla
  249. Quick Stainless Works exhaust for V wagon review and video
  250. When are larger injectors necessary???
