: 2009-2015 Cadillac CTS-V Performance Mods
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14
  1. D3 Lowering Springs!!!
  2. Stainless Works CTS-V Headers & Exhaust
  3. 2011 cts-v heavily modded, problem with stability control
  4. Looking at used CTSV that is heavily modded
  5. Airaid on 2011 cts v coupe
  6. High performance brake linings
  7. *Shocking: Performance Distributors’ SOS LSA Coil Packs!!
  8. Is there an overview for LSA fuel tuning? Car stumbles after the new 2.55 pulley.
  9. Injectors ID850
  10. Airaid install ground wire fender mount
  11. Rear Tire Size
  12. which cam?? need help
  13. ZL1 lid milling
  14. Airaid install gone awry
  15. Got my Stainless works exhaust installed
  16. Tuner in the northern california area!
  17. Full customize cylinder block and heads
  18. $50 Buck Airaid Intake Rebate Thru Sept
  19. Potential track wheel setup?
  20. Cadzilla Comes to LIFE!
  21. Engiine coolant gets up to 226* before fans comes on!
  22. boost and valve train mod questions
  23. Floatng valves
  24. Making lsa into ls9.
  25. Best Deals on Exhaust @ MarylandSpeed- (Borla, Corsa, B&B, Kooks, Magnaflow, SW etc)
  26. Big Savings on Kooks Headers! Free Ceramic Coating or Save More!
  27. widest tire on a coupe rear wheel
  28. So what do I need to install the ZL1 lid? Got Lid, gasket, and one OEM hose…..
  29. K&N air filter question on new V.
  30. Need some help Re: upper pulley
  31. 180 Degree Headers: Discussion.
  32. DSC going crazy after installing Michelin Pilot SS
  33. Does the stock exhaust fit in the back of the vagon?
  34. Finally doing it... 2.55 pulley and a tune...
  35. V2 Short Shifter Recommendations
  36. E3 plugs review
  37. Creative Steel Short Shifter
  38. Harmonic Damper Bolt
  39. Hennessey HPE 700 Package
  40. Any parts to buy now & install down the road? Scarcity of parts in the near future?
  41. Big boost HP ??
  42. Which Diff Cooler?
  43. Dont want to void my warranty
  44. 7.0L swap overheating
  45. 514 WHP W/ AirRaid, Corsa Cat Back, Lingenfelter 2.55 upper pulley, Auto Transmission
  46. New to the Forum
  47. Cheaper way to Twin your V?
  48. cat back exhaust question
  49. Quick idler question
  50. Spark plugs
  51. stage one pulley upgrade question
  52. Catch Can
  53. Is there a daily driver brake pad that performs as well on the track?
  54. Izzy, Izzy Performance Dyno & Tuning, and Tom Vanvugt, (SOCAL)
  55. Coupe borla exhaust
  56. excessive brake dust?
  57. 160* Thermostat Question
  58. Already have Corsa Sport, looking at...
  59. My Mod List
  60. Gates green belt part # for 2.85 upper, 10.00 lower, 50mm & 100 mm idlers:
  61. CNC ported Throttle Bodies in stock!
  62. Waking up a stock CTS-V
  63. Exhaust Dilemma. Kooks Headers.....
  64. Question about EFI Live AutoCal and W4Me
  65. Lingenfelter CTS-V Pulley Upgrade
  66. Unstable at wide open throttle after 80mph car wobbles side to side
  67. Wagon Exhaust - Corsa vs SW
  68. qtp help
  69. Exhaust too Loud and Backfires after upgrades Need Advice
  70. Exhaust
  71. newbie suspension question
  72. Help Needed- Problem with rear shocks- Need Advice
  73. Great sound after Lingenfelter pulley and CAI kit
  74. how much did you pay for your cutouts install?
  75. D3 Competition Springs Problem
  76. Shifting from 5th to 6th in an A6 and it won't let me at high RPM's
  77. 160 Thermostat
  78. WTT: Corsa Touring for Corsa Sport
  79. Best place to buy qtp cut out
  80. Aero / Underhood temp gains question
  81. CNC Ported throttle body for the CTS-V
  82. best tuner in nyc or surrounding area
  83. Rev Xtreme Chiller aka Killer Chiller questions
  84. Milwaukee/Chicago Area Tuner
  85. Temporary "Service Stabilitrak" Error
  86. Brakes by Cadillac CTS-V2 Body by Holden Pontiac
  87. Found new spot for Catch Can !
  88. STALLING when coasting to a stop on INCLINE
  89. Orlando, FL Shops
  90. D3 Harmonic Balancer & Supercharger Drive Pulley available
  91. BRAKES - Are new rotors required on every brake job?
  92. Lingenfelter 700 - CAR STALLS WHEN STOPPING, BACKFIRES, LOSS OF POWER AT WOT
  93. My 2009 CTS Lo Beams both quit, NO Ballast No Hid No power to the plugs
  94. +57HP,+32TQ w/Airaid and Tune by R.P.M.
  95. Streetslayer twin billet clutch
  96. Well that lasted less than 2 months....
  97. How to reduce blower whine?
  98. Exhaust Sale @ MarylandSpeed! (Borla, Corsa, B&B, Kooks, Magnaflow, SW etc) FREE SHP!
  99. Beat the Heat Kooks Header Sale - Free Ceramic Coating or Save More!!
  100. clutch replacement
  101. Here's an argument for just changing out your "reusable" filter
  102. 305-30-20's?
  103. Seattle Area Tuner/Shop
  104. Trying to find some mounts
  105. cts-v upgrade
  106. Top speed test M6 transmission. Found speedlimmiter
  107. Hennessy V700 Package
  108. Tranny; Does it learn
  109. performance after mods
  110. leased ctsv want to do pully swap but gotta couple of ?
  111. Pulley needed?
  112. What Mod would you do in this situation?
  113. 700WHP on a stock block??????
  114. Newbie questions
  115. Help! Point me in direction of stock exhaust
  116. DFW Dyno Tuning
  117. 109 octane
  118. ZL1 supercharger lid
  119. Anyone with the HeartBeat out there?????
  120. Church Automotive Consulting- Best Tune Experience I've ever had
  121. Questions about tires!!!!
  122. Stability track issue
  123. anyone done this with Corsa Sport Axel back?
  124. Where to start
  125. God Bless the Hennessey (HPE) Lake Forest facility & its personnel.
  126. Fuel Injectors needed?
  127. No rev match on downshift after tune
  128. Finally did some mods. 652 hp. Vid below.
  129. Is a dyno tune worth it.....
  130. Looking to pull the trigger
  131. Exhaust recommendation
  132. Pulley combo..
  133. Vagon gots new pipes
  134. QTP Low Profile Cutouts Now @ MarylandSpeed- Free Shipping!
  135. New to forum, new cts-v, would love some info
  136. Needed: Exhaust Shop in or near Atlanta, GA to install QTP Electric Cut-outs.
  137. What will a higher stall torque converter do for me?
  138. Cadillac CTS V Wagon Exhaust
  139. I did it. I finally got the balls to wrench my first mod. Lowering springs.
  140. HX expansion tank. This version looks nice.
  141. I just bought a 2010 v sedan
  142. Automatic transmission help/advise?
  143. Looking for a tuner near Northern Virginia
  144. More power. 1500 to 2000 dollar
  145. Need help w Upper pulley /lower combo
  146. PLEASE READ! Anyone have issues with Eibach springs?
  147. racingBrake 2 piece failure on track.
  148. Gen-2 Bolt in 9" IRS kit
  149. 3 in exhaust pipes
  150. Engine overheating at the track
  151. Palm beach raceway
  152. Pirella Trofeo R
  153. Kooks Tax Time Sale- Free Coating or Save Big @ MarylandSpeed!
  154. Question about pulleys, tunes
  155. Pulley swap with no sides?
  156. V2 tuning question for autos
  157. Air Intake
  158. 2.5 upper pulley and diablo intune
  159. Airaid Intake
  160. d3 intercooler/heat exchanger and pump upgrade
  161. High flow cat or cat delete?
  162. fast 65" injectors and Upper pulley
  163. Weapon x intake? Any one using one?
  164. Just bought a 2009 CTS-V Sedan
  165. exhaust shooting flames ?
  166. CTS V Tuner - Philadelphia Area
  167. 800-1000 dollar! Need more power.
  168. ? The best tire/rim combo for a square street set-up?
  169. Transmission Issue
  170. Recaro seat question
  171. 2012 CTS-V D3 Upgrades
  172. any upper pulley that only raises boost about 1lb?
  173. DIY Exhaust Options
  174. Clutch question
  175. Little rough idle
  176. need launch help plz
  177. Damn Turbo Buicks:
  178. Wanted Stock intercooler pump
  179. Tracked tires replacement
  180. Upper Pulley Install cost ?
  181. AirRaid Intake
  182. Los Angeles Tuner Shop Needed
  183. Wait4me nav in motion module
  184. 20" wheels that weigh about what factory wheels do?
  185. Is the work im wanting done flawed???????
  186. Flex Fuel Sensor
  187. Wait4Me Tuner - Unlocked?
  188. Air box Screws
  189. Springs
  190. Air/Oil Separator instead of catch can?
  191. Best simple upgrade?
  192. catch can oil ?
  193. Bigger tank for ice???
  194. Dyno results 11 CTS V Coupe with CAI
  195. Kooks headers/Grren Cats/No tune? Anyone have experience with this?
  196. Help with opinions on new exhaust!
  197. Dex cool?
  198. OK... its time. I need traction on a 650whp V.
  199. Airaid cai question
  200. Searching for a Performance shop in Houston tx.
  201. Smoking down my old tires...
  202. mobile app for I-5 phone
  203. Lingenfelter Kit questions
  204. lowering 09V with Eibachs
  205. CTS-V Wagon making a High pitch Howling Noise
  206. 2013 Cadilac CTS-V - Help on Exhaust, and CAI Intake options
  207. My V Coupe before and after Corsa Sport axle back exhaust install
  208. New Personal Best - 11.720 ET / 120.78 MPH - Factory Stock
  209. Airaid Intake Install caused BIG problems...HELP!
  210. New best time
  211. ZL1 exhaust or bust
  212. 2012 CTS-V Coupe Air Intake Upgrade Step 1 - Tuning Required
  213. Cf airaid intake
  214. Good Shop in VA
  215. Camaro dual-mode exhaust?
  216. Tune shops in south Florida help
  217. Stock Cts-V rims TIRE options
  218. Spending about 800-1k on mods
  219. Difference between 09-11 and 12-13 LSA cranckshaft
  220. Square Setup
  221. boost increase
  222. Just got my corsa exhaust, any tips?
  223. Catback loss of HP or tq ?
  224. Pros and cons of adding an LS9 supercharger lid on an LSA
  225. Meth injection
  226. Tire selection help for ny residence.
  227. Catch can install-RX
  228. Appointment to modify my V this week!
  229. Next stage build is coming together
  230. Can you check a car for a tune?
  231. CNC Ported Throttle bodies for the LSA
  232. D3 Supercharger Lid Spacer (In stock!)
  233. Newbie....performance mods? Intake, tuner?
  234. Interference or Non-interference engines?
  235. slicks for 18" wheels
  236. meth injection
  237. I need 80 more hps
  238. Eibachs
  239. big and littles
  240. Just purchased an Airaid CAI
  241. drag radial for street and slicks for track
  242. Square Track Tire set-up with springs?
  243. Has anyone received a smog requirement on their renewal for a 2009 CTS-.?
  244. Gear ratios
  245. Water Meth Injection Opinions wanted.
  246. SMC Dual Catch Can or RX Dual Valve Catch Can - Help me Decide
  247. Sand Bags in my V"
  248. Recommendation for best Catch Can;Do we need two?
  249. Airaid CAI with K&N filter
  250. Stock vs. Airaid intake results at drag track
