- CTS Rear Wheel Hub Install
- Shock Replacement ( Rear ) Do I need to unbolt cradle? or just 3 bolts R and R ?
- Factory Stereo Problem
- Where to buy or rent a GM 6-Cylinder Cam Tool Set?
- any last minute tips before I schedule my 100k+ service?
- Can't Get Codes
- Leaking Roof
- Idle problem
- 2007 3.6L CTS - How do I know if I have the special extendend timing chain warranty?
- Flashing engine light.
- Exhaust Options for Track AND Touring?
- UH OH....transmission?
- 2003 3.2L CTS Oil Leak HELP!
- How do you guys feel about this all in one suspension kit?
- Shaking/Rattling Noise When AC is not on
- mesh grill
- ambient lighting
- Custom cadillac logo car covers - free s&h coupon code
- slight rough idle
- high mount 3rd brake light
- Re Cap Cars n Coffee 5/13/12 Freeport NY
- Bearings and Pads question
- Whining noise from underneath underneath shifter!
- I think I'm going in...!!!
- Fuses for sunroof
- Test Drive - '09 CTS 3.6
- Fog lights
- Battery Drainage
- AMSOIL Spring Special ~ 25% Off
- AT fluid filter
- New mufflers are too loud
- fuel filter
- Fog Light Mod
- 04 cts 3.6 engine,air bag light
- Delayed engagement into reverse
- Alpine Car System
- rim identification help needed
- Are you &'ing kidding me...
- 2007 CTS STOCK Bose Subwoofer looking to buy
- Purchasing a car youve never seen
- P2098- Post Catalyst Fuel Trim System Too Lean; Bank 2
- You know you drive a black car when...
- Tranmission removal proceedure for the 5l40e
- Tires tires tires!!
- New here need help
- What happenes when a motor mount goes bad? How long do they last?
- New here I have a question 2005 cts 3.6l
- I think I'm in it deep.
- trouble codes
- I have reached 100K miles. Buy the T-Belt KIT or just the T-Belt?
- Oops! Screwed The Pooch
- '04 Cadillac CTS CD player (BOSE) replacement
- Free delivery offer for forum members - no minimum purchase
- headliner?
- Part Number for Allen Bolt to Rotor/Hub?
- Connection from my mobile/Pandora to CTS-V 2005 stereo?
- 2007 CTS 2.8 check engine light... engine shakes
- I need a battery!
- need help with trouble codes
- Radio locked
- where i mounted my hid ballast.
- Brake pad question?
- Trunk will not open
- Rear driver side door lock, Grinding noise
- Door Pillar Covers, How I can remove these pieces?
- Personalization issues, DVD Navi unit on 2003 CTS
- Failed cts break in damage pics
- First post w/car pic
- 2005 CTS Start up and engine shut off problems
- Manual passenger seat recliner question
- UPDATE ON 05 CTS enine swap.
- Free shipping for forum members ends midnight 05/08/2012 no minimum purchase required
- Modified 2.8 - Not mine
- Good buy?
- Visor Vanity Lights Don't Turn Off
- HELP My 20 inch rims rub
- Timing Chain Noise :(
- Timing Chain Kit, where to get it?
- what is this engine sensor for? 2003 cts
- First post
- Shocks and struts
- cleaning tape player
- Shocks and struts
- Exhaust rattle
- CRAP. Wrong flipping oil
- US-UK conversions
- horrible rotten egg smell coming from air vents
- Anybody do a cooling system flush?
- Automatic Transmission Lines/Radiator Problem: DIY?
- lowered cts questions
- Cadillac Merchandise - Free S&H Offer For Forum Members
- Proper tite inflation for custom size tires/wheels on CTS
- thank you
- rear differential lsd questions
- 4.75 chevy bolt pattern?
- Replace your '03 rear bezel
- Vynyl stickers
- Misfire
- Volts pushing 14.7
- One problem or many?
- Need help finding the gaskets I need and not purchasing the wrong parts.
- Cadillac CTS 2004 Sport 20 inch rim question.
- 2006 CTS 18" Package & Assembly Photos
- Windshield wipers gone crazy
- C TEK Charger
- 3000k or 8000k
- Differential Noise
- Stock Stereo question
- Starting Up message+Air Conditioning+Recall on Brakes for corrosion
- 2004 CTS 3.6L Hard downshifting, whining noises, loss of power, shifting incorrectly
- questions about replacing ecm
- Noise from drivers door lock actuator
- 2006 cts passenger airbag
- Searched high and low
- My first post.
- Greeting Message
- Sunroof does not open.
- Some problems
- 2.8L/3.6L owners w/ oil consumption or broken timing chains <120,000 miles
- Well done X Rolls-Royce!!
- Staggered wheel fitment on '03
- custom air filter heatshield update
- anyone changed the starter on an 03?
- suspension?
- Theft deterrent, traction control lights on and fuel gauge inoperative
- ambient lighting
- Wierd noise on cold starts
- Wheel Decal eBay Link!!
- Crash with my CTS (Pictures!)
- Spring Changes! (PICS)
- what oil do you use?
- Shops in NJ?
- need oem rim
- Need help with bolt pattern 03 CTS...
- I will be Cadillac's indentured servant
- Borla exhaust leak
- Fog Light
- Forum Member Coupon Code - Free S&H No Minimum Purchase Amount
- water in both passenger doors.
- Bleeding brake fluid
- 2007 cts 3.6 help needed about code p0017
- 05 CTS 3.6L Dilemma - oil consumption
- Cadillac CTS 2003 NO AC
- '06 CTS Water standing in rear floorboard
- Info needed on 03 cts
- screw in tire
- How to remove engine cover?
- LOWER V GRILLE AND RED SPORTS GRILLE FOR SELL!!!!check it out!
- Have we figured out the wheel hop problem?
- First time 2003 cts owner, need info
- Urgent Car Troubles!!!!!!!
- Free s&h for forum members - no minimum purchase required
- Oil Pressure Switch & Belt Tensioner
- Dorman Now Produce's Lower Control Arms
- jonharrison
- How to change headlight bulb on driver side. Easy way Tutorial.
- Need new tires
- Rims
- Throttle Body Sensor on 3.2L
- HELP!! How to use seafoam in 2007 cts 2.8L
- Trying to buy a water pump off ebay, seeing two totally different items.
- Brass Clips - Top Vent Assembly...
- How much for Engine+trans?
- Bose stereo question/ problem
- aiming fog lights ont 06 cts
- Does Your CTS Whine ?
- What wheels are these? Need to get centercaps for them
- 03 Cts Camber kits? Most kits say 04 up? My rear camber off too much with 20s.
- Cylinder misfire help
- '03 Timing Belt
- It's time to change the shock absorbers
- Chrome window door sills
- Drive Shaft Bushing
- Differential Bushing Removal Tool
- Manual Transmision Rebuild/Reconditioning questions
- Daylight fogs only???
- engine replaced
- Help! Engine making bad clicking noise. With Video.
- whinning noise 2006 cts 3.6 liter cadillac
- OEM Stereo for 2003 CTS
- Wierd sound coming from tranmission or driveshaft? Help.
- New Rims & Tinted Lights ... opinions?
- 20" rims need some advice
- Brodit Proclip on RHD CTS (2006)
- power doors
- Keep CTS or get CTS-V?
- power doors
- What's the best chrome mesh grille for $100-200?
- Fog light mod.
- Front End Creaking
- Airbag light came on after filling up gas today, need help with code identification.
- A bit off-topic - Gokarting
- Has anyone tried this?
- Finally
- I changed the alternator but it's still not charging.
- HID headlight case
- Well what do you think it is.............
- 03 cts cd mechanical fail
- Loose part
- Lightbulb removal
- Remote Keyless Entry System Stopped Working on 2003 CTS Sedan
- Burning Oil Smell in Passenger Compartment
- 1st to 2nd gen. steering wheel swap
- 2004 CTS Base with 3.2
- Truck light cover part question
- Theft System/Fuel Pump?
- Front end scraping nose
- Oh its been a while
- Question on replacing 3rd brake light
- When i signal my highbeams always switch on
- Installing aftermarket headlights
- speedo needle size
- doing t-chain what else should I replace?
- Great brake vendor
- How do you guys feel about shade tree mechanics?
- 18" RIMs CTS
- Well now what...
- Throttle Position Sensor or Throttle body?
- Starter Moves in Small Bursts - Won't Start - Changed Battery & Starter - T Belt Good
- Impossible to find CTS Sports Grille's
- Roof antenna swap complete (w/ Pics!!)
- 2006 CTS Auto Trans Kicks on acceleration
- Cruisin at 216+
- New rims 17
- Radio
- Tint front windshield?
- Fuel gauge
- MPGs Plummeting!!!
- Painted the rear panel black (Pictures!)
- antenna on rear window?
- Radio screen display problem! Pic attached (Searched, no luck)
- 03 CTS 3.2 key stuck in ignition, stuck in park, service theft system
- Motorized License Plate Group Buy
- Dash display randomly displays "Traffic Report"
- Replacing Lower Control Arm
- 03 Cadillac CTS cassette CD radio
- Power Steering Cap - Discontinued - 2003 CTS
- 2003 CTS EBCM or?
- XM / Onstar roof antenna UPGRADE!
- Need 3.2 engine
- Open Headers/Exhaust Cut Outs on a 3.6?
- Can anyone tell me what hood modification this is!!
- timing belt broke on highway.
- Replacing Horn With Stock One ?
- Service Manual for 2003 CTS (yes I'm new)
- little purple wire
- sensors.
- Flaking radio paint
- Tire Size question for 17" factory alloys...
