: Cadillac ATS Performance Forum
Pages : 1 [2] 3
  1. Quick review of KPE transmission tune
  2. Installed downpipe and Borla now sounds ricey
  3. What will void my factory warranty?
  4. 2014 ATS 3.6 Performance Hesitation & Intermitent Rough Idle?
  5. Cai.
  6. 11.80 in my 2.0 ATS :)
  7. 400whp 2.0t ats
  8. catch can necessary on 3.6 ats?
  9. Air intake silencer
  10. whats the REAL difference between the KPE VS Diablo tuner
  11. RX Performance
  12. Kpe vs trifecta tune - which would you use?
  13. Opinions on Diablosport for 3.6 awd
  14. Diablosport tuner for 3.6 awd
  15. Nitto NT05 tires?
  16. anyone mount a boost gauge in their ats??
  17. Borla, KPE, or Magnaflow?
  18. DIY? ATS 2.0L Manual: groaning clutch petal
  19. Einbach Performance Anti-Sway bars vs. FE3 Suspension?
  20. Drive-Train performance/quality?
  21. Pfadt/ZZPerformance/D3 Parts?
  22. Performance parts for cobalt on ats
  23. KPE 3.6 Exhaust?
  24. RX Catch Can ATS intake manifold whistle solved!
  25. the RX kit VS the TRS fab kit
  26. 2013 ATS 2.0 T Dyno #'s /Upgrade list
  27. Borla Axle Back 11844
  28. 2015 ats coup cue system!!!
  29. Piston Damage
  30. GM's ATS Performance exhaust upgrade
  31. anyone with the early LTG (270tq) get the spark plug/detonation TSB?
  32. 3.6 LFX catch can
  33. #3 Piston failure
  34. Where to buy catch can?
  35. TRS contact info
  36. How many of you have had 2,3 or 4 blown motors????? 2.0T
  37. took my awd 2.0 to the track.
  38. BC Racing Coilover for ATS
  39. Max boost on pump gas?
  40. clunk on 1-2 shift
  41. Why no catch can from GM?
  42. Got m KPE tune installed.. My first impressions
  43. Pfadt Race Engineering back in business?!
  44. What Are Best Mods To Do To 2.0T Motor
  45. Updated 2.0T tunes from Diablosport
  46. Looking for 2014 ATS body kit
  47. Drove a loaner Caddy SRX 3.6 recently..
  48. DIY Air Intake Tube
  49. 3.6 what have you done to increase power
  50. Is this pfadt kit worth the $
  51. Remote Start Issue
  52. 2.0T power drop off at high rpms
  53. 295 Touque Update For 2014 ATS?
  54. Diablo intune
  55. 3.6L Manual Trans. Conversion? Motor Swaps?
  56. Performance after plug swap
  57. Cadillac OEM 19's
  58. AT Downshifting on it's own
  59. Something doesn't seem right here...
  60. 17" tire options - 255/35?
  61. Does the k&n filter increase noise?
  62. Diablo 3.6 tune 1/4 mile
  63. ZZP performance Silicon Intake Tube
  64. New Official Cadillac "Suspension Modification Kit"
  65. Downpipe for ATS 2.0T... Less then 300.00
  66. FMIC installed
  67. Identifying Aftermarket Calibrations before Warranty Repairs
  68. TRS Intake tube and catless down pipe + 21st Century Tune = :-)
  69. Bov
  70. Best Custom Exhaust - Opinions: Magnaflow vs. KPE
  71. Is it possible to use a supercharger for the camaro v6 on the 3.6 ats?
  72. Custom Exhaust VS Aftermarket; Is there really a difference?
  73. Is it the tires or the horsepower?
  74. Anyone Used CRC Intake Valve Cleaner?
  75. No Headers for the ATS 3.6 LFX motor
  76. 3.6 ATS tunes now available from Diablosport!
  77. Suspension Install Write Up?
  78. HOW TO: Drain the intercooler
  79. Rear Brake Calipers ?
  80. 2013 2.0T - Engine being pulled out
  81. 2.0 Turbo issues with lack of power
  82. 2.0T tuning / track night in FL
  83. Where can I get a Trifecta tune??
  84. Lowered ATS Wheel Alignment spec's
  85. Diablo 3.6 Tune Update / Review......
  86. 2015 ATS Torque Boost
  87. Best Low-Cost Performance Mods
  88. Has Anybody Experienced this with their 2.0t Automatic?
  89. Blown piston (engine) coverage - an extended warranty
  90. Coupe Wheel Fitment
  91. Diablosport trinity 91 tune knock issues. (california)
  92. 3 blown 2.0T motors for me now!!!
  93. just got my car back and....
  94. DiabloMike can you help me
  95. What my car sounded/felt like before it went boom
  96. Intercooler Weep Hole
  97. 3.6 liter tuning
  98. Diablosport Holiday Sale- Save Big on Tuners for a Limited Time- Free Next Day Air!
  99. DIY PCV to Catch Can Line Routing
  100. Diablo Mike
  101. 2.0T Piston Failures - Automatic Trans Only?
  102. Are catch cans working?
  103. 6,984 miles 2 BLOWN ENGINES CADILLAC IS GARBAGE!!!!!!!!!!!!!!
  104. Diablo Intune dead after 1 day. Anyone else?
  105. Lowered 2.0T Sedan
  106. Need Help Re: 2013 ats 2.0 turbo engine replacement by dealer
  107. Replacing Run Flat Tires
  108. 2015 ATS turbo loaner car
  109. 2015 ATS Coupe 2.0 Performance review
  110. Cold air intake-ats turbo
  111. broken sway bar mount bolt
  112. MarylandSpeed Black Friday through Cyber Monday - The Sale of all Sales is Here!
  113. Engine goes again. 2nd time for pistons/engine
  114. 3.6 ATS testers needed for tune development at Diablosport!
  115. Diablosport Intune & Trinity - Free Next Day Air or SAVE BIG!
  116. Tire and wheel swap question..
  117. 2.0T Bad Pistons - Roll Call & Build Dates
  118. Another 2.0t bites the dust. We need a LIST of members who have failures!!
  119. DIY? Magnaflow Exhaust
  120. Where is diagnostic connector on 2015 ATS coupe?
  121. 2.0T Bad pistons epedemic? Rough idle possibly = blown motor?
  122. How much exhaust gas from oil cap is normal? Piston blow-by issue?
  123. 2.0 T oil use
  124. Got a little closer to 11s, ran out of time. :(
  125. Weight Balance Challenge 2.0T RWD 6MT
  126. 2.0 Oil Change
  127. New header
  128. Rattling noise (timing set/Tensioner) possible
  129. Loss of power 2.0T
  130. 2014 ATS 2.0T cracked piston, with pics.
  131. BWoody Performance ATS Rear Sway Bar End Links - 2.0 Revised Design is now Available!
  132. ATS Needs New Pistons...
  133. Catless DP and Cat delete
  134. Took my '14 2.0 Turbo to the Track
  135. Is intake valve coking on the 3.6 really that bad
  136. New Engine
  137. Aaron Pfadt's ATS, suspension/electrical issues
  138. Catch Can Q&A
  139. 14 2.0T Diablo Trinity Tuner
  140. Stock 14 2.0T 1/4 Mile
  141. Will 09+ CTS-V Brembos fit on ATS?
  142. PVC Venting To Atmosphere
  143. Exhaust options?
  144. Diablo Trinity
  145. DIY Turbo Air Tube & Catch Can Install
  146. Installed KPE tune for the 3.6
  147. Save Big on Corsa Exhausts for 2.0L Turbo ATS - Polished or Black Diamond Tips!
  148. Spark plugs? tuned modded what plugs?
  149. Cannot Wait
  150. Iat's
  151. ebc yellow pads
  152. Eibach lowering springs for 2014 3.6 AWD - Proceed with caution!
  153. Beware - Eibach Front Sway bar for 3.6 AWD...It does not fit!
  154. Time for new pistons
  155. Engine detonation example
  156. DIY Down Pipe Install
  157. Took ATS back to track
  158. 3.6 ATS tune interest?
  159. Camber adjustment ?
  160. Updated tune for 2.0? Loaner was better with shifts and much quicker
  161. ZZP packages
  162. Warranty
  163. Eibach Sway Bars
  164. Do we have Electronc Limited Slip Diffs? It sure looks like it!
  165. First time at the track with ATS and Diablo Tune
  166. Share your Diablosport tuner settings
  167. DIY: 2.0T Ecotec LTG Off The Shelf Intake
  168. ATS Bluetooth Phone issues - Radio locks up!
  169. TRIFECTA presents: World's Fastest ATS vs World's Fastest ATS vs World's Fastest ATS
  170. TRIFECTA presents: Cadillac ATS 2.0T LTG EFR Turbocharger Powerkit (TRIFECTA T55)
  171. 2014 ATS 2.0T Exhaust
  172. Rear axle fluid change
  173. Diablo Tune Review
  174. engine ticking
  175. Has anyone lowered a 3.6 yet?
  176. eibach front sway bar installed
  177. 2014ats rough idle and whining noise 2.0t
  178. TRIFECTA presents: Cadillac ATS 2.0T LTG Intake Powerkit (TRIFECTA T30.1)
  179. TRIFECTA presents: Cadillac ATS 2.0 LTG Resonated Exhaust Downpipe (T35.1)
  180. E85 Tuning now available for 2.0T ATS and 3.6L ATS from IPF Tuning
  181. 2.0t?? go out and look at your exhaust
  182. 13-15 ATS/CTS 2.0T now supported by inTune and Trinity!
  183. Performance Torque Converter for 3.6?
  184. Magnaflow 3.6 Cat Back Exhaust System
  185. 3.6 auto stock trans file hp tuner?
  186. 87 Octane For Monotonous Highway Driving
  187. stock 2.0t max boost psi
  188. How long before your first brake job and tire change?
  189. racing brake pads and fluid
  190. 17" wheels on 3.6 premium RWD (has MRC)
  191. Need HpTuner Help
  192. throttle body spacer
  193. Finally..... ZZP is coming though.
  194. Down pipe vs Cleaned out converter.
  195. DIY Spark Plug R & R
  196. Chuggin engine and Putrid Smell
  197. Just got a 5 gal. can of 100 octane .
  198. Intake almost finished
  199. Slotted Rotors
  200. Turbo Blankets
  201. Hose on intake?
  202. Dumb Hypothetical Thread; Open At Your Own Risk
  203. Seriously considering a catch can now....
  204. PFADT P35 package - dealer issue?
  205. Awd ats staggered
  206. Aftermarket Exhaust experiences
  207. HELP: how remove spring in headlight stalk to prevent drl/autolamp mode
  208. The beast has blown
  209. exhaust leak ???
  210. what does this do?
  211. longer brake pedal travel after corners
  212. Idle Relearn Issue
  213. 3.6 ATS Intake Upgrade Complete
  214. Torque Gain on 2015 ATS and ATS 2014
  215. Anyone with trs intake/ can question
  216. ATS 3.6 Auto first 1/4 mile track night
  217. Sport Pedal Install
  218. E85 idle issue
  219. I'm pissed 138 mph
  220. Shifts
  221. Performance parts crossover ATS to CTS ??
  222. AWD Power Distribution?
  223. Just had my car Dyno'd
  224. instilling eibach sway bars
  225. '09-14 CTS-V rims on ATS?
  226. 2013 ATS 3.6 Exhaust video / sound
  227. 2.0 t 5qts oil /2.0 t awd 6 qts. ?
  228. Oil for track use
  229. Spraying the intercooler ??
  230. Squeak after eibach?
  231. 12V key-on power source in engine bay?
  232. ATS Performance Brakes
  233. Rear Sway Bar Link Install
  234. Cadillac ATS 2.0T high Negative Fuel Trims at idle until brake pressed PLEASE HELP!!
  235. Burnouts/ traction control
  236. HUGE Discounts on Magnaflow Catback Exhausts for ATS!
  237. HELP!! 2.0T RWD auto really down on power, need input
  238. My TRS106 Experience
  239. TRIFECTA presents: Cadillac ATS 3.6 LFX Supercharger Powerkit (TRIFECTA T50)
  240. VT Tuning E85 Tune - Review
  241. Do I need a Tune with Pfadt parts? Is this a good price?
  242. 2.0T 6MT Sport Mode question
  243. turbo timers ?
  244. Last but not least, ATS recall.....
  245. 21st Century Muscle Car Tune on my 2014 ATS 2.0t
  246. Tune ats turbo
  247. Opensource Software
  248. Nitrous 2013 ATS 3.6
  249. Diablosport 2.0T ATS tune development
  250. Best tire size for 19 x 8.5 wheels
