: 2004-2007 Cadillac CTS-V Performance Mods
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Maggie owners
  2. Front shock thuds and thunks - suggestions welcomed
  3. Strut brace mod after Maggie?
  4. Installed KWs on the V today w/ pics
  5. Ram Clutches Available !
  6. Best clutch for a daily driver/roll-on racer?
  7. When is it Too Late for Forced Induction?
  8. Performance Chips
  9. Rattle after clutch/header install
  10. 04 CTS-V Stage 2 T56 buildup
  11. Cadillac CTS: How do you set the mile odometer to read regularly"
  12. Stock vs Lightweight Flywheel
  13. Gforce axles - How it is made
  14. Thanksgiving Special !
  15. Help Prioritizing Mods
  16. B&m short throw shifter problem, please help
  17. Anyone run these? Eagle F1 Asymmetric
  18. Request for my Maggie guys.
  19. Our new driveshafts are now ready
  20. Links to gutted mufflers sound clips...
  21. UUC wow, what bad customer service....
  22. Twin Turbos Take 2
  23. Check engine light
  24. *Finally installed and tuned to reach the 400 mark*
  25. Oil Catch Can Installed
  26. Katech Shifter Issues
  27. 402 LS2 stroker or 418 LS3 stroker?
  28. Creative Steel motor and transmission mount installed
  29. Drove an LS6 w/ Maggie today...
  30. FS Custom fuel rail FAST 102 for CTS V
  31. Rubbing front tires with H&R springs...
  32. Wheel hop Goodies
  33. quick clutch install tech question
  34. Buy everything????
  35. new ls1 longblock installed
  36. Not sure where to go from here
  37. AP steel braided brake lines now available for our V's
  38. Decided to tune my relatively stock CTS-V
  39. Specter Werkes CTS V Cradle bushings, 04-05 Only back in stock
  40. Naked LS6! Hot Pics Inside....
  41. Ls3 iron long block for boost
  42. used magnuson 112
  43. belt tensioner
  44. Gasket inside Maggie coming off?
  45. Magnuson Intake Relocate to Fender Well *Pics* *Data*
  46. Replacing the magnavolt with kenne bell boost a pump
  47. HoustonV
  48. e-cutouts.... will these fit?????
  49. Getting the MP112, what else?
  50. Cam/head work/etc parts/services list, what am I missing? Any Suggestions?
  51. stock rib LS-2 harmonic balancer pulley
  52. 04 CTS-V LS6 with Kooks Longtubes 387 SAE RWHP!
  53. Car cuts out - time for upgrades
  54. Sounds like driveshaft replacement time.....
  55. B&B headers back and tune
  56. Picked up a new set of FG2s
  57. Nice License Plate Frame - Very Good Company
  58. Coilovers: KW Variant 3 vs Moben
  59. Manifold, Billet Fuel Rails, Catch Can and Valve Cover Install- Need Help
  60. LS6 Horsepower w/o Headers, Maggies & Such
  61. What a rear end!!
  62. Kooks Install, need some advice
  63. Pisnuoff modified shifter + CS trans mount, 2nd gear hitting driveshaft ???
  64. Lifters Question
  65. Flex Disc manufacture ? ? ?
  66. Shifter choices
  67. Mods for 04V w/80K
  68. Wider tires.....would it cause stabillity Trac to kick on
  69. Texas Mile!
  70. Have a few full B&B catback kits still in stock if anyone wants a deal.
  71. Will be testing a new two piece drive shaft for my 2005 v anyone interested in gb
  72. intake choices...
  73. Right front strut leaking when fully extended? (on a lift)
  74. DSS drive shaft ?
  75. Cs-v owner new to the forum (assistance needed)
  76. Finsihed Pic of our 2004 CTSV Black Widow TVS2300 Package
  77. New Suspension Mods - best way to combat newly aquired understeer?
  78. GForce Performance Chip, any comments?
  79. Racing Brake 2-piece rear brake rotors
  80. Had enough of the monster - from monster to twin disk clutch upgrade
  81. Best still under warranty ls6 mods
  82. Lingenfelter oil cooler adapter kit
  83. Creative Steel Diff Bushing BRAND NEW BLACK !
  84. So I gutted the stock mufflers
  85. Can't wait till tomorrow!
  86. The definitive h&r / mm spacer lowering thread
  87. New Lower Price DSS Race Axles $1,100 Shipped
  88. Magnuson MP122 *Videos*
  89. Rocker arm upgrade - Is there any power to be had over stock?
  90. My experience with motor mounts and transmission mounts
  91. What are the stock '05 dyno numbers?
  92. LS2 vs LS6 T56 trans
  93. Torquing of front chassis bolts
  94. Cam'd out my Vee (wooohoo!)
  95. Maggie back on
  96. Front Caliper V2 to V1
  97. Probably Swapping out 112 for tvs, who wants the 112?
  98. Maggie and Header install
  99. Magnuson MP122 Installed on my 04' LS6
  100. End all thread on Clutch pedal sticking issues
  101. Inline Fuel Pump
  102. Where to get 8rib 2.7 maggie pulley?
  103. Replacing Transmission UNDER WARRANTY! :-)
  104. MAP and his new bushing kit????
  105. Looking to borrow some wheels in NJ/NY area
  106. Procharger or Supercharger?
  107. Weight Reduction Checklist
  108. meet and greet
  109. Gen 4 Differential
  110. Pacesetter Headers??
  111. Maggie problem
  112. Cam Suggestions?
  113. FAST LSXr 102 with 102 TB PICS.....it works!
  114. cutout questoins
  115. Lovin' my Monster Stg2/lwfw combo :)
  116. Maggie LS6 with 90mm TB Dyno
  117. Performance Shops
  118. More tire questions
  119. Charging System, looking for the F - terminal
  120. Lowering done with Mightymouse / H&R
  121. Re-tune after CAI?
  122. First trip to the dragstrip with the V last night
  123. Where to find Maggie intake port gasket(s)?
  124. Real dyno numbers before and after muffler delete!!
  125. Supercharger Question
  126. Wire schemetics for 05 and 06 Comtrol modules
  127. Headers Question
  128. LSA engine
  129. Balancer install - need tips and tricks
  130. Boost dropping
  131. SNL Tune - now making funny whining noise...
  132. 2005 CTS-V dyno vid
  133. NGK TR6 - What gap should I be running?
  134. Alignment Specs? What are people using for track and Auto-x days?
  135. Any good deals on injectors?
  136. Looking For Subframe connectors for '04
  137. Brake bleeding issue
  138. Lets see your lowered CTS-V
  139. Gto TVS 1900 on an ls2 CTS-V?
  140. Best place to get QA1's, and any tips/tricks for install?
  141. Tire Size Form
  142. DIY Intake Measurements?
  143. Had my local shop modify the GM Performance exhaust *pics*
  144. Speed Inc?
  145. Corsa question on a 05 newly installed
  146. Anyone swap Corsa resonators with an x-pipe????
  147. First Autocross in the V (plenty of vids)
  148. V-series logo apparel, accessories & custom floor mats
  149. A long road never taken
  150. Front mount cold air intake, anyone ever explore the option
  151. H&R springs, trim front bumpstops?
  152. Good shops in So Cal (LA/Orange County)
  153. Muffler Delete Soundclips - Before and After
  154. New Mods for 100K miles.
  155. I need a stock 04-07 exhaust.
  156. True Rear Coilovers???
  157. Anyone have a 2.9 or 3.0 pulley
  158. Procharging a V
  159. PISNUOFF modified shifter install - any further instructions before I get at it?
  160. 10AN Oil Cooler set up
  161. Need a shift knob ASAP! Can you help?
  162. reputable shops in midwest
  163. another 06 dyno
  164. QA1 pitching problem solved
  165. car vibrate?
  166. What size tires CAN i run? (track wheels/tires only)
  167. Cam gain on Maggied V
  168. Final results on our ctsv tvs2300!!!
  169. Anyone in Northern NJ have a TTP tune with just CAI and exhaust?
  170. Went to the track for baseline #'s....
  171. 2005 Cadillac Cts-v w Side Pipes
  172. Fuel pressure dropping
  173. twp piece rotors
  174. Maggie V mod advise
  175. 2004 w/Maggie Dyno Tune
  176. 06 ctsv dyno
  177. Any good writeups or tips and tricks for SS brake line install?
  178. K&N FIPK vs stock
  179. Trubendz highflow midpipe finally ready to order
  180. Exedy twin disk install and review
  181. Cheapest way... single mass flywheel
  182. Anyone use the BMRfabs pinion support ?
  183. Best "Bang-for-your-Buck" Road Course Mods?
  184. Adding Headers to my cts-v o_O
  185. Broke a valve spring *PICS*
  186. Replacement Drive shaft for a 2005 V
  187. Timing Chain Replacement need some thoughts
  188. J-hooked rotors and racing brake et500 pads
  189. Whats your thought? 224/228 114+2
  190. Cat-Less Kooks 1 7/8 LT's on their way!!!
  191. Borla XR-1 race mufflers
  192. LS7 Clutch configuration switch question
  193. LS6 Cam install notes and results
  194. Inexpensive set of fg2's
  195. borla
  196. Trans fluid change
  197. Spring Cutting - A few Questions
  198. Maggie making noise
  199. I need your advice
  200. Is the GM Factory sports exhaust..
  201. QA1 shocks with stock springs
  202. Kooks Headers : Deal of The Day - FREE SHIPPING
  203. Parts for 2004 - 2007 CTS-V
  204. Just ordered a set of H&R springs!
  205. Maggie question: 2.7 without grinding?
  206. Falken RT-615K
  207. Pacesetter headers
  208. got my kooks with highflow cats installed
  209. What do these mods do for my cts-v
  210. Just got the V back from tuning
  211. Kooks install question
  212. whos running a procharger?
  213. Mysterious Brake fluid leak
  214. Which pads to get
  215. Rear Diff Movement...
  216. EdgeRacing is gone! Cheap tires in S. Fla?
  217. installed eibach sways
  218. Yet another Kooks headers question
  219. Just installed Maggie with Kooks and....
  220. Anyone running an ATI SuperDamper?
  221. Tuning gurus....have a question
  222. Billy Boat Performance Exhaust 2004 - 2007 CTS-V Available
  223. GFORCE ENGINEERING IRS FAB 9 for the CTS-V
  224. Custom Nitrous Vd around DFW
  225. need advise on intake manifold
  226. Have a chance to get a deal on a HPE S-CAM
  227. BMR Anti Wheel Hop Kit
  228. LS7 clutch kit - driving impressions / review
  229. Engine parameters made simple
  230. Headers or exhaust systems
  231. ZR1 twin disk, has anyone thought about throwing one of these in ?
  232. WTB Stock CTS-V Exhaust
  233. Anyone just weld in some high flow cats?
  234. Rocker Arm Install problem
  235. axle/cradle bushing install fail
  236. V-Series Logo merchandise & Custom Floor Mats
  237. Will Edelbrock shorty headers for the Pontiac GTO 6.0 fit our CTS-V's?
  238. Fuel pump opinions
  239. Got the 90mm TB on
  240. some questions for the guys who have done headers
  241. Installed One Piece DS
  242. Off the Blocks
  243. Cheapest way to 200mph.
  244. Vendor with best price on Ground Control kit
  245. Tuner options?
  246. Crowned Customs:
  247. What do think of this driveshaft option?
  248. getrag break-in procedures
  249. Flowmaster Super 44's question
  250. My Oil Temp Gauge Doesn't Work...Ideas?
