: 2004-2007 Cadillac CTS-V Performance Mods
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Mail-Order Tuner - Frost versus StealthV - Your Opinions?
  2. 92mm TB vs. ported LS6 TB
  3. Does anyone use the BMR suspension upgrades?
  4. 3M Windo-Weld Urethane for mounts???
  5. Rear Diff Bushing Install?
  6. Help Buying a Cold Air Intake
  7. Help the Newbie - Step 2
  8. 6L80/90E Swap???
  9. Lowering spring install question(s) (beyond FAQ's instructions)
  10. Corsa Vs. Borla/Flowmaster
  11. Engine Oil Cooler, External or in the radiator?
  12. Lets just say "I think I spent too much on gauges"
  13. Help the Newbie - 2006 CTS-V with a $2-5k Budget
  14. Motor Mount Bracket Stud Replacement
  15. Pacesetter header connection ?
  16. Stainless Works vs Kooks Headers
  17. Diagnosed a misfire to find my lifters were the issue
  18. Suspension
  19. QA1 Install - Thoughts, Comments and Questions
  20. Maggie install begins, intercooler mounts and fuel pump?
  21. Calling all "self" tuners.....Which is the tuning software of choice?
  22. Mystery wire Please help!!!
  23. SoCal V's - Cars & Coffee - Irvine CA - Saturday - 04-09-11
  24. I've searched, just want to double check before I order...LS7 Clutch Discussion
  25. Any comments on the cam I'm thinking of getting?
  26. CREATIVE STEEL: DIFF BLOCK, Extra Support For The Rear Differential Bushing
  27. CREATIVE STEEL: CTS-V 8.8 Rear Diff Swap BOLT IN
  28. performance fuel pump question
  29. ST Brace for Maggie
  30. Brake Lines
  31. Help needed on axle install
  32. FAST fuel rails without the 102 intake?
  33. Eforce Delivered!!!
  34. specs on DS coupler
  35. Short Shifter backlash noises - any fixes?
  36. CV Joints
  37. header diameter question
  38. looking for a performance shop in southern cali..
  39. Magnuson MP 122HH Dyno Results Inside
  40. Ported LS6 TB . . Worth it?
  41. What are OEM Shock options
  42. Seriously considering converting to e85 fuel
  43. 80lb. injector for LS2????
  44. Variable effort steering actuator?
  45. I would love to gget my hands on these BAD!!!
  46. OBX Headers Leaking
  47. Control arm bushing measurements
  48. camshaft and maggie?
  49. Heads Up: Gforce Axle Boot Issue
  50. Has anyone swapped the 3.91 gears from the SRX?
  51. Spectre CAI
  52. Do these dyno numbers seem right?
  53. Maggie Install advice....
  54. Maggied V - Here's the Rub...
  55. Samco Water hoses
  56. Creative Steel Diff bushing warrenty!
  57. Broke Stock Airbox Inlet Need CAI Advice
  58. 02 Extensions
  59. Kooks Install w/ Dyno
  60. Check your intake manifold bolts!
  61. V2 brakes for the v1
  62. B&B Headers & Exhaust, Wait4Me Dyno Tune
  63. Install time on harmonic balancer question
  64. Magnuson loose fuel injectors question Please help
  65. Supercharger? Advice Please
  66. First time Cadillac owner
  67. Exhuast nightmares
  68. Test Car Needed for ProFab Muscle Car Air Intake System
  69. OBX electric fuel pump
  70. Rear Rotor Nightmare
  71. ordered the Maggie today...
  72. Joining the maggied V's in Minnesota
  73. Pacesetter? OBX? Kooks?
  74. Another Eforce teaser thread!!
  75. CTS V Z06 Clutch
  76. BMR Brace for LS2?
  77. Pulled the trigger on a Maggie
  78. Am I nuts... why hasn't anyone bought this
  79. 2004 CTS-V w/Random Tech highflow cats, x pipe and muffler delete
  80. looking to cam my v in northern new england anyone know about slowhawk and there work
  81. Creative steel driveshaft coupler
  82. Spark plug reading question
  83. Finished Motor Mount Swap
  84. ET800 pads - thumbs up
  85. Dump your spring rate and suspension advice here
  86. Changing my pads and rotors on my 2004 v
  87. What's your G-meter say?
  88. Went with Whipple
  89. Lingenfelter conversion part 2
  90. Maggie owners: cover for the drive shaft
  91. Lookie what the FedEx guy dropped off today!! (Brake content inside)
  92. Lowering Spacers???
  93. net 500whp?
  94. LS6, blower, compression question
  95. Brake fluid weep from bleeder after track day?
  96. Is a throtle bottle upgrade worth it 2005 CTSV
  97. 90mm Throttle Body on LS6 - New Style LS3/LS7 TBs No Good
  98. For those road course guys living in warm climate areas... switch to 10w30?
  99. Diff upgrades?
  100. Advice on Lingenfelter conversion please
  101. Rear Diff Solution - Is there one? HELP Please.
  102. San Francisco/Bay Area coilovers?
  103. LS6 and supercharger bad idea? Compression too high?
  104. Custom Cold Air Intake, 102mm MAF, 90mm TPIS TB, FAST 92mm and 42lb SVO green tops
  105. Blower, cam size, and California smog
  106. What did you pay for a clutch swap?
  107. LS6 Internally Balanced or Externally Balanced?
  108. Yet Another Lowering Question! ( I havent been around in awhile)
  109. Eliminating the factory cats.
  110. DSS Axles : Free Shipping !
  111. Plugs, Wires, Oil, and Oil Filter - Which ones...
  112. Eibach springs/ MM spacers Install HELP!
  113. Flowmaster Mufflers new contest - "Show us your flows"
  114. Service manual link
  115. LS6 mods please help
  116. Eforce Teaser
  117. Installed Pacesetter Headers
  118. ls6 mods
  119. D3's new V1 motor mounts
  120. Has anyone had thie Maggie MP112 ported?
  121. MSD CTS-V starter question and CoolingMist Methanol setup question
  122. CAGS elliminator choices
  123. stereo problem
  124. Any recent Maggie installs using SCT Tuner?
  125. exhaust problems
  126. 03 Vette Magnacharger fit CTS-V?
  127. Dyno!
  128. Valve cover removal.
  129. Which exhaust and Headers?
  130. OBX Headers to Corsa exhaust
  131. KWs my turn at last.
  132. Maggie vs Procharger vs Elderbeock
  133. drive shaft fell apart...
  134. Will the Eaton M122 from a Cobra fit a CTS-V Maggie?
  135. VIDEO: Cam'd CTS-V Tuned and Ready to Rock and Roll...
  136. Install instructions for Z06 end links & MM spacers?
  137. Tune up, spark plugs and wire
  138. Budget Camshaft build???
  139. What Mod Next? Opinions wanted!!
  140. No probs with winter so far!
  141. Any ideas on wtf this exhaust is all about?
  142. Cats or No Cats?
  143. V plug wire that clear headers?
  144. An interesting header read I found worth sharing...
  145. Anyone spun a main bearing on their LS2?
  146. What longtubes will bolt up to the stock exhaust (or replacement)?
  147. Exhaust setup options?
  148. Omega Thermistor part# 44005
  149. harmonic pully balancer for the 6.0
  150. *MSD Red Coil Packs
  151. Mounts
  152. obd gauge plugin
  153. First Ever Penske 7500 Double Adjustable true coilover for cts v
  154. Good Tuners?
  155. Cost for new springs/shocks??
  156. Is There a True Hop Fix Yet?
  157. LS7 clutch remote bleeder
  158. V2 rotor/caliper retrofit for V1 cars
  159. LS7 - Clutch/Flywheel install
  160. How touchy are the v's tunes.
  161. Well what-do-ya-know, 2.6" pully w/out grinding
  162. TR6060 Transmission Swap
  163. anyone wanna sell their supercharger???
  164. Recommendations for a Performance Shop Near Indy?
  165. anybody gotten resonator delete 04 cts-v?
  166. Wrenches needed for Stainless steel brake line install
  167. Help with maggie pulley swap
  168. Good local shop SoCal
  169. Camshaft position sensor, can't clear code.
  170. Transmission Stuck in Reverse
  171. Cheap K&N Intake on Ebay...ending soon!
  172. Having trouble removing engine from transmission.
  173. Are all o2 sensors born equal
  174. What bushing is this?
  175. Blew out an 06 diff, how many on here have done that? Best wheel hop fix??
  176. What happened to the member who had the Edelbrock E-Force installed?
  177. Who has their 2004 V at RDP Motorsports?
  178. Quick maggie install question
  179. Rear trailing arm bushings (for the knuckle) - anyone have their old stock bushings?
  180. Royal purple synchromesh in our T56 M12(little research)
  181. Royal purple synchromesh in our T56 M12(little research)
  182. B&B Headers
  183. 6.0 iron blck question??
  184. 07 Intake for CA?
  185. LS7 clutch+FW - mistake? EWILL3RD need your input!
  186. cts v exhaust
  187. Water - Methanol Kits Available
  188. D3 Cadillac offers KW V.3 Coilovers for 1st Gen CTS-V
  189. For those with muffler delete...
  190. Headers, High-flow Cats and Factory / Stock Exhaust Catback Drone
  191. Anyone have pics of a Black V with gunmetal wheels?
  192. underdrive pulley????? not sure what to do
  193. Clutch Suggestions
  194. headers or exhaust first?
  195. Gforce 9" IRS in car vids
  196. E-CutOuts before or after resonator?
  197. what else needed w/ header install?
  198. Installed my OBX Headers today > WOW!!
  199. Head work, cam, tune, dyno sheet and neon underbody light kit installed with pics!
  200. SLP Parts
  201. Snapped off MAP sensor.....&$#@%!!!!
  202. CTS-V Keyless Entry Dead; not a fuse apparently
  203. Trouble w/ CAGS install Part WIR-205 from TPI Parts; FBody Performance seller on Ebay
  204. Mystery Mods Revealed
  205. Stock clutch - Installed height
  206. noob here. are V shocks interchable with the standard cts?
  207. Dual fuel pumps
  208. Finally installed the QA1's...
  209. Cruising AFR and Magie gas mileage
  210. I need lowering spring spacers...p p p please
  211. what type of CAI for a 04 CTS-V
  212. Rps twin disc
  213. LS6 CTS-V: Bigger throttle body? Also dyno results...
  214. Locate the IAT wires from the MAF sensor
  215. edelbrocks e force supercharger for the ls2
  216. Cross drilled rotors Or not.
  217. what to do to an 04 CTS-V
  218. Shifter/Shifting Issues!
  219. DSS Axles : Christmas Special !
  220. Christmas Special : D3 Products !
  221. Building an LS3 Stroker.
  222. Front @ Rear upper and lower control arm bushings
  223. 05 cts-v tuning problems please help!
  224. need 20" drag radial asap!
  225. Cam Install Questions
  226. Tremec Transmission Freshened @ 172K
  227. R&R CTS-V engine cooling fans....
  228. keep busting rocker arms
  229. How to R&R the CTS-V PCM Module
  230. Drive Line Upgrades.. Motor & Trans Mounts, Rear Diff Bushing & Shafts & More..
  231. Flywheel
  232. Gforce Anti Wheel-Hop Axles
  233. wtb stock motor mounts
  234. New headers? OBX, Cheap Stainless?
  235. short shifter advice....I know
  236. Project 05 CTS-V Rebuild....Maggie LS7 clutch Kooks plus more....
  237. LS6 rev limit - bottom end?
  238. Mod Hell 1 year later and the dreaded "Check Engine" light
  239. Katech LS9 Clutch - First Impression
  240. Shifter, tires, axle and other mods for daily driver I've done
  241. Mini Tubs Coming Soon
  242. Shot in the dark: Magnaflow Question
  243. Cheapest place to buy LS6 Magnacharger
  244. considering FAST intake, what do i need to know?
  245. Maggie owners
  246. Front shock thuds and thunks - suggestions welcomed
  247. Strut brace mod after Maggie?
  248. Installed KWs on the V today w/ pics
  249. Ram Clutches Available !
  250. Best clutch for a daily driver/roll-on racer?
