: 2004-2007 Cadillac CTS-V Performance Mods
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Milling Patriot Heads
  2. What should I do at the same time I do my clutch?
  3. Iffy diff
  4. Driveshaft choice with gforce 9"
  5. uuc diff bushing no longer available :(
  6. Rear hub replacement
  7. More sound out of stock intake?
  8. Diff bushing removal tool question - How big is the cut out to Clear the Diff housing
  9. exhaust ideas
  10. Diff Oil
  11. 30 WHP with Intake?
  12. Noodle trailing arms ordering thread. Y'all with rubbin' wheelz git in here!
  13. MP112 Cam - is this good/bad/ugly??
  14. I sure would like to start my build !!!
  15. question on motor build...
  16. Loose Shift knob after UUC shifter install
  17. check out our new Driveshafts
  18. LS6 stroker build... Component suggestions?
  19. Quick advice needed - engine refresh
  20. LS7 Clutch Kit Purchase
  21. 410hp/369tq with head/cam package. sound right?
  22. Is anyone upgrading their brakes or going to a BBK?
  23. spped shops n austin?
  24. Looking for advise on next upgrade
  25. Finally completed LS7 clutch install... dual mass flywheel failure.
  26. Best cam for cts v
  27. Ordering Tires- ENNY, MEENY, MINY, MOE
  28. Midpipes??
  29. Looking For Tuner Near Chicago
  30. Heads & Cam done = 455 RWHP on Mustang Dyno
  31. Coilover purchase...
  32. Rear end goes KABOOM!!!
  33. Deatschwerks fuel pump info
  34. kinetic energy recovery
  35. TVS2300 upgrade - read this if you're considering it
  36. Avoid the PA50-VETTE like the plague!
  37. Midwest IRS Shootout May 5th
  38. spark plug wires
  39. Where do I find / buy Magnaflow high flow cats for my V1
  40. Liquid-intercooled procharger?
  41. New Tires for Spring
  42. E-brake Relocated to Console - Anyone do this?
  43. I may be the first person to Spend money to make my V Quieter...
  44. Headers installed steering right has slight hiccup
  45. Headers Question
  46. Clutch Install Cost
  47. intake question
  48. Porting stock heads
  49. QA-1 on stock springs picture request.
  50. Dhm Low Pro Cutouts installed
  51. need help! maggie died
  52. shifter bushings
  53. Maggie install question...coolant for the intercooler
  54. Exhaust Decisions
  55. I need some HELP with a rear end issue....
  56. a bigger tire on a stock wheel?
  57. Tri State area cam install+tune
  58. BMR Pinion Support Brace Issues
  59. Video !! First start up after head cam swap
  60. 5 lug swap for the V?
  61. HEADERS: OBX or PACESETTER?
  62. Broke a valve spring
  63. Preseason Kooks Header Sale- Free Coating or Save a Bunch!
  64. Free Install if you book in January
  65. WTK: I just bought my first CTS-V (2004) with 46.0000 miles on it. I am
  66. Couple videos after maggie install
  67. Ebay MP112 - Sketchy?
  68. muffler delete..
  69. need tuning help on 2006 v
  70. LS-9X clutch, difficulty shifting while not moving
  71. What is the brake kit on this T2 car?
  72. Any good deals on clutches?
  73. Broke bolt inside head! h/c guys ?
  74. cheaper short throw shifter
  75. Mod itch... headers
  76. Selling my V
  77. Suspension motion ratios
  78. What size is the bore on a stock clutch master?
  79. volant cold air intake
  80. So my diff is still making a rubbing noise on turns after fluid change
  81. LS7 or Katech ZR1
  82. new clutch in the 04
  83. Noise from the Tranny \ Competition Mode "gone"
  84. Fuel system questions
  85. Crank Pulley Failure? Help!
  86. head/cam installation help
  87. Pulling Motor/Tranny/Diff from bottom of CTS-V
  88. six lug rims??? and cheap power adders???
  89. anyone know where to get straight pipes no cats?
  90. 2 sets of Team Dynamics wheels
  91. Tuning / Clutch / Rear End Help
  92. Ls7 install with katech spacer ?
  93. Where do the creative steel shifter bushings go?
  94. Get 10% off and Free Shipping on Gforce Engineering products now till Jan 2nd
  95. New stock springs or the entire strut?
  96. Where to get poly subframe bushings
  97. LS-7 Clutch install concern/ question...
  98. Trunion upgrade
  99. BMR TA and Toe Rod install questions
  100. Can't powershift at high RPM, clutch or trans????
  101. Racetronix fuel harness install question
  102. Ctsv grill
  103. Sparks from belt assembly???
  104. maggie help plz
  105. Solid rear diff bushing
  106. Well, i couldnt wait to cam it.....
  107. What can be done with $5K
  108. Wortec 6 Piston Caliper
  109. Fuel Pump / MSD Boost a pump troubleshoot
  110. LC855 - New Wheels Checklist?
  111. Anybody interested in nitrous?
  112. Shifter bushings question
  113. Lingenfelter package with no badges?
  114. The Build...
  115. Wideband necessary w/ cam & headers?
  116. Cam/Heads or Exhaust
  117. CTS-V vs Z06 cams on the LS6
  118. Ugh!! I've searched and searched. Any one know who makes this Salve Cylinder
  119. 10% Off Stainless Works Holiday Sale
  120. Retiring the V from Autocros
  121. Bad lifter ?
  122. The MarylandSpeed Black Friday/Holiday Sale is Here!
  123. First time ever on a dyno
  124. Camber adjustment for KW equipped car?
  125. UMI Performance Mount Review
  126. LS6 to LSX 454 conversion questions.
  127. She lives!
  128. Project "VANQUISH" Widebody kit for CTS-V
  129. Wrong TPMS?
  130. just bought kooks headers :D
  131. Mod bug got me. Help me spend money wisely
  132. Sad day....Lost my motor in the V. Options?
  133. Question about Torque Management and our weird gas pedal
  134. Ground Control - How do you get the sleeve off of the shock body?
  135. Motor Mounts oops!
  136. 05 ctsv corsa exhaust question
  137. G Force Single axle upgrade 06-07 impressions
  138. Introduction!
  139. Anyone interested in Flash Tunes?
  140. Dry Sump Tank
  141. Tell us about your Aftermarket Diff
  142. Supercharger!!!
  143. My V won't shift into Gear?? HELP ME PLEASE
  144. re-installing my suspension stuff- eibach sways, gc, qa1- which spring combo to use?
  145. BMR wheelhop kit doesn't fit
  146. Bmr diff. Brace question
  147. CTS-V fuel Pickup question
  148. Rear Diff Cooler request
  149. Newly done installs and tune, advice please...
  150. Brake p0rn (2pc PerformanceAFX)
  151. This is our stock Resonator
  152. Suspension Upgrade Questions
  153. Harmonic Ballancer... Y U R PROBLEM!?
  154. Creative Steel 8.8" Exhaust Clearance
  155. UMI Preformance motor mounts
  156. Oval exhaust systems
  157. Announcing the Gforce Lifetime Warranty
  158. So who's got the STS turbo kit on their V?
  159. CV Joint Upgrade ???
  160. G-force axles one side or both?
  161. Muffler Delete Video
  162. Creative Steel Trans Mount & Diff Bushing Installed :)
  163. Power Steering
  164. CTS-V Aluminum Radiator Special Sale - Alradco
  165. Cheap fuel line removal "tool"
  166. Rear end and axle issue - what would you do?
  167. BBP Cold Air Intake?
  168. Converting to -6 AN fuel line
  169. Just ordered up a Ron Davis radiator
  170. What Octane do you use?
  171. Swapped out my Magnaflows for some Dynomax bullets
  172. My F1c Pro-Charged CTS-V is complete
  173. LS6 to LS2 Throttle Body Harness (Conversion)
  174. Weird one. Kooks, Corsa, CC mounts...now belts shredding?
  175. Clutch Help! PLEASE
  176. Corsa Last Call before Big Price Increase!
  177. Suede Shift Knob Question.
  178. Ported Throttle Body Question
  179. Shifter Bushings on Stock Shifter ??
  180. Muffler delete or muffler packing removal??
  181. Fall Sale on Kooks Headers! Free Coating or Save a Bunch!
  182. Solid Upper and lower A arms mounts
  183. Who has the best price for QA1 shocks?
  184. Weird electrical problem
  185. Alternate intake tubeing......
  186. RPM Motors built Aluminum 418ci first start up
  187. Decided to pick up a LS7 Clutch
  188. NEW Katech Performance Logo T-shirts only $8*, two colors available
  189. Sparco seats winter project (PICS)
  190. CS 8.8" and DSS Axles and Shafts have Arrived. Install Time!
  191. LS7 clutch swap
  192. What's the best performing ride height for Ground Control 550/650 + FG2 shocks?
  193. DMH cutouts FINALLY arrived 5wks later
  194. LS7 clutch upgrade
  195. Grinding noise?
  196. Wide wheels rubbing your trailing arms? A solution!
  197. 5th Gen Camaro LS3 Clutch
  198. Braille 3121 lightweight battery install (PICS)
  199. Horn location?
  200. A&A C5 Kit, Alternative to the Maggie?
  201. attn: StealthV
  202. heads and cam package
  203. Lingenfelter C5 oil cooler Kit L320010197
  204. Tranny is crooked? How can I guarantee my drivetrain is straight?
  205. MAP Trailing Arms with TIC Bushings
  206. Broken Axle
  207. Replacing clutch on an '06 V1....
  208. A couple performance questions
  209. GForce Anti-wheelhop axle kit youtube vids!
  210. Magnaflow youtube clip
  211. Made a score...can't wait to install
  212. Gforce 9" Rear End Burnout Results....now with video!
  213. Creative Steel vs UUC Diff Bushing Longevity
  214. Any interest in a procharger for our v1?
  215. gutting stock converters
  216. New 2 piece Chromoly Driveshaft from DSS being tested 300m stub and 108mm CV included
  217. Muffler Delete Questions?
  218. What should be done when installing a W4M tune? crank relearn? how?
  219. ATT Mr Matt Seager
  220. Gut the Cats? Hi-flo? Test Pipe? wait for Kooks & Cats?
  221. track tire sizes for OEM 8.5 rim?
  222. Installing Eibach Pro-kit springs
  223. Katech's new VISION, LOGO, and 100-PAGE WEBSITE + secrets revealed!
  224. High Performance Tuning Options for Cadillac V-Series Vehicles
  225. Clutch Advice - LS7? Centerforce?
  226. Hp tuners
  227. Help.... Kooks/Corsa install problem
  228. Stock CTS-V Dyno Number question.
  229. 2007 CTS-V Starter issues
  230. First Mods Complets (Exhaust and full mounts) / dyno tune. Numbers in the thread.
  231. Full Return Fuel system
  232. Feeler thread for TVS 1900/2300 upgrade kit
  233. Don't read this unless you want false hope! RATS!
  234. '06 V lowered with H&R and MM spacers
  235. looking to advance power
  236. Rear End Kit Weigh In. Creative Steel 8.8 vs. G-force 9.0
  237. Broken Inner CV
  238. CTS-V HID Headlamps
  239. PerformanceAFX 2pc rotors
  240. Canyon Run Videos: D3 Cadillac CTS-V Track Car at Auto Club Speedway in Fontana, CA
  241. Left rear stainless brake line cut
  242. EPS CAM dyno numbers
  243. Is this a good price for Kooks headers and highflow cats?
  244. 1 Off Custom Made Twin Turbo Kit For Sale Feeler
  245. CTS-V accessory belt spacing same as early LS1 F-bodies?
  246. KW Coilovers, Katech Shifter Muffler Delete. Busy weekend!
  247. C5 Five hub conversion question (want to upgrade to v2 brakes/wheels)
  248. Volant Help
  249. Non-pro. Mechanic LFW w 1st Gen Vs. Calgary. LS7 Clutch. Creative Steel Mounts.
  250. Baseline dyno of 2007 and new clutch
