View Full Version : 2004-2007 Cadillac CTS-V Performance Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26
  1. LS7 Clutch and Slave... Where do I get the bleed line?
  2. Speedo help and few maggie install questions
  3. Rear End Goes Boom!!!!
  4. cam position sensor/harness
  5. To Wrap or not to Wrap (headers question)
  6. LS7 in 2006 LS2 CTS-V: Help with Misc Parts
  7. Improv MPG with 3.42 rear and .5 6th?
  8. WTB DMH or QTP 3in dual E Cutouts
  9. Decision time
  10. decision time part 2:
  11. choices on a good set of heads that dont cost me a arm and a leg?
  12. ASP underdrive pulley
  13. Chip For my Baby?
  14. header diameter question with Maggie
  15. Dexcool - Why Dilute It?
  16. Need tune..lower NY area. any suggestions
  17. Mishimoto Universal Rad... does it fit?
  18. Rear Differential Gearing Change?
  19. Bad Ass couplers soon to be a reality
  20. Another Short Shifter Option Possiblly
  21. GM Racing sway bar kit must go damn it!
  22. New heat exchanger solutions for maggies??
  23. Anyone have a new LS7 clutch lying around...
  24. LS9 Clutch Carnage
  25. New cam = new headaches
  26. Advice on meth kits
  27. GM Performance Engines
  28. Another Cts-V Cam install
  29. What shifter is this???
  30. Car Dyno Tuned Today...Results
  31. Hardcore racers mod.
  32. 245/45/18 front, 255/45/18 rears OKAY?
  33. This is what I think of Moroso race wires
  34. Staggered Axles
  35. Is this kit worth it?
  36. Harness Bar for CTS-V?
  37. For track rats running harnesses - what to do about seatbelt chime?
  38. KWs and other suspension tech
  39. Where to buy a 165* T-Stat
  40. Exhaust Removal Tips?
  41. Racing Eyes / Tow straps
  42. Does anyone make Poly upper and lower control arm bushings for our cars?
  43. So how do I tune this beast?
  44. Newbie - Week #1 Modding Results
  45. Tuners: How are you getting Air / Fuel ratios when tuning, and where is it mounted?
  46. PCM for Less
  47. Took a pretty cool video with the GoPro *PFC Brake Content inside!*
  48. External tach output for 04 V
  49. Free expert advice department (that's all you other CTS-V owners!)
  50. LS3 in LS6 CTS-V ECM compatibilty issues?
  51. LS7 Clutch swap, how do you have your slave line routed?
  52. Cam or warranty?
  53. Anyone have an LS6 Intake for sale?
  54. LPE Short Shift install
  55. cuttouts and cel
  56. ? for you cam guys
  57. Cradle bushings or G-Force axle?
  58. PICS Team Dynamic track set up. PICS
  59. everything went great until the harmonic balancer...
  60. Need info on KarsIII for Custom sub-frame connectors
  61. GeForce Axle, UUC Bushing, CS Bushing Block Installed
  62. Anyone have a 04-05 CTS-V throttle controller for sale?
  63. Newbie - Week #2 Modding Results
  64. UUC shifter built with knob mount backwards
  65. GM OEM intake tube - help identify a part, please!
  66. going turbo 400
  67. In need of some Maggie info!
  68. Poll type question... Fuel Pump vs RWHP
  69. Spark plug ?
  70. pacesetter lt's
  71. MAP sensor low voltage
  72. Factory Brembo rebuild kits
  73. Representing the V community in the 2011 One Lap of America
  74. Ground Control coil over install
  75. MAF and IAT (OBD2) - Informal Poll
  76. AMSOIL Dominator Coolant Boost, Red Line Water Wetter Tested
  77. too many threads on the same subject AKA: shifter ball wont fit right
  78. Quick help on a couple of items-please!
  79. Oil cooler results
  80. Electronic exhaust cutouts, what size and brand?
  81. 90K mile DD....Headers/MM/LS7 or not?
  82. My exhaust Mods... (Looking for feedback)
  83. AS the build closes...
  84. Another Timeslip.
  85. Kooks Corsa Maggie Question
  86. Grounding a Wide band o2 Sensor
  87. Some videos from my last event at Sebring
  88. Cadillac CTSV questions (lowering & wheels)
  89. Head Recommendation? Combination feedback?
  90. '06 LS2 Baseline Dyno.
  91. Need recommendation on drop in hi flow cats
  92. Clutch upgrade. Is the LS7 a good choice?
  93. LS7 clutch installation - Do I need ARP bolts?
  94. Oiling issues on track. Are they a concern?
  95. Who do you BLAME?
  96. Yes, you need a crank relearn after an ECU swap
  97. PISNUOFF Shifter install time
  98. Maggie Coolant Expansion. Thoughts?
  99. Ride height Problem
  100. Dyno Results - Maggied V - Possibly E85 in the future?
  101. Adjustable Endlinks
  102. Twin plate clutch disengagment issues
  103. 418 Dyno graph and idle video
  104. HELP! - Snapped lower strut mount bolt
  105. Poll question on Anti-Wheel hop remedy.
  106. Tire pressure sensors and Stability Control
  107. Inexpensive twin disc clutch setup
  108. Maggied V- Oil catch, necessity?
  109. Free Shipping!!!
  110. Cutouts Finally Installed.
  111. build completed today, 06 CTS-V just road tested
  112. Needed: Stock resonator
  113. CTS-V Coilovers from LG Motorsports
  114. Supercharged guys? anyone running the ZR1 cam?
  115. Rear Wheel net increase with ls7 clutch/flywheel?
  116. Will I ever get to enjoy this V?
  117. ERP brand Cross drilled rotors and ceramic pads
  118. Has anyone tried an Eforce LS2 Corvette kit on a LS2 CTS-V
  119. So close to pulling the trigger on an 06 or 09...
  120. Best Aftermarket Short-Throw Shifter for 2006 CTS-V???
  121. Finally installed H&R's & MM spacers - a few comments and questions
  122. Headers Cam !Muffler
  123. Low MPGs
  124. Picked up a set of Pacesetters
  125. AC problem
  126. Lake Tahoe Trip
  127. Question for you guys
  128. LS7 Flywheel, should I get balanced or not?
  129. Fuel pump help shuts off after two seconds
  130. Volant CAI with S/C
  131. Short Shifter - Random Harness Disconnected by Factory?
  132. Driveshaft won't come... off!
  133. 2xCTS-Vs - Speed Limiter & Hot Oil Temp!
  134. Need help fast Valdosta ga area
  135. Great news on my parade clunk!
  136. FG2 (front) shock leaking - How long can it go?
  137. Gforce Engineering 9" kits
  138. Brake pad question
  139. Anyone have problems installing the UUC shifter?
  140. 1st Stop - Mod Hell, Check Engine Light On -Knock Sensor Code
  141. Anyone running QA1's??
  142. Distrubing noise from supercharger
  143. Spun rod bearing (long story)
  144. Track Day tires?
  145. Uh oh.. this is bad... - Clutch Bleed Screw dropped in bellhousing
  146. OD of factory rear trailing arm knuckle bushing
  147. Anyone want a set of cut stock springs?
  148. Fuel Pump - stock
  149. 2005 cts-v open headers/ cut out video
  150. Got Katech LS9 Clutch Kit Installed ... finally.
  151. LS7 clutch and flywheel is in!
  152. I think its broken in now
  153. To tune or not to tune...
  154. Looking at Pacesetter LT Headers
  155. Who makes the best polyurethane bushings for 05 CTS-V?
  156. Rear upper shock mount replacement
  157. Tuning with JET Performacne Programmer
  158. GM Performance Swaybars just in time for V Day...
  159. No more flow issues
  160. Best Gear Oil
  161. Best intake manifold/TB on the LS6?
  162. Building a l92/ls3 upper swap shopping list....
  163. Stabilitrak isues
  164. Anyone running a spintech muffler?
  165. Jut got my Gforce 9 done today!
  166. Is the anti wheel hop kit worth it?
  167. Do California smog legal headers exist?
  168. Magna-v's Gforce 9" install
  169. Upgraded front wheel bearings - SKF X-Tracker
  170. cutouts on a rpm switch??
  171. 12" deep fuel cell
  172. Bad Slave, Bad Clutch, or Bad Transmission?
  173. My clutch went to the floor and stayed there.
  174. Success - C5/C6 pfadt shock mounts go on
  175. Long shot - BMR rear tie rod ends
  176. B&M Short Shifter Availability?
  177. Amsoil stock panel replacement filter?
  178. Spring 2011 Modding Results
  179. Need tires again, 3 track days in a week and a half....
  180. Yet another Maggie question....anyone w/ FI experience please chime in.
  181. First time at the strip. 12.95 @ 114.29
  182. Exhaust and CAI
  183. KW V3 current pricing/best deal?
  184. Custom exhaust for sale or trade???
  185. OEM Fuel Gauge Issue
  186. Snorkel
  187. Trans mounts??
  188. Hiccups (literally) after new mods...
  189. 2007 v clutch replacement
  190. looking for a supercharger 4a 05 cstv LS6
  191. TVS 2300 build (finally) commencing
  192. Goodridge Stainless Steel Brake Line Installation
  193. lose some more weight for track days how? what?
  194. Hennessey Performance Engineering SoCal Open house 07-30-2011
  195. Cam Install DONE...
  196. Trunk mounted meth tank installed (pics)
  197. need another remote bleeder ASAP! HELP
  198. X-Pipe Pros & Cons
  199. clutch installed now V won't start
  200. How do I find the fault codes when I get a CEL?
  201. Is a ported 80mm BBK throttle body worth the $400?
  202. Nitrous
  203. Testing a new area for high performance discussion
  204. Katech Stage II LS6 (pics)
  205. MP-112 Magnuson Supercharger Pics
  206. Question for the hardcore racers...Need some help deciding
  207. Maggie 112 kitts priced to move
  208. fuel pump for 700rwhp
  209. Superchips tuner?
  210. Another Tire Thread...... 255's x 4?
  211. New Vendor checking in with some Introductory deals! (MarylandSpeed)
  212. Hendrix Engineering Axle WARNING!
  213. Geforce Rear End almost here
  214. Slicks......which ones?
  215. Should i cam the wife's car?
  216. Broke another race axle
  217. HeavyMetals Love - PMs ??
  218. Calling MP112 Owners!
  219. Walbro in tank 255 fuel pump
  220. straight pipes vs high flow cats
  221. Got Diff?
  222. P0327 code?
  223. 2006 CTS-V clutch issue...
  224. 04 CTS-V traction control issue
  225. Good shop in central FL for dynotune for my 2007 cts-v?
  226. LS1 F-body Quick Time Scatter Shield fit an 04-07 CTS-V ?
  227. Hp tuners, LC-1 and 2005 cts-v question
  228. Lose 80 lbs. for track day in 20 minutes
  229. Dyno Sheets
  230. Hey, new to the forums, looking for some estimated HP numbers from my list of mods...
  231. My Mod List, Prioritize! Problems!
  232. Exhaust Bolts - What is the best way to get them out.
  233. Reduced engine power FML...time to INCREASE power with 90 mm TB on LS6 Maggie
  234. Best HP gain For the least $$$
  235. B&B exhaust w/ Xpipe
  236. Gforce 9" Rear End Install Tutorial Writeup Write Up
  237. New here and just want to share my opinion
  238. Corsa replacement parts?
  239. Baseline dyno of 2007 and new clutch
  240. Non-pro. Mechanic LFW w 1st Gen Vs. Calgary. LS7 Clutch. Creative Steel Mounts.
  241. Volant Help
  242. C5 Five hub conversion question (want to upgrade to v2 brakes/wheels)
  243. KW Coilovers, Katech Shifter Muffler Delete. Busy weekend!
  244. CTS-V accessory belt spacing same as early LS1 F-bodies?
  245. 1 Off Custom Made Twin Turbo Kit For Sale Feeler
  246. Is this a good price for Kooks headers and highflow cats?
  247. EPS CAM dyno numbers
  248. Left rear stainless brake line cut
  249. Canyon Run Videos: D3 Cadillac CTS-V Track Car at Auto Club Speedway in Fontana, CA
  250. PerformanceAFX 2pc rotors
