: 2004-2007 Cadillac CTS-V Performance Mods
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Ordered my cam last week should be here around the 30th. Anything i should know or wa
  2. Which water pump to use with ls3 swap
  3. Dade Broward Shop
  4. Need Your Advice
  5. headers 04 ctsv
  6. I know it has been beaten to death.....
  7. PSA: Check those Coleman Rotors!
  8. Engine and transmision mounts
  9. 04 ctsv cam choice
  10. high idle?
  11. B&B Resonator Catback VS. Muffler Delete
  12. CF Splitter build
  13. Denting the header primary for steering shaft clearance.
  14. First Drag Strip trip coming up, need advice, launching and setting up the car
  15. Going N/A for a while before I go Super so I need input!
  16. lowering motor out with subframe
  17. Diff Fluid change using GM Fluid and LSD additive
  18. Best MOD you can do easy!
  19. Opinions 200K service...
  20. Just installed Belltech (KW) Coilovers: Pics Inside.
  21. Clutch reviews/recommendations
  22. Engine was resting on nothing?! | Motor mounts were out and jack was not supporting
  23. LS3 and direct port nitrous?
  24. Timing Chain Guide?
  25. Anyone gone from Specter Werkes cradle inserts to CS/Revshift cradle bushings?
  26. Removed all bolts for motor mounts | Engine will not lift from frame
  27. Anyone used the Katech LS6 Torquer camshaft in their 2004-2005 V?
  28. Which newer model V differentials fit 04-07?
  29. 80a vs 95a hardness | RevShift Motor Mounts
  30. DIY 5 Lug conversion 5x120 - the easy way
  31. H/C/I Progress
  32. Default Is anyone running a Diablosport Trinity tuner on their V?
  33. Hiccups after LS7 clutch install
  34. SC vs. Turbo
  35. Can someone explain how over torquing the LS7 pressure plate effects engagement, etc
  36. Where is everybody...
  37. Engine shudder on shut-down
  38. Monster Twin Disc Clutch Install Writeup
  39. Piston question
  40. Buying headers
  41. Shifter extremely loose overnight...any ideas?
  42. Gto Holden shifter
  43. High Flow cats or no
  44. Creative Steel: I Need Someone to Install Some Mounts In TUCSON, AZ.
  45. Magnum T-56 into 1st gen....solutions to shifter linkage
  46. Pacesetter Headers
  47. Aftermarket cam...
  48. Creative Steel: 04-07 CTS-V 5 Lug Swap
  49. Oiling questions
  50. Dumb question time broken motor mount.
  51. Clutch for 05 v 383 stroker build?
  52. FAST 92 or 102?
  53. X pipe or Corsa Resonator?
  54. Gm performance (Borla)
  55. 04-07 B&B Exhaust with PRT Mufflers
  56. Why are o2 sensors so tall (on the outside)
  57. Removed TPMS and now I have CEL
  58. 2007 CTS-V suspension
  59. Rear camber issue
  60. aftermarket ls2 throttle body ?
  61. 8.8 diff....
  62. Obx
  63. Exhaust Manifold Headers
  64. V2 Calipers on V1 How-to
  65. Finalizing remaining parts list for LS6 Head/Cam swap. Need some assistance.
  66. Maggie and good heads
  67. going to try and make the Meziere fit...
  68. Injector question
  69. Upgraded to platinum supporter, CAR FASTER/WHEELHOP REDUCED! What mods now??????
  70. header bolt size
  71. Front sub-frame bushings
  72. revshift motor mounts
  73. Muffler Delete Caused Rough Idle
  74. Ls6 busted pistons, rebuild suggestions?
  75. LS2 harmonic balancer options
  76. Finally got it done!
  77. intake/exhaust mods without full tune
  78. Ls6 build & questions
  79. just ordered ls7 clutch, what else?
  80. Neutral safety switch/ no start
  81. UUC Motor Mounts
  82. Map sensor snapped while driving?????
  83. 5 lug wheel options
  84. Lifters....yeah, its that time I think.
  85. aftermarket fuel level gauge
  86. K&N Intake fitment question
  87. Newb question about cleaning MAF Sensor
  88. Alradco radiator group buy.
  89. new engine
  90. superchips 2724
  91. monster clutch question
  92. 550 dollar TPIS / SW headers on ebay?!???
  93. ARP Bolt kits
  94. B&B Install question??
  95. Yet another wheel hop thread
  96. Mufflers Only?
  97. Creative Steel Rear Toe rod group buy!
  98. Possible V2 Caliper Retrofit Option
  99. Anyone know of 2006 CTS-V Manual to Automatic Transmission Swap?
  100. Trans Cross-member Alignment?
  101. CTSV LS3 Belt drive assembly question
  102. Fuel Rail Crossover
  103. MAF questions
  104. UUC CTS-V Brake Line Kit Question
  105. muffler and resonator delete?
  106. Just an idea and curiousty on CAI from more knowleadgable ones
  107. Fuel Mod - Twin DW300 fuel pumps (pics)
  108. I've been out, but busy... (big turbo build)
  109. Custom Hurst Shifter Review - 07CTSV \ PISNUOFF \ Brian
  110. Made some Subframe Connectors today
  111. Kooks, HF Cats, Stock Exhaust: Sound Clips Please
  112. Aftermarket Suspension Preference
  113. Cts V exhaust question
  114. Hi flow catalytic converters for '04-'07 V.
  115. Suspension Woes... Need advice about Qa1, Eibach etc.
  116. Creative Steel: Front Sway Bar Bushings
  117. LS6 Engine swap options
  118. 3.55 cobra 8.8
  119. Hurst shifters for the V.
  120. 2006 CTS-V NEED MOD Advice
  121. Will the LS2 intake fit the LS6??
  122. TR6060 in 1st gen CTSV.... now an option from RPM
  123. Lingenfelter LS6 intake
  124. ATI Super Damper Blems on eBay
  125. alradco radiator overheating?
  126. sticky hp thread?
  127. need help! cradle bushing removal, creative steel tool
  128. LS6 Cam Selection
  129. Answering the question nobody asked: Can Camaro shorty headers be used on a V?
  130. fluids
  131. Revshift Motor Mount Sale!
  132. Tr6060 - 2005 cts-v
  133. overheating!
  134. Pinion angle/flex disc
  135. Mallett CTS V Questions
  136. Creative Steel Wide Wheel Trailing Arms
  137. FNG help!
  138. Shifter base and linkage needed
  139. Ls7 engine swap
  140. Hurst 3916030: Improved on by PISNUOFF
  141. Revshift Christmas Day 25% Off Sale!
  142. Pacesetter Headers
  143. If you who want a HUD for your car check this
  144. Looking for a cam
  145. Exhaust Plan - Seeking Opinions
  146. Time to up the power
  147. tune tomorrow!!!
  148. 265/40-18 on stock wheels(all around)
  149. differential girdle...
  150. Exhaust question
  151. Replacing Balancer
  152. Creative Steel: Cradle Bushings Removal Tool
  153. Revshift 2 Weeks of Christmas 15% Off Sale!
  154. Hey guys just got a ls6 cts-v and have some questions.
  155. Suspension help!!! D2 coilover kit
  156. Top End Kit Questions and Information Request
  157. steering rack failure
  158. LS7 clutch kit - part numbers, installation tips, etc
  159. Dilemma: LSA heads + LS3 Intake?
  160. Creative Steel: Lower Front Control Arms
  161. Black Friday prices all this weekend at Gforce Engineering
  162. Creative Steel SUPER SALE!
  163. Engine swap?
  164. Piston to Valve clearance
  165. My mod money just got gobbled up.
  166. Ecm #
  167. Katech LS9 Clutch help needed
  168. RevShift / Creative Steel Rear Differential Bushing - Testing
  169. Problem with DriveShaft Shop Aluminum Driveshaft Install - Need Input
  170. Random thought about wheelhop reduction and axle configuration
  171. Injector dimensions / fit
  172. Magnacharger cam selection
  173. Tire rubbing after suspension work
  174. WTB Exhaust
  175. CREATIVE STEEL: Rear Sub-frame Bushings
  176. Best Shifting Linkage for street use... ? Like Hurst, ect..
  177. Best / affordable solutions for oil cooling and diff cooling
  178. New tires and alignment really make that big a difference??
  179. Excel Spreadsheet - Engine Speed vs. MPH
  180. Cts-V Sway Bar
  181. Any one have info on changing Inner Tie Rods?
  182. BMR Suspension Specials!!
  183. Revshift - unshielded MM damage (pics)
  184. Katech LS9x clutch install - shifter is notchy, reverse is difficult
  185. DIY ? Rear cradle bushings?
  186. RevShift - Blue Differential Bushing, Starting to "clunk"
  187. Next best mod??
  188. LSA piston questions
  189. Creative Steel, Revshift, or Both
  190. Any interest in aluminum shifter bushings (in lieu of the "Home Depot mod")?
  191. catback gain
  192. McLeod RST LS7 slave
  193. After my Revshift Red Cradle Bushing install
  194. CTS-V Shopping! For high horsepower potential, should I hold out for an LS2 car?
  195. Lingenfelter Air Filter - How to Clean?
  196. Opinions on this z06 clutch setup for my V...
  197. Issues installting brass T56 isolator cup bushing on trans shift selector
  198. Went to the drag strip last weekend......
  199. Think we are done with Coleman Rotors...
  200. Girl with performance mods :) needs advice
  201. Monster Stage 2 clutch with 18lb flywheel installed, now very difficult to shift...
  202. Killed my shift knob
  203. Driveshaft the same as CTS?
  204. Going to tear it all apart - water pump ?
  205. Back up on blocks for winter work
  206. Adjustable Billet Motor Mount w/Poly Urethane Dampener
  207. Motor Rebuild Needed - R&R myself or have it done?
  208. Clutch slave / remote bleeder / hose leak troubleshooting
  209. Getting confused about the shifter
  210. Exhaust recommendations - LS2 with Corsa
  211. 275/35/R18 on all 4 corners
  212. E-charger for our cars?
  213. Lose clutch pedal height at high rpm
  214. What is the best AutoX Tire on a Cost/fun/longevity basis?
  215. Track Weak Points
  216. Flex disc / driveshaft coupler Camaro part number & SGF replacement
  217. Chassis Braces
  218. I found a monster in my car. I don't know what to believe anymore.
  219. Goodridge brake line kit for '04-'07 CTS V (part number 12242)
  220. gforce rear end...
  221. The other shifter bushings
  222. 04 cts v 2nd gear grind
  223. Best mods to start
  224. Note to self: Check front end links tightness on the deck as well.
  225. Magnaflow install issues.
  226. Thought I'd share some pics from my LSX build
  227. Developing exhaust sound
  228. New flywheel installed. Tune needed?
  229. Affordable High flow cat options
  230. Monster speed bleeder leak
  231. CCW SP600 Wheels - Pic attached
  232. New Tire Time - Nitto's Left Me in the Ditch!!
  233. Halfway through my motor mount install...
  234. Unsprung Weight Reduction: 09-13 Forged Aluminum Knuckle?
  235. CTS-V Mod Hell - Fall 2013
  236. LS7 clutch
  237. LS7 Cluch Kit w/ LS7 Slave
  238. Build complete! problem I cant figure out now...
  239. Only half of cradle bushings installed???
  240. changing diff oil
  241. About to upgrade brakes
  242. Question about LS7 clutch in CTS
  243. Revshift Blue cradle bushing Fail
  244. 425whp LS6
  245. Just snapped TWO studs on my exhaust manifolds, Need Headers suggestions ASAP!
  246. pig in slop
  247. Catless kooks to corsa?
  248. Volant Intake on '06
  249. Creative Steel: AFTER Labor day Sale
  250. Ls7 clutch kit..what slave?
