: 2004-2007 Cadillac CTS-V Performance Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mount
  2. 1 7/8th vs 1 3/4" headers
  3. Looking to stop wheel hop need help!!!
  4. Surprising Weight Savings from Aftermarket Wheels
  5. anyone know how to contact voodoo performance for rear suspension
  6. Nitrous Oxide....way better than cags!
  7. DYNO Runs - Thread
  8. CTS-VR Intake
  9. Hendrix Econo-Axle In Hand *Pics*
  10. Kooks question.... again.
  11. 275/40 RE-11 on stock rim?
  12. CAGS! Eliminator. The best mod EVER!!!
  13. Ls2 90mm on a Ls6?
  14. 1 7/8 kooks Installed :D
  15. Pre-Cat Cutouts
  16. TKS Fab Front and Rear Strut bars
  17. has anyone used these?
  18. LSx Intake for a 4 Barrel
  19. Dual Mass Turd
  20. UUC Motor Mounts Version 2
  21. anyone running a FAST 92MM intake manifold
  22. Kooks with stock exhaust?
  23. Free shipping on cadillac logo merchandise & custom lloyd mats
  24. Not impressed with KARS III...so far.
  25. Gto superchargers tvs2300
  26. 2005 CTS V Katech 427 oil temp problems.
  27. Latest Heads/Cam combos
  28. FINALLY!! I can blow up rears on DEMAND!!
  29. Gforce Engineering axles
  30. Specter Werkes Cradle Bushings 04/05
  31. Upgrade your Stock Shifter and Bushings
  32. KW Coil Over Setup
  33. Air Intakes, Filters, and Computers
  34. Time for a clutch...What path would you go?
  35. Anyone have a Procharged V?
  36. I finally have my Hendrix Pro axles!!! Hendrix ???
  37. Mallett Supercharger or Heads & Cam???
  38. Which Maggie Guyz Has One of These?
  39. LS2 Steath V & lingenfelter intake
  40. Limited Slip ???
  41. 2300 TVS Blower Swap
  42. Optima Red Top side post in service date 09/07/09
  43. New Supporting Vendor
  44. New trans mount (wow!)
  45. looking for cat delete
  46. Going back to the Dyno, have questions
  47. LS6 vs. LS2...Yes, I did a search.
  48. H&R Lowered Pics
  49. 4 point harness for V
  50. Lindsay 2 piece rotors (Trackday update)
  51. Excelsior Motorsports - So Cal V Dyno / Mods shop
  52. Stupid tire pressure question???
  53. Steel braided brake hoses back in stock
  54. Magnaflow Mufflers
  55. Harrop Superchargers
  56. Weight Loss Clinic (V on a diet)
  57. Hendrix econo axle hand delievered
  58. FREE H.E.X. Clutch!
  59. Need a measurement..Please help
  60. Which fuel pump with Ms. Maggie?
  61. anyone running the K-sport coilovers ?
  62. This will probably get deleted too
  63. ATTN: Suspension / Rear End Manufacturers!!!
  64. Wheel-hop eliminated/no upgraded axles
  65. Poly motor mounts sizzling
  66. Braille Battery Install
  67. KARS III Kit Install help
  68. Suspension improvements? (Pedders)
  69. Amsoil Royal Purple etc. Noticable difference?
  70. Changing shift knob on a stock shifter?
  71. a few questions about Kooks headers+cats
  72. LS2 K&N CAI with lean codes
  73. Hendrix Econa axle take two
  74. more video
  75. Broken end links
  76. K&N CAI whistle between 1800-2200 RPM?
  77. CTS-V Differenial Mod
  78. Spark plugs...what should i use?
  79. Kooks Dilema
  80. Hendrix Engineering = QUALITY clutch/flywheel combo
  81. Anyone have tpis headers?
  82. Sway Bar failure!!!
  83. Headers and exhaust or JUST exhaust?
  84. Engine Idle Question
  85. MSD Coils
  86. HE Axles & rear springs installed :) videos
  87. vid of my cam, exhaust
  88. UUC bushings and modified stock shifter :D
  89. Newest Dyno Numbers 8-22-09
  90. Brake pads - any suggestions for less dust but best performance?
  91. front end creaking after ground control install
  92. Accusump Project
  93. F/S cts v parts
  94. Lifetime Performance Oil Filter???
  95. Where is Stealth V ?, now you know!
  96. Urethane reinforced rear craddle bushings?
  97. Firecore50 Plug wires now available from Gforce1320
  98. Who sells cradle bushing for our car?
  99. Clutch Questions? Enter.
  100. Diff temperature monitoring in stock instrument cluster
  101. Can you identify this exhaust?
  102. Convert your V1 into a V2
  103. Gc 600/650
  104. Huge Install Weekend
  105. LUVMY04V Has a New shifter! (he is all about performance since the new Layout)
  106. Anticipated dyno numbers with Maggie...
  107. Mp122???
  108. FAQ/DIY/How-To/Common Questions
  109. More Exhaust Questions...
  110. buying lowering spring
  111. Another Short Throw Shifter question...TPIS?
  112. Track Day Blackhawk Farms
  113. Larger Custom Snout and TB for Maggie?
  114. H.E. pro axles (hop)
  115. Shredded Gatorback
  116. How to lower rears even more
  117. Cam install is done :D
  118. Free B&M shifter for stock one...
  119. who would buy a rearend replacement .8.8 or 9
  120. Accessory wheels widen!
  121. Max lift on LS6 without flycutting?
  122. K&N Intake Question
  123. LS7 Clutch - Let's Get the Final Word
  124. Hendrix Clutch Assembly
  125. CTS V rear end options
  126. Down Low Eibach Pro
  127. Ultra Mounts Poly Motor Mounts from MotorMounts Full Review
  128. Tranzilla
  129. Toe Rodz... I gots questions...
  130. Engine and Transmission Mod - get an LSA?
  131. Goodridge vs UUC Brake lines?
  132. FG2s on Ebay
  133. Maggie spins but I have no boost!!!!
  134. LS7 clutch and I think I screwed myself
  135. Help me decide.....!!
  136. Slave questions.... please step inside
  137. New BMR Pinion Support
  138. Got the KW Variant3s (V3s) installed today
  139. Honestly, Really??
  140. What headers and other mods for my Maggied V???
  141. Would this fit?
  142. Headers - How much of a difference will there be between 1 7/8 vs 1 3/4 on a FI setup
  143. New remote Bleeder option? .... looks like it
  144. UUC 2 piece rotors...
  145. I'm going to do it!!!! 99.9999% sure.
  146. Happy with maggie 2nd time around
  147. H&R extreme dissapointment...
  148. Could I make this work on my LS6???
  149. Just pulled the trigger..
  150. taking the v to EPP
  151. CTS-V Exhaust on a regular CTS
  152. Eibach Spring install & now front end bouncing
  153. Got a Funky, Barely Audible Drivetrain Noise
  154. GM Super DOT 4 Clutch Fluid or Any DOT 4?
  155. Monster Clutch Stage 2.5 with 15lb Flywheel Review
  156. tech Discussion: LS2 + centrifugal = 750rwhp/690ftlbs
  157. My twin turbo 408 is almost done
  158. Motor Mounts
  159. Same Dyno, New Numbers (Adjusted tune)
  160. I give up.
  161. Air Box Modification
  162. INstalled the replacement UUC motor mounts (Thanks Luke!)
  163. Changed TB and still in reduced power
  164. Maggied and Forged 418 LS3
  165. Hendrix-Engineering econo axle tester needed!
  166. RacingBrake Two-Piece Rotors for CTS-V
  167. B&B headers to magnaflow
  168. Initial Observations on UUC Flywheel Install
  169. Gforce Engineering half shafts
  170. MAGGIE is coming home to Colorado!!!
  171. UUC Motor Mount Install Ques for Maggie-Equipped Cars
  172. Got My Maggied LS3 V back: First pic: CAI
  173. Added Magnaflow exhaust,,,
  174. what does LINDSAY CADILLAC sell?
  175. Maggie Belt almost slips off
  176. Oil catch can with Maggie?
  177. where to get corsa?
  178. Houston/Tomball TX CTS-Vs
  179. Buying Corsa Cans
  180. Cheap / Good FRC's
  181. Maggie boxed and sent back to its maker
  182. Maggie CAI - not the regular kind
  183. ATTN: Gearheads - Stroker Build
  184. Clutch Questions...Help!
  185. Sprayed the Nitrous on the Dyno aaaand..........
  186. Maggie on ebay = seemingly good deal
  187. Hendrix-Engineering intrudces Stepped Headers!!!
  188. Kooks headers sale
  189. another exhaust reference for ya: Magnaflow mufflers in place of stockers video
  190. hacked up exhaust-whats inside..
  191. eibach springs
  192. eibach springs
  193. Deep in Mod Hell...CAI Problem with Nitrous Plate
  194. BBK SSi Intake Manifold for 97-04 LS1
  195. track video with dss axles
  196. Last chanse! H.e. Axles $1599
  197. Maggie heat exchanger / intercooler reservoir upgrade?
  198. Warranty is almost up, I have a boxed up blower. Do I take the plunge?
  199. Intakes - which suck and which suck more ?
  200. Kars III Install Question
  201. Anyone need a stock exhaust ?
  202. Sometimes I seriously hate this car. Codes inside.
  203. kooks headers to magnaflow catback?
  204. Show Me V-Day III!!!!
  205. Looking for a stock V exhaust in Chicago Area
  206. borla baby!
  207. UUC Flywheel and MM Pics (I'm bored)
  208. Thinking of buying an '04 CTS-V with a Maggie today!!!
  209. Magnaflow k&n intakes at the best prices guaranteed
  210. those of you with lingenfelter CAI.....
  211. Fidanza clutch & F/W set-up LS6 or LS7???
  212. Anyone with headers and a catback, how's the noise?
  213. Introduction and some questions (also a heads up on Eibach springs) :)
  214. MAF code popped up
  215. Oh No My Clutch!
  216. Dyno results - looking for feedback
  217. Recommendation on CAI
  218. 1/4 mile king?
  219. New Custom Nitrous Switch Panel *PICS*
  220. Loss of Power on my 05V? - Help!
  221. Whats a used maggie worth? Anyone in need?
  222. Hendrix Axle Install
  223. 05 Magnaflow Cat Back on 06
  224. Check Engine Light Question
  225. Stock Sway Link Part #
  226. A race car is born
  227. So you're thinking about getting exhaust work done...
  228. Transmission Warranty Work - Bad News
  229. Just Springs
  230. RPM Dyno Day, Post up your dyno charts,,,yeah even you Tom
  231. Tip for maggie owners - downsize
  232. Warning to guys buying Lowering Springs on ebay!!!
  233. Secret Nitrous Installed, Tuned, Dyno'd. Pics and vids here
  234. Motor mounts are great but I still have a clutch problem!
  235. So much for a warranty...
  236. Custom Made (by me) Nitrous Arming Switch Panel **PICS**
  237. V axles back to NC for repair
  238. HSW CTS-V 78mm Plate Kit and All-Out Nitrous Accessory Kit is Here **PICS**
  239. Another CTS-V Motor Mount Supplier
  240. Shifter Bushing - So Confusing
  241. Sts twin turbo kit huge sale!
  242. Dss axles users!!!
  243. Took my 2005 CTS-V to the drag strip. And..
  244. Transmission or Shifter Problems
  245. No more clunk for me!
  246. Last Night's Trip to the Strip...Meh..
  247. New V owner with a few maggie questions...
  248. Plug Wires?
  249. UUC flywheel/stock clutch vs. LS7 setup
  250. looking to put maggie on 07 ls2 anybody do that
