: 2004-2007 Cadillac CTS-V Performance Mods
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Best Mods for $ ??
  2. Diff Differential Bushing Install Removal
  3. Axle Install How to
  4. 09 Differential
  5. Those with maggie - Come in having an issue
  6. Hotchkis is good!
  7. Getting parts together for clutch and headers
  8. Gforce CTS-V Anti-Wheel hop axle kits
  9. How can I tell what differential my V has?
  10. 383 Build starts tomorrow.
  11. Secondary cooling fan motor....
  12. Video of Mustang Dyno Run for Twitch (Tony)
  13. Fast 92 Intake No Longer In Production
  14. ACT HD 6 puck clutch kit
  15. On the fence about running E85? --- Duel Flash PCM!
  16. Differential leak from diff vent.
  17. "sticking" throttle after new mods (kooks, k&n intake,spark plugs)
  18. !Tire costs going up 8 to 12% on Jan 21st!
  19. Modded my shifter this weekend
  20. Forgot to lube the oil filter gasket
  21. And we have a cam now
  22. Doing some Installs today!
  23. What are the thread dimensions on clutch slave cylinder
  24. Madman's rear IRS
  25. Motor Mount - Stock vs upgraded - under car video
  26. For those who have done the MOD
  27. Check this out!!!!
  28. First Mod!!! Virgin V...
  29. In for brakes and find...
  30. Who sells front-end poly or alum. bushings
  31. where are you guys buying your maggie kits?
  32. Those with Maggie's check for belt wear.
  33. Good RPM signal to use for dyno pulls?
  34. V1 vs Japan sedans...
  35. Axle popping out of Diff!? HELP
  36. Eibach Pro-Alignment Camber Kit 5.81260K CADILLAC CTS
  37. 4" Intake DIY
  38. is this real?
  39. Trailing Arms bushings
  40. help with a LS2 maggied ctsv
  41. 05 CTS-V Muffler Only Replacement
  42. Kooks Exhaust 10% Discount and Free Shipping
  43. Heat soah aid
  44. School me on clutch choices
  45. Hotchkis question
  46. anybody done a twin intank pump set up?
  47. Time for New Tires
  48. E85 Conversion on Maggie'd V
  49. Tune???
  50. Coil-overs
  51. Energy Suspension Forum Pole
  52. Nitrous dyno results
  53. new style intake manifold - benefits - see link
  54. Christmas Present (Finally Some Kooks Headers/HF cats)
  55. Fitment issue w/ 2006+ K&N CAI
  56. Whipple Supercharger (3.3l) installed on LS6 CTS-V (should work for LS2 as well)!!!
  57. Time for a New Clutch
  58. 0-60 Maggied V?
  59. CA. smog legal cam choices (suggestions)
  60. typhoon 96mm intake manifold
  61. Wheel Hop Question
  62. Power steering hose?
  63. 8" crankshaft pulley vs 2.6 w/ tensioner
  64. Kooks headers and Magnaflow Exhaust
  65. A word of caution!!!!!
  66. Big Thumbs Up to Magnuson
  67. In the middle of header installation.... question!!
  68. Embarrassing emergency question in regards to header studs
  69. Maggie + HE axles
  70. Harmonic Balancer Replacement Questions
  71. Seafoam before or after header install?
  72. BMR Strut Tower Brace For Sale
  73. LS6 oil pan CTS V
  74. Some news I need to share
  75. Installing Headers and Full Exhaust...
  76. Available ring + pinion ratios?
  77. crank relearn???
  78. 2006 mass air flow
  79. Anyone do cts-v dyno tune in ottawa, ontario canada? Or near here?
  80. Stock OEM muffler cfm?
  81. I need an 06-07 CTS-V
  82. Searched the forum and still confused, HELP!
  83. Brake bleeding trackside
  84. Why are there no full exhaust systems w/ H pipe or other for cts v?
  85. BFG R1 Track Tires (265/35ZR18) (a few ???s)
  86. Maggie i-cooler hoses flat?
  87. Dyno'ed the V today
  88. Kooks headers to MagnaFlow exhaust help
  89. so i finally did it!
  90. good deal on Kooks headers
  91. LS7 slave failure
  92. cts-v mod plan.. help me out
  93. Overdrive Pulley
  94. Rev Speed: Stock vs LS7 Flywheel VIDEOS!
  95. Magnacharger going in this weekend, help me with the check list
  96. H&R Install Question
  97. Possible DISSASTER!!!! HELP!
  98. Help me pick a CAM and accessories for my Maggie'd V
  99. UUC short shifter
  100. Hooker Headers for the CTS-V?
  101. FAST fuel rails - whats used to connect to main fuel line
  102. maggie
  103. Stock CTS-V exhaust headers...
  104. dyno and ABS
  105. Injectors Choosing, be careful
  106. lowered v
  107. She won't start
  108. Upgrading stoping power for track use...
  109. Has anyone measured or noticed gains from replacing intake snorkel
  110. Z06 Struts/shocks? or 09 ctsv's
  111. GMPP is AWESOME.
  112. MSD 8.5mm Wires versus Taylor 10.4mm
  113. Another "here's my dyno graph" thread
  114. RPM help
  115. Corsa Catback 4 sale 800 shipped
  116. Well she broke again.
  117. UUC Bushings/Shifter, LS7 Clutch in. My review
  118. All New Creative Steel/Ultramounts Poly Diff Bushing Installed!!
  119. Twin supercharger.. old news?
  120. Cheap Sways!
  121. Which Redline Transmission Fluid?
  122. See as most everyone has one Ill ask......
  123. CEL points to low signal at MAF sensor
  124. Cheap, brand new FG2's
  125. Just got B&B exhaust --- a bit confused!!
  126. Motor mount dilemma
  127. Axle installer FAIL!
  128. we are looking for someone who wants to do a Whipple
  129. Magnaflow Issues
  130. Need a favor
  131. Anyone have a corsa exhaust system for a 07? used/new
  132. Lightweight flywheel question
  133. Straight Axle conversion option!
  134. Reliable Net Merchants?
  135. Cleaning out garage
  136. Supercharger Motivation
  137. 800 HP Tranny options?
  138. Cts-v 2006 automatic conversion
  139. Got Some Test Pipes to Replace Stock Cats
  140. Specter Werkes Cradle Bushings
  141. Eibach Spring Part # Question
  142. LS7 Clutch Kit Ordered..To Remote Bleed or Not to Remote Bleed?
  143. Clutch Help
  144. Accessory power location
  145. Nitrous purge location
  146. X pipe ??
  147. Other than stock shifter bushing with Katech shifter?
  148. Ebay Rotors & EBC Yellows = AWESOME
  149. My V finally feels like a true "Sports" sedan
  150. HELP, were is the speed sensor located ?
  151. Fitting a compressor and air tank in the spare tire well...
  152. Is this old news?
  153. Monster Clutch Co. Holiday sale
  154. Air Filter Part Number (cone filter - aftermarket)
  155. LS6 Intake Part Number
  156. Help! Super Newbie here!
  157. I got it on last night.....The Maggie that is!
  158. Textralia exo-skell install help!!!
  159. Anyone install a resonator on a Magnaflow exhaust?
  160. Methanol Injection
  161. Going to make new Motor Mounts Have Q's
  162. Does anyone make a remote bleeder for the CTS-V slave???
  163. What basic mods won't void the warranty?
  164. Anyone know what kind of shifter this is?
  165. Half Shafts...
  166. Check Ebay for exhausts quick!
  167. Dyno baseline for nearly stock '05 V
  168. Gotta go back to stock springs with air bags
  169. New exhaust front to back
  170. how much $ for pinion support bushing install through dealer
  171. PAH!! Bolt on 80HP of Awsomeness!!
  172. 04 ctsv vs 08 vette ls3 auto
  173. What's the best hand held tuner for a 2006-2007?
  174. All I ever wanted to know about CAM's and a few other questions
  175. Brakes stock vs aftermarket for DD
  176. Baselining the V - a visit to the strip
  177. Looking for headers (kooks) install walkthrough
  178. LS2 ported throttle body
  179. Where can I find a Maggie LS6 Valley cover ASAP??
  180. Flip Drive Belt System for Maggies
  181. PS2s to Hankooks
  182. 315 too much rubber??
  183. Gforce axle testing conclusions
  184. About to order B&B headers and exhaust!!
  185. Yet another Tire Question
  186. auto-x on 275/40 rear tires
  187. Z06 or CTS V
  188. Gforce Engineering axle kit ordering
  189. Want to lower my V
  190. Who Wants an Off-Road Test Pipe That Will Still Pass Visual Inspection?
  191. Headers and cats on.....now a question
  192. what is part number of 05 V ECU?
  193. New Maggie Installed
  194. Need part numbers for LS6 MAP sensor and IAT sensor for maggie.
  195. New mods and dyno sheet.
  196. Gforce Axles Review
  197. E85?
  198. New maggie headed my way via Hendrix Engineering
  199. GC Question
  200. Relatively new V owner seeking some advice
  201. Borla Exhaust
  202. World's Fastest CTS-V in Standing 1-Mile
  203. Race Series or Performance series?
  204. Lowered suspension feel - new owner
  205. Which cold air intake is the best? Ported TB??
  206. maggie+90mm TB.
  207. MSD products?
  208. Too many diffs in stock
  209. Spec Clutch
  210. Craig's List Cam\Head Package
  211. Best NOS: Which kit and why
  212. 102 mm maf
  213. New numbers after dyno tune
  214. Lowering Parts I don't need....maybe you do? z06 endlinks, lowering spacers
  215. Hendrix Clutch Review
  216. Hendrix econo axle installed....it works!
  217. I bet this is one reason why we have clunk! (Video)
  218. Help with shif linkage and clutch
  219. Am I missing something?
  220. Cam, Header install almost wrapped up
  221. Maggied 05, fuel rail cover questions
  222. Have you guys heard of these brakes??
  223. Looking for rear toe rods and trailing arms
  224. Brake Job - new rotors help
  225. Installing B&B headers and catback in 2 weeks!!
  226. Fuel Pump Change?
  227. Specter Werkes Cradle Bushings ready to ship
  228. Broke the Crank Pulley last night
  229. LS7 Throttle Body
  230. Question on a FAST INTAKE????
  231. B&B resonator
  232. Hendrix HEX Clutch Review
  233. Hendrix-Engineering econo axle ready to ship!
  234. Cquence rotors...
  235. Monster Clutch Install
  236. Yet another cam question
  237. Creative Steel/Ultra Mounts Transmission Mount Full Review
  238. Hendrix Econo-Axle Review
  239. **rlj5 runs 11.64**
  240. More Maggie info....please help.
  241. Maggie group buy
  242. B&M short throw shifter??
  243. Need CAGS, who sells it?
  244. Now I know why they call it the fastest color....
  245. WTB Stock Motor & Trans Mounts
  246. Diagnosis Needed
  247. A bit confused about "tuning"...help needed!
  248. @#$^!* UUC Transmission Mount
  249. Will no cats cause any problems??
  250. Photos of Creative Steel Ultra Mounts Transmission Mount Vs. UUC Transmission Mount
