: 2004-2007 Cadillac CTS-V Performance Mods
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. My Maggi has developed a weird noise...
  2. Poly bushings for the rear
  3. UUC Lightweight Flywheel WANTED
  4. Looking for StealthV
  5. Used Maggie Purchase - In progress - Advice?
  6. Pulley options with kevlar belt
  7. Addicted to MODS
  8. [Help] Engine Misfires
  9. 408 cam selection
  10. Stock Headers to Corsa connections
  11. Wrapped header + SW 3in Exhaust
  12. Lightened Flywheel Conversation
  13. Changing Rotors
  14. Cam guys... How much for install?
  15. Alky-Control meth kit
  16. Hendrix Econo Axle
  17. Honest Opinions (RT Cats)
  18. CTS V owner near Charlotte, NC
  19. Firecore50 Wires now available in a 45 deg boot
  20. Shim dimension help please !
  21. Traction/Satbility Control won't disable?
  22. Poly motor mounts in stock
  23. **New Design CS Mounts and LS7 Clutch install**
  24. Looking for rear strut bar? I found 5 Get'em while they last
  25. Not the oil seal... My Hendrix axle too short?!
  26. install time for ground control
  27. Head and Cam Combo - Ready to pull the trigger - any input?
  28. Clutches? Monster or ? Ordering ASAP
  29. Help! Put Hendrix axle in, went for a drive, oil spray all over back of my car
  30. spark plugs.. NGK irridium Bosch fusion +4
  31. Axles
  32. B&B catback with KOOKS
  33. Swift springs
  34. TB off a '01 Vette work?
  35. FYI : Set of FG2's on Ebay
  36. Intake kit interchangability
  37. DIY Intake, metals bad...anyone tried sewer pipe?
  38. Cutout location
  39. C5 Headers on ls6 CTS-V
  40. CHANGING 5.7 to 6.2
  41. Anyone ever use these pads/rotors???
  42. Love this car.
  43. Just got new front struts at 90k...do I need to replace rears too?
  44. Corned weighed my V
  45. Tires?
  46. Great Deal on DSS 2004 - 2007 Axles
  47. 383 Start up and idle and a little rev
  48. 3.3L Whipple kit installed
  49. QA1 questions????
  50. Adjustable endlinks for front and rear sway's
  51. Header Gaskets
  52. Anyone else notice their C.S. Motor mounts sagging ?
  53. TPIS shifter in and it's awesome
  54. Help, snapping swaybar endlinks
  55. Upgrades
  56. New V Owner - Recommendations Appreciated
  57. Will a 222/226 .597/.598 115LSA cam pass emissions?
  58. cam'd cts-v dyno vid.
  59. Thinking about selling my B&B catback and headers.....
  60. cats?
  61. cam and tune questions!
  62. 2004 V ECU Tune - Who's the best?
  63. V died while driving at 100, then works fine after
  64. Guys with 10.5'' rims on there cars please step inside
  65. vogtland lowering springs?
  66. ECM losing brain cells?
  67. Anything to be gained with dyno tune on stock CTS-V???
  68. Subframe Connectors
  69. Fidanza Twin 6.5 Review
  70. My car is on the way to Madmans
  71. Buyer beware!!!!
  72. Illinois Shops - Make reccommendation
  73. Camshaft opinions / ported TB?
  74. My custom grind cam whp #'s
  75. OMG I think I may have destroyed cooling system
  76. Colorado V's. Shop recommendations.
  77. Who is making rear strut tower bars??
  78. Rules Reminder: NO STREET RACING VIDEOS
  79. New Monster on the Street?
  80. Cam Opinions
  81. Looking for pointers/opinions
  82. Hendrix-Engineering track day invite!
  83. Bought a Textralia clutch from C5 Vette, what else do I need for install?
  84. UUC vs. CS diff bushing?
  85. Slow 07' V?
  86. Whipple, Kenne Bell or TVS
  87. UUC brake hose users, caliper fasteners ever loosen?
  88. Please guys help me track down and fix this front suspension CLUNK
  89. Anyone got an 11 second V?
  90. Dumb Question...V vs. Vette
  91. Who Makes Custom Intakes?
  92. Electronic Cutouts
  93. Looking for Hotchkis sways
  94. flapper or variable exhausts
  95. Corsa Mufflers getting louder
  96. Headers without tune???
  97. Head and Cam Recommendation
  98. Hawks, Carbotechs and Two Piece Rotors...OHH My!
  99. Quick wtb on FG2 shocks and Eibach springs
  100. B&B catted headers+ Magnaflow catback
  101. Batteries
  102. W4ME Tune, Speedo problem??
  103. 2 pc. Replacement rotors??
  104. Kooks+cats, stock exhaust w/Magnaflow muffler sound clip?
  105. Is at it again
  106. C6 Z06 Calipers on CTs-V???
  107. Eibach Spacers Question
  108. "My" Differential solution progress
  109. RT High Flow Cats
  110. 6th gear grinding??? Anyone else
  111. Adam of PerformanceLSX.com Texas trip
  112. Maggie is installed :)
  113. Rad flaw. - information purpose thread
  114. size of stock mufflers? also tip recomendations?
  115. got my new intake installed
  116. part number for gen 3 v1 diff?
  117. Hi-flo cats or No cats?
  118. BNeal1022's Specter Cradle Bushing Writeup.
  119. Pacesetter Headers ON SALE
  120. BMR AWK and Specter Cardle bushings
  121. Differential Solution : Ford 8.8 IRS
  122. Exhaust system advice?
  123. Dyno Results - MAP Twin / BBE LT's / Magnaflow
  124. Wow, car runs like poop. (Headers)
  125. harmonic balancer slid back
  126. Best place to buy Maggie?
  127. Looking for pics of custom exhaust.
  128. Best place buy motor mounts trans mount differential bushings
  129. No Warranty Issues with Hendrix Econo-Axle........
  130. Anyone have experience with Blackbear tunes?
  131. Creative Steel "Caddy-Soft" Transmission Mount with Black "Race-Firm" Motor Mounts
  132. Hendrix-Engineering passangerside econo axle
  133. I Need a New Air Filter
  134. Widebands
  135. In need of Cross Drilled Rotors...Anyone know of any good deals??
  136. Clutch weights and what you need to know.
  137. Calling all clutch gurus, issue with spec
  138. Installing wideband afr
  139. Plugs and Wires
  140. How much HP from common mods?
  141. Got my Headers installed! 382 RWHP
  142. Exhaust?
  143. BNeal1022's CS Grey Diff Bushing Writeup.
  144. Stability control @ hwy speeds
  145. Do you gain any HP with just High Flow cats?
  146. GM Drilled Rotors - Question
  147. MAGNAFLOW Catback #16636
  148. FAST FAST LSXR 102mm Intake Manifold For LS1/6 Engines
  149. Small under car mod
  150. What motor mounts/tranny mount are the best?
  151. H&R 1.2" and 1" drop. What else do I need?
  152. Where to buy Kooks
  153. Dyno Today!!
  154. Cam idle **Video**
  155. Monster Clutches on sale - $100. off
  156. MAPerformance Twin Disk Pricing/Info
  157. Brake pads EBC or Hawks
  158. AAIIIC's oil cooler thread
  159. New Vendor: Herron Performance
  160. Suggestions needed
  161. ls3 heads on ls2
  162. Hot Deal For DSS 2004 - 2006 Axles
  163. Fidanza Clutch FUBAR install
  164. MAPerformance Twin Disk *Dyno Graph Inside*
  165. UPS Brought Me a Nice New Box from Nitrous Outlet!
  166. best mods order list
  167. Who's running a SPEC 3 or 3+
  168. Headers Fun!!
  169. Gforce Engineering race axles
  170. Pacesetter Headers
  171. Maggie
  172. Camshaft Questions
  173. Penske coilover spring-rates
  174. Will a factory F-Body Hurst shifter fit in the V?
  175. Mods to the Maggie ?
  176. MaPerformance it's Fidanza twin disc clutch time.
  177. Magnuson Supercharger Customer Service
  178. Endlink options
  179. Quick upgrade questions
  180. maggied LS2 adding Headers what pulleys?
  181. V-series logo accessories, merchandise and custom automotive mats
  182. 5 lugs wheels on cts-v
  183. Posted Some Nitrous Parts in the Classifieds
  184. Headers...
  185. Illinois V owners - what shop do you use???
  186. Drivetrain shudder and rearend clicking noise - looking for input
  187. am i stupid for wanting to put drag radials on the V?
  188. Passenger shock is blown and leaks are plentiful
  189. Put on my test pipes today...
  190. Anyone Have Experience with Header Cones?
  191. another soon to be owner of a V w/ headers
  192. Interesting new motor mount development
  193. anyone have used H&R Springs for sale?
  194. K&N AND lean codes
  195. Katech Header Exhaust Clip
  196. Installed Moben Novitech package and Hotchkis sways
  197. P0171 and P0174
  198. Yet Another Brake Question
  199. San Diego Cam Swap?
  200. 454 VS Maggie Setup
  201. RaceChrono, Cell Phone laptimer
  202. Mods for an Autobahn bound CTS-V
  203. Creative Steel Trans Mount Install!
  204. Headers all wrapped up
  205. Stainless Works
  206. +50 hp gain in 5 minutes
  207. Found a nice treat tonight
  208. Swapping x pipe for h pipe, corsa exhaust
  209. Geforce Axles Review (Short version)
  210. Poly swaybar bushings - anyone tried some "universal" ones?
  211. Sound Slip of my new setup
  212. Z06 Endlinks installed pics and comparison
  213. Help with Gforce Axle install
  214. Needing a proven vendor for doing several mods at once - Texas/Oklahoma/Kansas Area
  215. Will a 2009 LSA engine/trans fit in '04 V?
  216. Cam installed today **Video**
  217. OK...so you've had headers for 6+ months...still happy???
  218. Camber curve?
  219. Not all Carbon Fiber Belongs in the Appearance Section!
  220. 07 cts-v upgrades
  221. Motor Mount Suppliers
  222. You can not beat this deal!!
  223. Creative Steel trans mount with short throw shifter.
  224. Gears?
  225. 04 cts-v issues.
  226. Make sure you buy a ls2 thermostat for your LS6
  227. New 402 motor in the works
  228. Hendrix-Engineering axle the only ONE that works
  229. Frankensteined my V
  230. rear axle question difference betwwen 04-05 and 06-07
  231. Those with creative Motor Mounts please enter.
  232. Question for those with QA1's
  233. 8-Ribbed Guys
  234. East Coast Tuners, NY/NJ (TTP or Tune Time Performance?)
  235. Wheel hop kit pic needed
  236. Dana 44 swap in an 05?
  237. Manufacturer of stock exhaust system
  238. Another Shifter Install w/ Hurst knob
  239. Question on HE econo axle install
  240. Maggie Question
  241. Monster Level 2 with 18lb flywheel **VIDEO**
  242. Gforce Axles Results **VIDEO**
  243. Gforce Anti-Wheel hop axle feedback thread
  244. Hendrix-Engineering back to vendor status
  245. Katech STS Question?
  246. Tuning? 20RWHP??
  247. My rebuilt rear diff setup
  248. Anyone Building a Motor want a set of CTS-VR Lifters?
  249. A balancer question (mostly academic)
  250. Underdrive pulley
