: 2004-2007 Cadillac CTS-V General Discussion
  1. Finally bought a V!
  2. Stability control won't disengage
  3. Need Instructions on Replacing the E-Brake Mechanism and Pedal Assembly - 2004 CTS-V
  4. New V owner
  5. If you want to bypass the BOSE check this:
  6. Need assistance with diagnosing a noise - Videos included
  7. GMVIS report for recall info please!
  8. Fair asking price for '04-V in need of repair.
  9. Rally postponed due to the ice storm has been rescheduled for February 22
  10. alternator plug wire
  11. Car audio HELP!? Subs Amps RMS? So confusing!
  12. 2004 cts starts off blowing warm air then goes cold.
  13. Re headlights not working
  14. TPMS part number(s)
  15. Rear view mirror plug
  16. Cadi's Stock sub removal help! Replacement ?'s
  17. cts-v and your biceps
  18. Free Shipping Offer: Cadillac Floor Mats & Car Covers
  19. Electrical short?
  20. knock sensor
  21. For Those of You Who Have Replaced/Removed Your Full Exhaust...
  22. New V owner with a few questions
  23. Harmonic Balancer
  24. Upper Control Arm Torque Spec?
  25. Cold Day Blues
  26. Muffler....
  27. Exhaust Hangers
  28. 2007 CTS-V Front Side Marker Bulb Replacement
  29. Front Speakers Not working
  30. 04 CTS-V introduction
  31. Sub options please?
  32. Replaced rad
  33. Crate engine ignorance question!
  34. Can't get the trans to seat - relatively pointless post
  35. New V Owner - some questions after research
  36. Budget V?
  37. Shifter Issue/High Mileage V1 owners should read this!
  38. Thank you RevShift!
  39. Top Gear UK review of cts-v?
  40. 06 CTS V motor mount replacement
  41. New motor...no electrical power
  42. 2004 CTS-V vs 2001 bmw M3
  43. tt cts v
  44. Navigation Firmware
  45. Power Steering Pressure Hose Replacement
  46. Radio Personalization Mode stuck OFF! How to turn it ON?
  47. trans/clutch fluid replacement
  48. Radio stuck on nav. "Agree" screen
  49. Merry Xmas. An old one, but a good one.
  50. Squealing noise, carrier bearing?
  51. First day of owning '07 CTS-V
  52. Turn me on to a CTS-V
  53. Temp gauge accuracy?
  54. Clutch Fluid Disappearing
  55. Mystery part?
  56. Dressed to the 9's on a trip to Mexico
  57. New Owner of "Badilac" in Orlando Saying Hello!
  58. 2005 DIC with navigation programming?
  59. PSA: Replace/upgrade your spindle and driveshaft bolts for $25!
  60. Intro of a new 04 V owner.
  61. Control Arm Ball Joints & Misc Parts
  62. Sewing Machine Sound Coming from Engine
  63. 05 CTS v stock radio volume knob not working. HELP
  64. 04 v bad vibration, 1st, 2nd 3rd gears as accel
  65. Need advice, possibly purchasing 04 CTS v tomorrow. More details inside.
  66. 3rd and 4th Gear selection at Idle ?
  67. door latch?
  68. DVD Wont Read Navi Disk
  69. 2004 CTS-V 50K miles feels like rear suspension is shot
  70. Electrical - battery short?
  71. looking to buy 2007 V
  72. Replace Oil Pan?
  73. oil temp overheating
  74. random leak
  75. vibration
  76. Airbag Emblem
  77. Headlamp question
  78. Looking to buy a 2006 model
  79. Does anyone make a filtration-oriented (rather than performance) cone filter?
  80. Nav Issue
  81. NEED SUSPENSION HELP! cant find shocks
  82. FML Road debris through my grill! Advice needed.
  83. Rally postponed!
  84. Strange Knocking
  85. its impossible to have a nice Daily driver...
  86. O2 simulator wiring help
  87. Looking at an 07 V tomorrow...service history question/concern
  88. p0449 code question
  89. Radio not turning on (??)
  90. Sensors or ground?
  91. Engine rebuild, stuff to do while it's out
  92. Black Friday shopping spree....finally bought a V!
  93. Talk me into buying an 04 CTS V
  94. Revshift 2013 Black Friday Sale
  95. Need help finding interior dome light 2005 cts-v
  96. Name that leak (bellhousing)
  97. Alradco Radiator Sale
  98. 2005 CTS-V will not go into reverse….
  99. The V turned 9
  100. Could it be Motor Mounts?
  101. 275 stuffed, but rub ?
  102. Where to buy Forgestar F14?
  103. two forums enter, one forum leaves.
  104. Quick picture of the V
  105. Transmission concerns about high mileage CTS-Vs
  106. Rear caliper issues
  107. Anybody in the houston area wanna help me replace mydiff bushing?
  108. AC Delco plug wires
  109. What did you do to your V today?
  110. What are your mpg's in town/ hwy?
  111. Noise at idle when clutch not engaged
  112. My V was Stolen. if you see it please call the police
  113. V Sway Bar Seattle
  114. Children's Book Run, a charity road rally benefiting Scottish Rite Hospital
  115. Oil temp at startup
  116. Hows this rear differential bushing look to you?
  117. New '05 V owner would like some insight ...
  118. Reset Airbag System without GM Tool? I've searched, i've searched. Plz Help.
  119. Just bought a high mileage '06 V, what should I fix/repair/replace?
  120. What is this part?
  121. 2005 power steering and overheating problem
  122. DIC "Change oil"
  123. Vibration after Exploding Diff
  124. Finally found the right CTS-V!
  125. Back up lens
  126. nice V - Hickory NC - Not mine....
  127. have i made a royal (purple) mistake?
  128. Who runs Continental DWS tires?
  129. Another potential new owner. Help please
  130. Service Stability System issue.
  131. 2 problems with end of daylight savings time
  132. Cts-v Nav Buttons
  133. Can I change the idler pulley?
  134. New potential CTS V buyer needs some info!
  135. 2005 CTS V, to buy or not to buy?
  136. Spare Flex disc....Needed
  137. Last Word on DIC Retention with Aftermarket Head Unit
  138. Serpentine belt slicing on dampener pulley
  139. New owner from Iowa... 2004 saved from the unknowing.
  140. Front suspension help. Makes ugly , ugly! noise
  141. Rear wheel facing the wrong way
  142. Broke my Glove Box, need replacement parts
  143. Positioning Two Post Arms for Lifting
  144. largest sensible tire
  145. Uh oh! found metal in my differential O.o
  146. Fuel Mystery
  147. 2005 V Removing the engine - proceedural question??
  148. Above normal coolant temps
  149. Whats up from KC !
  150. o2 sensor p0420 problem need how to change tips Please
  151. Introduction and some questions
  152. Amateur NAV Question(s)
  153. Time it takes to change? [Change what? Ooooooh, time to change a front strut!]
  154. rear diff gear options and results
  155. 2004 possible purchase, need opinions/insight...
  156. coolant leak
  157. anyone have a rear speaker they are not using?
  158. Random shut-off: engine, lights, everything
  159. 1st to 4th at 5k+ = grinding
  160. Codes
  161. Anyone ever had any luck compressing front springs with strut still on car?
  162. 1 & 2 driver not working all the time?
  163. Rear Diff Still Covered??
  164. Oh deer.
  165. Trunk leak question
  166. shifter problem
  167. Trans problem
  168. Drivers side motor mount bolts help
  169. Differential question 04v
  170. The Great Pumpkin Rally
  171. V Exhaust for sale?
  172. '06 CTS-V dimmer switch stopped working
  173. New V owner
  174. z06 water pump
  175. Typical water operating temperature range
  176. Broke T-56 Temperature Sensor
  177. How much do you pay for insurance?
  178. Had an odd problem today, need assistance.
  179. New V owner - Nav questions
  180. Car fell off jack, jackstand punched into floor panel
  181. PSA: Cleaner for Engine Bay & Window Trim
  182. 2005V rear door windows won't work unless thru driver switch
  183. Anyone recognize this 2005 CTS-V? Member here maybe?
  184. Something To Possibly Add To The **Look In Here First**, Aftermarket Driveshafts!!!..
  185. Subwoofer barely heard
  186. Loud click from passenger side of engine at idle
  187. PSA: Tighten Your Differential Bolts!
  188. Top speed followed by clutch problems...
  189. Swap LS6 With LSA?
  190. Does anyone have ramps you can actually drive the V up on?
  191. Lingenfelter Collection Open House
  192. New starter?
  193. 04 cts v price
  194. Need to Rebuilt a 2004 CTS-V motor
  195. HELP!!! STABILITY CONTROL problems
  196. Oil [viscosity questions]
  197. Loose shift knob
  198. Front / Rear Tire Wear
  199. Bolts in trunk floor
  200. Video from NASA at Watkins Glen (10-26 and 10-27)
  201. Mailbox and the V
  202. Fuel Rail Covers for Maggie'd LS6
  203. Modded CTS-V, opinions?
  204. Car wont Run..... No clue... need help
  205. stability control activates at high engine rpm.
  206. can't get the rear package tray out!?
  207. Cadillac going for World Challenge championship this weekend
  208. Which floor jack do you use with a lowered V
  209. Need parts help
  210. Pocono North pics and video
  211. S.E. Michigan Fall Cruise Vettes & V's Oct 19
  212. Ist Gear Pops
  213. 06 cts-v harmonic balancer removal
  214. Any CTS-V owners in Greenville SC area?
  215. How to for Front Shock replacement?
  216. Garage in Madison, NJ
  217. 04 Oil pump R&R in car??
  218. Reverse gear problems, what next?
  219. Superchager Cam
  220. Service Stability System
  221. ls7 clutch part list
  222. P.O.S. CD player DIC
  223. Need a differential!!
  224. Think this is a blown shock?
  225. Left bank lean
  226. Track Pics and Videos from NJMP 9/23/13
  227. Car wouldn't start this morning... any suggestions?
  228. Cutaway of stock mufflers?
  229. Top rad hose
  230. 04 CTS-V Engine Removal
  231. Does anyone have a schematic of the fog and head light relays?
  232. Whine found not the diff
  233. Ls2 vette harness in a 2006 ctsv
  234. Obnoxious whining
  235. Headlight assemblies
  236. Power steering Pump pressure line Seal Part number ?
  237. Plugs and wires
  238. Anyone have the TSB number for the high oil temp electrical issue?
  239. Michigan V Owners - Let's go to the track!
  240. UUC shifter bushings..
  241. I'm in love with my CTS-V!
  242. rattle at shifting
  243. More V1 1/4 mile times
  244. Safe to drive to a muffler shop?
  245. How long do the tire pressure senders [TPMS sensors] last?
  246. What to look for when Purchasing a used CTS-V?
  247. Shop Video - Cadillac CTS-V / Suzuki Hayabusa / GSXR 1000
  248. Any DC area V drivers?
  249. Changing Top o2 Sensors
  250. Stock V1 1/4 time
