: 2004-2007 Cadillac CTS-V General Discussion
  1. rust on main frame rails
  2. Tabs where the bumper meets wheel well shield
  3. Key cylinder microswitch part # needed and Boca Raton mechanic wanted 33433 area
  4. Whats the true market value of a 23K mile 2005 V ??
  5. Throttle Body Cleaning??
  6. 05 acting like dead battery at start, but will start after a few tries???
  7. After market head units and factory sensors
  8. Potential CTS-V Owner - Looking for advice on purchase
  9. "Tuning" Madness + Engine Damage in 3...2...1
  10. What is this for in the door?
  11. Final Word - Gear Oil Comparison Full Lab Testing
  12. Roof rack and weight?
  13. CTS-V engine placement
  14. swapping out Canadian cluster
  15. 07 cts-v 12k miles
  16. Very poor audio quality with XM delete aux input
  17. Bittersweet...
  18. GM Employee Discount
  19. Shifter broke and left me stranded.
  20. 2004 Driveshaft center support bearing
  21. Circuit of The Americas February 26-28, 2016
  22. Dash Removal PDF to replace center speaker
  23. Midwest cars / rust
  24. 2006 CTS-V Front Sway Bar Rubbing on Struts when turning right or left. FIX???
  25. Should I get TPMS?
  26. cyl 3 misfire
  27. nitto tires fixed wheel hop
  28. 04 V/LS7 Clutch Swap
  29. Shifter linkage Broke: Help!
  30. Backup Camera
  31. P0353 and P0303 Woes
  32. New V owner here! Have a question - Nav screen personalized message?
  33. Hit a bobcat, here's the damage. What do you think the adjuster's estimate will be?
  34. CTS-V issue - Stability Control and Traction Control problem
  35. How comfortable for a big guy?
  36. how do these alignment numbers look?
  37. Help! Drive belt part # needed!
  38. Do We Still Use 4 oz. bottle of GM #1052358 Limited Slip Axle Lubricant Additive ?
  39. ISO of Ebony Driver Floor Mat
  40. ABS activating during normal dry stop. Occasional "service stability system" message.
  41. 2004 V - Oil Pressure Low - Stop Engine
  42. 2004 CTS-V new owner with questions - drivetrain vibrations
  43. 05 CTS-V P0174 - cannot get to go away
  44. Service vehicle soon
  45. Timing Chain Issues?
  46. Selling the V1
  47. Potential Buyer Wheel Hop Question
  48. Joining the veee crew
  49. Change Oil on screen???
  50. The Newb
  51. cel B0730 and C1030?
  52. rear axle shaft stuck in hub
  53. catalytic warranty
  54. Emblem Location
  55. Internal Wiring Problem...?
  56. Light on my dash.. tire sensor?
  57. oil temp issue only when turning.
  58. Clutch position sensor
  59. Need help reprogramming key fob?
  60. Need AC line part number..
  61. "Service steering system"
  62. motor shakes when i turn it off
  63. No power 1ST AND 2ND gear, help pls!!
  64. Rear brakes dragging/frozen
  65. Front Passenger Window Issue Need Advice on my 'O4 V
  66. No power to rear console outlet
  67. Road course track tires?
  68. "broken" Ash tray spring
  69. Remove cats = O2 problems?
  70. 04 CTS-V salvage title value
  71. Rear End Warranty
  72. P0856 - Traction Control Torque Request Circuit Malfunction
  73. Labor Day weekend Upgrades
  74. Replacing the transmission output shaft seal
  75. No power to the dash? My daily!
  76. Clutch Engaged light grinding noise while coasting in neutral, turning right only
  77. stabilitrac stays on
  78. Wilson Electric Alternators?
  79. Dealer won't use my "trap-door" mod for fuel pump recall
  80. Clutch remote bleeder recommendations
  81. Differences from 04 to 07 Models?
  82. Transmission going in to reverse not 5th!?
  83. Help! After jumping battery car has reduced power and engine is extremely rough
  84. 2006 w/83k for $17k or 2005 w/55k for $18k?
  85. 2005 CTS V Transmission Issue PLEASE HELP ME!!
  86. intermittent dashboard/DIC
  87. Seriously thinking of a V1
  88. Help with the car
  89. o2 Simulators
  90. 2006 CTS with navi
  91. Squeak from rear?
  92. Seat covers for '05 V - Need to protect the leather from dirty mechanic clothes
  93. Help motor mounts and oil pan seal 05 cts-v
  94. 2005 with 175k miles $10k - good deal?
  95. no wipers or washers? I'm stumped
  96. Just bought a 2006 CTS V and have some questions
  97. Collision damage
  98. Maggie Guy's Running Stock Fuel Pumps - No BAP ?
  99. Need new tires - should I avoid the "2011" Goodyear F1 GS-2's on Tirerack?
  100. '05 V A/C line chaffing, heads up (mine blew)
  101. Help ! Darkman (lol...sorry bro) Wiring Schematic Clutch Switch
  102. 2006 CTS-V LS2 to LS3 swap
  103. 05 CTSV intermittently won't start. It can be push started.
  104. Parking brake...gone?
  105. Water in the doors
  106. radiator deflector
  107. For The Peep's - CHEAP TPMS Sensor Set
  108. Permanently Disabling Stability System
  109. Upgrade to 2nd Gen???
  110. 2015 Woodward Dream Cruise - August 15th
  111. Darkman! Or anyone else... Onstar and bluetooth
  112. My new to me, 2005 CTS-V
  113. Bad Fuel gauge idle ? Fuel level sensor perhaps ?
  114. Is this a bad harmonic balancer?
  115. Lingenfelter Cars & Coffee
  116. Loss of power steering
  117. 'Service stability system' every time 04 V is started. Began after sitting 2 months..
  118. Wiring schematic needed.
  119. Rock hard brake pedal
  120. Possible diamond in the rough
  121. specs for alternator output & idiot light
  122. 2004 V- "With Clean Title "
  123. Crickets in the Engine... Idler Pulley problem?
  124. My First CTS V, 05
  125. Bushings Installation- Long Beach Area
  126. 2006 CTS-V Wheel bearings
  127. Looking for dealer service recommendations Central NJ
  128. 2005 cts-v with suspension issue with upper ball joints going out
  129. omg new problems...
  130. NASA Northeast Race pictures
  131. Central jersey cruise feeler
  132. I'm starting to get a misfire - what next?
  133. Groaning from Rear ALL the time
  134. Ground points
  135. Need help identifying part
  136. V1 Longevity
  137. oil pressure gauge inop?
  138. engine temps: can't find specs, looking into a variety of fixes
  139. Trunk Organizers / Organization: Pictures Please !
  140. Anyone had a water leak at the A-pillar airbag button?
  141. Breathing again after3 years
  142. Brake line recall
  143. Competitive Driving Mode
  144. Where did the classifieds section go ?
  145. xm radio dead
  146. Drive Shaft problems
  147. Where is Fuel Pump RELAY Located ?
  148. Linea Corse wheels: Touch-up paint?
  149. Emblem part #'s
  150. Traffic Circle / Lakewood Blvd. = Raven V1 Rollin Hard
  151. Top 10 Factory Options Every V Owner Has Come To Love
  152. Core support cover
  153. Guy has same license plate as I do ... sort of.
  154. Suggestions on installing Aux jack for iphone 05V?
  155. Creative Steel Memorial Day Sale
  156. Flood and Interior lights INOP
  157. My two babies - I'm so proud
  158. Indy V Meet June 6, 2015
  159. Knock in front left side! Common for bushing on strut to knock? 05 V
  160. Cadillac Challenge at Spring Mountain Motorsports Ranch
  161. Looking for GM Part # for the Bolt that bolts the Coolant Bypass Hose to Heads ****
  162. Steering wheel column lock picture or diagram
  163. Junk Motor Mounts
  164. Fuel pump whine
  165. 05V Nav unit circuit board broke
  166. beat a sti
  167. Issues after Alradco radiator installation
  168. Custom images on stock Nav system?
  169. 2005 fuel pump recall
  170. Brake light electrical schematic 2007 V
  171. How to "open" radiator fan wire connector
  172. parts source
  173. Keyless entry issues
  174. Power Steering whine
  175. 04 V no start
  176. My 06 v will not start
  177. Got my V!
  178. new to the board
  179. URGENT: Service Power Steering Notice
  180. Brand new 2004 CTS V today! It's new!
  181. Car stalls out in 1st and 2nd Gear
  182. High Idle When Moving
  183. A 72 sec Video for the Truly Bored Among You
  184. 1.5 ton aluminum floor jack?
  185. Linkage kit needed
  186. Whining from transmission/rear end?
  187. Oversteer
  188. 07 cts v oil problem
  189. Navigation Disk
  190. I'm new here. Looking to buy, asking for opinions.
  191. Another Recall - front brake lines
  192. Stability system tried to kill me.
  193. "engine to body harness" connectors - pin out?
  194. High Idle after cleaning MAF Sensor and Throttle Body
  195. CTS-V vs CTS base rear subframe / cradle
  196. Newb :) considering a 105k mile 2004 v. Questions !!
  197. Harmonic balancer question
  198. Chrome wheel repair??
  199. New guy with a new (to me) V
  200. Sunroof "sagging"
  201. Were some of the CTS V grilles plastic?
  202. E-brake cable routing rear cradle
  203. Driver auto seat problem?
  204. Track day report
  205. Front passenger seat. 07 CTS-V
  206. Need torque for Pinion Nut - conflicting info online
  207. broken spark plug
  208. safe to start car....
  209. Possible Stripped Crank Threads?
  210. Dorman Parts
  211. Key fob working except for trunk release
  212. Rear Suspension.
  213. I hope to get a REALLY QUICK answer to this!!
  214. Front Fascia
  215. Bumper Question
  216. Baker's on May 3rd Anyone?
  217. 06 V1 Front Suspension Issue. Help needed!
  218. PSA - AC Delco has $2/plug rebate on spark plugs for 2015
  219. Navigation DVD
  220. J 45845 Clone Caster/Camber Adjusting tool
  221. something broke
  222. Where to find/buy 05 half shaft/axle
  223. What is official name of this - Interior trim piece
  224. darkman > Shell Answer Man - where do you get the PDF's
  225. Diagnose my "Whine"
  226. help with drivers seat
  227. NewB and New (to me) CTS-V
  228. need some help on suspension
  229. NewB
  230. Windows not working
  231. Symptoms and problems I've had, and what remains. Data dump
  232. How do you shift your V?
  233. Tough day for the V (transmission)
  234. xm radio gone from presets
  235. CTS map DVD
  236. Few Issues: Engine Hot A/C Off, Check Coolant Level, TPMS Sensor Out, Other...
  237. Scrapping V parts soon!
  238. CTS V 2005 Rear differential
  239. Steering "knock"
  240. Vibration 1500 rpms and up. Can't figure it out :(
  241. Want my old car back... VIN 1G6DN56S550196424
  242. Cadillac Challenge | Buttonwillow Raceway March 8th, 2015
  243. Part Numbers & Online Vendor Recommendation - 2006 V
  244. 2005 V Prop (drive) shaft cv joint
  245. Differential Clutch Chatter
  246. 2007 srx seats fit into a 2004 cts-v
  247. Which ECM used 2007 CTS-V used ?
  248. help with front suspension
  249. Vacuum hose locations
  250. broken diff casing!!!
