: 2008-2013 Cadillac CTS General Discussion
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
  1. Shopping for a New CTS
  2. Motorweek ATS Coupe Rview
  3. Premium gas for 3.6?
  4. new kid on the block...trying to hook up a 2008 Caddy CTS
  5. 2011 HIGH Beam Question
  6. Zaino Sealant
  7. Rainsense wipers
  8. One-touch sunroof
  9. 2009 CTS Compass Calibration Problem
  10. GM Ignition Recall
  11. Hard wire radar detector 2011 Cts 4 Coupe Performance
  12. GM Nav Disc Update Issues
  13. CTS Reliabiliy
  14. HELP with 2009 CTS
  15. New to the forum HELLO All questions 2009 CTS?
  16. I bought a 2014 CTS Performance coupe -did i miss something?
  17. 68K Miles...Do I need new shocks?
  18. Voice Command List
  19. Aisin Manual transmission noisy?
  20. love u caddy
  21. Not an owner YET, what should I avoid?
  22. Service Air Bag
  23. used 2013
  24. Lil help please ........
  25. Is this "burn mark" normal on a CTS muffler?
  26. Bad News: Sales stopped
  27. Good news: CTS VTV
  28. 2010 CTS, lights around shifter
  29. CTS Coupe Summer Tires Issue
  30. Aftermarket Audio Upgrades
  31. 2010 cts problems
  32. 2010 CTS A/C fan noise that sounds like organic tree debris
  33. Tpms
  34. 2008 CTS Tow Eye/ Tow Hook
  35. 2011 CTS W/O Backup Cam
  36. Previously Owned CTS / Bluetooth Pairing Slots Full
  37. Cadillac CTS 2014 premium brand new -- for sale
  38. Wheel nut torque issues
  39. Suspension Clunk from stop Start....
  40. 2008 cts4 3.6di
  41. Dealership vs independent service
  42. Future cts owner looking for help / opinions
  43. Vibration in shifter
  44. 2009 CTS V6L DI.... High Mileage???
  45. Front tow hook threads - rho plate
  46. OnStar Battery Backup 2009 CTS
  47. 08 CTS DI- Buzzing Sound when accelerating
  48. Ventilated Seat Not Working
  49. Whats better new or rebuild
  50. O8 cts stopped moving/making grind noise
  51. Lloyd's Mats - Ebony
  52. `11 AWD driveshaft recall
  53. Blind zone warning thoughts
  54. C0050 Right Rear Abs Wheel Speed Sensor
  55. Custom cadillac floor mats & merchandise
  56. Compass in Nav Screen
  57. OEM Spark Plug part number for '09 CTS with 3.6 DI
  58. Three short beeps when entering?
  59. Hands free stopped working
  60. 3.0L CTS engine issues
  61. New Member Plugging In
  62. Timing Chain Recall / Special Warranty / Shady Dealer- Please help!
  63. New 2013-14 CTS recall
  64. Anyone else having issues with iOS8?
  65. 2014 CTS 3.6 Coupe Magnaflow Question
  66. I'm new to the whole "warranty" deal.... Could someone please school me on this topic
  67. My perfect Black '13 CTS Coupe AWD w/only 2K miles
  68. 2009 CTS HID burned out???
  69. Just bought a 2012 Sport Wagon Premium - LOVE it! Some questions re: Brakes...
  70. Squeaky seats in a 2012 CTS? Really??
  71. Buying a newer Cadillac
  72. 2009 Cadillac CTS - Anti-theft Sleep Mode?
  73. "Engine running on reduced power" message
  74. Vibrating steering wheel when braking
  75. CTS 3.0L takes time to rev up when merging lanes
  76. 295/30r20 rear tires fit a 2008 RWD sedan?
  77. The New Guy here
  78. Before I head to the dealer ... heated seats and speaker
  79. They're just saying...
  80. blue tooth
  81. Yet Another Recall: 2013-2014 Cadillac CTS
  82. 2011 CTS Steering Audio Controls sporadic malfunction.
  83. Anyone using a K&N air filter? What do you think?
  84. battery getting low
  85. New Member New Cadillac
  86. Remote Start Security Issue
  87. CTS-V Coupe Sunroof Leaking?
  88. 2008 cts 145,000 miles??
  89. Considering a 2012 CTS 3.6
  90. Looking for a write up for replacing front half shaft?
  91. Battery was removed, now a couple electronic problems that mechanic can't fix
  92. 2008 Base to Nav Swap + Aftermarket Audio Upgrade
  93. Trip mileage, oil check
  94. Engine cover removal for oil change
  95. 3500 mile roadtrip in a '12 Coupe with an olfrt in the drivers seat.
  96. Antifreeze leak question 09 DI
  97. Door Ding #@!%*
  98. idle speed (rpm) is changing at hot engine
  99. Thunk Sound in Rear
  100. Buying used 2011 Luxury 3.0 AWD Sedan. What to do as a new used owner
  101. Electronic parts list or a pdf
  102. P0300 Code, 2010 CTS 3.6
  103. I have a heating and cooling question?
  104. Is this normal? -- Headlights and Tail lights
  105. Rear Deck Rattle - Subwoofer
  106. 2008 door handles not opening the door when pulled
  107. CTS 4 front differential failure?
  108. Clanking Noise From Right Rear
  109. Electronic Key
  110. I like the 2nd generation CTS more, tell me why I am wrong
  111. Cadillac Headquarters Moving to New York
  112. A/C "Clicking" when car turned on.
  113. Key FOB Shell
  114. Torque rating for lug nuts
  115. Looking to buy a cts wagon
  116. Audio sterio and all chimes, directionals disabled - non function - silent
  117. Brand New NGK Iridium IX plugs after experiencing misfire in Cylinder #2
  118. 2008 17" Wheels Fuse to the Rotor
  119. How to jack up your car
  120. Troubles with brakes after 60k miles
  121. Broken input and output shafts - is this normal??
  122. Vibrating steering wheel when aplying the brakes?
  123. INDIANA WINTER- Need help! Winter tires/wheels for my 2011 CTS COUPE RWD
  124. Radio turns on while driving.
  125. Manufacturers Rep.
  126. Goodby and Thanks
  127. CTS wont start!
  128. 2013 CTS Sedan Luxury AWD Module question
  129. Turn Signal Bulbs on 2009 CTS Premium OEM HID Headlight Assembly
  130. 2012 CTS Coupe Sunroof
  131. New Michelin tires + thermostat replacement
  132. iPhone Integration
  133. 2012 cts coupe awd premiums
  134. New "saftey" recall "14497" received....
  135. 3rd Cylinder Misfire / Low Compression Due to Carbon Build Up?
  136. 2011 CTS, Drivers window and heated seats not working.
  137. Need "BRAKE" information
  138. Help from Coupe Owners
  139. Hello.
  140. Cadillac STOLE my gps, it can happen to you. Watch out.
  141. Free Shipping Offer: Cadillac Floor Mats, Car Covers and Merchandise
  142. service power steering issue problem
  143. Considering a CTS. Would you buy a used one?
  144. Getting a New Car
  145. Last straw
  146. Cadillac CTS Brown Leather Key Chain
  147. Serious, err, Sirius Question
  148. Light and stall
  149. JL Audio Stealthbox?
  150. Odd steering problem
  151. Audio config?
  152. 2010 factory bluetooth not powering down
  153. headlight questions.
  154. Production numbers for the CTS Coupe?
  155. Memory/heated&ventilated seat issue
  156. Proactively clean sunroof drains?
  157. Bluetooth problems
  158. quick question
  159. Codes/CEL
  160. Day time running lights
  161. LY7 ran dry on oil 3500 miles after change. Timing Chain warranty apply here?
  162. LY7 ran dry on oil 3500 miles after change. Timing Chain warranty apply here?
  163. Build sheet request
  164. front xenon bolb
  165. GM to Introduce Hands-Free Driving in Cadillac Model
  166. Right Rear Wheel Bearing Removel
  167. Abs code c0045 pressure sensor b
  168. 2010 Navigation problem
  169. 09 CTS cold wheather questions
  170. Wet passenger floorboard, inside window condensation
  171. Oil Life Mileage
  172. Cadillac moving to NY, NY ?
  173. 2008 CTS Nav system problems
  174. You take the coupe, the wagon, and now our wreath?
  175. HELP: 2008 CTS 3.6 throwing P0300 and P0303 misfire codes and burning oil
  176. Adaptive cruse control for new cts
  177. OnStar MIA?
  178. CPO 2012 Sport Wagon Performance AWD
  179. Electronic Key Battery?
  180. Damn Texting and Driving!!!
  181. 2013 cts luxury awd 3.0 Global A Electrical Architecture or other?
  182. New here, first time Cadillac owner....
  183. 2008 CTS Pop Up Display Keeps Restarting
  184. ignition lock out
  185. Front license plate bracket - Home made
  186. throttle position sensor vs. commanded actuator position
  187. My warning lights for my tire monitor system, my ABS, traction control??????
  188. Bye, Bye To My CTS
  189. Tire pressure light, but tires are fine
  190. I was thinking of a 14 CTS Coupe ... But ...
  191. Replace 2011 cadillac cts coupe battery???
  192. Public attitude toward Caddies
  193. Help Please!!!
  194. Wheel/Tire Issue - Dealer can't figure it out. I turn to the forums
  195. Talk about good looking
  196. aftermarket heated seats
  197. premium care
  198. Brand of tires when new
  199. Wheel/Tire Question
  200. Have question on programing a proximity key
  201. 2011 CTS still under factory warranty, dealer can't fix stalling issue, now what?
  202. RHO Plate
  203. Free Shipping Offer: Cadillac Floor Mats, Car Covers and Merchandise
  204. Wagon Accessories
  205. CTS spare tire
  206. flloor mats?
  207. What's in your armrest?
  208. AUX Port Not Working
  209. 2008 CTS AWD DI stumbles and quits on acceleration from stop
  210. Brake failure 08 CTS
  211. Help! Trunk won't close!
  212. 2010 CTS sunroof leak
  213. Maserati Engine?
  214. USB music file format
  215. How to tell what year NAV maps are?
  216. tinted windows and NAV?
  217. CTS Wagon cargo tray part#19211370
  218. Hard Noise at left side when hard
  219. 2013 Cadillac CTS Coupe dead battery
  220. Manual Trans (AY6) wont engage reverse, any likeness to the transmissions from 03-07?
  221. different engines
  222. power steering prob.
  223. $100.00 reward!
  224. CTS transmission failure
  225. Are wheel bearings, hubs, really covered under warranty?
  226. 2010 CTS passenger front window fell down
  227. Nav Screen Won't Pop Up
  228. positive cts stories
  229. Phone dock - my way
  230. Changing mufflers
  231. First Impression of 2014 CTS Performance Wagon
  232. I hope Cadillac sees this Commercial
  233. 1st driving vaca with the CTS
  234. 2011 CTS AWD - Inadvertent Airbag Deployment - Recall ?
  235. need help. please O2 sensors
  236. Front Airbag Sensor
  237. Air Bag Light
  238. Car Shows
  239. GM to Fix Remote Link App & Vehicle Diagnostics Reports re: Tire Pressure
  240. GOOD NEWS!! CRC GDI intake cleaner
  241. fun cts story
  242. Highlights of Cadillac's plans for the 2015-17 model years
  243. Information on Spark plugs, PCV Orifice, Cabin Fiter
  244. Axle/spindle nut size
  245. 2009 Battery Draining
  246. Does Cadillac service including wheel alignment
  247. '12 Coupe new to me
  248. Door panels and door dings
  249. Drive shaft support bearing
  250. Goodbye CTS
