: 2008-2013 Cadillac CTS General Discussion
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
  1. No audio from radio/cd player
  2. Window rolled down by itself while I was driving and wont roll back up
  3. key chime and ignition switch problems
  4. Android/Spotify CTS
  5. Infor on the ONSTAR Hardware upgrade in Canada
  6. LED foot lights, where can i wire them to?!
  7. Seeking advice!
  8. Cooling fan
  9. Bluetooth
  10. 2008 CTS rear window won't go down
  11. Wiper Blade Question
  12. Stability Trak Problems
  13. 2008 CTS vibration
  14. Coolant flush 2008
  15. what are these parts and what are their function?
  16. Transmission oil relay fuse missing
  17. differential fluid
  18. Help 3.6 timing chain issue
  19. side mirrors tilting
  20. Tire Replacement
  21. Rear Wiper Delay
  22. Battery Going?
  23. Considering 2010 CTS Wagon: what do I look out for?
  24. engine oil thread
  25. 2009 CTS 3.6 DI Engine Vibration ??? Idle
  26. E&G rear bumper mesh - hold up over time?
  27. 2010 AWD premium rotor size?
  28. Urgent help.. 2008 or 2009 shifter/ manual transmission.
  29. HELP ! Just bought a 2009 CTS DI , Can anyone check the vin
  30. no data on screen
  31. Looking at a cts4 2008 di with couple issues
  32. california emission
  33. 2010 3.6 CTS Wagon 38,515 Km odom. Do I need a fuel injection , intake & thrott/servc
  34. Is there a USB size limit
  35. Anyone Have This?
  36. 2008 CTS base radio bose amp wiring diagrams needed
  37. Service Stabilitrak/Service Traction control
  38. Rustproofing your CTS
  39. 2008 CTS Transmission slip and failure
  40. HID - no high beam and flash
  41. 2008 Cadillac CTS key fob issue
  42. Help needed with upgraded radio cts 2008
  43. Transmission fluid change
  44. 2012 CTS Clicking Noise
  45. Headliner/Interior Cost Guesstimate 09 CTS
  46. Need some Serious advice...
  47. Anyone have C0045 and C0242 at the same time?
  48. HELP, Coupe stuck throwing TCM Code
  49. CTS 3.0L Manual - Any good?
  50. Third Brake Light
  51. No "OH SH!T HANDLE"
  52. I think i blew my engine
  53. sunroof leaks
  54. Fluids
  55. Brand new to Caddy and another Timing chain issue
  56. New member to the CTS forum.
  57. Brakes clicking when braking at low speeds
  58. Weathertech Fitted Floor Mats, 2010 CTS w/ Manual Transmission
  59. 2009 CTS repair inquiry and costs
  60. Buying tires made 7 years ago. Your opinions are much appreciated.
  61. Door won't open !
  62. Finally found 'The ONE'!
  63. Navigation system
  64. At Freeway Speed 2012 CTS 6 Cyl shudders, loses power, stalls, doors unlock . . .
  65. Day time driving light out
  66. Road Noise
  67. 2009 CTS Sport and Manual Modes not engaging
  68. speaker cover
  69. Radiator Fans On When car Starts - No engine code
  70. Is Your Car Oil Thirsty?
  71. Key not detected, ignition not turning
  72. TPMS - Is this possible?
  73. Temp control board
  74. MPG on a 2400 mile trip
  75. 2010 CTS shakes when braking but it is NOT the rotors
  76. 2011 3.6 AWD Temperature Gauge strange readings
  77. Injector Cleaner results
  78. Never say never
  79. 2008 CTS Gas smell from rear of car
  80. Coil Pack Question
  81. Is there glue on the sunroof drain pipes? if so what kind?
  82. Subwoofer Wires look cut
  83. Power Driver Seat Stopped moving forward
  84. OEM remote start kit for wagon - part# 22839317
  85. Tire Availabiity?
  86. 2010 awd premium wagon need help
  87. Need Help: 2009 life expectanct/Purchasing a 2009 CTS questions
  88. CTS HID DRL Broken Tab
  89. Found a CTS, pondering
  90. Cruise control
  91. Sunshade with Cadillac Emblem
  92. Cadillac CTS Wheel Bearing Sensor?
  93. need help... looking for cts 2008 rwd or awd? and Di or non DI?
  94. 2009 CTS Taillight not working but brake light is.
  95. Does anyone know what this fluid is?
  96. cts v rear reinforcement bar on non cts v
  97. Can a #1 Key Fob be programmed for the #2 memory position
  98. Mixing different brand tires on AWD Coupe
  99. 2009 Wheels on 2014?
  100. Wet where spare tire is? 2009 CTS4
  101. Radio Stays on After Door Opening
  102. CD Information on Bose
  103. What does CTS4 stand for?
  104. CTS coupe, damaged door interior
  105. New at this since don't participate in facebook, etc.
  106. 2012 CTS Premium Warranty Questions
  107. Where is the Bose Amp (Coupe)
  108. Stop the (soaking carpet) Insanity Forever! - Ultraview roof drain tubes
  109. 2009 CTS Premature Rust Aluminum Hood 3 Months Out of Warranty
  110. TSB 10-07-30-005a (Transmission output shaft and transfer case input "shearing")
  111. Vin Options Check
  112. Third brake light cover?
  113. 2009 CTS4 - musty smell, water
  114. New Member Hello and a Nav Update question
  115. Driver side carpet issue
  116. 2008 CTS4 Transmission and Transfer Case Input / Output Shaft issues
  117. Cts doors
  118. Service question
  119. 2010 CTS camshaft position sensor
  120. Man trapped in Corvette, dies if heat exhaustion - Coupe owners take note
  121. Steering Problems
  122. Random major down shifting
  123. How can you tell when your differential may need to be serviced?
  124. DIY: Ignition coil and spark plugs help
  125. I need a measurement to weld the upper tie bar
  126. gracenote update
  127. Traction control/ABS light is on....?
  128. Rain on the Center Console
  129. Hummmmmm - help diagnose humming sound
  130. Bluetooth music from devices
  131. Can dealer tell me how long codes have been in system...I think I got took!
  132. Brake pedal feel
  133. New member
  134. Best Replacement Wheel Bearings
  135. 2011 cts coupe reverse light not working
  136. 08 cts steering problem
  137. 3.0 AWD owners, anybody experience whine-whistle coming from engine around 2500rpm?
  138. New Owner, Some Questions
  139. 2012 CTS - evaluation and comments for buyer ???
  140. New CTS owner
  141. Pop Up stock display with an aftermarket unit?
  142. A singular seat problem
  143. Looking to Buy 2012 CTS AWD ... Just a Few Questions.
  144. 2009 CTS with less than 50,000 miles with Timing Chain problem
  145. AWD or RWD??
  146. How to reset new TPMS sensors?
  147. 2011 VCIM Programming for use in 2009 CTS?
  148. Anyone removed the front carrier on a CTS4?
  149. Vtc and resetting DIC???
  150. radio and bluetooth issues
  151. introduction
  152. Long road trip with no spare tire
  153. 09 CTS issue. ECM?
  154. Nav screen randomly blacks out
  155. Remote Start Recommendation
  156. Water In Floorboard Behind Driver's Seat
  157. Audio issue
  158. Chromaflair paints peeling after painting new fender
  159. Do I Really Need Premium Gas?
  160. dead battery
  161. Weird situation: Phantom oil leak?
  162. 2011 CTS Front Left Strut Sqeaking Noise
  163. just bought 08 cts extended warranty or no
  164. CTS sunroof leak issues
  165. 2008 Cadillac cts FCC id
  166. Another Newbie
  167. TECH II without CANdi module on an 08 CTS4
  168. Subwoofer?
  169. Goodyear RS-A2
  170. steering wheel emblem
  171. Upgrade to Remote Start on 2012 Base Coupe?
  172. Cadillac CTS 09 problem U0073
  173. door will sporadically not open from the inside or close when shut....
  174. Maintenance/Repair cost consideration or trade in.
  175. 2011 CTS coupe - Air bag control module location?
  176. New Guy
  177. Timing Chains UK Owners
  178. Nice report in MSN
  179. 2008 CTS A/C Drain Maintenance Tip
  180. windshield washer
  181. Deja Voodoo BMW-Style
  182. 2011 cts knock sensor p0333
  183. Green lights
  184. Traction Control
  185. part # of ignition tumbler on keyless ignition models?
  186. 2008 CTS Timing Chain - Dealer not sure if special warranty will cover repair
  187. Brakes screeching now
  188. Calling out HurstGN
  189. Navigation System
  190. OEM battery
  191. Ticking sound from under hood
  192. Seat exit/enter question
  193. 09 Lumbar support install
  194. P0008 Code
  195. Electrical Issue with Driver Door, Rear Right Passenger, and HVAC Panel Button
  196. High pitched whistle coming from???
  197. You MUST always check the dealers work...ALWAYS...
  198. Prospective buyer wants to know about maintenance
  199. Dragging feeling
  200. Bluetooth on 2010 cts won't turn on?
  201. Start problem After removing ECM fuse to clear engine code
  202. Its Happening!!! 2010 CTS Wagon
  203. 09 CTS low pitch rumble at speed
  204. I need instructions about how to remove the CTS driver's door panel
  205. KEYLESS ignition sticking in accessory mode
  206. engine coolant replacement
  207. Tire wear blow out replacement all or just the one?
  208. 2012 CTS makes squeaky gargling sound while driving
  209. dynamat
  210. Broken Tie Rod 2011 CTS 23k Miles
  211. Cyl #6 misfire/ multiple cyl misfire
  212. RPMs Surging Randomly in Sport Mode on 2009 CTS4
  213. 2010 CTS-4 Service Air Bag / Computer Resets when steering
  214. Front Bumper Misalignment (sides)
  215. Coolant leak
  216. Disappointed with new shocks - FE2
  217. 2012 CTS 3.0 starts without the key.
  218. Alternator DIC Voltage
  219. Front seat back release broken? How to get it out..
  220. MTBF 15 miles
  221. 2009 CTS Door Lock Issue
  222. 2009 CTS Passenger Door lock Problem
  223. 09 cts cooled seats not working
  224. Does anyone know if the dash/trim of the CTS (non-V) and the V are interchangeable..?
  225. How is the included Bose 8 speaker (Premium/Performance package 10 speaker) sound?
  226. 2010-2013 "Luxury" package and "Premium" package differences...?
  227. Looking for a new (used) 2008-2013 CTS - which years are the best...?
  228. Alternator
  229. I have a 2008 CTS DI with engine light on
  230. wiring diagram for CTS overhead console
  231. New to the Forum 2010 CTS Wagon 3.6 4
  232. 2010 CTS Outer Tail Light Lens Replacement
  233. 2011 CTS 3.0 Traction Control and TPS issue
  234. Noob intro. Finally got one.
  235. Where to buy EGR Valve
  236. Looking into a 2009 CTS
  237. Magnetic suspension
  238. 3rd brake light
  239. electrical issue - 2008 CTS
  240. CTS Sedan Leak.
  241. 2010 CTS Sedan Leaks
  242. newbie question on garage door opener
  243. Melting Coil Packs
  244. Rattle in rear end at certain speeds
  245. Car would not move
  246. 08 cts DI AWD traction control coming on for no reason
  247. Air Conditioner Clutch Not Engaging
  248. front turn signals
  249. 2008 Cadillac CTS LLT - Oil Ingestion Info
  250. wish they make this for our cars....
