: 2008-2013 Cadillac CTS General Discussion
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Back-up Cam Question Sort Of
  2. New to me 2009 CTS owner
  3. Stereo upgrade question? 2012- 8 speaker Bose
  4. Cadillac CTS Newbie
  5. 2010 CTS 3.6 Wagon Driver's side door wont open
  6. Front pan part number
  7. Wow - Just changed oil, and found NO POWER STEERING Fluid...
  8. Front end shimmy - I found the issue and it is scary
  9. High Mileage CTS?
  10. 2011 CTS Coupe - Headlights only work in "Auto"
  11. '12 CTS Coupe AWD- 18" Wheels...
  12. Buying a Third Wheel Hub Assembly, 2010 CTS
  13. Navi
  14. 2011 cadilac cts pcm location
  15. when changing airbags
  16. when changing airbags
  17. Oil on spark plugs - what's my engine trying to tell me?
  18. rear bumper bezel
  19. recall
  20. engine code issue
  21. What year used cts should I buy?
  22. 2010 CTS temperature up and down now controls the entertainment system!
  23. Wagons leave you drooling!
  24. iphone6,waze and bluetooth.
  25. 2012 CTS Headlight Assembly
  26. Heated Steering Wheel
  27. sunroof wind deflector
  28. Horn Blowing When Opening Hood
  29. Is this sound the purge solenoid ? (Video)
  30. 08 timing chain getting covered at 128k?
  31. 2008 Timing Chain Replacement
  32. 2008 CTS B2 AAA code
  33. High engine idle on cold start - normal?
  34. FE2 to FE1?
  35. Bluetooth question
  36. 2014 CTS Sport Wagon Luxury Edition...
  37. Wiper blade size
  38. Reverse tilt side mirrors
  39. Selling my 2014 CTS Performance Coupe
  40. I did it - new CTS owner in Czech Republic
  41. Is this sound coming from my engine normal ? (VIDEO)
  42. 2010 CTS Check Engine Madness! Help please!
  43. Alternator went out. Now more issues.
  44. Concrete Paint Scratch !!
  45. Adieu
  46. Accessory Position? Battery Dying?
  47. Transfer Case Issues... Poll
  48. timing chain
  49. Increase trunklid support pressure
  50. 2012 cts 3.6L original painted alum, previous owenr chromed 18" wheels. now pitted
  51. 2008 CTS AWD transfer case problem
  52. CTS Wagon battery
  53. 2012 CTS4 Coupe Whining noise on acceleration
  54. "Sport Mode" won't activate
  55. Coupe Performance Tires? Stick with different sizes?
  56. My 2011 CTS almost killed me
  57. J55 FE3 08 CTS, will 17" CTS wheels clear the calipers?
  58. Moisture in headlights - 2008 CTS
  59. Thanks for the info - 2010 CTS
  60. Best extended warranty post-manufacturer's warranty?
  61. Possibly trading the caddy.....
  62. Front Door Locks
  63. Center Stack Console Storage Cover Sticking - Only opens w/ Force
  64. Panoramic Roof Cover Dirty
  65. 20K mles!!! all is well!!!
  66. New iPhone 6 Issue, anyone else see this?
  67. Changing the (wood/carbon fibre) trim
  68. Static noise over radio when going over hard bumps
  69. Starting problems
  70. Wheel bearing/hub assembly covered under powertrain warranty for 2010 model year?
  71. Happy with Cue
  72. '09 CTS Hesitation & "Grinding" Noise after 800+ mi trip
  73. Is it time to sell my CTS
  74. how to remove oil filler tube?
  75. Problem with my audio
  76. Door switch/actuator?
  77. Anyone elses cts engine sound like this or is mine just loud ?
  78. straw that broke the camel's back (CTS Coupe)
  79. MORE problems - battery charging issue
  80. Missing USB port
  81. Electrical Issues
  82. '13 CTS Coupe tire change
  83. Price check on aisle 3......
  84. Tires & Wheels - allowable front/rear diameter mismatch?
  85. "Stabilitrak off, service stabilitrak, etc...
  86. Can't open front passenger door from inside or out
  87. Driver's seat control Relay, 2011, CTS sedan
  88. Location of Onstar module in CTS Sport Wagon
  89. start aborted theft deterrant
  90. CTS4 front diff acceptable play?
  91. no sound: speakers not working?????
  92. Fob cracking and coming apart
  93. Parcel shelf rattle
  94. Headlight Adjustment
  95. all gauges radio and a/c cutting off
  96. Certified Cadillacs
  97. New purchase 2010 CTS Wagon 3.0L AWD
  98. 2008 CTS Engine noise ? (Video)
  99. Intermittent no bass w/Bose.
  100. Very Rough Idle when AC on
  101. Is my 2011 CTS Coupe starter already going?
  102. The seat belt on the driver side isnt adjusting anymore
  103. Not sure if my 2009 CTS has bluetooth compatibility with my iPhone
  104. 2008 CTS and Site Newbie :)
  105. dash cameras, who uses them?
  106. Mobil1 5W-30 High Mileage Full Synthetic Motor
  107. The Shark is going in for major surgery
  108. Cruise control
  109. Timing Chain Issue
  110. 2009 CTS (timing chain problem)
  111. Navigation Update
  112. Trunk leak - 2011 Coupe with no sunroof
  113. Thump when backing up
  114. 2012 CTS Performance 4 Year Warranty Period
  115. 2009 CTS 3.6 DI - no crank, no start
  116. No audio from radio/cd player
  117. Window rolled down by itself while I was driving and wont roll back up
  118. key chime and ignition switch problems
  119. Android/Spotify CTS
  120. Infor on the ONSTAR Hardware upgrade in Canada
  121. LED foot lights, where can i wire them to?!
  122. Seeking advice!
  123. Cooling fan
  124. Bluetooth
  125. 2008 CTS rear window won't go down
  126. Wiper Blade Question
  127. Stability Trak Problems
  128. 2008 CTS vibration
  129. Coolant flush 2008
  130. what are these parts and what are their function?
  131. Transmission oil relay fuse missing
  132. differential fluid
  133. Help 3.6 timing chain issue
  134. side mirrors tilting
  135. Tire Replacement
  136. Rear Wiper Delay
  137. Battery Going?
  138. Considering 2010 CTS Wagon: what do I look out for?
  139. engine oil thread
  140. 2009 CTS 3.6 DI Engine Vibration ??? Idle
  141. E&G rear bumper mesh - hold up over time?
  142. 2010 AWD premium rotor size?
  143. Urgent help.. 2008 or 2009 shifter/ manual transmission.
  144. HELP ! Just bought a 2009 CTS DI , Can anyone check the vin
  145. no data on screen
  146. Looking at a cts4 2008 di with couple issues
  147. california emission
  148. 2010 3.6 CTS Wagon 38,515 Km odom. Do I need a fuel injection , intake & thrott/servc
  149. Is there a USB size limit
  150. Anyone Have This?
  151. 2008 CTS base radio bose amp wiring diagrams needed
  152. Service Stabilitrak/Service Traction control
  153. Rustproofing your CTS
  154. 2008 CTS Transmission slip and failure
  155. HID - no high beam and flash
  156. 2008 Cadillac CTS key fob issue
  157. Help needed with upgraded radio cts 2008
  158. Transmission fluid change
  159. 2012 CTS Clicking Noise
  160. Headliner/Interior Cost Guesstimate 09 CTS
  161. Need some Serious advice...
  162. Anyone have C0045 and C0242 at the same time?
  163. HELP, Coupe stuck throwing TCM Code
  164. CTS 3.0L Manual - Any good?
  165. Third Brake Light
  166. No "OH SH!T HANDLE"
  167. I think i blew my engine
  168. sunroof leaks
  169. Fluids
  170. Brand new to Caddy and another Timing chain issue
  171. New member to the CTS forum.
  172. Brakes clicking when braking at low speeds
  173. Weathertech Fitted Floor Mats, 2010 CTS w/ Manual Transmission
  174. 2009 CTS repair inquiry and costs
  175. Buying tires made 7 years ago. Your opinions are much appreciated.
  176. Door won't open !
  177. Finally found 'The ONE'!
  178. Navigation system
  179. At Freeway Speed 2012 CTS 6 Cyl shudders, loses power, stalls, doors unlock . . .
  180. Day time driving light out
  181. Road Noise
  182. 2009 CTS Sport and Manual Modes not engaging
  183. speaker cover
  184. Radiator Fans On When car Starts - No engine code
  185. Is Your Car Oil Thirsty?
  186. Key not detected, ignition not turning
  187. TPMS - Is this possible?
  188. Temp control board
  189. MPG on a 2400 mile trip
  190. 2010 CTS shakes when braking but it is NOT the rotors
  191. 2011 3.6 AWD Temperature Gauge strange readings
  192. Injector Cleaner results
  193. Never say never
  194. 2008 CTS Gas smell from rear of car
  195. Coil Pack Question
  196. Is there glue on the sunroof drain pipes? if so what kind?
  197. Subwoofer Wires look cut
  198. Power Driver Seat Stopped moving forward
  199. OEM remote start kit for wagon - part# 22839317
  200. Tire Availabiity?
  201. 2010 awd premium wagon need help
  202. Need Help: 2009 life expectanct/Purchasing a 2009 CTS questions
  203. CTS HID DRL Broken Tab
  204. Found a CTS, pondering
  205. Cruise control
  206. Sunshade with Cadillac Emblem
  207. Cadillac CTS Wheel Bearing Sensor?
  208. need help... looking for cts 2008 rwd or awd? and Di or non DI?
  209. 2009 CTS Taillight not working but brake light is.
  210. Does anyone know what this fluid is?
  211. cts v rear reinforcement bar on non cts v
  212. Can a #1 Key Fob be programmed for the #2 memory position
  213. Mixing different brand tires on AWD Coupe
  214. 2009 Wheels on 2014?
  215. Wet where spare tire is? 2009 CTS4
  216. Radio Stays on After Door Opening
  217. CD Information on Bose
  218. What does CTS4 stand for?
  219. CTS coupe, damaged door interior
  220. New at this since don't participate in facebook, etc.
  221. 2012 CTS Premium Warranty Questions
  222. Where is the Bose Amp (Coupe)
  223. Stop the (soaking carpet) Insanity Forever! - Ultraview roof drain tubes
  224. 2009 CTS Premature Rust Aluminum Hood 3 Months Out of Warranty
  225. TSB 10-07-30-005a (Transmission output shaft and transfer case input "shearing")
  226. Vin Options Check
  227. Third brake light cover?
  228. 2009 CTS4 - musty smell, water
  229. New Member Hello and a Nav Update question
  230. Driver side carpet issue
  231. 2008 CTS4 Transmission and Transfer Case Input / Output Shaft issues
  232. Cts doors
  233. Service question
  234. 2010 CTS camshaft position sensor
  235. Man trapped in Corvette, dies if heat exhaustion - Coupe owners take note
  236. Steering Problems
  237. Random major down shifting
  238. How can you tell when your differential may need to be serviced?
  239. DIY: Ignition coil and spark plugs help
  240. I need a measurement to weld the upper tie bar
  241. gracenote update
  242. Traction control/ABS light is on....?
  243. Rain on the Center Console
  244. Hummmmmm - help diagnose humming sound
  245. Bluetooth music from devices
  246. Can dealer tell me how long codes have been in system...I think I got took!
  247. Brake pedal feel
  248. New member
  249. Best Replacement Wheel Bearings
  250. 2011 cts coupe reverse light not working
