: 2008-2013 Cadillac CTS General Discussion
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
  1. Strange cord hanging from headliner
  2. Sunroof leakage filling up tray under glove box
  3. 2012 CTS Front Door Switch
  4. any gm technician near antioch illinois need help with 09 cadillac cts
  5. Cooling Fan Help 11' Coupe
  6. Brake pins.
  7. AC leakage - no cooling
  8. Finally Bletooth!
  9. How to remove or replace the under hood fuse box 2011 cts sedan
  10. CTS Service Stability control, Service traction control.
  11. LTR and AUX PWR Fuses Blown
  12. 2009 Tail light vertical 'light bar" went out tonight.
  13. Need Help with Check Engine Light and Code P0030
  14. Rusty Metal noise when I apply brakes
  15. maintence schedule - 2012 CTS
  16. help factory warranty expires is three days . its at the dealer today
  17. last three days in factory bumper to bumper warranty help
  18. Scratches / marks on my cts body
  19. Dash says "Engine overheating, Shut off A/C"
  20. New 08 owner
  21. 2008 CTS 8 Speaker Bose Question
  22. No fog lights ?
  23. Questions about TPMS - tire pressure monitoring SENSOR
  24. Need Transfer Case Fluid Drain/Fill Procedure for AWD
  25. Where is the sticker with the RPO codes located?
  26. Just Purchased 2012 CTS Sedan Used .. Few Questions
  27. 2009 AWD GDI Premium Performance, noise and traction control light on right turn
  28. Rear window stopped working after I removed door panel
  29. to extend warranty or not?
  30. Nav system keeps shutting off
  31. 2009 non V CTS Suspension Creaks
  32. 2009 2wd CTSsedan Best Jacking Peoceedure
  33. New CTS 2013 Owner - Random Questions
  34. 2008 CTS headlamp bulbs - New guy needs help
  35. Brake pads need changing
  36. What size bit to remove rotors - 2011 CTS
  37. Rear door won't open
  38. Clutch smell CTS 2008
  39. 2011 CTS AWD loud rapping noise in tunnel when turning left
  40. Where to get a trunk net
  41. P0008 comes on and off
  42. Transmission leak
  43. 08-09 cts4 under carriage wash?
  44. Sound system doesn't read all the songs I downloaded.
  45. Codes P0087 & P0089 ( engine power reduced ) please help!
  46. Roof Rack for 2009 CTS?
  47. Instruments/NAV/Audio Screens Too Dim to Read
  48. Connect Your CTS!
  49. Rear window went down by itself and won't go up? Got it to go once?
  50. Keyless Entry Intermittent Issues
  51. Is it worth it
  52. Whistling Noise
  53. Front seat removal
  54. Question for Nav equiped car owners
  55. Key not detected
  56. Rear window in coupe showing lamination
  57. Brakes [Formerly "Breaks"]
  58. My Caddy is not good for me...
  59. Access front audio speaker
  60. 2010 CTS 3.0 Manual Trans problems
  61. Looking At Buying 2013 CTS
  62. CTS -08 2.8 V6 Only in Europe?
  63. Spark plugs
  64. CTS4 steering shakes for first ~1km and smooths out
  65. P0008, AGAIN, and slow acceleration
  66. Water dripping from front overhead console
  67. 09 Cadillac CTS BOSE Wiring harness pins?
  68. Suspension Question???
  69. Wet floor board
  70. Used 2009 AWD won't start - help with troubleshooting!
  71. Suspension feels "bouncy" after trans repair
  72. New Bose Amp, Dealer Programming Needed?
  73. rear tray trunk side naked
  74. Window Gets Stuck After it Rains
  75. Nav questions
  76. Need to run a few things by you guys.
  77. New exhaust supply issue for 2012 CTS 4-dr sedan
  78. 2011 creak in steering
  79. 2009 CTS Brake Parts
  80. cheaper alternative for Falken FK 452 tires
  81. CTS 2008 3.6 VV-T "tack" noise
  82. Want a caddy
  83. front axle nut torque
  84. Relearn TPMS with aftermarket key fob.... Help please...
  85. Shift to park?
  86. Shift to park?
  87. Keyless Unlock broken
  88. My First Caddy Yall
  89. Water pump
  90. Long delay in getting 2012 CTS Sedan exhaust pipe replaced
  91. Aftermarket Extended Warranty
  92. Clicking Noise at Speed
  93. Debating a used 2011-2014 CTS Coupe - Any issues/things to know?
  94. Aux Pwr
  95. Features questions
  96. Is this trim on correctly?
  97. Connecting OEM rear camera to aftermarket head unit- questions?
  98. Windows went down during car wash!
  99. Just picked up a 2013 CTS4
  100. Chemical smell in HVAC
  101. New here with an 2013 CTS
  102. Newest on the 6L90 2->3 gear flare?
  103. Jeans rubbing off on New 09 CTS Seat
  104. how much should i pay for a 2010 cts4 with 5,557 miles like new 3.0l trans 6spd auto.
  105. How do I reboot my 2009 CTS
  106. Spring servicing
  107. exhaust smoke at idle, plume at WOT
  108. More than condensation
  109. '09 CTS Windshield Wiper Blades
  110. Engine stumbling while door locks cycling?
  111. Cracked Flywheel
  112. Using navigation without other audio
  113. Battery instantly dead
  114. Storage issue
  115. 2009 cts 3.6l di - possible fuel injector replacement?
  116. Drivers side mirror problem after door electric work
  117. Water pump bolts
  118. FE1 to FE2 suspension change
  119. need help Hid headlight problem
  120. Wagon liftgate opening by itself
  121. 08 CTS suspension removal
  122. Found Headlight water/moisture FIX
  123. Build date
  124. Please advise where to purchase reasonably priced J55 pads and rotors.
  125. P0008 & P0496 after winter storage
  126. loud vibrating
  127. Problem with airbag sensor passenger seat
  128. 2008 cts with nav
  129. After Market Alarms
  130. Headlights not working when headlight in "On" position but work on in "Auto" 2011 CTS
  131. AUX port & No USB Port, What are my options? (2012 CTS)
  132. Key Stuck in ignition
  133. Red fluid on the under cover?
  134. Service Traction Control
  135. shoot out of the cannon
  136. ....and more problems 2010 cts4
  137. Change headlight direction for left-hand traffic?
  138. cleaning your key fob
  139. Unresponsive AC buttons after water leak
  140. Catalytic converter replacement
  141. 2009 CTS4 Bad Vibrations
  142. 08 CTS - Back passenger window randomly gets stuck down - usually after rain.
  143. Location of Onstar Module?
  144. CTS Wagon Questions.
  145. 2013 Coupe window?
  146. seat6 belts
  147. Door actuators won't work quick fix
  148. New Metra kit for aftermarket stereo??
  149. OnStar app
  150. 2008 CTS Beeping sound
  151. Trunk release not working.....
  152. car has rough idle, misfire codes
  153. Option Packages/Trim Levels
  154. rear pads
  155. Said goodbye to my CTS.
  156. Cruise Control Intermittent Malfunction
  157. BUILD THREAD: Slammed 2010 CTS Wagon V6
  158. CTS 2010 Overheating Problem
  159. 2010 CTS sedan 3.0 bearings
  160. Thinking about purchasing a 2008+ CTS...Does Cadillac still overheat?
  161. BOSE Sound System issues Help please
  162. Air Conditioned Seat Issue
  163. Dash lights up like a Christmas tree
  164. outside temperature display sometimes "gets stuck"
  165. VIN Number Search Information
  166. Serpentine belt
  167. Sad to say ... selling the CTS
  168. Just purchased an '11 CTS 3.6 Performance.....
  169. Tire Wear Issue - 2010 CTS4 w/ 65,000 mi.
  170. Wheel paint code
  171. 2010 CTS Problem Programming DIC
  172. Wheel Bearing/Hub replacement CTS4 Fronts
  173. 2012 CTS Drivers Side Sill/Scuff plate
  174. Suspension Grease Fittings
  175. Sunroof Tint
  176. Major transmission failure risk
  177. What can I do - 2008 CTS BCM problems
  178. 2011 CTS: bangs between second and third on upshift (only after driving for a while)
  179. 2013 CTS 3.0 Rough idle?
  180. Heavy duty brakes, bullshit?
  181. Have some damage under the front of my 2009 and not sure what I am looking at...
  182. Car sounds like it has mud tires.
  183. Android in my CTS!
  184. Did the door actuators/anti-theft change in 2011??
  185. Tire Sizes
  186. 2010 CTS - unusual noise when turning steering wheel
  187. How do I know which Tire Pressure Monitor Sensor to get?
  188. known issues for a 2010 3.6 AWD CTS?
  189. 2010 CTS4 Rear Camber Adjustment?
  190. Need help bad... Changed #6 plug and coil. Runs worse.
  191. Service Parts Identification codes
  192. 09 DI 3.6 AWD Tranny Hanging
  193. will this engine swap work?
  194. New here with a 2010 cts4 premium
  195. bg k44
  196. DIC error messages came up today!
  197. Navigation System Malfunctioning
  198. has anyone had remote start issues in the cold weather?
  199. CTS 2013 woofer upgrade
  200. Oil pressure gauge acting up
  201. Tsk Tsk Cadillac (Leaking Sunroof Revisted)
  202. has anyone came up with a fix for the radio that reboots itself NAV
  203. Free Onstar - 3 Months
  204. Passenger Front wheel bearing assembly replacement
  205. Can you prevent the nav screen from coming up?
  206. Owner's Manual pages missing
  207. Extended Warranty from AMT Warranty Corp
  208. Best way to lift.....
  209. transmission
  210. Shock Absorber Replacement
  211. Bluetooth acting weird
  212. 2008 CTS Starter Issue
  213. 2010 wagon rear washer not working
  214. Buying a Cadillac, Looking for some answers!
  215. Turn Signal Problem
  216. Which TCM for 08 CTS ?
  217. 2010 FE2 shocks/struts
  218. parking assist failure
  219. white color exterior choices
  220. The real blame for Tinman's Blown Engine?
  221. Strange Headlight Problems
  222. Ignition Coil
  223. Time For Brakes...Best Price?
  224. fuel door does NOT OPEN
  225. Bluetooth question
  226. 2nd gen driveshafts/issues and concerns
  227. Timing Chain Noise at Start Up
  228. 2012 CTS4 3.6 (AWD) "popping" over passenger rear tire
  229. New to the cadillac family
  230. He's Dead, Jim!
  231. New member, what's going on with my caddy?
  232. 09 cts hesitation issues
  233. Looking to buy
  234. Cadillac CTS 2010 (Service Tire System Message)
  235. Fluid Change Intervals?
  236. Reduce power
  237. Engine Vibration when car in gear standing still.
  238. 2012 DI AWD Coupe Oil Leak
  239. 2011 CTS coupe seat gets stuck half way when moving forward
  240. What on earth is going on with my Transmission Fluid Change/Refill...
  241. "Service Theft Deterrent System" display comes up and I can't start my car. HELP! CTS
  242. String Melting/Burning Plastic Smell
  243. 2010 CTS Wagon Tail Lights
  244. Either I'm picky...or I got a lemon!
  245. EPA Seeks to Prohibit Conversion of Vehicles Into Racecars
  246. 2011 CTS Sport Wagon roof bar removal
  247. ECM Bad or Not? Challenging Question!
  248. Front end noise over small bumps (solved)
  249. looking for stock used springs
  250. trunk won't auto unlock sometimes
