: 2008-2013 Cadillac CTS General Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
  1. Replaced battery on FOB(s). They now will not work at all - 2012 CTS
  2. $515 for Transmission Fluid Leak?
  3. Reset stereo VIN in 2008 CTS
  4. Who lives on long island ny
  5. Sticky Door Locks - And Door handle woes
  6. Mtx re-q5 install help please
  7. new to forum. 2013 cts questions
  8. 100K Service Items
  9. After getting gas cts 2012 fob is dead can't get into car 10 min it starts to work
  10. 2009 CTS Oil Pressure Sensor
  11. Special tools ? for Hub Removal
  12. garage door opener - operating range very short
  13. Headlights quick dim at low RPM's
  14. Full code scanner recommendations
  15. Power steering pump replacement
  16. The Pimp comes home with a question.
  17. oil smell inside cabin from catch can
  18. Heated windshield spot?
  19. Coolant smell
  20. Forum problems
  21. 2011 CTS Luxury Sedan Question
  22. Need help with Cruise Control Switch in my CTS 2010
  23. Console and radio died
  24. Radio reset
  25. My Cross-Country Journey To Bring Home a 2012 Cadillac CTS Premium Sport Wagon
  26. USB Retained Power?
  27. Music Navigator Question - New User
  28. Winter tires and transfer case.
  29. 2009 Physical Key Doesn't unlock door???
  30. Water in trunk id
  31. Interior door handle doesn't work Intermittently
  32. Sunroof noise
  33. 2012 CTS4 Headlight - need help with light out
  34. 2011 cts coupe - Service Stabilitrack after running over a curb
  35. 2009 Locked Out After Remote Start??
  36. Remote start
  37. Coupe wheels on a sedan?
  38. Bummer!
  39. New member
  40. 2013 Key Fob Programming
  41. GM Oil Life Monitor Explained
  42. Losing Oil through my egr tube
  43. Driver seat heat doesn't-2011 CTS Coupe
  44. Do I have a Premium Coupe or a Performance coupe?
  45. Worth of CPO vs non CPO
  46. Dumb transmission question.
  47. Rear bumper better than I expected
  48. What's the best smartphone mount available for the 2nd Generation CTS?
  49. Oil life interface questions
  50. 32K miles and I'm leaking already!!!
  51. New 2k8 CTS4 owner, having some issues.. venting & questions inside, plz bear w/ me.
  52. 2008 CTS - Replacing Trunk Lift Support Struts
  53. Trouble cold starting
  54. Got the 2016 Nav Update
  55. New to site - 2008 CTS Iphone Dock ?
  56. idleing low
  57. Were you sent the wrong Navigation disc this year?
  58. Startup After New Battery 2010 CTS Wagon
  59. How well does the OnStar app work?
  60. EVAP Leak
  61. abs c0040
  62. What do I do?
  63. Car Stuck on Road for New Years, Please Chime In.
  64. 2011 CTS build sheet
  65. Replaced 2009 sedan with 2012 coupe
  66. a little tip for replacing broken plastic clips on the engine bay dress-up covers
  67. Looking for New Shocks
  68. 2008 CTS AWD V6...... wheel
  69. To buy a 2013 coupe or not. Very torn
  70. Trunk won't open
  71. FE3 suspension wheel hub/bearing
  72. Coupe Door computer malfunction???
  73. Winter storage
  74. Dangnabbit- It happened again - driveline bolts came loose.
  75. Dash Cam installation; Wiring - 2010 CTS Sedan (3.0 Luxury - with Sunroof)
  76. squeaking
  77. 2010 CTS4 Maintenance Brake Assist and Stabilitrak Warning.!!
  78. Torx bit size? Changing Rotors
  79. Vibration After Incline?
  80. Parking assist module location?? For 2008 cts
  81. Can I convert from HID to Halogen - what's involved Please Help
  82. RockAuto Closeout Deals!!!
  83. Looking for 2009 CTS RH Side Front Fog Lamp Bezel
  84. 2009 Remote Start Quirk
  85. New to me car…(short story)
  86. Possible overheating causes??
  87. Passenger side HID Headlight Replacement Help
  88. Center arm rest removal on 2010 CTS Performance?
  89. EU infotainment version, take 2
  90. '13 radio/w.nav problems
  91. Water Pump + Water Outlet Pipe
  92. White smoke at WOT
  93. Using a 3rd Gen CTS FOB on a 2nd Gen
  94. Battery replacement
  95. Tire Pump Repair System
  96. Intermittent backfire during cold starts
  97. Can the front license plate bracket be removed without leaving holes?
  98. My 2009 is gone, thinking about a 2012 or 2013
  99. 2013 CTS Stereo Wiring Help Needed
  100. 2009 CTS AWD Rear Carrier Replacement question
  101. bulb #
  102. CTS battery terminal connection
  103. Front end creaking loud when applying brake at stop.
  104. Drivers Side Heated Seat not working
  105. Dash board (p,r,n,d went out)
  106. Steering wheel/ gear shift handle vibration
  107. Audio Problem — System Can't Read Some Songs
  108. Trans Flush VS proper fluid and filter change?
  109. Still under factory warranty, but denied for 2 issues
  110. wheel alignment camber/caster tool alternative?
  111. Turn lights and Hazards stopped working after bandaid trunk latch/release 2011 cts
  112. Cashmere interiors anyone?
  113. driver side carpet soaking after rain
  114. Interesting Finding
  115. 2011 CTS 3.6DI Cooling Fan Issue
  116. Hesitation
  117. new tires in the rain?
  118. Significant chassis differences between AWD and RWD?
  119. cant find oil pressure sensor
  120. Winter in Wi. and planned mods.
  121. 2008 CTS front dashboard speaker removal
  122. Water Pump
  123. Knock/backlash while acceleration on low speeds
  124. 2010 CTS Exterior Mirrors
  125. Corner Lights won't shut off?
  126. 2013 door mirror- remove glass mirror?
  127. 08 CTS High Beam issue
  128. Winter in Chicago is Approaching: Best Tires for 2011 CTS?
  129. posssible base bose problem
  130. Really really really
  131. Car jerk Crazy from 60 to 80 mph
  132. 2011 CTS & iPhone 5 — Sudden Bluetooth Problem
  133. 2008 CTS 3.6L DTC P0430 Catalyst System Efficiency Below Threshold Bank 2
  134. EVAP/Purge Valve clicking diagnosis
  135. 2008 CTS 3.6L Clicking noise comming from device that is in-line with fuel line
  136. How hard is it to Replace the drivers side motor mount on 2008 CTS AWD
  137. P0301 and Service Traction Control showing in DIC
  138. weird stuff
  139. Hiccup?
  140. Latest European map base version?
  141. Driver's seat goes to drive position too soon
  142. Apple Music via GM Dongle
  143. Key fob stopped working (5 buttons)
  144. Removing Window Tint
  145. Airbags light ! CTS 2012 3.6
  146. Sport Wagon sunroof leak ruined Bose sub woofer
  147. Bluetooth is in french
  148. 2009 cts navigation upgrade
  149. Selling my '12 Silver coupe...
  150. front differential Whyne noise.. solved
  151. Metal on metal noise but only when turning?
  152. Shakey idle
  153. Trade in values say... WHAT? Resale?
  154. Gas Cap...CEL?
  155. 2011 CTS-4 Ride Quality Question
  156. Noise from underneath...
  157. Dome on top od dash pad.
  158. Different versions of backup cameras
  159. Garage Pic
  160. 2011 cts coupe stripped output shaft
  161. Do trans indicators in center console illuminate with lights on?
  162. after market rotors and pads bedding.
  163. Hub Bearings + speed sensors
  164. Spark plug change
  165. Taillight leaking issue??
  166. 09 cts won't start.
  167. 2012 CTS Sport Wagon Stance Question(s)?
  168. Picked up 2013 Performance Sedan..already an issue - high oil pressure
  169. CTS Maintenance Not in the Owners Manual - Help?
  170. Starting 2011 Coupe with Broken Fob
  171. Anti Theft Service - Not Starting
  172. Fob / Key programming.
  173. CTS 2008 - water on floor
  174. What's included with 2012 performance package?
  175. How reliable are 2nd gen CTSs? Older years in particular.
  176. CTS Manual Aisin 6 Speed No Reverse and Sloppy Forward Gears
  177. ABS and Traction Control lights on but can't find problem
  178. 08 cts performance package tire size
  179. Hauling bikes with the Sportwagon
  180. Battery Replacement
  181. No sound from my speakers,when radio is off a tap tap sound is constantly
  182. noisy door lock/unlock
  183. 2009 3.6 DI won't start after fueling
  184. RKE transmitter, key access programming issues.
  185. Can I Downgrade from HID Adaptive Headlights to Poverty Model Headlights?
  186. oil filter housing
  187. Sport mode issue on 2012 coupe
  188. Odometer and other readings stuck
  189. Adding Bluetooth Streaming Audio and iPhone Lightning audio connectivity to my CTS
  190. passenger door issue
  191. Fuel Gauge Problem?
  192. 2012 CTS disconnected battery to change driver seat cover abs traction control light
  193. CTS coupe
  194. Strange issue...battery
  195. Looking to buy a Wagon
  196. rear backlight
  197. Tire wear - Why?
  198. To ship, or not to ship.
  199. White smoke...
  200. HIDs shut off after engine start
  201. Navigation ends before actual arrival
  202. Decisions, decisions - 2010 CTS 3.0 ???
  203. 2010 CTS making clicking noise from passanger vent
  204. Cts dome light issue
  205. Dome light problem
  206. Can you set the timing on a 2009 CTS 3.6DI without removing the timing chain covers?
  207. 2012 CTS Lux with aesthetic issues
  208. dif oil
  209. Passenger airbag on/off light stays on all the time
  210. Has anyone replaced their cd/dvd/nav unit with a used replacement: 2011 cts
  211. DIY 2012 Cadillac 3.6l CTS Coupe oil change
  212. 2013 CTS Coupe First Impressions (and first post)
  213. 3rd Gen Tech vs Ours?
  214. Have you gotten P0008?
  215. RH speakers cutting out intermittently
  216. Tpms 2008 cts
  217. Used 2008 service contract advise
  218. AWD feels like it is binding during low speed turns
  219. Service Stabilitrak soon after hitting a curb and knocking wheel out of alignment
  220. What do you guys plan to do in the winter this year for traction?
  221. Put new radio in now car won't start!! Any Ideas??
  222. Common 3.6 oil leaks?
  223. engine flush
  224. Electrical & Engine Problems - 2011 CTS Coupe 3.6 Premium
  225. Crankcase Ventilation System
  226. Rear end/suspension, gen1 vs gen2
  227. No heat on driver's side
  228. Jerky steering
  229. MSM fuse blowing with nothing happening
  230. Differences between Base and Luxury Model CTS
  231. CTS DI Smoke & Oil level
  232. Kicker 12" l7 solo-baric
  233. New member. Can't wait to pick up my CTS
  234. The door lock diagnosis
  235. Resetting mile counter for oil....
  236. buying extended warranty AFTER original warranty expires
  237. Is Mobil 1 still synthetic oil of choice...
  238. Air filter recommendations?
  239. Extended warranty question
  240. Hdd replacement?
  241. Wagon Tail Lights
  242. CTS Rock Auto Closeout Parts
  243. Any reason why...
  244. Tranny mount bolts? and slight rattle?
  245. Console USB port not charging Droid 4
  246. Aftermarket Wheel Fitment
  247. NAV stuck on hang up screen - was a solution ever found?
  248. 2008 CTS intermittently will not start
  249. front & rear badges p/n
  250. Is it normal for the needle to move alot?
