: 2008-2013 Cadillac CTS Performance Mods
Pages : 1 [2] 3 4
  1. Vmax iceolator
  2. Does air intake void warranty?
  3. 2012 cts coupe awd
  4. how much is too LOW FOR 20" RIMS before i rub the front fender 08 cts sedan
  5. Suggestions for other Performance Mods - 2011 CTS Coupe 3.6l (RPO LLT) RWD
  6. CTS 3.6l Question on the intake will it fit?
  7. 09 CTS 3.6DI AWD Exhaust (GM Perfomance)
  8. Rusted magnaflow after 4 months
  9. Exhaust port rattle?
  10. Power steering
  11. Tuner
  12. What lowering springs to buy Eibach, H&R or D3?
  13. Chevy Performance Parts for Coupes
  14. Power
  15. 2010 cts low fuel warning??
  16. CTS4 AWD owners
  17. Which CTS
  18. CTS Help
  19. Anyone Looking for a Paddle Shift Setup?
  20. Catch can alternative options
  21. Building the CTS I really want
  22. Volant CAI 2010 3.6l
  23. Local dealer "stay away from K&N"
  24. Trifecta Tune Questions
  25. Suspension mods; what can i expect?
  26. My 2010 CTS4 Sport Wagon brake upgrade
  27. Catch Can?
  28. Front Strust/shocks
  29. HELP... Evap Code wont pass Emissions
  30. Excited about today - triffecta tunning
  31. CADILLAC CTS Stainless Cat-Back System Questions?
  32. Custom Exhaust?
  33. HID Headlght Upgrade Question
  34. Which of these two are the better performing UHP A/S tire?....
  35. New Cold Air Intake
  36. 2009 CTS trouble with acceleration on the highway, 115K, need help
  37. Cadillac 2008 radio vin relearn problem
  38. Cadillac CTS Intake System
  39. Misfire fix however
  40. 2013 CTS Coupe & Sedans cannot be ecu tuned???
  41. Alternator issue maybe?
  42. Where to get an LSD?
  43. CTS-V Sway Bars..Will they fit the 6 cylinder Models?
  44. Another Fix It FYI---Loose Drive Shaft Bolts
  45. 08 135k mi CTS 3.6DI project- how would you "mod/rebuild" it?
  46. thermostat on an 08 CTS
  47. Cutouts Installed
  48. 2012 cts with rust?
  49. 2008 3.6 DI Multiple Misfire Fix FYI
  50. CTS DIY maintenance; easy?
  51. G-Force Performance Chip
  52. 2010 cts and iphone 5s not working
  53. Enough with the Bull S%$
  54. CAI Recommendations?
  55. 1st Gen CTS-V Brakes on a 2nd Gen CTS
  56. Off the wall v8 swap question...
  57. I can hear the door unlock but it wont open without the key 2009 CTS
  58. 2011 Manual Dyno Numbers
  59. Roots Blower?
  60. Help Needed - FE1 to FE2 Suspension Change Out.... PART NUMBERS REQUIRED
  61. 2008 cadillac cts engine cradle
  62. Loved my SRX so much I bought a 08 CTS4 last week
  63. Spark plug Gap size?
  64. 20" pros and cons
  65. RevXtreme products?
  66. Brembo with cross drilled/slotted rotors installed
  67. Differential in 2010 3.0L?
  68. Any love for the 3.0's?
  69. LS powered CTS?
  70. CTS forced induction
  71. What is the diameter of the exhaust pipe?
  72. AWD wagon exhaust ?
  73. exhaust for 2011 cts 2door awd 3.6 liter
  74. Cross drilled rotors for coupe?
  75. 2012 CTS 3.6 AWD Wagon performance upgrade
  76. Air intake!
  77. LFX PORTED THROTTLE BODY ( for 3.6 from Vmaxmotorsports ) FOR SALE - $ 250
  78. How do factory brake cooling ducts on 2008+ CTS non-v attach to foglamp bezel?
  79. 2010 CTS 3.6 engine oil air vapor catch can install
  80. Breather for Oil Fill Cap
  81. hi new member looking to buy a supercharger
  82. Cold Air Intake for my 3.6 CTS (2009)
  83. 2012 & 2013 LFX engine Tubro system, $6900 complete installed & dyno tuned
  84. "Free" Mods
  85. 2010 cts sedan 3.0
  86. Flow master super 40 or 44 or magnaflow
  87. Are "Mods" even worth it in real world appications???
  88. CTS Coupe 2012 AWD Thumping When turning
  89. Top mounted Supercharger
  90. Sway Bars
  91. removing magnaflow performance exhaust
  92. Attention any magnaflow users
  93. 13 CTS Coupe remote start problem
  94. Avoid The Dreaded Drone
  95. Catch can
  96. Cadillac CTS Navigation Update Failure......!
  97. CTS coupe VS ????
  98. 2008 / 2009 factory exhaust setup view from underneath?
  99. H&R Springs -- confused about "claimed" drop *pics*
  100. JE5 vs J55 Brakes
  101. I have a 2008 CTS 3.6L no DI what is a good starter upgrade to boost performance?
  102. 3.6l v6 24v mpfi dohc vs 3.0l v6 24v gdi dohc
  103. Attention everyone interested in v6 FI
  104. 2013 CTS Incentives
  105. 2013 CTS Nvigation
  106. oil gauge maxes out and
  107. Warped rotors and need some more juice
  108. Cold air intake for 2012 CTS coupe?
  109. Cadillac CTS 3.6L V6 263HP oul burninf!!! HELP!!! No warranty!
  110. Fitch fuel catalyst for cts?
  111. Weird vibration on my CTS
  112. Easy mod for a beginner
  113. Cts lease return
  114. affordable coilover alternative
  115. 2009 CTS Battery Drain ( Disappointed with Cadillac reponse)
  116. 2012 cts 3.0 awd
  117. Summer Special - CTS Intake and Tune Package
  118. Actual exhaust size 3.6DI
  119. 2010 CTS performance mods???
  120. 011 CTS AWD exhaust options??
  121. performance mods.. anything else to make my car faster? HELP!!
  122. [DIY] Install CTS-V Brembo Brakes on CTS (Part 4, REAR)
  123. What exhaust do you recommend for my 13 V?
  124. Steering wheel mounted shift buttons
  125. D3 Competition Sway Bar Kit (Back in stock!!!)
  126. Exhaust questions
  127. 2012+ Airraid CAI
  128. Will They Fit?!
  129. Rotor/Pad recommendations for '09 CTS4 with Sport Suspension Option
  130. rev pops
  131. New navigation software
  132. Mod Idea
  133. 2010 CTS Performance Build Sheet or Window Sticker
  134. [DIY] Install CTS-V Brembo Brakes on CTS (Part 1, GETTING STARTED)
  135. [DIY] Install CTS-V Brembo Brakes on CTS (Part 2, DISASSEMBLY, FRONT)
  136. [DIY] Install CTS-V Brembo Brakes on CTS (Part 3, INSTALL NEW PARTS, FRONT)
  137. Mod question
  138. CTS Performance upgrades 3.6 DI
  139. Help needed to select EBC Brakes - 2010 cts premium
  140. 2009 cts: Persisteng leaking roof even after being served twice by ed morse cadillac
  141. Aiiraid CIA problem
  142. Ceramic Brakes for Heavy Duty Brakes?
  143. Repacing just the stock mufflers? (not complete catback kits).
  144. Magnaflow exhaust installed on a 2010 CTS ADW
  145. LFX Catch Can Help
  146. How much difference do headers make?
  147. D3 Air Intake - Sounds Sweet
  148. Stock Exhaust tweeks?
  149. Best exhaust option for 2008 cts 3.6 DI performance & luxury package
  150. AWD owners! RX just got our new AWD eddy current loaded dyno in!
  151. Eibach issue
  152. D3 intake
  153. Slight pulsing vibration @ highway speeds? Any ideas?
  154. h & r springs problem
  155. has anyone flashed a cts with only stock parts?
  156. steady increase in power
  157. EBC Brake pads ( IMPORTANT )
  158. How can I make my 3.6 Base CTS faster?
  159. Stiff Ride on 2010 CTS 4
  160. 2011 CTS 3.6 liter installing GForce chip...which two wires?
  161. Alcantara wheel upgrade
  162. JDP CTS-V Stage 2 6-Piston Upgrade Package on CTS
  163. Fuel injection
  164. Replacing dome interior bulbs 2010 cts
  165. Wanted: Stock Springs or HELP!
  166. Any good exhausts for 011 cts awd?
  167. 3.6 DI Cold Air Intake?
  168. Help with Radio Upgrade
  169. Warranty? Bought a Water/Salvage 2011 CTS
  170. Dual exhaust 2011CTS
  171. MGP Caliper Covers with Vossen CV3 Rims. Opinions needed!
  172. Dashcam power kit fuse box hardwire install on CTS-V 2009
  173. Vossen CV3 rims on 2011 CTS Coupe, Please help
  174. Won't shift into sport or manual mode
  175. What aftermarket sub fits?
  176. GM Performance Exhaust?
  177. trifecta tune
  178. Power Slot rotors are junk-you are on your own at 90 days
  179. Trifecta 20% OFF 03-21-13 - 04-15-13
  180. 1st Time Cadillac Owner
  181. Exhaust Tip Questions
  182. cai 2009 cts
  183. cai 2009 cts
  184. CTS AWD Magnaflow Cat Back Exaust
  185. Easiest/economical way to boos HP on 2012 CTS4 3.0
  186. 2012 Cadillac CTS Coupe - 15216 MagnafFlow Performance Exhaust system
  187. DIY - How to install Lowering Springs (Eibach Pro-kit)on your 2012 Cadillac CTS Coupe
  188. Camaro Short Shifter??
  189. What can a 2008 CTS4 use from a V
  190. Coilovers
  191. Anyone with a D3 CAI - Issues with oil leakage
  192. Volant cold air intake kit for 3.6 Who has one???
  193. Upgraded Brakes for 3.6 DI Performance Models
  194. 2011 Coupe takeoffs
  195. Exhaust for my 3.0L
  196. 2008/2009 Tuning Upgrade?
  197. AWD CTS 3.6 build thread......the works!!
  198. Gibson exhaust for CTS
  199. So, even with all these catch can threads, you still think you don't need one?
  200. 2012+ Performance Thread For LFX 3.6L V6 Engine - Discussion & Resources
  201. Needed: 2012 or newer CTS (LFX) for turbo system fitment
  202. Rx Catch Can "Gurgle"
  203. Sunroof Shade Won't Go Back
  204. Best lowering/performance springs
  205. TCM tune help
  206. Cts coupe shifter vibration
  207. Magnaflow exhaust owners
  208. Loud squeeking noise!
  209. Exhaust Suggestions
  210. Traction control/ stabilitrak off
  211. 93 octane with trifecta tune?
  212. 2009 cts-v 618 rwhp 650t
  213. E85
  214. Breather on PCV
  215. Intake for 2011 3.0L
  216. Cadillac cts-vcoupe
  217. Performance cams for our engine?
  218. Upgrades to EBC Ultimax rotor and Redstuff pads
  219. First time Cadillac owner! 2008 cts 3.6di
  220. Borla exhaust in a coupe?
  221. Eibach Springs
  222. Intake
  223. Catch can a must on DI motor
  224. any documented performance gains from tuning, intake, iceolater, etc?
  225. CHEAP!! Airaid 250-252c Cold Air Intake System 2008-11 Cadillac CTS 3.6L (Fits: CTS)
  226. Iceolator
  227. Bad News Racing Trifecta Cable Sale- 11/23-12/31
  228. Steering Wheel shift buttons sold on Amazon
  229. Gforce performance chip $69
  230. Max rim size and specs
  231. 14 HP upgrade fir 2013
  232. LFX Dyno Tuning!!!!
  233. Supercharger
  234. Another Catch Can Installation (with pics)
  235. cts-v bbk
  236. trim removal
  237. Exhaust Set UP
  238. Installed Cold Air Intake from D- 3 and my Gas milage average went to 14.7 ?
  239. Emblem removal
  240. Volant Intake Delay
  241. Supercharged
  242. Lowering my CTS Coupe AWD!
  243. Exhaust question
  244. 2010 CTS AWD Gas Mileage
  245. Deep sound
  246. 2010 CTS 4 with 3.0L mods...need some help.
  247. Performance chip
  248. Super Charged!
  249. need advice
  250. grill/engine cover
