- 94 northstar starting problem
- Can i use synthetic oil in northstar?
- Getting Screwed
- Where is the main engine to body ground?
- white smoke n hp loss
- Is it me, or are alot of N*s having cracked blocks
- this is not an arguement thread for oil !
- 95 northstar tranny
- Is It Possible To???
- Engine stopped at the end of an exit ramp Any IDEAS WHY?
- Serpentine belt
- Need a VIN to a STS with the Z(W) option, I have the option but I don't like the Euro
- Removing EGR on a'96 SLS
- Whats the easy way to change the alternator on a Northstar? (99 Deville)
- Northstar shifting past redline
- 93/94 engines
- No Heat at Idle
- What's involved to drop the oil pan?
- Iradium spark plugs for 99deville? Better or worse? What the best plug & wires??
- Tell me about Force Motors/pressure control solenoids
- 99 Head Gasket Warranty?
- How can u save gas on a 99 deville?
- PC0327 - 96DeVille
- 1995 STS Cooling problems?
- Sts engine has this knocking sound
- Heater Core Leak/ Need Some Help, Please
- GM MAF sensor information and Discussion
- bottom end problems??
- Car runs hot but doesn't over heat
- Fuel Line Leak
- I have a cracked block, what next?
- RTV Silicone on Transmission Side Cover?
- hypothetically speaking
- 02 STS uses tons of oil
- Northstar Modifications
- 10w40 in N*
- 94 STS starts only if pressing gas, idles rough, dies after a couple minutes
- upgrading 94 concours
- '98 STS valve cover
- HELP- Dropped a bolt in the intake valley
- Intake manifold crack?
- Need Some Code Help 02 Seville
- Crankshaft position sensor
- engine compatibility
- 1994 DeVille Concourse
- misfire at idle
- Need help removing 99 STS northstar motor
- 1st time motor pull for HG on 99 N*, some questions
- 97 Etc N* Head Gasket Project
- Headgasket Leaks & Repairs
- check coolant light on???
- High idle/ IAC clicking?
- HELP!! Fuel Rail Recall Problems 1996 Seville
- Engine stutter/punch
- P0741 TCC Stuck ON, tried much, what next
- What is the Northstar suppose to sound like?
- 2003 Sts 0-70
- IAC valve
- strange rumble sound during hard acceleration.
- 2002 STC - Front Engine Mount Broken
- Mobil 1 5W30 meets GM spec 4718M but Mobil 1 10W30 DOES NOT. WHAT GIVES?
- Unbolting "beauty cover" on a 1999 Deville What GIVES
- Where is my IAT Sensor located? 99 sts
- 1997 Seville SLS
- Arizona Cadillac Owners Cheap Northstar Engine
- questions about PC0300 code on 96 deville
- Help with this code...97 Cadillac deville
- Drive vs 3 What's better???
- Cam numbers?
- What Spark Plugs for a 1999 DeVille Northstar?
- Using synthetic oil in a Northstar-Why does Cadillac recommend 10W30?
- Engine Oil Myths including ZDP by GM
- anyone ever use HEAL-A-SEAL
- Does vacuum sound from Surge Tank equal head gaskets?
- 94 Northstar Flexplate knocking noice. HELP!!
- 2003 DHS - Sluggish - EGR?
- Whirring/grinding That's Speed Sensitive
- 2002 deville/dhs engine trouble
- How can I clean the Mass Air Flow??
- Thanks for nothing, Northstar.
- P0147 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 3 - overheating
- Crank sensor tech 95 sts
- 1st gear WOT
- The End
- 99 STS Turbo charged video
- valve seals
- 1999 Seville Ignition DTC Help!
- Smoking Northstar?
- How long is your NS dipstick?
- weep holes
- engine swap for a 2001 dts
- P0741 - TCC System Stuck Off
- new Delco spark plug wires installed
- 1998 Cadillac Deville overheating
- Help Having A Heart Attack! P039 / TRanny?
- N* programmer?
- Is it possible?
- Northstar Buick
- N* Runs Rough at Cold Start
- Bank 1 , 2 ??????
- Engine build
- P0300,p - Engine Misfire Detected 2002 deville, help please
- 2003 Deville with RWD
- Starter location
- Questions, Questions, and more Questions
- 93 sts traction disabled
- rental lincoln
- how to stay away from power loss
- 96 sts supercharger
- Are headgasket issues getting more common lately?
- 1998 Seville STS Chiptuning
- Tranny problems?
- Northstar Dyno Registry
- New Engine...climate control issues.
- Cryogenics
- My Photo Essay N* Head Gasket Repair Job
- Custom intake and nitrous
- 94 concours
- SLS Y-Code Engine: Do I need to replace the EGR Valve? PCM?
- service manual
- Possible Applications for Northstar?
- Need help....PLZ!!
- so i got a few PCM codes
- GM's Veiw on Fuel and Oil Additives
- How do I Reset the Change Oil Message?
- so when i went to pull codes, it just said all
- T061 T083
- 97 Deville No Longer Starts
- help on my 99' seville sls
- Starting issue
- 97 SLS Motor Swap to an 03. Is it possible?
- head
- 99 SLS and Straight DexCool rather than 50/50
- No 1st Gear!!!
- Cheap Northstar in NH, 35,000 miles
- Steering Wheel puff of smoke
- on the tranny subject
- Talk about luck!!
- New motor runs a lil hotter?
- o2 sensor question
- What is HOT for a blown head gasket
- Need Help Info On Where To Buy Rebuilt Engine
- compatable parts
- NorthStar swap wiring harness
- product question
- How long do you think caddy will keep the N*?
- SS Fuel Rail Removal
- Would this be a wise choice? [CAI] on a 184,000 mile northstar
- E85 on northstar ???
- just got my Plates
- 1996 Cadillac DeVille NO CODES ????
- Engine code - EOP
- Type of engine?
- Turbo Charged STS Cadillac
- Northstar Cam specs
- How can I drive 1000 miles with a coolant leak?
- To Rebuild or not.
- Do you use dealer for Northstar repairs?
- How long do Northstar engines last?
- 4.6 northstar fuel pressure?
- 150 miles in limp home mode
- CKP Question for One of the Techs
- Any problems trying 20W-50 in a '97?
- New 95' STS owner with tech question
- tune up ,whats involved?
- Oh shoot...need help ASAP...:(
- Radiator Cooling Fans not running
- Ram Air! (Maybe)
- Engine runs a bit rough during cold winter starts
- "break in" period for new Northstar engine
- How many miles to you get per tankfull with your north*?
- Inserts
- GM now offers Premium Remanufactured 4.6L Northstar
- 00 to 03 engine in a 98 or 99 Seville.
- recommended shop in Toronto/Kitchener area
- After head gasket repair engine knocks
- transaxel fluid change
- N* Injectors and Fuel Pressure Regulator
- transaxel filter
- 2002 plentum leak
- Sts Running Terrible
- 96 Cylinder head on 93 block
- My car has 121k on it..should I change the trany fluid?
- 96 to 99 Eldo, Deville, and 96, 97 Seville Tuning
- valve noise at startup
- Breaking in a N*
- Invisible leak (coolant)
- Another seafoam thread
- Is there an easy way to change coolant?
- what is considered normal coolant temperture for a north*?
- please identify mystery black box 01 DTS
- Northstar Headgasket/Bolt Failure? Please let us know
- Flushing Radiator
- Are there any worthwhile performance mods for the 98 north*?
- Was there more then one north* engine in 1998?
- Three (3) Codes on 1996 SLS: P1406, P0401, P0108
- Northstar Air Consumption.
- Eldo Gone....
- 4T80-E Transmission Fluid Change - DONE!
- P119 - Shorted Fuel Injector Problem
- How often do you WOT your north*?
- Before i go to beat the crap outta my car - WOT cleaning
- denso wires ???
- timeserts -so do these things prevent bad head gaskets
- Northstar 32 valve good for swap-out?
- '94 sts.. ignition coils, ignition control module?
- Car will not turn over....
- Has anyone ever got the P0741 code?
- Are there any good oil additives to add...
- I read a post about top tier gasoline....
- '95 Concours hard starting when it's cold outside
- my service engine soon light is on
- bad idea to use 87 octane?
- royal purple on a N*
- 03 n* and trans in a 99 SLS
- What gives the Northstar its "whirring" sound at idle?
- 96 sts starter problems, questions?
- How would i get a custom pcm?
- Beef up a 4.6L NStar?
- squeeky serpatine belt *new belt and tensioner*
- N* performance
- what year was it?
- opinions on high flow cats
- Gasoline Consumption question
- Looking for a Timesert Kit
- Engine Performance mods 95 STS
- Which oil i need for my 96 eldorado????
- How long should I let the N* warm up in the morning?
- Timesert Kits?
- 1997 SLS (overheating)
- Changing brakes on 96 SLS
- 2000 dts northstar reliabilty
- 2002 ETC Collector-mobile.
- What's the difference between the STS and SLS engines?
- Internal Mods For Northstar
- 99 to 00+ swap differences
- stuttering at idle
- 1999 Cadillac STS love/hate relationship...
- Free Northstar Engine
- Help the new guy make a good decision
- High Performance Head Gaskets?
- Parts ID
- Not run for 6 years, what would you do?
- 00 PCM on a 99 engine
- Blown Headgasket
- Aluminum Block porisity
- Its Alive
- oil life monitor problem
- P094 limp mode, no overdrive
- Valve Stem Seal Puller
