- Northstar Aftermarket Support
- Do Northstars burn oil fast???
- Help!!
- Northstar overheating
- Most common problems with NS motor
- Engine size ?????
- What is the deal with the Crank Position Sensor and...
- sneaky coolant leak, Northstar
- Bad plug wires get you crazy codes
- stupid dipstick
- N* Head Gasket repair part I/ Remove engine
- idle speed adjust?
- Belt Question
- Emissions System
- 99 SLS probelms
- help with codes?
- Head Work
- New person here - piston replacement question
- How to get to plugs on 00 STS?
- 1995 SLS Engine and Trans
- tps 1995 sts adjusted
- are the '93 and '95 northstar computers the same?
- Cracked Water Pump Housing Northstar
- Erratic fuel level gauge & a few other ???
- Time serts head gaskets and cadillac refunds
- 1990 Sedan Deville Valve Job
- Limited slip...sort of
- Octane reading
- Check Oilk Level wont stop
- Please help..engine coolant ?....
- Traction Control on STS ???
- 96 Seville, Check Engine Light, New owner?
- Help with cooling system
- ? on seville northstar motor?
- Help! I have a 1997 Concours(traction c) I would love to know where this wire goes??
- maintenence records?
- rear windows fog up
- Northstar - Golf swap
- PCM codes
- 1997 Deville problems
- Smelling Coolant inside - 93 STS
- Battery Replacement on 95 STS
- Service Brake Fluid Switch
- Transmition shifting ?'s
- Engine cutout 93STS north*
- Oil Life Message Problem
- Can I get some pictures (N* mounting)?
- OBD codes
- 95-sts wont start
- idle sts-95
- Anyone know where I can find cheap o2 sensors?!
- So....someone wanna rent me a timesert kit?
- Ignition module failure?
- Need help understanding a code
- Best oil for Northstar engines?
- Northstar questions: engine and tranny mounts
- Service Engine Light
- Idle speed
- Intermitant DTC P1416, where do I start looking?
- phenolic spacers cleaning
- Regular Unleaded
- Throttle Body
- 97 Concours....SOLD!
- Help Codes
- Thermostat
- 4.0/4.6 Combustion Chambers
- Intake air sensor / resistor mod
- valve job? something burning......
- Easy method of telling you need a coolant change!!!!!
- 97 dedan deville speedometer display out...
- 4.6L engine knock at idle
- High Performance driving
- Starting Issue
- High octane
- Headgaskets
- hard starting, won't pass smog symptoms
- Info on converter lock,,code PO39
- Northstar engine numbers
- Locking converter/check engine SOON
- How to replace front motor MOUNT
- can any one help
- Motor Rocks
- Torque converter lockup?
- Help!
- Regular Gas
- Nitrous Kit for Northstars - It exists
- why do people tell me northstars are junk?
- Coolant Loss
- VERY slight valve knock on '98 STS Northstar?
- Won't shift out of 1st gear
- Let's get some performance parts!
- Just how fragile are they?
- experienced mechanic in Los Angeles
- RWD 5-speeds
- Let's get an OBD Programmer...
- Limiters on 96 STS
- 1996 northstar in 95 eldorado - Strange things happening!
- Technical Photo Section?
- service engine light is on
- engine compatibility
- code help please
- 99' STS low-end torque is sluggish?
- Blessed With Head Gasket Leakage as Well...
- timesert kit
- performance pcm/ecu mods ODB II (96+ ) (i.e. 1999 sts)
- Can the 300 HP be swapped with 275 HP motor?
- North star motor swap
- Diagnostic codes and running rough
- cam timing tool
- Hard Shifting Transmision
- Squeek, scrape, whir.
- transmission removal in 94 eldorado???
- 2001 seville sparkplug location
- need advice-- cooling
- engine removal and install procedures
- Temperature problem???
- Starter replacement, what is the easiest way?
- Bearings?
- are northstars interferene engines?
- northstar head warpage?
- "LOW ENGINE COOLANT" came on...
- timeserts
- Northstar idle speed motor instsall
- Rss (c)1743, 1783, 1785 ??
- 4T80E drain plug location?
- Missfire 93 sts
- Idle is higher than normal and fluctuates
- STS 13:63, you ask how?
- Ok I can check my codes but how do you check them individually?
- Cadillac Hot Rodders!
- Keyless Entry Programming Procedure
- How to change Trans. Fluid?
- Borla exhaust needs your help
- Where's the Chip?
- Battery No Charge light on/ Alternator?
- New Owner Can I work on My Seville N* myself? Is it too electronic?
- northstars
- I am New here
- spark plug wires
- Sudden Stall
- What would you do? (fun project)
- Problems that were fixed (technical question)
- Waterpump Replacement
- I broke it!!
- 1999 Caddy Seville Sts
- High Mileage Northstar Thread: Who can beat me?
- 120,000 Miles on a Northstar?
- Rusted Fuel Filter
- Need some technical help/ suggestions from guys that know!!
- turbo for a northstar?
- Difference in 275HP & 300HP Engines
- Heads
- What size rims ....... (technical info)
- 95 SLS how to check coolant levels?
- Looking for Time sert kit
- Mobil 1 Synthetic Oil
- Screen in the intake system
- 100,000+ questions
- PVC Valve and Fuel Filter
- how to seperate the trans form the motor etc
- Ways to tell if your northstar motor is blown........look
- General Deville Maintenance
- New street rodder issue has N* Part 2!
- Need supporting info RE: 4.6 head bolts
- Northstar motor blown at 80,000 help...........
- Throttel Body Plate Size ???
- Caddy transplant
- 00 - 03 Seville questions:
- Northstar oil burning - what to do?
- That Coolant thing...
- B1136
- Allante losing coolant via bypass
- 2000 Dts - Rough Idle
- Resetting Change Oil Message
- finally made a few mods to the STS
- Knock sensor blues!!!
- Emission Message
- New Struts? When to replace them.
- Oil
- STSi heads availability
- seeping head gasket
- Premium Fuel
- just wanted to say hi to everyone!!!!!
- NOS on northstar??
- engine squeeking
- Engine Problems?
- Engine/Coolant Temp?
- How much to rebuild a northstar?
- Is there a SLS/STS performance chip/programer yet?
- how to turn off tractin
- "Check Oil Level"
- coolant color
- Firing order-
- engine miss
- North* with a manual?????
- Gasoline question
- sls tranny problem
- Hot Rod Caddy or LS1?
- upper motor mount part numbers?
- Cooling system sealants....
- A word about air filters
- Some Interesting facts...
- Transmission valve box?
- SES light
- Northstar STS story
- Clearing codes
- Oil in Coolant
- Is it just me, or did they use a shoehorn to get the N'Star under the hood of my STS?
- 2K 4.6 NS- No worries or no probs mentioned YET??
- Intermittent Hesitation
- Hey guys..quick question!
- How Strong is the Northstar Bottom End?
- tranny slipage on 97 deville
- Northstar 4.0L seems a little hot. Removed Thermostat. Bad Idea?
- Operating Temp??????
- Maintain Cooling system?
- Northstar Pull Question
- cracked spark plug
- 98+ Seville Free cold air intake mod
- Clearing Codes
- Check Coolent Level Keeps showing up
- blown headgasket
- 1994 Concours Transmission Question
- burned exhaust valve's ?!?!
- The Northstar Issue
- Head gasket or??? HELP Plz
- My 1997 ETC
- Nitrous Systems
- anyone with subscription, willing to run carfax for me?
- fuel rail
- Cadillac 32v Northstar 1993
- 98 Concours
- Blown head gasket
- Stabilzer Links
- Northstar Motor Intakes
- Rebuilding my Northstar please help!
- hot weather and hot northstar..HELP!
- 94 SLS Radiator
- Unusual Howling noise.
- Northstar Heating Up
- Throttle Body Bypass
- Ignition coil or ignition module ?
- stupid POS Alternator!!!
- a/c compressor/ clutch removal-install
- Cooling Fan Relay Location
- Tranny code P0741 & P1860
- Eldorado ?
- water pump pulley
- What can I do to push my '93 Eldo to the max?
