View Full Version : Northstar Performance and Technical Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26
  1. valve cover gasket replacement
  2. How much does a Northstar Engine weigh??(I searched but did not find the answer)
  3. TCC System Stuck Off
  4. No More Cadillac's Throw Away Northstar Engine
  5. Anyone know ANYTHING about McCord Power Plates?
  6. 95 sls cam pulleys & belt
  7. Rough Idle after 87 Octane
  8. Exhaust Cam numbers
  9. Supercharger for the N*
  10. More Muffler advice...experts??
  11. How to ID N* engine
  12. Free Valvoline maxlife
  13. Quietest exhaust muffler
  14. northstar eldo fuel
  15. Cheapest place to buy plugs and wires for a 97 Deville
  16. NEEED HELP...Anybody near Framingham or Boston MA
  17. # 1 cylinder misfire
  18. Need Ideas
  19. wide-open throttle ("WOT")
  20. Fuel Injector
  21. Iradium Ix Spark Plug
  22. Overheat Cat Caonverter
  23. Car won't start...just my luck
  24. Throttle body Helix and MPG?
  25. clogged Cat?
  26. PLEASE HELP ME! Northstar is idling fast...
  27. New member, questions and suggestions
  28. (MAS) questions?????????????
  29. Northstar - Starting Problems
  30. hard idle on my 94'Deville Concourse
  31. N* performance approach?
  32. 1994 STS Headbolts
  33. Adding a K&N to 97 N*
  34. Drive with Trans. Code?
  35. Tune Up?
  36. '94 N* runs lumpy - hesitates. Any ideas?
  37. new STS with true dual exhaust???
  38. 97 Lower end thump/knock between 2 and 3k
  39. Code help
  40. Will Not Start - Think Fuel Pump?
  41. idle problem
  42. Fuel pressure at idle/WOT?
  43. oil spraying everywhere from headgasket
  44. Overwrite Obd1
  45. Compression Test
  46. Has anyone done a performance chip?
  47. Stuck in the middle??
  48. Bad Gas? - the reprecussions
  49. engine coolant tempature
  50. My NorthStar project....
  51. radiator coolant
  52. 4T80E shift kit??? and pro tech???
  53. Pontiac Northstar
  54. Spark Plug replacement
  55. Cat
  56. 94 STS with cruise & idle problem. Please help
  57. How Much Transmission Oil?
  58. How many Northstars
  59. DTS horsepower
  60. Infamous Northstar Oil Leak
  61. Decipher acronyms?
  62. Engine Coolant Tenperature
  63. Reapair Manual
  64. Time-sert Repair Kit
  65. Motor Mount Question
  66. Life after timeserts
  67. Northstar 320 hp crate motor
  68. Searching for the Northstar- Please Help
  69. Code P065 & uneven idle
  70. horsepower
  71. Passkey problems and Computer codes
  72. Crank pulley on 94 SLS
  73. Starter Problems
  74. Headgasket replace
  75. transmission is kidna ... odd?
  76. Code C1217 '99 Seville SLS
  77. Anyone ever put on glasspacks on a N*, or heard waht it sounds like?
  78. I'm smelling antifreeze but can't find it!!!
  79. Another Temp thread...
  80. 92 eldorado engine swap
  81. Changing Spark Plugs on Northstar?
  82. How do you check for codes???
  83. Now my deville is overheating !?!?!
  84. Well now that i am getting a free new exhaust...
  85. Transmission lurch
  86. Service Engine Soon
  87. chance to buy a N*.....
  88. Radiator leak on Seville Can it be repaired?
  89. Speed limiter & Tech II
  90. Where to find head bolts?
  91. Oil light comes on in an 98 Deville N*.
  92. Installed my Dynomax Turbo Mufflers
  93. ISC motor correct idling adjustment problem
  94. cooling system problems
  95. 96 eldorado
  96. Stock intake box modifications...
  97. Valve clatter at cold startup
  98. 93 sts w/97 n. s. fuel pump problem
  99. Code I052, Keep Alive Memory What is this? How to fix?
  100. Whats code tc0023?
  101. the shift solenoids
  102. Idler Pulley and Tensioner bolts
  103. So anybody around boston want to help out a fellow Caddy owner?
  104. Engine identification?
  105. wierd traction control problem!!!
  106. Performance Modifications
  107. Haynes manual
  108. Northstar with 120,000 miles ...any problems coming????
  109. Service Engine Soon..... ODBII codes
  110. bad block ?
  111. Where has my coolant gone ?
  112. Crank Position Sensor
  113. Removing EGR on northstar
  114. battery cable repair
  115. My 97 Head Gasket Problem
  116. Anthony Cipriano: Re. Your remarks on Olds Diesel Engine
  117. OBD1 PCM Output Section
  118. feul gauge
  119. 2001 Deville Overheating Problem
  120. 99 deville lifted head
  121. Replacing o2 sensor on a 97 deville
  122. IPC Overides
  123. Speed limit setting on 98 STS
  124. My first code.
  125. Delorean with a northstar.. & 94 Camaro... Links attached
  126. 94 SLS Air Conditioner
  127. hey guys..newbie with some questions!
  128. O-2 Trouble codes
  129. Cadillac Thermostat
  130. Engine Stall/ shut down
  131. Oil Weight Question
  132. Northstar fuel economy?
  133. Passenger climate control
  134. HELP, service emissions eystem
  135. Dipstick 95 SLS
  136. Help with part #?
  137. STS 95: Hard gear shift
  138. power steering pump replacement- ? special tool
  139. 1998 Deville With Hard Starting And A Slight Gas Odor
  140. 1998 Seville rear wheel speed sensor
  141. Fluid Evacuators
  142. Bolt size ?
  143. Proper Spark plug gap?
  144. Prgramming Keyless Entry Remote 98 Deville
  145. Factory Service manuals
  146. Reset codes
  147. 1997 to 2000 engine swap
  148. 96 sts shifter handle
  149. temp guage 97 sts
  150. Diagnostic Troubleshooting
  151. Badly Misfiring 97 STS
  152. Spun bearings in my '94 STS
  153. drain plugs in 97 sts block WHERE?
  154. Best Aftermarket add ons...?
  155. 96 Eldorado
  156. Northstar Pics Please
  157. dynomax exhaust
  158. i need help with codes b2710,b2780
  159. Can't Figure Out How To Set IPC Overides
  160. Northstar in VW Golf. Link Attached.
  161. anyone doing THIS with their N*?
  162. Air Intake Kits
  163. GMPT PV8 (Northstar) engine Cylinder Liner help...
  164. If I Dont Use Premium Unleaded Will It Ruin My 96STS
  165. In English, Please...
  166. error codes
  167. 98 STS Codes
  168. 1999 Deville , Code says convertor is not locking up
  169. 98 Sedan Deville-TRANS HOT-IDLE ENGINE
  170. How do I changes coolant hose
  171. Performance Air Intake Kits ?
  172. N2O in my '98 STS
  173. head gasket and maintainence
  174. 1996 Cadillac Seville running hot? (or not) help needed
  175. help! 2500 rpm idle
  176. I got the codes, now what?
  177. Evap Soleniod
  178. 94 Concours getting 13 MPG What could be wrong?
  179. pcv valve
  180. Oil Amount Debate, Do you put in 7.5 quarts or less at oil change?
  181. What is code p1645 mean
  182. Oil change and coolant
  183. CHanging the top-speed cut-out.
  184. how much extra HP will i get
  185. Used northstar
  186. 94 STS bogging and stalling?
  187. Overheating-head gaskets-screw it!!!
  188. ETC Crossover Leak
  189. Fuel Rail Recall Update
  190. Norstar governor
  191. 2005 Bonneville gets N*
  192. Fuel Rail Recall Missinformation
  193. Scan Tool Questions
  194. CARFAX (engine / car serial Numbers)
  195. Who has done a lot of mods to NS powered cars?
  196. Oxygen sensor problems
  197. All was fine until... hard cold start prob
  198. No orange light in Park, D, 2,1 in cluster on Concours?
  199. new 99 eng for 97 how much is different?
  200. 96 deville error codes P0147 and P0146, where do I look?
  201. po741 error shifting problem
  202. Leaking coolant
  203. Cat-back systems
  204. Throttle Body Cleaning
  205. coolant temp sensor
  206. carfaxing a used northstar
  207. Exhaust crossover
  208. 1994 sts 94K miles overheating
  209. Timesert kit for sale
  210. rough idle
  211. IPC lights ....out
  212. 96 sts transmission
  213. Fuel Rail Recall, just got the letter
  214. Changing That Water Pump Belt
  215. headgasket repairs
  216. Traction Control & a code.....
  217. newb looking for part numbers
  218. Solenoid/Valve Body/Trans Pan Pics!!!!!!!!
  219. Volant Air Intake
  220. Oil pressure check
  221. replacing my 96 northstar
  222. Where is it all?
  223. Will I suck her dry if....
  224. Shift Solenoid Kit Pics of Parts!!!!
  225. About to kick my caddy
  226. 98 STS Has DIC That Still Registers 100% Trans Fluid Life
  227. Northstar missing at idle
  228. Fuel Rail Leak on 98 Deville!!!
  229. Best Bar's Leak...C16 Liquid
  230. To replace or repair the n. star
  231. 97 Deville Question
  232. northstar extended warranty
  233. Noticeably Better Gas Mileage..On 10 yr old+ Engine!?
  234. Gas miles -- Standard DeVille vs DTS
  235. Changing out Fuel Rail??
  236. intake manifold bolt torque?
  237. Strange Things Happing
  238. Gas pedal click
  239. Starting to get rough idle
  240. Fixin' to pull the engine
  241. Head Gasket Leak : NO OVERHEAT with coolant supplement
  242. TPS replacement problem
  243. Fuel Leak
  244. Northstar transplant and electronics
  245. Best way to prevent an oil leak on N*?
  246. 180F or 195F Thermostat for 94 N*?
  247. Misfiring and Service Engine light
  248. Coils / Intermittent "missing" on my 99 STS
  249. Hey Hotrodelectric
  250. Northstar Expectancy
