View Full Version : Northstar Performance and Technical Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. the day has come: headgasket
  2. '99 Seville STS
  3. What are the differences between 99> and 00< motors?
  4. Why do these motors break rods?
  5. pretty betty deville
  6. how reliable is northstars limp mode
  7. 1999 deville almost overheating
  8. 3.71 ever better with smaller wheels?
  9. Refrigerant pressure
  10. Minor Coolant Leak
  11. 93 sts misfires, stalls, very rough idle, looking for cause
  12. Any thoughts? Code P1350 p1375
  13. Injector spec for a Y2000 N*
  14. oil cooler
  15. TPS issue: Codes P0122, P1122. Help!
  16. Need Help Installing Air Filter ?
  17. 2002 Deville coolant leak
  18. Blew the head gaskets replacing the motor
  19. 1997 deville stalling at idle
  20. bad headgasket
  21. N* running Hot, Real Hot
  22. 99 deville oil pump
  23. 2001 Northstar AIR Valve
  24. Hydraulic valve-lash adjustor evaluation?
  25. 99 deville - RFA U1000 Help
  26. 91 GMC Sierra, with a Northstar?
  27. 96 96 Northstar Noise and Oil light issue With Video
  28. Speedomoter Reads wrong
  29. 2001 Deville Falls Dead
  30. 98 sls overheating
  31. EVAP Purge Solenoid
  32. P0171, P0174 After replaced Plenum
  33. 97 deville overheating??
  34. Batteries, voltage, power, and Optima
  35. Intake Manifold Removal Snag
  36. Smoke
  37. Come for a vacation while your HG's are replaced
  38. Exhaust manifold swap?
  39. Temp Indicator Question!
  40. Does Anyone Have Any Ideas???
  41. 2001 deville misfire
  42. '98 heads and cams on a 2000 block
  43. Fuel Rail / Fuel Injector Removal
  44. No Spark
  45. Puffs of smoke while revving in park
  46. Warping the Heads???
  47. A/c Discharge Hose
  48. Northstar Valve seals?
  49. Main studs?
  50. Notice of price increase on HG replacement
  51. Mystery Vacuum Hose
  52. Bad Thermostats or blown Head Gasket??? Help
  53. timeserts
  54. Question about Time Serts?
  55. Iridium Spar Plugs
  56. Stock crank HP?
  57. How much better are the 00+ headgaskets.
  58. 97 ELDARADO w/ blown H/G
  59. allante 9 engine swap to a y engine
  60. Weird transmission behavior - any ideas?
  61. 3" Exhaust all the way back?
  62. FWD Sump swap for RWD?
  63. Early engine number needed
  64. Low oil pressure enigine stop no start
  65. Need Motor Mount R&R procedure in Tech Tips
  66. Crankshaft Position Sensor
  67. 2002 Eldog
  68. changing starter on 1998 deville--have you done it?
  69. 01 STS - Engine cutting out on accel
  70. Ram Air set-up on a 95 STS
  71. NorthStar painting touch up?
  72. Camchain timing
  73. 03 front (left) motor mount help
  74. Oil filter IArea
  75. I may need all forum members help, especially those who have ordered the stud kits.
  76. Do NS engines have an "air regulator"?
  77. Injector Alternatives
  78. Best year for a NorthStar??
  79. 95 N* intake issue
  80. How to lock flywheel without $150 tool?
  81. 2001 Deville DTS PO300 Random Misfires
  82. Cadillac STS Coolant, service stability system...
  83. anyone ever use Engine Ice Hi-Performance Coolant
  84. 1994 cadillac sts coolant loss
  85. What size of Time-Sert I have to buy ?
  86. 96 Eldo ETC I found the ABS computer cover...how do I get in it?? Do I force it?
  87. 96 Eldo engine sputters and stalls. P0300 and P1380 Engine Misfire.
  88. 01 STS Water pump grumbling noise
  89. Replacement Engine
  90. Coolant loss?
  91. what is the difference between the concourse and regular?
  92. '97 DeVille SES but no current codes?
  93. 95 sts hard shifting/chugging trans?
  94. combustion gas test turned yellow
  95. Northstar Died? no vacuum, no compression on cyl 6.
  96. Myrtle Beach Repair Shop
  97. High oil pressure
  98. Transmission help
  99. P0621
  100. 96 Seville AC system
  101. air box
  102. Engine almost stalls
  103. Help needed before I break something...
  104. Lean Cruise Tune
  105. 95 seville died and wont start
  106. would bad hg's cause the lower radiator hose not to get warm??
  107. Help..Which is #2 cylinder and other question
  108. cam sensor trigger
  109. getting p0741 code please help!!
  110. need help
  111. anyone know what this writing can mean?
  112. Primary timing chain sprocket wear?
  113. Still no short run power
  114. 96 concours crank prob
  115. On Vacation, just a bit of fun street racing....
  116. What is Normal Valve Train Noise?
  117. Fpr
  118. Need urgent help with spark plug wires
  119. PCM codes P0138 and P1139
  120. could this be a hg issue?
  121. barely running Northstar
  122. slightly overheating and coolant leak
  123. Help with TCC replacement parts list
  124. radiator fans not cutting on
  125. saying goodbye
  126. Transmission problems after HG fixed!!!
  127. 1996 STS Engine seized again what could be wrong?
  128. is there supposed to be something in the bottom radiator hoes?
  129. Bad head gasket without any symptoms???
  130. Crank Pulley removal/install
  131. how to check if the headgasket is in good shape before buying?
  132. newb question about tune-ups
  133. 1999 DeVille Coolant leak
  134. Coolant C/O Question
  135. HP rating from a sticker
  136. shelby northstar
  137. Wierd shaped bolt holding in IAC
  138. Check out my Headgasket Job in the car!!!!
  139. Crossover Manifold, Pipe Gasket Part Number
  140. Intake Manifold Cracked at Bolt Heads
  141. For all of us with the fluxuating speedometer / intermittent cruise control
  142. Transmission Strengths/Weaknesses
  143. looking for head gasket repair in tx
  144. Different Headgasket Question
  145. what is the difference between vin 9 and vin Y
  146. I need to find someone closer than Canada to do my headgaskets !!
  147. Sold one of my '97 to my best friend, now it won't start
  148. 2001 STS vac leak at intake
  149. Overheats less in 3
  150. TERRIBLE Gas mileage "help"
  151. damm am i hard headed...over heating still
  152. still overheating need help...
  153. Found Coolant in the Valley. What could it be???
  154. Difficulty level on swapping a N* 4.6?
  155. Help with engine removal for STS
  156. Can 97 N* lifters be disassembled?
  157. front motor mount
  158. A/C delete pulley
  159. coolant leak
  160. Overpressurize relief valve boot
  161. 97 deville blown head gasket question
  162. The best preventative maintenance for my 97 N*?
  163. Service Stability System
  164. duramax1980
  165. 98 NS Brackets
  166. Intake Manifold Removal, '97 SLS
  167. Northstar Bracket
  168. my 1st post transmission problems i think
  169. Priming the oil pump on a northstar engine
  170. 2000 STS, N*interchangibility?
  171. Trying to find Intake Manifold Spacer
  172. PCM wiring without a complete car harness
  173. 99 ETC Weak hot restart?
  174. deville 2000 HG ???
  175. DHS would stall upon starting... would not idle
  176. Why Check the Oil When Hot?
  177. very little coolant circulation...i hope its not a head gasket
  178. '99 STS Oil Smell?
  179. why didnt gm recall northstar engines for head gasket?
  180. Any good Northstar Mechanics in SoCal
  181. radiator drain valve
  182. New Studs to incorporate alignment pins
  183. 1997 Power Steering Pump Questions
  184. 2000 N* Head Gasket probability
  185. 00' STS N* Conversion ???
  186. 99 Deville/Headgasket Issue
  187. Misfire PC0300 Code
  188. Code P0741...Really confused.....Need help!!!
  189. Finally tore the motor apart
  190. 1997 sts stalled, Won't start
  191. HARD loud knock @ acceleration. help
  192. 93 Northstar Dies randomly. HELP!
  193. 95 SLS throttle body vacuum plug
  194. 2006 DTS engine issue
  195. 97 northstar balancer removal
  196. Advice on Northstar Transmission???
  197. oil in the antifreeze & overheating
  198. HG blown 375 days after a $3500 repair
  199. Northstar Coil Bank
  200. Engine wiring harness removal
  201. 97 seville sls coolant loss
  202. 98 deville engine question
  203. STS Blowing Out Oil But From WHERE?????
  204. '93 STS Oil cooler
  205. What kind of seal installer to use?
  206. Northstar head gasket replacement with warranty, Louisville KY - 1500 + parts
  207. how easy is changing the thermostat yourself
  208. Low speed stall
  209. Coolant Issue "00 STS"
  210. failed state inspection because of p0507
  211. Alternator questions....
  212. Bars Leaks Liquid Copper?
  213. which of these codes will cause my service engine light to be on?
  214. 97 Deville oil pan leak
  215. Please Help with long cranking time
  216. high idle
  217. Aftermarket Intake for '99 DeVille base model
  218. 02 Deville rough idle & codes
  219. 1998 Eldorado Head Gasket - 2nd time in 375-days
  220. Started to hear an intermittent grinding noise
  221. $788 To fix P0410 Code
  222. Car Stalled, won't restart
  223. Smell Coolant after Driving??
  224. 1994 STS quit in driveway, seems battery went dead.
  225. 2000 seville sts misfire
  226. Idle Air Control Valve (IAC)
  227. 94 sts intake cover gasket
  228. HG Budget for 97 STS
  229. Help.. 2000 dts tranny blown
  230. 1999 Seville SLS hard start P1350/P1375
  231. Crap!!! Coolant leak! what do I do!?!?!?
  232. 97 Northstar Oil leak
  233. 94 Eldorado Idle problem
  234. Best service manual (rebuilding)
  235. low oil pressure indictator
  236. Any idea what I should pay to get the evap solenoid replaced ?
  237. Thinking of rebuilding motor... questions..
  238. 2001 Deville getting hot
  239. Oil pressure
  240. Cooling system tablets after HG job
  241. HG Jobs for all, anywhere in Canada or USA in my new shop
  242. where to get headgasket job done?
  243. Northstar Engine Gets Gummy?
  244. STS low power
  245. Northstar engine miss
  246. 2002 Deville P3008 code
  247. Real Performance Parts for the L37
  248. HELP outta town with tranny issues
  249. Cooling fans and hard driving- temp spikes
  250. Convert 98 SLS motor into STS motor?
