View Full Version : Northstar Performance and Technical Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Help with ACM codes please.
  2. Headgasket/temperatute swings
  3. HELP PO25 code ????????
  4. Concours '94 Problem
  5. Pcm Gone Loco?
  6. Northstar losing oil
  7. Stop Engine Low Oil Presssure
  8. Factory air intake box question
  9. '94 DeVille Concours North*
  10. Bad idle and deacceleration
  11. '94 SLS smoking bad
  12. '94 STS rattle
  13. Changed starter, now very hard start, run, white smoke.
  14. Overfill oil in northstar, keep reading bad stuff
  15. Oil Leak
  16. 4T80E shift algorhythm logic -- what are the facts?
  17. stalling
  18. '94 SLS Head bolt Torque value?
  19. Radiator leak...how much $$$?
  20. supercharger for the Northstar
  21. 97 STS Code Info U1027
  22. 1999 Deville trouble codes
  23. "Normal" Northstar Coolant Operating Temp?
  24. Compass reads incorrect sometimes?
  25. northstar oil consumtion
  26. p076 presure solenoid problem
  27. Can someone tell me what these codes mean?
  28. Northstar Swap question
  29. 94 SLS questions
  30. 1996 Northstar Excess Fuel Consumption
  31. 97 N* low oil pressure light flickering
  32. Sorry Caddy Dudes!
  33. Can I swap an 02 N*into my 98 STS?
  34. Code Question for a 2000 deville north*.
  35. Help Needed - 95 SLS Stalls then won't idle or Revs Like Crazy! Lots of codes!
  36. 1996 ESC 40K, Does Trans-fluid need changing?
  37. Northstar/HotRod/Blower
  38. Backfire and smoke under the Hood
  39. looking for some new ideas and help with northstar motor
  40. Oil Pressure Drop on V8 NS
  41. What next? PCM shot or something I'm missing? Please help.
  42. 95 Northstart Leaking Coolant
  43. N* Power Steering Pump Pressurizing
  44. Overheating: correct diagnostics
  45. Update on PCM gone Loco
  46. taking off oil pan?
  47. tires for 99 STS??
  48. A question on diagnostic codes
  49. what engine years will fit my 94 sls?
  50. 1993 Eldo...ALL THE OIL CAME OUT
  51. '94 SLS, 4.6L, how do you set the cam alignment?
  52. Transmission NIGHTMARE
  53. northstar swap?
  54. Noisy Northstar
  55. Northstar stud problem
  56. N* performance help
  57. What do these codes mean in plain english ?
  58. Shift Solenoids A & B, Need some Help!
  59. P0609 - help
  60. 95 Cadillac Seville Northstar 4.6 V8 Swap...
  61. old engine, bad engine?
  62. Vacuum pressure
  63. HELP! Need serpentine belt diagram
  64. 97 DeVille Concours still runnin hot
  65. 97 Deville ran 278 Degrees..any chance i did not blow the heads?"
  66. Installing Oil Pressure Gauge???
  67. N* hp over the years...
  68. Replacing Timeserts in 96 Eldorado
  69. where can i buy rear control arm bushings?
  70. P022 code TPS open
  71. Need help with '94 STS codes
  72. 94 Caddy Concours Tranny/Linkage?
  73. Help need info.
  74. Oil Seal Tool ?
  75. accuracy of temp sensor???? please help
  76. Looking for Northstar Parts!
  77. Best Price/ Dealer for Time-serts?
  78. engine braking a la overrun clutch
  79. 95 STS Crank sensor,location ??? help
  80. Cooling System Hoses
  81. Spark Plug Replacement
  82. Running Rich?????
  83. Hi, new here with q on a 99 Eld.
  84. Found: Northstar Engine Info:
  85. A guy with a turbocharged Northstar powered Fiero...
  86. A guy with TWO N* engines in his Caddy...The TwinStar
  87. A helicopter powered by...Northstar engine
  88. Northstar Twin Turbo...
  89. Toyota MR2 powered by...Northstar
  90. what is the conditioner called to add to the radiator coolant??
  91. New Owner, 97 Eldo, A Few Thoughts And Questions
  92. 99 STS Engine Temp Sensor problem
  93. Cost of rebuilding transmission?
  94. sensor names?!?!?!
  95. 97 DeVille Concours low oil pressure stop engine???
  96. Update on my 99' Eldo issues.. and thanks
  97. will 99 n* spark plug wires fit 97 n* ???
  98. Slipping out of overdrive and P094 code
  99. service.gm.com username/password
  100. Oil Leak Question
  101. new server with past informative posts
  102. Low battery voltage causing hard starts ?
  103. Removing the front valve cover on 98 N*???
  104. Leaking Coolant, where is it coming from?
  105. NorthStar reliability?
  106. '95 Northstar into a '94?
  107. having a starting problem on my 94 sls
  108. Northstar 1993 Explosion - Urgent Need
  109. Using 1st, 2nd, 3rd gears in 99' STS
  110. n*Headgasket Diag. the Hardway
  111. Intermittant detonation
  112. removing northstar engine AC COMPRESSOR question
  113. Ok computer genius!! I need you help please
  114. coolant level
  115. Trouble starting once engine is warm
  116. do I need two sets of timeserts?
  117. 97 eldorado etc with a stumble
  118. Shift solonoid ?, not like in thread below
  119. 1996 cadillac deville for sale
  120. headgasket blown?
  121. Overheating '99 D'Elegance, need to sell....
  122. NEW (used) Cadillac Owner Deville Northstar 32V
  123. gasket
  124. what year engine is this!
  125. Dex-cool controversy
  126. How do i clean the heads on my aluminum block?
  127. bad smell and smoke
  128. overheating
  129. General Northstar info needed
  130. oil pressure light
  131. Throttle Body Question...
  132. My crank pulley is wobbling...
  133. Dex Cool
  134. Surge tank
  135. Guide to replace water pump...
  136. 93 Allante Northstar oil leak
  137. Lower temp stat & fan sensor?
  138. 96 Edlo Cranks will not start
  139. Intake Manifold removal
  140. hole in the block!!!!!!!!!!
  141. Where can I cash in a blown PCM core?
  142. northstar oil leak issues
  143. best oil for the 96 northstar 133000 miles
  144. Motor Noise
  145. Headgasket change ????
  146. Infinitely better than the 'turbonoter'!
  147. What happened?
  148. Is there any update on a head gasket sealer that works?
  149. I want more power out of my Northstar
  150. Replaced plug wires and plugs still misfire code
  151. Service Engine Soon? No apparent problems
  152. P036 & P056?
  153. Missfire - NEED HELP
  154. OBD2 Code RSM0038???
  155. Misfire and coils
  156. So far I'm not thrilled
  157. air filter in a 1999 Deville
  158. Can we get a moment of silence...
  159. Northstar question!
  160. Firing order
  161. high trans line pressure
  162. 93 Eldorado 4.6 Northstar "chuggle"
  163. inside radiator leak/transmission leak?
  164. Sharp right turn=Puff of blue smoke!
  165. pull engine from the top in sections ?
  166. Error code P035
  167. changing PCValve on 94 eldorado
  168. Flushing 4T80E....how many quarts of fluid?
  169. Parts lookup by GM part #?? is it possible?
  170. new radiator, now engine overheats
  171. new radiator, now engine overheats
  172. How about Eldo Performance Mods?
  173. Spark Plugs
  174. Coolant leak and desparate
  175. Coolant leak 98 DeVille and desparate
  176. c
  177. trans. leak
  178. My Nitrous project is under way...
  179. lifting out the '94 northstar.. please take a look
  180. Possible Idling Problem?
  181. 95 seville starter help!! plz look
  182. head gasket and engine in-vehicle possible?
  183. My cheap-ass tune up
  184. Po39
  185. Regular vs Premium Gas
  186. Can anyone tell me if I have a bad head gasket
  187. Trans Fluid Change Question
  188. cable acting up, white smoke 94 sls
  189. 98 STS airbox mod?
  190. Has anybody bothered to check their Calculated Octane Rating on their OBDI Northstar?
  191. lean fuel mixture
  192. transmission oil loss
  193. 89in-lb? Seriously?
  194. 55.6 mpg
  195. Coolant supplement tabs not added at coolant change. Now what???
  196. Opinions Needed
  197. 99 deville/Northstar
  198. check transmission message
  199. 98 deville hard starting
  200. 93 Eldorado
  201. So K&N air filter is no good?
  202. 96 Deville Northstar, No Oil Pressure out of the blue.
  203. Oil pan bolt torque
  204. 1993 STS Rough Idle
  205. Deville 96 Coolant leaking ...
  206. HiPo Northstars in the house?
  207. Fuel Pressure Regulator and hot start problems
  208. Anyone else's N* tick at idle?
  209. Found used NS, need advice.....
  210. Oil Leaks
  211. Old Fuel Rail Vs. New Fuel Rail
  212. Tricky
  213. 94 running hot!?????
  214. Time serts pulling out of block
  215. 2002 DTS Spark Plugs
  216. 1998 Northstar For Sell
  217. 1993 Northstar
  218. 98 Head Gasket Job
  219. Piggyback computer is installed
  220. Engine noise
  221. Fram Sure Drain
  222. getting the O2 sensor changed
  223. 01 STS stalls when stoped at light!
  224. Quick Oil Change Question....
  225. head bolt torque settings
  226. ??Smoking 96DeVille??
  227. Reverse (ing) ...
  228. Pictures of relocated PCM
  229. Crank sensors
  230. 100000 mile maintenance
  231. Noisy engine
  232. O2 Sensor
  233. Why does dirty TB cause crazy idle?
  234. STS Mufflers
  235. 1993 Exploding Intake Plenum
  236. Too Much Spent, Same Problem
  237. spark plug wires?
  238. Bottom end/block from another engine?
  239. EGR valve location
  240. symtoms of bad wtr pump, 97 concours
  241. 94 sls whats causing a high idle?!
  242. Adjusting Tming (94 concours)
  243. Post Explosion Roughness
  244. removing the crank pulley
  245. Popular choice for spark plugs in my 99 STS???
  246. Prestone Super Radiator Flush
  247. Dex-Cool no longer made?
  248. Question on maintanance
  249. Loud snapping sound during startup/shutdown
  250. NOOB needs some help!!... northstar blown!!!
