View Full Version : Cadillac Powertrain Control Module (PCM) Tuning
  1. 96 deville PCM Layout
  2. Pcm Question
  3. my seconds PCM just blew up
  4. 03 to 06 Truck tune for a Maggie MP112
  5. i have an old PCM
  6. Northstar model
  7. 2003 escalade with PCM fault?
  8. get around anti-theft?
  9. could my pcm cause my ac relay not to gorund?
  10. Coil Bank Testing
  11. E67 Northstar Tuning
  12. 06/07 RWD STS Engine and Trans in a 57 Chevy
  13. Anyone want to start a 3.6L tuning discussion?
  14. 1990 Cadillac Brougham- Replacing ECU with laptop. Possible or Crazy?
  15. What is Tuning? By Definition
  16. Name on dic
  17. PCM question
  18. 97 Caddy STS 4.6 Tuning
  19. 350 TBI tuning
  20. What is an Aj tune?
  21. Experience with replacement performance chips
  22. Who can do a tune on an '07 ESV w/a 6.2?
  23. Tech II vs MDI
  24. 98 Eldo pcm into a 97 STS
  25. New PCM flashed and doesn't work
  26. Northstar engine for racer-need help with wiring
  27. Does anyone have a broadcast code on a 90-95 Touring Sedan 4.9L car?
  28. HPT vs EFILive vs TunerCat RTOBD2 vs SCT Advantage vs Jet Dynamic Spectrum Tuner
  29. PC based Scan tools
  30. What all can a Tech IA or Tech II do??
  31. Where to find Tech-II programmer - Chicago?
  32. Obd I (<1995) Tuner Prom
  33. Free software for some of our GM Cars!
  34. DIY NB O2 A/F Gauge
  35. Limitter adjustment/removal
  36. changing fan scheduling?
  37. have question about self diagnostic
  38. stall out
  39. Running a Northstar on a LS1 PCM.
  40. 93 to 95 Northstar Tuning
  41. 93 Eldo Northstar Map Sensor?
  42. 98 & 99 SLS & STS Tuning only
  43. Some differences in MAF mode vs SD Mode
  44. How to manually trigger Manual Mode / Performance Mode shifting on LT1 powered cars
  45. LT1 doesn't pick up well
  46. Northstar Tuning
  47. can i go from awd to 2wd?? but why?
  48. Tuning 4.9l engine
  49. PCM upgrade for 99-00 Escalades!
  50. PCM and VATS
  51. Pushing the envolope on mpg through tuning
  52. EFILive Supports 06-07 Devilles!
  53. Talk to my PCM
  54. Instant Throttle Response??
  55. 2001 SLS vs STS
  56. LT1 B/D PCM tune vs LT1 F/Y Tune
  57. Swapping Northstar for LS Engine
  58. Does anyone have the broadcast code?
  59. Fuel Pressure in Tuning
  60. PCM Tuning Progam for NorthStar V8's?
  61. Poor gas milage and other stuff....
  62. Cat Converter Overtemp?
  63. Going MAFLess?
  64. Low cost larger MAF & adapter
  65. Knock Modules and applications
  66. What can be done with an L05?
  67. Tune a 4.1?
  68. What tuners do we have here?
  69. PCM abbreviation?
