: Cadillac DTS Forum - 2006 through 2012
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Front seat options for 2007 DTS Luxury II
  2. Headlights
  3. Removing rear-seat vanity mirrors
  4. Depo Auto Lamp for 06 DTS
  5. Tail light removal 2007 DTS
  6. 2006 dts performance tire monitor sys.
  7. 2006 DTS performance headlight problems
  8. Front end noise and turning question!! Please advise!
  9. Is it possible to put magnetic struts and shocks on a base DTS model?
  10. Ghost in the trunk
  11. Fuel Filter
  12. upgrade from base features possible?
  13. back seat DTS wiring problem
  14. 2006 Cadillac DTS - Radio Buzzes on Brake Light or Blinker
  15. Tear in Landau roof
  16. 2006 DTS tire size
  17. Windshield Wipers
  18. 2006 DTS - Adjust rear height sensors ?
  19. Bluetooth conn. question
  20. ? Deciding on a New Paint Job ? Help ! (07 Cadillac DTS)
  21. Check engine and stabilitrak light
  22. trunk lid stop lights 2006 dts
  23. Recommendatoins for bicycle rack on a DTS?
  24. Windshield Washer Fluid Wont Dispense
  25. Cardone Axle vs AC Delco Axle
  26. 06 dts high idle
  27. How do you access the front parking sensor?
  28. Tires for DTS
  29. Heated WasherFluid
  30. Need Help Steering Wheel Shake!!
  31. Where is the parking assist diagnostics in Tech2?
  32. All door speakers stopped working
  33. Cadi Newbie!!
  34. 8.5 quarts of oil?
  35. Purchasing a DTS
  36. Looking into buying a 2006 DTS
  37. Water leaking from map-light fixtures after cold weather
  38. 2006 DTS leaking oil
  39. 06 DTS overheating
  40. 06 DTS Bluetooth
  41. fuel injector stays open
  42. 06 DTS performance lighting issues help please!
  43. hesitation
  44. 06 Lux3
  45. DTS in the snow
  46. 2006 DTS front hub, immediate help please!!!!
  47. Service suspension system?
  48. DTS will not crank!
  49. Passenger headlight flickering
  50. 07 DTS Radio/Nav Repair
  51. Little help before installing aftermarket radio
  52. 06 DTS Lux III, all my sensors are haywire
  53. Where is the ESC module in a 2008 DTS?
  54. Is there a parking brake adjustment on these cars?
  55. RCLDR replacement - need programmed?
  56. 2006 dts engine cover and front seat covers.
  57. Whats this "BOING" sound from the front suspension?
  58. 2006 dts ignition key problem
  59. Changing the brake fluid.
  60. Auto-Window roll up feature no longer working?
  61. Re-Setting Transmission Fluid Life?
  62. 2009 DTS alternator 95,000 miles
  63. 2006 dts performance tune up
  64. Replace back up/reverse light
  65. Catalytic Converter P0420
  66. 06 DTS Performance charging issue
  67. '08 DTS won't go into overdrive, no SES light
  68. 2006 DTS 157k - Front Engine / Motor Mount
  69. 2007 DTS bogging down upon cold start
  70. Misfire issue - 2008 DTS base
  71. Traction control warning - 2006 DTS
  72. Used DTS Reliability Tips
  73. Custom Cadillac Logo Floor Mats
  74. 2007 DTS Both service Stabilitrack and Service Traction control on
  75. Problem with driver's courtesy light
  76. Won't stay running
  77. Vogue Signature V Tires???
  78. Can I get the Key Recall Serviced at Buick Dealership?
  79. 2006 DTS ran out of gas now it won't even crank no warning lights
  80. 2007 dts ddm no power to door
  81. Radiator fans not working
  82. 2006 dts - heated seats not working
  83. GPS Antenna location
  84. Auto Body help in Chicago
  85. extended warranty recommends
  86. Just got an 09 DTS and have 2 questions
  87. What type of leather do I have?
  88. How to tell if a 2008 came with factory remote start?
  89. Front Brake Lines Safety Issue!!!
  90. Constant Knocking Sound In 2006 DTS?
  91. Oem radio
  92. Changed the belts
  93. My first cadillac 2006 DTS luxury 2
  94. Engine system
  95. OKAY, HERE'S ONE TO STUMP YOU ALL! I'm like HUH?
  96. 07 DTS headlights
  97. 2006 DTS - right front headlight
  98. 06 DTS sat for 2 weeks, now completely dead
  99. 1st time driving my DTS in the snow, drives great...with a little "problem".
  100. 2006 DTS flickwering side marker light
  101. 06 DTS factory radio Switch
  102. Best tires for a 2006 dts preformance.
  103. Trivial trim/emblem questions! In search of info
  104. headlights done - with video help.
  105. Rear level control system help - 2006 DTS
  106. CF site picture procedures ?
  107. Tire Monnitor Tbl Lite is
  108. Accelertion has become LOUDER??
  109. headlight or ballast?
  110. Sluggish
  111. Side Mirror Tightening
  112. 2009 DTS Climate control problem
  113. obdII p0700 p2534 codes help
  114. Looking to purchase a DTS
  115. 08 DTS Radio diagram
  116. ECU Updated now flat band around 35 mph -normal?
  117. Strut Mount Bearing
  118. which had better ride 00-05 or 06-12?
  119. 2006 DTS transmission problems
  120. Cold-weather engine codes P0411 and P1400
  121. 2006 DTS sqeak from right side of engine
  122. 2008 Steering Wheel Button
  123. Where can I find a speaker grille for rear passenger door?
  124. Service Dept of Cadillac dealership sub-contracting work out to other repair facility
  125. 2006 headlights
  126. Steeeing Wheel wont turn left sometimes when foot on brake pedal
  127. I broke it...arrrrg!
  128. Navigation and Back-up cameras
  129. upgraded brakes
  130. 2010 DTS mileage and fuel
  131. Does your DTS have a locking gas door ?
  132. 2006 DTS Vacuum Line?
  133. 2006 DTS service parking sys
  134. 2006 DTS burnt oil smell
  135. 2009 DTS Rear Level Control - Stuck in the Up Position
  136. 2010 DTS: Is an alignment a normal part of a wheel hub replacement?
  137. Premium Brands CPO Limited Warranty by G.M.
  138. 4T80E fail 2 transmissions in 30 days
  139. 2006 DTS Headlight Problems
  140. First Cadillac - 2007 DTS with 122K - questions
  141. Adding XM capability?
  142. Lumbar replacement...
  143. Heated/cooled seats run for 30 seconds, then shut off...drivers side only..
  144. trunk wont open
  145. 2006 Radio part number
  146. 2006 DTS HID fog light problems
  147. DTS just reaching 70k mile range
  148. fixed the dreaded rust!
  149. desperate; Need pre-programmed BCM for my 2007 DTS
  150. 07 DTS Driver's Seat Squeaks!!!
  151. 2006 DTS: Check Engine Light
  152. Cold weather - gas smell and runs rough after starting
  153. navigation update disc for 2007 DTS
  154. 2008 dts code reader, suspension.
  155. Navigation upgrade for 2006 DTS
  156. Capless Gas Cap
  157. 2006 DTS hesitation or stumble
  158. Rough Ride After New Strut Assemblies
  159. DTS Transmission indicator lights
  160. Valvoline Maxlife High Mileage - Good - Safe ?
  161. Dealer Service Code P0420
  162. steering wheel heater
  163. drivers door light stays on??help?
  164. My first Cadillac!!!
  165. '07 DTS problems
  166. How do I find the options in my VIN ?
  167. Heater blows cold air at a long red light.
  168. A little sluggish!
  169. wheel bearing
  170. '07 DTS Battery Replacement
  171. Wheel/tire sizes for DTS ?
  172. Older Style Chrome Blade Wheels on '06 DTS - pic attached
  173. Finding OEM-style Navigation Systems for DTS
  174. Oil leaks - Northstar ?
  175. Trip report
  176. 2008 dts vin#1g6kd57968uv28832
  177. Wheel Alignment Issues with DTS
  178. It can play CDs, it can play burned CDs with MP3s. Burned DVDs?
  179. passenger side door mirror housing came loose
  180. EGR Tube
  181. XM factory radio subscription question?
  182. Back in a 'Lac
  183. 07 DTS XM Antenna
  184. Brakes & Rotors
  185. You mean to tell me... (oil level sensor rant)
  186. Location of Remote keyless entry receiver for 2006 DTS
  187. Alternator for 2006 DTS
  188. 2010 dts 3rd brake light (trunk light) slightly out
  189. Jump starting or connecting trickle charger to 2006 DTS
  190. 2007-2009 DTS recalls
  191. DTS auction prices?
  192. Reverse lights
  193. 2007 DTS Windows
  194. 2010 DTS trunk torsion bar popped
  195. blower motor not functional
  196. 2006 DTS, V8, Strut Replacement Guidance
  197. grill
  198. dts vin numbers
  199. Our very 1st Caddy 07 DTS
  200. any thoughts on the reusable K+N air filters ?
  201. compare 2000 eldo etc vs 2006 dts.
  202. Somebody tell me something about aluminum wheel air leaks
  203. 16" Wheel / Snow tires for a 06 DTS Performance. Will 16" rims fit? Factory is 18"
  204. the dreaded RUST!
  205. Erratic transmission shifting.
  206. Transmission Help
  207. 2007 DTS wont start
  208. Easily add VCIM Bluetooh to your 06-08 DTS for $40!
  209. DTS 2010 'performance' model-do back seats fold??
  210. '10 DTS Performance
  211. 2006 DTS Headlights are too Bright???
  212. 2006 DTS Low Mileage Needs First Major Service - Suggerstions Please
  213. Rear Driver side Window off track, grinding noise?
  214. 2007 DTS Throttle Position Sensor
  215. 2005 DTS no blower in the front.
  216. In the market looking at Caddys
  217. Want to lower 2008 dts
  218. First Post -- Bought a 2006 DTS
  219. 2008 "Top half" rear-defroster out
  220. 2007 DTS DRL Bulb Part Number?
  221. 2008 DTS trim
  222. Suspension Message Bypass
  223. 2006 lower engine oil leak
  224. Uncomfortable seats?
  225. Underhood Paint Colors?
  226. Dts-v
  227. Losing transmission fluid
  228. Transaxle serviced?
  229. Extended Warranty
  230. Hi, I read that the n,star engine in 2008 corrected the half case oil leak problem,
  231. Passenger Control Module/Door Switch Replacement Question
  232. DTS Performance vs regular Fuel Economy
  233. 2006 DTS = Odd issue
  234. Gear-selector indicator lights. Different colors on 07 and 08
  235. Headlights come on way too early!
  236. Retained Acc Power question
  237. 2 Issues - No AC/Heat on dashboard vents and Blown Subwoofer
  238. Front Parking Assist Sensor Replacement
  239. Goodby DTS. Hello STS, Goodby STS and Hello DTS
  240. 2006 DTS dreaded half case leak--any idea if GM will assist?
  241. Custom cadillac logo floor mats nd merchandise
  242. Bose/nav radio general question
  243. Goodbye DTS, Hello XTS!
  244. Poor am radio
  245. transmission fluid
  246. 2007 DTS Steering Wheel Radio Controls
  247. Is my 2007 DTS Performance model equipped with magnetic ride control?
  248. 07 DTS Battery Replacement
  249. Should I trade my 2000 dts for 2006 dts with 200k miles.
  250. DTS 2010 ( idle overheating )
