- Diagnostic questions
- wheels
- Will 95 STS trunk motor swap/90 allante topmotor
- battery drain 1988
- cooling fans
- convertible top
- 1989 Issues
- Radiator 1988 seem to be missing sensor
- 90 alarm factory alarm disable
- Need help with a few issues of an 89
- 4.5 Liter Allante in tampa Junkyard
- 87 Allante: broken front sway bar
- allante problems?
- Retractable hardtop Allante
- ABS problems
- 1990 allante engine help
- What should a 87 parts car cost?
- Need Replacement Bose speakers (4)
- window out of adjustment
- leather re-color samples
- Been looking for an Allante
- new style windscreen
- 1993 Allante
- Tail light Error Message
- Add a hardtop?
- Spark plug advice?
- performance?
- closer to legit...
- no reference voltage at MAP sensor
- Spotted an Available 89
- Guide to removing door panel/ window motor replacement
- Loud Pop when powering up Radio
- VHS tape top down procedure
- tape player
- performance chip 93 nstar???
- Anyone convert your Allante to a Northstar ?
- Radio not working
- Looking For Red Head Rests & Minicovers
- what other cars' bose speakers work in Allante?
- Cadillac License Plate Frames - Forum Discount
- cigarette lighter info
- Seat Belt Extension
- Allanté AVATAR
- B483 ABS/TCS Disabled: How is this possible?
- Enginge Control System Fault
- 90 Allante HARD BRAKES!!!
- cooling fan fault
- other center armrest fit an 88?
- Question to Stealth.....
- leaks 1988 51K
- top down weather
- heat gauge
- Show us your Allante
- 91 Allante Power Sterring Leak
- Allante seatbelt replacement
- MetroAgt6508
- East coast meet up in NJ
- 89 Service Information Manual
- Brake dragging
- Phase I vs. Phase II Allante
- Early model '93's
- Steering Wheel....
- Thanks for the help!
- what should I check on -87, want to buy one
- Help
- 1989 Allante am/fm radio
- Allante PAWN shops ? ? ?
- OFF-Topic, finding the various ALLANTE CLICKs
- can you change the cd player?
- 93 Allante w/electrical flutter
- Technické specifikace Cadillac Allanté Pace cars
- the Allante CALL-HOME thread
- Allante SILVER INGOTS
- Allante Wheelskins Geninue Leather Steering Wheel Cover
- Need a drivers side 1987 taillight
- Steering wheel fit
- Allante makes the clip: Manifesting the American Dream
- Allante - no kids, no passengers, no cargo ...
- Lights come on by themselves then drain battery
- Droping an Allante
- System Fault
- Programming 89 Allante Garage Door Opener
- idle problem when hot
- fuses
- recent purchased a 1988 few questions
- Supercharger
- 91 pearl allante 4 sale black leather new black top
- Buying advice, what to look for on a 91
- My new 88 Allante has cracked engine block!
- Tampa Club
- '91--Trunk lift struts?????
- thinking of buying.....
- Official GM Licensed Cadillac Logo Hats
- Found a hardtop
- Squeaky Hardtop
- floor mats allante 1987
- wanted: allante floor mats
- WTB Allante Intake
- Aack, Wife Wants to Sell Vette for an Allante
- How do I replace my bcm on my 91' allante
- 93 Passenger Window won't go up!!
- Cracked Armrest!!!!
- engines
- first allante
- Allante in new Cadillac ads!
- F7 Transmission solenoids
- swapping DIC 89 with 91
- tac inop or incorrect.
- cadillac parts
- fuel injector / top engine cleaning
- air conditoner
- Ignition switch spring back
- 4.1 L Engine Available with 33,000 Documented Miles
- throttle sticking ?
- access to driver's door speaker
- 88 Shopping in Stealth Mode
- ! ! ! update ! ! !
- Service Replacement Transmission Assembly
- tell me what to do
- Lost Power
- Hard Brakes with kick back??
- Fan stays on after turning car off??
- Allante Hardtop Holder and Cover
- electric problem
- 93 rear window seal
- Looking for a seat belt holder
- Chicago Area Meet
- Allante- instrument panel lights
- Wheres the least amount of rust?
- RPO Code Help
- Melted Taillight Sockets?
- 89 Electrical Fault
- First Allante- recommended service manual
- to buy or not
- Gauging interest in 1993 Allante
- Another Traction Disabled,ABS Disabled
- Allante Cold Air Intake
- Is Front Brakes/wheels running HOT Normal???
- Is the Allante Owners Club Forum more alive?
- cooling fan modulte fault and A/C
- High mount lamp
- Rear Speaker Howling on 88 Allante
- Allante 1993, worth more in parts?
- Wiring Harness for Steering Column
- Car Covers
- 93 Allante Tail light cover(lens)???
- Floppy Visors
- DashBoard Light Replacement
- Code E046
- RADIO, Powered up with ignition off??
- What's the truth about '93 Allante Seats?
- Sirius Radio in Allante
- Top pull down causing battery drain. Help!
- 1987 Allante electrical system problem
- 1988 Allante For Sale, 50,000 Miles, $10,000 OBO
- Brakes
- Cruise Control Not Working
- Color change in Allante interior
- Dash is warping!! Help!
- 1987 Allante, fully loaded with only 11,000 Miles - Anyone interested?
- Radio or Power Windows?
- Leather dye
- Body Side Molding
- Fuel pump
- Thinking of buying a 1990 Allante.
- LCD screen for the radio
- 93 changeout
- Brake Fluid Flush and refill
- 89 Allante Owner needs help
- fuel filter
- Window motor. Who sells it?
- Anyone knowledgable about the allante?
- Rim Fitament
- Trunk Pulldown
- Allante Wheel Specs
- Allante Brake Problem
- 87 pull down motor stuck
- Will these tires fit?
- 93 Dash / Instrumentation
- Car doesn't start. Help!
- 93 quarter window doesn't close
- Is this right?? $6000
- Cd Player Problems in '93 Allante
- Seat belt extender
- Mini Covers
- Looking for Parts - '88 Allante
- 1988 Allante Electronics Problems
- Stop Oil Leaks Without Surgery
- System Failure
- Window regulator
- Leather seats
- 1989 ABS cycling
- 1989 Switch Rebuid
- 1989 Heater Problem
- 1987 New Allante Owner with a Question
- Forward Side Marker Lamps
- Keyless Entry
- Looking at buying a 89 Pearl White wiith Hard Top
- Engine control system fault
- Climate Control on '93 Allante on the fritz
- Beautiful Day...
- Radio ?
- In need of a 93 allante door
- Seat options for 1993
- headlight change ?
- New Paintjob
- Convertible top weatherstripping
- 89 Pearl White wiith Hard Top 4 Sale
- Checking Past Service History
- 1987 Allante stereo not working correctly
- Rear window replacement on 93 convertible?
- A Poll From Current Owners
- Soft Top Replacement
- Looking for the Allante owner that emailed me about the "system failure"
- 2 Wrecked Allantes
- 87' w/Lighting Failures
- Fuel Pump Saga
- Allante hardtop coversion.
- 1989 Allante up for auction on Wed 11/2
- got to the track
- A National Meet Location Vote!!
- Frustrated--pull down
- Need 5 year old service bulletin info/data
- Replacement Battery - 93
- Inside Windshield
- Odometer reads when car is stopped
- Ride Control Service
- Traction Control Button?
- New guy with historical question
- Replacing Serpentine Belt
- Need "Switch HDLP & INTR" bulb #
- Top
- XLR Wheel and tire combinations
- ABS disabled, Traction disabled???
- "Change Engine Oil" Problem
- 90.5 Allante parts car for sale.
- Yes I'm new
- Allante Instrumet Panel Lights Fuse
- Nubie
- WANTED: L/S Vent Window
- jrorra
- jrorra
- 87 Allante for sale - why so cheap?
- convertible motor
- What About This Allante?
- Abandoned Allante Behind My Highrise! (pics)
- Allante Restoration advice
- 89 transmission
- Interesting Northstar article for you '93 owners
