Wanted antenna 1983 Cadillac Fleetwood Brougham Coupe Wanted new or used
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 3 of 3
Cadillac Fleetwood Classified Ads Discussion, antenna 1983 Cadillac Fleetwood Brougham Coupe Wanted new or used in Cadillac Classifieds Marketplace; My antenna will not come down even so the motor is running. The only way I can remove it, is ...
    David Biarritz is offline Cadillac Owners Member
    Automobile(s): 1961 Eldorado Biarritz 1983 Fleetwood Brougham coupe
    Apr 2013
    Melbourne Australia
    13
    Cool antenna 1983 Cadillac Fleetwood Brougham Coupe Wanted new or used
    My antenna will not come down even so the motor is running. The only way I can remove it, is to cut the mast to allow it out the bottom of the fender.
    Apr 2013
    Melbourne Australia
    13
    Re: antenna 1983 Cadillac Fleetwood Brougham Coupe Wanted new or used
    I have now removed the antenna by removing the mast.
    I removed all the retainer clips and drilled out the rivets and found that the mast tail was broken in the tube.
    I managed to do all this through the access hole, bottom of the fender.
    Removed everything with minimal damage.
    Any body out there with a used antenna or mast for sale ?
    ckulibert is offline Cadillac Owners Member
    Automobile(s): 1980 Seville, 1983 Deville, 1999 Deville, 1994 Fleetwood
    Dec 2011
    Mayville, WI
    12
    Call Roger at 715-377-9328. He should have one.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
