cadillac
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Cadillac Technical Archive | Cadillac Dealers | Cadillac Reviews | Cadillac Dealer Reviews | Cadillac Vendors | Decals
gm social network
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 63
Like Tree2Likes
Cadillac Escalade, EXT and ESV Forum - 2007+ Discussion, Any other 07's owners with Piston Slap? in Cadillac Escalade Forums; We'll after 6000 miles, it's happened. My 07 has the dreaded piston slap. Thought they would have solved this issue ...
    Kickboxer is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Dec 2006
    119
    We'll after 6000 miles, it's happened. My 07 has the dreaded piston slap. Thought they would have solved this issue with the new 6.2 liter issue but it's surely there for about 10-15 seconds on cold startup. Anyone else getting this?
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Many
    LLT
    LLT is offline Cadillac Owners Fanatic
    Jun 2006
    347
    Re: Any other 07's owners with Piston Slap?
    I'm guessing if it's 6,000 miles you just recently did an oil change. Related to that perhaps?
    I don't have piston slap on my current unit.
    nofinga911 is offline Cadillac Owners Fanatic
    Automobile(s): 07' White Diamond EXT
    Oct 2006
    QuEeNz Ny
    25
    475
    Quote Originally Posted by LLT View Post
    can someone tell me what piston slap is?
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads)
    LLT
    Jun 2006
    347
    Piston slap is when there's too much clearance between the piston and the cylinder walls -- as the pistons go up and down, they "slap" against the walls.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2013 & 2012 CTS-V Coupes ,(3)2012 Escalade's, 2008 SRX
    Apr 2003
    Huntingdon Valley, Pa.
    11,599
    No problem with that in any of my 07's yet.
    BMBSALES's Avatar
    BMBSALES is offline Cadillac Owners Fanatic
    Automobile(s): 10 CTS-V, 07 EXT, 06 STS-V, 06 C6, YAM R1
    Mar 2006
    NC
    497
    they def make some noise when you start em up cold...
    Guyz1996deville's Avatar
    Guyz1996deville is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 Escalade
    Jul 2005
    Milwaukee
    32
    532
    Are the clearances of the wrist pin too tight, or are the cylinders the machined oversize? There is only one way to find out. I would address the issue and wait to see if the clearances change. Then it is on file to at the dealership..
    EXTadic is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Ext (sable black) and 1966 chevelle
    Feb 2006
    So Cali (818)
    42
    251
    Quote Originally Posted by Kickboxer View Post
    Are you sure you're not hearing lifter tap? sometimes lifters will leak down while sitting and typically thats what most peolpe will hear ticking at start-up. Piston slap can usually be heard more clearly during engine deceleration. or when you snap the throttle open and listen as the engine revs down.
    Apr 2003
    11,599
    I was getting piston slap when my last 07' exploded.
    caddycruiser's Avatar
    caddycruiser is offline Cadillac Owners Connoisseur
    Automobile(s): '93 Fleetwood Brougham...Dad's
    Jul 2003
    Southern DE
    26
    4,377
    Quote Originally Posted by hcvone View Post
    Yes, that was true...
    While this issue doesn't seem completely out of place on this engine, given how it's been a constant problem with all of the GM LS-series engines since '97 (others too, but those are the main offenders), it's still a bit odd. They made design changes back with the last gen trucks around '03/04 and cured a lot of the problem, but a handful still had noise. After some mileage and over a year, our '02 Avalanche 5.3L would tap a bit at initial cold idle, but that was it--and our '04 Suburban 5.3L, with the design revisions, hasn't made even a single tick in 2.5 years and 43k miles.
    Might be exacerbated by excessive cold or an oil irregularity, but still probably should be checked out.
    Here's a good (well, not "good", but...) site with more info on the issue and also sound clips, for those of you unfamiliar with it:
    http://www.pistonslap.com/
    BMBSALES's Avatar
    Mar 2006
    NC
    497
    That's A Great Site.
    Jul 2003
    Southern DE
    26
    4,377
    Quote Originally Posted by BMBSALES View Post
    It doesn't portray things in the best light, but at least they have enough proper technical data that's easy to understand what the issue is. LOTS of the mentioned engines have had the problem, but at the same time an equal or larger majority out there also haven't.
    That, and with the small design changes in '03/04, it really has become a much more limited thing to pop up. Case in point, like our '02 5.3L that had a bit of tap when cold vs. our '04 5.3L post changes that's never made a peep.
    becker500 is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade
    Mar 2004
    29
    I have 10k on my '07 and I noticed lately at start-up in the cold it is starting to sound like a diesel. WTF! Based on what I'm reading here it sounds like it could be piston slap. Also, I back straight out of my garage then crank it to the right in drive and there is some sort of strange drivetrain noise as well. I'll let you know what the dealer says.
  16. #14
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    Alexandria, VA
    44
    10,984
    This "piston slap" issue is more of a perception problem than a real issue.
    The heart of the problem lies in the fact that it is a powerful, relatively high revving engine. If you compared a modern piston to one that "doesn't do it" from the 70's let us say, you'd notice some striking differences.
    What typically prevents piston slap is the "skirt" of the piston.
    There are twisting forces on the piston that try to spin it in the bore, the skirts on our pistons used to be quite long and did a nice job of preventing this tendency of rotation quietly. Over the years engineers realized that they can get better revs and smoother engines by reducing the mass of the piston and sadly the skirt was a good place for them to accomplish this, they shaved that puppy down to almost nothing and lightened the piston by quite a bit. (lower mass makes for higher revs also)
    Newer pistons look really weird as compared to the Gen II engines of old. There is nothing really wrong with the engine, it just has a tendency to make some noise until the pistons expand. Bear in mind just one explosion from one cylinder at idle would be powerful enough to blow your head off.
    Pistons are prone to expansion and contraction with temperature and are machined to very close tolerances taking this expansion into account.
    When cold they are actually quite smaller than they are when hot, as the piston expands to "fill" the bore the noise will quiet down.
    This is no indication of damage, wear, or impending failure as some would have you believe. It is actually an advancement in technology that consumeres demanded. Now that they have what they want they are not happy with the consequences of a slight noise on cold start up. If you try to install larger pistons, when they expand under temperature, they will stop moving in the bores and destroy the engine, a much larger inconvenience than a little clatter on a cold start I would think.
    If you'd like GM to put quiet pistons back in your vehicle, get ready to pay more at the pump for gas and have a lower level of performance from your vehicle.
    It is up to you. If you'd like the latter, please feel free to call your lawyer.
    I am not trying to flame anyone, just stating what I know.
    Please don't read any offence into my comments, none was intended.
  17. #15
    Jul 2003
    Southern DE
    26
    4,377
    Great point to make, definitely. The only issue I could see is vehicles that have had the issue to an almost extreme issue where it sounds like it's going to detonate at idle and continues to clang and pop while driving--I knew a few people from the club with 5.3L Avalanches that did that, and ended up needing significant work.
    But that falls into the category of just engine design/assembly irregularities overall. There was a "fix" a couple of years ago that seems to have cured most of the problem in a lot of the LS engines, with no detriment whatsoever to the performance, so that's also a point to consider.
    The fact that some engines from the same "batch" can be silent and others sound like they're going to explode is probably the strangest thing, and what caused complaints and sites like that above to be started. If some are fine, then what the heck is wrong with mine, kind of thing.
Sponsored Cadillac Ads - Click here to show your support and REMOVE advertisements!
  • You may not post replies
Read about Cadillac ATS | Cadillac ATS Forum | Lincoln | Buick | Hyundai Genesis Forum | Kia Forte Forum
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | Cadillac Chrome and Black Chrome Wheels | window tinting
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
