what tire size for 07 Escalade ?
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, what tire size for 07 Escalade ? in Cadillac Escalade Forums; To what extent can you go on an 07 Escalade with 24' rims. Does a 305-35-24 fits better than a ...
    medlines's Avatar
    medlines is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade
    Aug 2005
    New York & Romania
    458
    Questionwhat tire size for 07 Escalade ?
    Does a 305-35-24 fits better than a 305-45-24 or 325-35-24.
    I need info to decide which tire size should I buy and have the best fit and the least rubbing problems.
    thanks.
    05 Cadillac Escalade's Avatar
    05 Cadillac Escalade is offline Cadillac Owners Connoisseur
    Automobile(s): None - 2007 Range Rover
    Dec 2005
    South Florida
    28
    1,452
    Re: what tire size for 07 Escalade ?
    Best fitment for the 2007 Escalade with 24" wheels is 305/35/24. This will give you the least amount of rubbing, if any.
    Thanks.
    medlines's Avatar
    Aug 2005
    New York & Romania
    458
    Thanks , that's what I was thinking too.
    medlines's Avatar
    Aug 2005
    New York & Romania
    458
    ok, I checked over the TIS Website for the 07 model and I found these wheel sizes, which one is the correct one.
    part number wheel size bolt circle offset rear spacing
    TIS0724103 24x10 6x5.5 GM 35 6 7/8
    TIS0724109 24X10
    5x5 18 6 1/4
    TIS0724138 24X10 6x5/6x135 18 6 1/4
    TIS0724173 24X10 5x5.5/5x135 18 6 1/4
    6x5.5 GM
    5x5
    So all of the above are on the TIS website, so which one is the correct one.
    I called TIS and they said that the larger the offset the less it will stick out.
    I called superbuytires and one of their employees said he can add some inserts of some sort and bring the 18 offset to 35 offset, and this will be a perfect fit. !!!!!!!!!!!!!
    Can anybody clarify?
    thanks.
    medlines's Avatar
    Aug 2005
    New York & Romania
    458
    TIS0724109 24X10 5x5 18 6 1/4
    6x5.5 GM
    5x5
    thanks.
  8. Remove Advertisements
