Warning about flash to pass feature on 07's
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Warning about flash to pass feature on 07's in Cadillac Escalade Forums; I just bought a new 07 Escalade a couple of weeks ago. I often use the flash to pass on ...
    fridaym5 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2006
    12
    I just bought a new 07 Escalade a couple of weeks ago. I often use the flash to pass on all the vehicles that I have owned. I was trying to use it the other day and it didn't seem to be working. I took it into the dealer and the dealer claims that it only works while the headlights are on. This seems not only stupid but also dangerous. I checked other escalades and they are all the same. I checked several other models of Cadillacs and they work as expected - even when the lights are off you can flash. I got home and read in my manual on page 198 and it clearly says that the flash to pass feature should work at all times, even when the lights are in auto position. I don't believe that any other cars on the road work like this. Why would they do this on the Escalade only.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Re: Warning about flash to pass feature on 07's
    Are you pulling the lever towards you or pushing it away from you?
    FTP only works if you pull the lever back towards yourself.
    It's opposite of activating the high beams.
    The normal high beam (push away) will only turn on the high beams with the lights on.
    05 Cadillac Escalade's Avatar
    05 Cadillac Escalade is offline Cadillac Owners Connoisseur
    Automobile(s): None - 2007 Range Rover
    Dec 2005
    South Florida
    28
    1,452
    Quote Originally Posted by ewill3rd View Post
    Thanks.
    AWF_AXIS's Avatar
    AWF_AXIS is offline Cadillac Owners Fanatic
    Mar 2006
    Truckee, CA
    364
    I have a theory about this. HID's take several seconds to "warm up". Since the high-beams are not Halogen like the 03-06 models, there simply isn't a valid solution for this feature.
    If you notice some of the other German cars with HID only lights (Audi), the HID's are lit up as DRL's, and so are already "hot" for flashing. Those with Halogen high-beams don't need this.
    And if you didn't already notice, the high-beam flashing when the lights are hot (on the '07) is rather lethargic.
    Dave
    Sep 2006
    12
    I also have a 06 corvette - flash feature works fine , also read page 198 in your manual says it should work anytime.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,289
    Quote Originally Posted by AWF_AXIS View Post
    Dave
    The high beams are halogen, only low beams are HID
    Apr 2003
    13,289
    The flash to pass does not work on either of my 07's unless the headlights are on, and of course this is not correct.
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    I'll check a couple of them but that's how it has worked for quite a few years now. Maybe something is different.
    I only get to mess with them if they are broken so I am going off experience here.
    Apr 2003
    13,289
    EW, the lever pulls back like it should work how the earlier years did, but nothing happens. Did you get a chance to look into the radio deal with the aux. Thank you
    AWF_AXIS's Avatar
    Mar 2006
    Truckee, CA
    364
    Quote Originally Posted by hcvone View Post
    Actually, on the '07s, if you look, there is no Halogen HIGH beams. There is a internal shutter behind the HID lens that opens the beam up as a high beam.
    This is pretty easy to see by just looking at the front of the truck with the high-beam on, and listening to the high-beam solenoid activate as you "flash to pass".
    It's the time it takes the solenoid to activiate that gives it the "sluggish" feel, compared to a halogen light.
    Dave
    Apr 2003
    13,289
    Dave
    You are correct, and I stand corrected. I was just checking it out, and now understand why there can not be a "flash to pass" now, they are using the same HID for low and high beams. What's pretty strange is in the 07' headlight assy. there are three sets of lights, the lowest are the HID low and high beams, the top is day time running lights (which can be turned off by rotating the headlight know to the left) there are bulbs in the center position that do not seem to come on.
    Sep 2006
    12
    Read Pg 198 in your manual - they should work anytime.This is not only wrong its dangerous, show me other vehicles that work like this.lets get to the bottom of this-I rely on this feature.
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    It doesn't work anytime.
    I looked at it today, not sure why it even has the switch that pulls back.
    I'll try to look into it some more, it looks like with HIDs this feature is not possible. They won't strike the lamps for an instant, it would burn up the lights for that. It should use the incandescent bulbs in the top but those might only be DRL.
    Just out of curiosity, does anyone really honestly and truthfully use this feature?
    I know the argument is "it says so in the owners manual" but truth be told.... is this something you really use or what?
    Just asking out of curiosity, please don't read anything into it.
  16. #14
    Apr 2003
    13,289
    EW, I have been looking into too, you can still use it with the headlights on to flash someone with their highbeams on. I use it on the highway when I am behind someone to get out of the way, but can live with out it. I want to see how they work so I plan to pull the headlight assy out to check it out.
  17. #15
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    Just out of curiosity, does anyone really honestly and truthfully use this feature?.
    no because you never know if the person you flash is a psycho who will kill you
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
  18. Remove Advertisements
