Warning about flash to pass feature on 07's - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 40 of 40
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Warning about flash to pass feature on 07's in Cadillac Escalade Forums; I thought I counted 6 flashes in the tow/haul mode, have to check it next time I drive....
  1. #31
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,280
    Re: Warning about flash to pass feature on 07's
  2. #32
    AWF_AXIS's Avatar
    AWF_AXIS is offline Cadillac Owners Fanatic
    Mar 2006
    Truckee, CA
    364
    Yes, 6 flashes. However, since I have to have my battery changed, I'm going to try and get all the TIS listed updates applied. Maybe the new/current software update is 4 in tow mode?
    Dave
  3. #33
    Apr 2003
    13,280
    Let me know because my newest one seems to be up to date on updates.
  5. #34
    Bear is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade EXT
    Feb 2004
    179
    So, it sounds to me like what is needed is a change to the DLR lights. Maybe they need to be swapped out for 2 element lamps which could be used to support a FTP when the headlamps are not active. Just throwing a design change idea out.
  6. #35
    Apr 2003
    13,280
    Quote Originally Posted by Bear View Post
    The HID low beam/high beam setup works really well on the 07', we just don't have that feature anymore. Have to see how it bothers me as I put miles on.
  7. #36
    jaycough is offline Cadillac Owners Fanatic
    Automobile(s): 2007 esv
    Feb 2006
    cape coral,fl
    160
    Quote Originally Posted by jaycough View Post
    on mine, parking lights just light tail and amber on side of headlamp. top is DRL and the middle doesn't do a thing.
    HID lights up and stays on when you hit fob for 10-15 seconds
    OK took another look at it, top is parking, middle is DRL and bottom is HID.
  8. #37
    Apr 2003
    13,280
    You have to really take a good look at it because of all the reflectors in the different areas.
  9. #38
    oldsguy is offline Cadillac Owners Member
    Automobile(s): 1995 Cadillac Fleetwood Brougham
    Apr 2005
    18
    In Ohio, passing is considered an insult and if you give any indication that you are about to pass, the car in question will automatically speed up to prevent you from doing so. This is when my LT1 comes in handy. They'll speed up if you don't warn them, either.
    My Cadillac is the only car I've ever had with FTP. I can't really figure out what's so great about this option; I've always found that just using the light switch to turn the lights on and off worked just as well. Oh well, I guess people must be too lazy to reach over to the lightswitch.
    Chris
  10. #39
    djmodifyd is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade
    Jun 2006
    Des Moines, IA
    231
    i never use ftp as well
    i only use it at night to flash people with their brights on
  11. #40
    fridaym5 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2006
    12
    read pg 198 in your owners manual-my 07 escalade dos'nt work as the manual says- but i want it to.
  12. Remove Advertisements
