Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 2007+
Cadillac Escalade, EXT and ESV Forum - 2007+ Forum for discussions regarding the Third Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: 07 Escalade Spare Tire
Old 05-05-06, 10:13 PM
View jrame's Photo Album
Casino Cash: $250
Does anyone know where the entry point is for the jack handle to lower the spare tire on the 07 Escalade?
  #2 (permalink)
Old 05-06-06, 07:35 PM
05 Cadillac Escalade's Avatar
Cadillac(s): None - 2007 Range Rover
View 05 Cadillac Escalade's Photo Album
Casino Cash: $250
Re: 07 Escalade Spare Tire
Oh no. Please don't tell me you already got a flat?
Thanks.
  #3 (permalink)
Old 12-11-08, 01:54 AM
Cadillac(s): 2007 escalade esv
View xhorxhi's Photo Album
Casino Cash: $275
On the Escalade ESV 2007, page 476 in the owners manual describes a pretty complicated process. There is a hole (the spare tire lock) in the rear bumper covered by a little door, the hoist shaft access cover. To access it, first you have to remove the hitch cover, by turning two fasteners located at the bottom of the cover counterclockwise, then pull the cover down and rotate it towards you. Then you open the hoist shaft access cover to access the spare tire lock. Then it says you insert the ignition key, turn it clockwise and then pull it to remove the spare tire lock. Then you assemble the two jack handle extensions and wheel wrench, and insert the open end of the extension through the hoist shaft access hole.
Now, my question is: What is the original size spare tire for the 2007 Escalade ESV? Next question: would a P265 65R18 fit on this vehicle?
  #4 (permalink)
Old 12-11-08, 08:47 AM
Moderator
Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's
View hcvone's Photo Album
Casino Cash: $3350
I am pretty sure the spare is a 17" tire that is the same diameter as the stock size tires, just can not confirm that right now because of where I am.
Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer**
Web Site hcvind.com
  #5 (permalink)
Old 12-11-08, 04:50 PM
RidingDirty's Avatar
Cadillac(s): 2007 Escalade ESV
View RidingDirty's Photo Album
Casino Cash: $3565
you are correct!!!!
  #6 (permalink)
Old 12-11-08, 11:27 PM
Casino Cash: $275
We are wondering, given that our 2007 Cadillac Escalade ESV came with special 22 inch rims, and the owners manual says this is the standard, if a set of 18 inch wheels would work. This is the P265 65 R 18. The car currently has 285 45R 22.
  #7 (permalink)
Old 12-11-08, 11:31 PM
Casino Cash: $275
Our 2007 Cadillac Escalade ESV came with P285 45 R 22 tires on 22 inch rims. The spare is 17 inch. How can the vehicle drive with one smaller wheel and tire? We'd like to get a spare set and see a set of P265 65R18 tires with original cadillac factory wheels for sale. We'd like to be sure they will fit. Can anyone confirm?
  #8 (permalink)
Old 12-12-08, 08:32 AM
Moderator
Casino Cash: $3350
The spare is a 17" wheel but the tire is about the same diameter as the stock tires (18" or 22"), so it will work fine as a spare if needed. Yes you can use 18" wheels on your truck, they were the stock size wheels and the 22's were the option, I use the stock 18's myself for my winter wheels.
  #9 (permalink)
Old 12-12-08, 08:55 AM
fear1's Avatar
Cadillac(s): Cadillac
View fear1's Photo Album
Casino Cash: $1220
Stock Tire - 285/45R22 >Search Tires Tire 1 - 265/65R18
Section Width: 11.22 in 285 mm
Section Width: 10.43 in 265 mm
Rim Diameter: 22 in 558.8 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 9 - 10.5 in
Rim Width Range: 7.5 - 9.5 in
Overall Diameter: 32.09 in 815.08 mm
Overall Diameter: 31.56 in 801.62 mm
Sidewall Height: 5.04 in 128.01 mm
Sidewall Height: 6.78 in 172.21 mm
Radius: 16.04 in 407.41 mm
Radius: 15.78 in 400.81 mm
Circumference: 100.8 in 2560.3 mm
Circumference: 99.14 in 2518.1 mm
Revs per Mile: 648.1
Revs per Mile: 659.0
Actual Speed: 60 mph 100 km/h
Speedometer1: 61.0 mph 101. km/h
Speedometer Difference: - Speedometer Difference: 1.681% too fast
Diameter Difference: - Diameter Difference: 1.66%
Tags: , ,
escalade, spare, tire
Censor is OFF
