Body Control Module Replacement
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Body Control Module Replacement in Cadillac Escalade Forums; Has anyone replaced the BCM? I have a 2007 Escalade ESV and may have a bad BCM. The part on-line ...
    07 ESV KC is offline Cadillac Owners Member
    Automobile(s): 07 Escalade ESV
    Aug 2012
    Kansas City
    55
    Has anyone replaced the BCM? I have a 2007 Escalade ESV and may have a bad BCM. The part on-line is about $100 lower than the dealer cost. It seems like the BCM is fairly straight forward to get at. In researching, it sounds like the dealer has to be involved to program for your specific vehicle. Any tips for a self service approach to this? Dealer quote was about $800. I would like to reduce this as much as possible and reasonable.
    big rob 1's Avatar
    big rob 1 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 EXT
    Nov 2010
    Bay Area, CA
    410
    Re: Body Control Module Replacement
    I had swap the BCM in my 2003 silverado, and I bought the BCM on amazon (was $250 verses the dealer $600) and then brought it into the dealer and paid the 1 hour of labor to have it flashed.
    Aug 2012
    Kansas City
    55
    That sounds a lot better than $800. What I'm reading says that you can eventually get your car started so I guess that worked for you. Was it straight forward to remove and replace?
    Thanks for the help.
    Aug 2012
    Kansas City
    55
    Any tests to confirm a bad BCM?
    texas1's Avatar
    texas1 is offline Cadillac Owners Fanatic
    Aug 2012
    DFW
    147
    I have a spare bcm
    Aug 2012
    Kansas City
    55
    Quote Originally Posted by texas1
    I have a spare bcm
    Should the bcm be supplying constant power to the rt rear stop/turn ? On a wire diagram, it Looks like the turn switch closes the ground circuit. The left and the right rear seem to use the same ground. So, if my left turn is working then the ground path must be OK. That would leave no power from the BCM. There are two constant power wires on the left lamp (lt blue and a red). There is only one on the right lamp at the moment. All this points to no power coming from the BCM. Anyone know which connector and pin to look at on the BCM to check for power going out to the rt rear stop/turn? Can't seem to quit trying to figure this out. It's driving me crazy.
    Aug 2012
    Kansas City
    55
    Ok. There is power to the drivers side interior fuse panel. That would seem to indicate that the BCM is putting out power to the stop/turn lamps but no power at the wire harness just below the right rear lamp. Any thoughts on where to look! I was planning to trace back and look for a break or something. Does the wire stay the same color from back to front? Does anyone have any good wire schematics that show these kind of details for the right rear turn/ stop voltage supply for a 2007 Escalade ESV? My conclusion here is I don't think it is my BCM.
    Aug 2012
    Kansas City
    55
    FOUND IT.....I think. Just before the wire harness goes into the UBEC from the firewall, there is a group of wires that leave the plastic wire harness protector and go into the UBEC fusebox, I can't see them but their resting with pressure on a metal bracket. When I pull up on the wires, the turn signal and brake light work, when I push down, the fuse blows. I stuffed a piece of foam rubber between the wires and the bracket to keep them off the bracket. If it stays on, I may just leave it for awhile.
  11. Remove Advertisements
