Center Caps
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Center Caps in Cadillac Escalade Forums; Quick question, why do some Escalades have a Chromed out center cap, while others have the colored crest in the ...
    rapposm's Avatar
    rapposm is offline Cadillac Owners Member
    Automobile(s): Escalade
    Jun 2014
    45
    60
    Center Caps
    Quick question, why do some Escalades have a Chromed out center cap, while others have the colored crest in the Center Cap.
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,642
    Re: Center Caps
    Cadillac changed to colored cap in 2010, IIRC. The factory color center caps will fit the 2007 and newer.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,280
    Re: Center Caps
    There are two different center caps make sure you get the correct ones
    Prormk is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Escalade
    Feb 2014
    North to the Future
    194
    Re: Center Caps
    Two different designs for the 22" center caps 2007 - 2014?
    As far as cap retainment design?
    Apr 2003
    13,280
    Re: Center Caps
    Yes one has slots that one the slots are milled to the end of the cap, see pics
    Feb 2014
    North to the Future
    194
    Re: Center Caps
    But the spring ring and clips should be the same diameter and specs to work on the same wheel right?
    I don't know, thats why I'm asking. Unless they changed something with the wheel, they should be the same fitment?
    CadX6 is offline Cadillac Owners Fanatic
    May 2004
    247
    Re: Center Caps
    When I lost one cap on my 2009 on the expressway, my dealer had to go thru a whole bunch of different part numbers to find one that would attach correctly and stay on. I had factory 22's.
    Losing caps was a common occurrence around that time & some dealers would replace them under warranty since it was a "known defect" otherwise they were about $75. Mine was replaced for free.
    Apr 2003
    13,280
    Re: Center Caps
    Both will fit, but the newer wheels seem slightly larger because the "older caps" pic 1 are a loose fit on the wheels, I just went out and checked a 2007 and a 2012 and the 07' fit loosely and the 12' was a good firm fit, I have no idea why, maybe different wheel manufacturers.
    Prormk likes this.
    Feb 2014
    North to the Future
    194
    Re: Center Caps
    Different manufacturers would make sense. Good info here.
    Thanks guys.
    Apr 2003
    13,280
    Re: Center Caps
    I have a set of 4 the what is shown in pic 1, they are colored flags, not sure why I have them in my desk but they appear to be perfect, cheap, make me an offer
    rapposm's Avatar
    Jun 2014
    45
    60
    Re: Center Caps
    My current Center caps are able to spin when on get rims, is that normal?
    Apr 2003
    13,280
    Re: Center Caps
    Quote Originally Posted by rapposm View Post
    Mine do not, the spring ring may not be in place on the inside of the caps, it can move and this will cause less pressure to hold the cap to the wheel
    evois is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 escalade hybrid
    Sep 2009
    little rock, AR
    2,986
    Correct, the wire ring has to be inside the clips to hold the cap.
  16. #14
    rapposm's Avatar
    Jun 2014
    45
    60
    Re: Center Caps
    Is it possible to provide me with a picture of how the spring needs to look, picture of the back of the Center cap?
  17. #15
    Apr 2003
    13,280
    Re: Center Caps
    Yea look backwards at my pics in post 5, the spring ring sits between the fingers, it tends to slip inward causing no pressure on the fingers and a loose cap fit on the wheel, you may have to GENTLY bend them outward for everything to be tight again, the ring will kind of snap into it's place
  18. Remove Advertisements
