A/c issues
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, A/c issues in Cadillac Escalade Forums; 07 escalade not blowing a/c or hot air, after fooling with it I got it to barely blow a/c but ...
    Mikes07 is offline Cadillac Owners Member
    Nov 2012
    37
    66
    A/c issues
    07 escalade not blowing a/c or hot air, after fooling with it I got it to barely blow a/c but once I turned truck off got nothing again? Any ideas?
    Nice Ride is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 ESV Platinum / 2013 SRX Premium
    Jan 2012
    1,251
    Re: A/c issues
    Assuming fan is working Ok, it will not hurt to 1st try adding 1 can of Freon, see if the compressor turns on. If so, just low due to a possible leak. Look for signs of Freon oil on condenser or fittings. If its a tiny leak, adding a can will get you going until you have the time and money for the repair.
    Nov 2012
    37
    66
    Re: A/c issues
    It was blower motor resistor, pulled it and checked voltage. It was bad. All good now.
