Need Help to Lift Rear Escalade ESV 3" inches
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Need Help to Lift Rear Escalade ESV 3" inches in Cadillac Escalade Forums; I will be adding a hefty amount of weight on the rear due to add an audio system. I am ...
    new york city's Avatar
    new york city is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade ESV
    Oct 2013
    28
    268
    I am already running on 30" inch rims with 255/30/30 (I had to do some cutting on the inner wheel well plastics)
    When I hit a hard bump I feel the tires scrape just a little bit against the inner plastic (have to do a little more cutting I guess)
    Overall, I want to lift my 2007 escalade esv 3" inches (if that's enough) in order to add the music system.
    If I do lift it 3" inches, with the weight added would it level back to around the same height as is right now?
    And is this lift good enough?
    http://www.ebay.com/itm/Air-Lift-607...6eb56c&vxp=mtr
    Any help is highly appreciated. Thanks.
    PS: also, it says "Will not fit models with factory auto leveling option" and I have no idea if my car has that.
    Oct 2013
    28
    268
    Re: Need Help to Lift Rear Escalade ESV 3" inches
    152 views? Some please help! Lol
    packman01's Avatar
    packman01 is offline Cadillac Owners Member
    Automobile(s): 2007 escalade ext
    Jan 2012
    37
    79
    Why not just put air bags I n place of the springs ,amg you can control the hight ect
    The ebay add u posted would do the same but pretty sure it doesn't raise the truck just helps if you tow to rise up the springs to help
    ToddEdge is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade AWD
    Oct 2013
    42
    75
    I have the air lift 1000 in mine but, only air them up when I have the 6400# boat attached. It will raise it to level where the air system falls a little short with all that tongue weight. In regards to running it all the time aired up, it will ride rough.
    Oct 2013
    28
    268
    @Toddedge, So I can buy those (in the link I provided) Add a sound system that will be pretty heavy? It will lift up my truck from the rear?
    Oct 2013
    42
    75
    Yes, or you can convert to a coil spring without the air system and add 1"-2" spacers to get it to set level, based on the added weight. I've had both.
    The air suspension is supposed to self level, with the added weight. With my boat(800 pounds of tongue weight on the rear of the Escalade), the air system just can't pump it up enough. My dealer has checked it and said that all is well but, it isn't enough.
    Personally, with a car as nice as an Escalade, I'd go with full aftermarket air ride so you have 100% control.
    Todd
    Oct 2013
    28
    268
    Ok I but can I just add those air bags in the link I provided from ebay? I just basically want to add them & lift the car up when it goes down with the added weight I will have
    bigwill1323704's Avatar
    bigwill1323704 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 EXT
    Oct 2012
    28
    181
    add a rear leveling kit
  11. Remove Advertisements
