Overfilled 2007 escalade engine oil
Results 1 to 10 of 10
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Overfilled 2007 escalade engine oil in Cadillac Escalade Forums; I have a 2007 escalade esv, 160k miles. I take a lot of care of my escalade, its in perf ...
    ALKEMIST187 is offline Cadillac Owners Member
    Automobile(s): 2007 ESCALADE ESV
    Oct 2011
    36
    41
    I have a 2007 escalade esv, 160k miles. I take a lot of care of my escalade, its in perf condition thank god! So I was going on a road trip, about 800 miles roundtrip. I checked my oil level, it showed that it was at the 4th hole, so about a quart low. I added some lucas synthetic an entire quart. Drove it was normal engine driving, I was driving back late at night, and felt some slagging on the engine, as if the engine was using too much power. So i checked the oil level, and it showed it was overfilled. I couldnt drain it until i came home. So now my question is, how badly have i messed my engine up, I am afraid I may have done a lot of harm to it. I have taken a lot of care of my escalade. I can see that the excess oil did leak from the top, as I could see it once I got underneath the car. It drives perfectly normal, no check engine light or anything. So is there anything wrong for driving those 800 miles? What should I look for and how may I tell. Truly appreciate all of your responses and help. thanks a lot
    SpyShops NY's Avatar
    SpyShops NY is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Escalade, 2004 CTS, 2003 ESV, Now 2008 Escalade
    Oct 2012
    Fresh Meadows, NY
    38
    795
    Don't do it I would go to jiffy lube, I would not chance it
    2kflhr's Avatar
    2kflhr is offline Cadillac Owners Enthusiast
    Automobile(s): '10 Escalade, '97 Eldo ETC (Z)
    Dec 2004
    Mooresville, NC
    58
    879
    Re: Overfilled 2007 escalade engine oil
    Too much oil causes aeration in the oil and reduces its ability to lubricate. How much overfiled was it? I would check it again with the engine cold and see if it is still overfilled. I usually check mine cold as there is typically only a 5% expansion rate when hot. With an expansion rate of 5% it really doen't matter if hot or cold but if it is hot you need to allow at least five minutes for the oil to drain back into the pan before checking.
    Oct 2011
    36
    41
    There was max 1 quart extra of oil. I have drained a little over half a quart out. How much of a negative impact will 1 extra quart have for about 800 miles highway driving? thanks a lot
    Oct 2012
    Fresh Meadows, NY
    38
    795
    no I drove from florida to new York with minus 2 quarts, I had gotten a oil change in pompano on my way back home to NYC and I forgot my oil dip stick I got back to NYC when I opened the hood I saw oil all over the right side where the oil goes and saw oil all over so I had to put in 2 quarts plus a new dip stick
    To answer your question yes you can drive with minus 1 quart
    Oct 2011
    36
    41
    I had plus 1 quart, 1 quart overfilled. that drive down to fla is def fun
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,642
    Me personally, wouldn't worry about a qt over
    2kflhr's Avatar
    Dec 2004
    Mooresville, NC
    58
    879
    Quote Originally Posted by MrHolland View Post
    I agree.
    Oct 2011
    36
    41
    Thanks a lot, I truly appreciate it!
    Punmax is offline Cadillac Owners Enthusiast
    May 2009
    26
    993
    I'm pretty sure GM would not let over-filling the engine oil by only a quart damage the engine. I would take it to a GM dealer and get a proper oil change done. Don't trust the idiots at Jiffy Lube or a similar location with your oil.
  13. Remove Advertisements
