iSimple Connect Opinions for 2008 Escalade? - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 90
Like Tree6Likes
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, iSimple Connect Opinions for 2008 Escalade? in Cadillac Escalade Forums; Hello ScarabChris, Thanks for sharing this with the community. I apologize for any inconvenience not having an AUX input in ...
  1. #31
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Re: iSimple Connect Opinions for 2008 Escalade?
    Hello ScarabChris,
    Thanks for sharing this with the community. I apologize for any inconvenience not having an AUX input in your vehicle has caused, but I am glad you were able to resolve your concern and can listen to your music now. If additional questions or concerns arise, please feel free to send us a private message.
    Sincerely,
    Laura M.
    Cadillac Customer Care
  2. #32
    kippjones's Avatar
    kippjones is offline Cadillac Owners Fanatic
    Automobile(s): 2005 ESV & 2008 Escalade
    Apr 2004
    208
    Ordered the ISGM651 today....
  3. #33
    JLeosnow is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Escalade ESV AWD
    Feb 2014
    Loretto, MN(55357)
    49
    228
    Quote Originally Posted by kippjones View Post
    I did as well. I think I am going to wait to install it so that I can install the navi/DVD/camera unlock unit at the same time...
    -John
  5. #34
    big rob 1's Avatar
    big rob 1 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 EXT
    Nov 2010
    Bay Area, CA
    410
    Quote Originally Posted by JLeosnow View Post
    -John
    Thats what I would do.
    I DIDN'T and repeated a LOT of work over.
  6. #35
    kippjones's Avatar
    Apr 2004
    208
    Installed today. Went well, a plastic trim tool set is mandatory unless you want to risk scratching your interior. The only challenge was fitting the new iSimple harness behind Nav unit. This can be tricky to get the Nav unit back in place with the extra harness behind the Nav unit.
    I found that getting into the iSimple menus can take a bit of practice to get used to but once you are familiar with the menu and pair your device, this device really works well. I am using an Android so I do not get to see all the "data" for calls and streaming. I will try my wife's iPhone 5 later ad note the differences. Streaming from my S3 was instant and the audio quality was excellent.
  7. #36
    Mikes07 is offline Cadillac Owners Member
    Nov 2012
    37
    66
    Does anyone have pics of there install?
  8. #37
    AZKlaus is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Escalade EXT Premium
    Jun 2013
    429
    I'm planning on going this route with a Galaxy S4, do you get any data at all? At least a phone number for caller ID?
  9. #38
    kippjones's Avatar
    Apr 2004
    208
    Yes, phone number shows up for incoming calls. Streaming music works perfectly however it only says "streaming" on the head unit. Voice dialing connects you directly to the phone assistant. You can either say "call Joe" or "call 555-555-1212" and it will confirm your request and then dial. While you are streaming music, calls will come in and then it goes right back to streaming at the end of the call. Very nice.
  10. #39
    Feb 2014
    Loretto, MN(55357)
    49
    228
    Question for anyone that has installed the NU-GM29/navi/DVD/camera unlock? My questions after looking thru the installation instructions are:
    1) It appears that you actually have to splice/tap into 2 external wires that are not part of a plug-and-play wire harness? Is that correct?
    2) It appear that you loose your back-up/reverse lights when the camera is activated? Is that also a true statement?
    Thanks,
    -John
  11. #40
    Feb 2014
    Loretto, MN(55357)
    49
    228
    Also curious in regards to the install of the ISGM651 if it will use the integrated/factory OEM microphone or do I have to install the microphone that is supplied in this kit? I'm hoping I can use the factory microphone and it is part of/built into the ISGM651 unit....
    Thanks,
    -John
  12. #41
    kippjones's Avatar
    Apr 2004
    208
    Thanks,
    -John
    John,
    The ISGM651 uses a separate provided mic. It may be possible to use the factory mic but I do not know how to integrate the factory mic.
  13. #42
    Feb 2014
    Loretto, MN(55357)
    49
    228
    John,
    Thank you for that info kippjones, I,appreciate it! So, where do people mount this mic. and how obvious is it? I'm assuming it's wired as well? Does it make for an eyesore of an install?
    Thanks again,
    -John
  14. #43
    kippjones's Avatar
    Apr 2004
    208
    I installed mine on the driver side column at the top near where it says airbag. Just a regular black mic, hid the wire well. Very easy.
  15. #44
    big rob 1's Avatar
    Nov 2010
    Bay Area, CA
    410
    Thanks,
    -John
    You only need to splice into those wires if you want to enable the rear view camera while moving forward, I don't care about that feature, so I didn't splice into them.
    Thanks,
    -John
    Separate mic as said already
    Thanks again,
    -John
    Yes it is wired, really long. I installed mine over the rear view mirror clipped to the headliner. Out of sight and aimed at me.
    If you want a picture I can take one tomorrow.
  16. #45
    Feb 2014
    Loretto, MN(55357)
    49
    228
    Quote Originally Posted by big rob 1 View Post
    A few pics would be great big rob 1. Thanks!
    -John
  17. Remove Advertisements
