Not your typical Heated Seats not working, please read! Passenger seat no power!!
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By smoke13264
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, Not your typical Heated Seats not working, please read! Passenger seat no power!! in Cadillac Escalade Forums; I have read all of the threads about seat heaters not working, looking at the module that is attached to ...
    big rob 1's Avatar
    big rob 1 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 EXT
    Nov 2010
    Bay Area, CA
    410
    I have read all of the threads about seat heaters not working, looking at the module that is attached to the seat and the issues with the pins and what not. This is a bit different. Please read on........
    First of all my seat heaters work, when my passenger seat has power....
    When the passenger seat doesn't have power, both the seat heaters/coolers do not work (on either side)
    I have checked every fuse on the driver side dash, under the hood and the circuit breakers by the drivers foot area. Everything that is supposed to have power does, and the fuses/breakers are all fine.
    I first noticed this last week, and made a different thread but now that more research has gone into it, I am very lost.
    I have included pictures of the module and the harness, if anyone has a wiring diagram on where/how power gets up to the seat/module that would be helpful...
    Pics of the harness that plugs into the module
    pics of the module pins
    I am 100% positive that the motor is NOT seized in the passenger seat, that it is a power delivery issue somewhere. Weird it just happened out of nowhere...
    Anyone know what pins should have power/ground in that first pic? I can start pinning and checking for power/ground to pinpoint where the problem is.
    Thanks so much for any help!
    smoke13264 is offline Cadillac Owners Member
    Automobile(s): 2007 escalade had 04 ext
    Mar 2010
    Long Island NY
    12
    Re: Not your typical Heated Seats not working, please read! Passenger seat no power!!
    too easy behind the passanger seat on the floor are also some connectors that have gotten loose just repulg I had this prob alot
    big rob 1 likes this.
    big rob 1's Avatar
    Nov 2010
    Bay Area, CA
    410
    Quote Originally Posted by smoke13264 View Post
    Hard to believe but you were totally right.
    This was the loose connector
    Thanks! I was thinking something totally different (BCM or something)!!!
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    You were lucky, usually when the connector gets loose it shorts and burns the connectors out.
    belairll is offline Cadillac Owners Member
    Automobile(s): 09 Escalade, 06 SRX, 09 Quattroporte, 44 Willys MB, 57 Belai
    Jan 2006
    Germany
    9
    Hey guys,
    I have the same problem on my 09 Escalade.
    I just checked all those conectors. When I disconnect the last one behind the passenger seat and plug it right back, I do hear a click and then 2 times a short sound like a fan. But thats it. If I turn the seat heater out, there is no click, like on the passenger side, no more. No warm seat.
    Please helm me !!
    Lars from Germany
    jeremyt1998 is offline Cadillac Owners Member
    Automobile(s): 2009 Cadillac Escalade Platinum
    Jun 2011
    3
    You were right on! I've had trouble with seat not moving and with the cold weather I noticed the heated seats not working. Reconnected plug and started working! Thanks for the pics, knew exactly which one to replug.
    Jan 2006
    Germany
    9
    But its not working with me.
    Please help
    Do anyone has a diagramm ?
    Lars from Germany
    Mar 2010
    Long Island NY
    12
    Lars, if you look at big Robs first pic more than likely that connector under the passenger's seat is burning out pull the connector and take a look. I have been dealing with this problem for 7 years lol. also try replacing the fuse under the hood just in case good luck
  11. Remove Advertisements
